Valid Fortinet - NSE4_FGT_AD-7.6 - Fortinet NSE 4 - FortiOS 7.6 Administrator Ex
Posted at 1/10/2026 09:29:07
What's more, part of that SurePassExams NSE4_FGT_AD-7.6 dumps now are free: https://drive.google.com/open?id=1L6fBdsY0fWOP4WWadBnp01bVvrXs_Io2
To make you be rest assured to buy the NSE4_FGT_AD-7.6 exam materials on the Internet, our SurePassExams have cooperated with the biggest international security payment system PayPal to guarantee the security of your payment. After the payment, you can instantly download NSE4_FGT_AD-7.6 Exam Dumps, and as long as there is any NSE4_FGT_AD-7.6 exam software updates in one year, our system will immediately notify you. To choose SurePassExams is equivalent to choose the best quality service.
Fortinet NSE4_FGT_AD-7.6 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Firewall Policies and Authentication: This domain focuses on creating firewall policies, configuring SNAT and DNAT for address translation, implementing various authentication methods, and deploying FSSO for user identification.
| | Topic 2 | - VPN: This domain focuses on implementing meshed or partially redundant IPsec VPN topologies for secure connections.
| | Topic 3 | - Deployment and System Configuration: This domain covers initial FortiGate setup, logging configuration and troubleshooting, FGCP HA cluster configuration, resource and connectivity diagnostics, FortiGate cloud deployments (CNF and VM), and FortiSASE administration with user onboarding.
| | Topic 4 | - Content Inspection: This domain addresses inspecting encrypted traffic using certificates, understanding inspection modes and web filtering, configuring application control, deploying antivirus scanning modes, and implementing IPS for threat protection.
| | Topic 5 | - Routing: This domain covers configuring static routes for packet forwarding and implementing SD-WAN to load balance traffic across multiple WAN links.
100% Pass Quiz NSE4_FGT_AD-7.6 - Fortinet NSE 4 - FortiOS 7.6 Administrator –The Best Exam Sample QuestionsIn fact, our NSE4_FGT_AD-7.6 study materials are not expensive at all. The prices of the NSE4_FGT_AD-7.6 exam questions are reasonable and affordable while the quality of them are unmatched high. So with minimum costs you can harvest desirable outcomes more than you can imagine. By using our NSE4_FGT_AD-7.6 Training Materials you can gain immensely without incurring a large amount of expenditure. And we give some discounts on special festivals.
Fortinet NSE 4 - FortiOS 7.6 Administrator Sample Questions (Q44-Q49):NEW QUESTION # 44
Which three pieces of information does FortiGate use to identify the hostname of the SSL server when SSL certificate inspection is enabled? (Choose three.)
- A. The subject field in the server certificate.
- B. The subject alternative name (SAN) field in the server certificate.
- C. The serial number in the server certificate.
- D. The server name indication (SNI) extension in the client hello message.
- E. The host field in the HTTP header.
Answer: A,B,D
When using SSL certificate inspection, FortiGate is not decrypting the traffic. During the exchange of hello messages at the beginning of an SSL handshake, FortiGate parses the server name indication (SNI) from client Hello, which is an extension of the TLS protocol. The SNI tells FortiGate the hostname of the SSL server, which is validated against the DNS name before receipt of the server certificate. If there is no SNI exchanged, then FortiGate identifies the server by the value in the server by the value in the Subject field or SAN (Subject Alternative Name) field in the server certificate.
NEW QUESTION # 45
An administrator wants to configure dead peer detection (DPD) on IPsec VPN for detecting dead tunnels. The requirement is that FortiGate sends DPD probes only when there is no inbound traffic.
Which DPD mode on FortiGate meets this requirement?
- A. Enabled
- B. On Demand
- C. Disabled
- D. On Idle
Disable: Disable Dead Peer Detection.
On-idle: Trigger Dead Peer Detection when no IPsec traffic is received.
On-demand: Trigger Dead Peer Detection when no IPsec traffic is received AND FortiGate has been sending IPsec traffic. On-demand is the default setting.
NEW QUESTION # 46
What are two features of the NGFW profile-based mode? (Choose two.)
- A. NGFW profile-based mode must require the use of central source NAT policy.
- B. NGFW profile-based mode can only be applied globally and not on individual VDOMs.
- C. NGFW profile-based mode policies support both flow inspection and proxy inspection.
- D. NGFW profile-based mode supports applying applications and web filtering profiles in a firewall policy.
