ServiceNow CIS-Discovery Questions - For Best Result [2026]
Posted at 1/10/2026 09:24:14
View217
Replies4
P.S. Free & New CIS-Discovery dumps are available on Google Drive shared by TestPassed: https://drive.google.com/open?id=1Q6CKit3BnP9P5zDuUiSqFNrmU6Zdu_8y
A steadily rising competition has been noted in the tech field. Countless candidates around the globe aspire to be Certified Implementation Specialist - Discovery in this field. Once you become ServiceNow certified, a whole new scope opens up to you and you are immediately hired by reputed firms. Even though the Certified Implementation Specialist - Discovery certification boosts your career options, you have to pass the CIS-Discovery Exam.
Are you still worried about the exam? Dont worry! Our CIS-Discovery exam torrent can help you overcome this stumbling block during your working or learning process. Under the instruction of our CIS-Discovery test prep, you are able to finish your task in a very short time and pass the exam without mistakes to obtain the ServiceNow certificate. We will tailor services to different individuals and help them take part in their aimed exams after only 20-30 hours practice and training. Moreover, we have experts to update CIS-Discovery Quiz torrent in terms of theories and contents according to the changeable world on a daily basis, which can ensure that you are not falling behind of others by some slight knowledge gaps.
CIS-Discovery Exam Score & Reliable CIS-Discovery Exam BootcampPerhaps you are in a bad condition and need help to solve all the troubles. Dont worry, once you realize economic freedom, nothing can disturb your life. Our CIS-Discovery study materials can help you out. Learning is the best way to make money. So you need to learn our CIS-Discovery study materials carefully after you have paid for them. As long as you are determined to change your current condition, nothing can stop you. Once you get the CIS-Discovery certificate, all things around you will turn positive changes. Never give up yourself. You have the right to own a bright future.
ServiceNow CIS-Discovery Exam Syllabus Topics:| Topic | Details | | Topic 1 | - CI Class Manager (i.e. CMDB Health Dashboard, CI Class Manager, CMDB Tables, Reclassification, CMDB Relationships)
| | Topic 2 | - Discovery Engagement Readiness
- Discovery Configuration
- Operations (i.e. Match, Parse variable, Parse file, Parsing strategies)
| | Topic 3 | - Application Identification and Connection Sections (Patterns, Identification and Connection Sections, Troubleshooting
| | Topic 4 | - CMDB Identification and Reconciliation (i.e. CI Identifiers, Reconciliation Definitions, Datasource Precedence, CMDB De-duplication)
| | Topic 5 | - Discovery Process Flow (i.e. PCIE Phases, ECC Queue, Status, Discovered Device
- Discovery Pattern Design
| | Topic 6 | - Discovery Troubleshooting (i.e. Discovery Errors, Duplicates, Credentials)
- Configuration Management Database
| | Topic 7 | - Operationalizing IT (i.e. MID Server and Discovery Dashboards, Benefits)
- Pattern Designer (i.e. Debug, Steps, Sections)
To become a ServiceNow CIS-Discovery Certified, candidates are required to demonstrate a deep understanding of ServiceNow Discovery and its related technologies. Certified Implementation Specialist - Discovery certification exam consists of 60 multiple-choice questions, and candidates are given 90 minutes to complete the exam. A passing score of 70% or higher is required to achieve certification.
ServiceNow Certified Implementation Specialist - Discovery Sample Questions (Q119-Q124):NEW QUESTION # 119
A Discovery Schedule contains a /24 subnet IP Range and a Shazzam batch size of 5000. How many times will a Shazzam probe be launched during discovery?
NEW QUESTION # 120
The ECC Queue provides ______ .
(Choose 2 answers)
Response:
- A. credentials used to login into MID Server host
- B. means for planning, analyzing, defining, measuring and improving availability of IT services in all its aspects
- C. a connected flow of probe and sensor activity
- D. the XML payload returned from or sent to an instance
NEW QUESTION # 121
What operation needs to be performed to modify credentials in a horizontal pattern from default to any other appropriate credentials?
Response:
- A. Update user
- B. Change credentials
- C. Modify credentials
- D. Change user
NEW QUESTION # 122
For what is File Based Discovery used?
- A. To discover the checksum of a file and store it to track for changes
- B. To discover that file names conform to a defined naming standard
- C. To discover the contents of flat files such as configuration files
- D. To discover file paths to recognize the signature of installed software
File Based Discovery is used to discover file paths to recognize the signature of installed software. File Based Discovery helps to identify what software is running on Windows and UNIX servers and devices by scanning the file system for specific files or directories that indicate the presence of a software product1. File Based Discovery can also check the file size, version, and checksum of the discovered files to verify the software installation2. File Based Discovery can be configured using file signatures, which are patterns that match the file paths of software products3.
References: 1: File Based Discovery - Support and Troubleshooting - Now Support Portal 2: Use file-based service discovery to discover scrape targets | Prometheus 3: How File based discovery can be used to populate software record running on Linux host. - Support and Troubleshooting - Now Support Portal
NEW QUESTION # 123
for enhanced performance, all windows probes use the folder as default.
Response:
- A. Administration share
- B. $admin share
- C. $root share
- D. $administration share
NEW QUESTION # 124
We have 24/7 Service Online Support services on our CIS-Discovery exam questions , and provide professional staff Remote Assistance. Besides, if you need an invoice of our CIS-Discovery practice materials please specify the invoice information and send us an email. Online customer service and mail Service is waiting for you all the time. And you can download the trial of our CIS-Discovery training engine for free before your purchase.
CIS-Discovery Exam Score: https://www.testpassed.com/CIS-Discovery-still-valid-exam.html
- Overcome Fear of Exam with ServiceNow CIS-Discovery Exam Dumps 👦 Copy URL [url]www.practicevce.com open and search for ⮆ CIS-Discovery ⮄ to download for free 🩺
ractice CIS-Discovery Exam Fee[/url] - Test CIS-Discovery Dump ♿ CIS-Discovery Actual Test Pdf 🗯 Visual CIS-Discovery Cert Test 🏓 Open ➡ [url]www.pdfvce.com ️⬅️ enter CIS-Discovery and obtain a free download 👞CIS-Discovery Reliable Study Materials[/url]
- Overcome Fear of Exam with ServiceNow CIS-Discovery Exam Dumps 🚲 Open { [url]www.vce4dumps.com } and search for ➡ CIS-Discovery ️⬅️ to download exam materials for free 🔌Visual CIS-Discovery Cert Test[/url]
- Overcome Fear of Exam with ServiceNow CIS-Discovery Exam Dumps 📍 ➽ [url]www.pdfvce.com 🢪 is best website to obtain CIS-Discovery for free download 🥊Exam CIS-Discovery Study Solutions[/url]
- Visual CIS-Discovery Cert Test 💮 CIS-Discovery Valid Study Materials 🧆 CIS-Discovery Exam Torrent ⚾ Download CIS-Discovery for free by simply entering ⇛ [url]www.validtorrent.com ⇚ website 🧄
ractice CIS-Discovery Exam Fee[/url] - Overcome Fear of Exam with ServiceNow CIS-Discovery Exam Dumps 🍣 Search for ▷ CIS-Discovery ◁ and download it for free on ▷ [url]www.pdfvce.com ◁ website 🐪New CIS-Discovery Exam Discount[/url]
- CIS-Discovery Test Pattern ⏪ CIS-Discovery Actualtest 📜 CIS-Discovery Certification Test Answers 🚵 Immediately open ➥ [url]www.practicevce.com 🡄 and search for { CIS-Discovery } to obtain a free download 🍆CIS-Discovery Exam Torrent[/url]
- ServiceNow CIS-Discovery Exam | New CIS-Discovery Test Cram - Ensure You Pass CIS-Discovery Exam For Sure 👲 Download CIS-Discovery for free by simply entering [url]www.pdfvce.com website 🧪
ractice CIS-Discovery Exam Fee[/url] - CIS-Discovery Valid Study Materials 😾 CIS-Discovery Examinations Actual Questions 🐈 Latest CIS-Discovery Test Vce 🖌 Go to website ☀ [url]www.troytecdumps.com ️☀️ open and search for ➡ CIS-Discovery ️⬅️ to download for free 😶CIS-Discovery Test Pattern[/url]
- [url=https://agfundernews.com/?s=Test%20CIS-Discovery%20Book%20%f0%9f%9a%8a%20Test%20CIS-Discovery%20Dump%20%f0%9f%85%bf%20Latest%20CIS-Discovery%20Practice%20Materials%20%f0%9f%9a%98%20Easily%20obtain%20free%20download%20of%20[%20CIS-Discovery%20]%20by%20searching%20on%20[%20www.pdfvce.com%20]%20%f0%9f%8c%87Test%20CIS-Discovery%20Dump]Test CIS-Discovery Book 🚊 Test CIS-Discovery Dump 🅿 Latest CIS-Discovery Practice Materials 🚘 Easily obtain free download of [ CIS-Discovery ] by searching on [ www.pdfvce.com ] 🌇Test CIS-Discovery Dump[/url]
- 100% Pass-Rate New CIS-Discovery Test Cram C The Best Exam Score for CIS-Discovery - Perfect Reliable CIS-Discovery Exam Bootcamp 🍁 Search for CIS-Discovery on ▷ [url]www.pdfdumps.com ◁ immediately to obtain a free download 🖐CIS-Discovery Examinations Actual Questions[/url]
- learn.techyble.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.sova.ph, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, tooter.in, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, werbemailfach.alboompro.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
BONUS!!! Download part of TestPassed CIS-Discovery dumps for free: https://drive.google.com/open?id=1Q6CKit3BnP9P5zDuUiSqFNrmU6Zdu_8y