NGFW (Next Generation Firewall) profile-based mode in FortiGate allows policies to use both flow- based and proxy-based inspection modes, providing flexibility depending on security and performance requirements. Additionally, profile-based mode supports applying applications and web filtering profiles directly in a firewall policy, allowing granular control over the traffic.
NEW QUESTION # 47
The FortiGate device HQ-NGFW-1 with the IP address 10.0.13.254 sends logs to the FortiAnalyzer device with the IP address 10.0.13.125. The administrator wants to verify that reliable logging is enabled on HQ-NGFW-1.
Which exhibit helps with the verification?
NEW QUESTION # 48
The predefined deep-inspection and custom-deep-inspection profiles exclude some web categories from SSL inspection, as shown in the exhibit For which two reasons are these web categories exempted? (Choose two.)
- A. The resources utilization is optimized because these websites are in the trusted domain list on FortiGate.
- B. The legal regulation aims to prioritize user privacy and protect sensitive information for these websites.
- C. The FortiGate temporary certificate denies the browser's access to websites that use HTTP Strict Transport Security.
- D. These websites are in an allowlist of reputable domain names maintained by FortiGuard.
In FortiOS 7.6, the predefined deep-inspection and custom-deep-inspection SSL inspection profiles intentionally exclude certain web categories (such as Finance and Banking and Health and Wellness) and well-known domains (for example, Apple, Google, Adobe). This behavior is documented and intentional.
The two correct reasons are:
B . The legal regulation aims to prioritize user privacy and protect sensitive information for these websites.
Correct
Categories like Finance and Banking and Health and Wellness commonly handle highly sensitive personal data.
Many privacy and compliance regulations (for example, GDPR, PCI-DSS, HIPAA-like requirements) discourage or restrict SSL interception for such traffic.
To reduce legal and compliance risks, FortiOS exempts these categories from deep SSL inspection by default.
This is explicitly stated in FortiOS SSL/SSH Inspection documentation.
C . These websites are in an allowlist of reputable domain names maintained by FortiGuard.
Correct
FortiGuard maintains a reputable/trusted domain list for well-known services and platforms.
These domains are excluded from deep inspection by default to:
Prevent application breakage
Avoid certificate pinning and compatibility issues
Maintain user experience
This is why domains such as Apple, Google, Adobe, and app stores appear under SSL inspection exemptions.
Why the other options are incorrect
A . Resource utilization optimization
Incorrect.
While reduced inspection can save resources, this is not the primary documented reason for exempting these categories.
D . FortiGate temporary certificate denies access to HSTS websites
Incorrect.
Although HSTS and certificate pinning can cause issues with SSL inspection, this option describes a side effect, not the reason for exemption.
The exemption exists to avoid such problems, not because the certificate denies access.
NEW QUESTION # 49
Now let me introduce the PDF version of our NSE4_FGT_AD-7.6 exam questions to you. Tt is very easy for you to download the PDF version of our NSE4_FGT_AD-7.6 study materials, and it has two ways to use. On the one hand, you can browse and learn our NSE4_FGT_AD-7.6 learning guide directly on the Internet. On the other hand, you can print it on paper so you can take notes. As it takes no place so that you can bring with you wherever you go.
Exam Dumps NSE4_FGT_AD-7.6 Free: https://www.surepassexams.com/NSE4_FGT_AD-7.6-exam-bootcamp.html
- NSE4_FGT_AD-7.6 100% Correct Answers 🗺 New Exam NSE4_FGT_AD-7.6 Braindumps 🌙 Training NSE4_FGT_AD-7.6 Pdf 💍 Copy URL ▛ [url]www.prepawayexam.com ▟ open and search for ➠ NSE4_FGT_AD-7.6 🠰 to download for free ☔NSE4_FGT_AD-7.6 Exam Engine[/url]
- Exam NSE4_FGT_AD-7.6 Fees 🌙 NSE4_FGT_AD-7.6 Exam Engine 🎼 Training NSE4_FGT_AD-7.6 Pdf ☣ Copy URL ➽ [url]www.pdfvce.com 🢪 open and search for ( NSE4_FGT_AD-7.6 ) to download for free 🐀Books NSE4_FGT_AD-7.6 PDF[/url]
- NSE4_FGT_AD-7.6 Certification Test Questions 👳 Books NSE4_FGT_AD-7.6 PDF 🎾 Exam NSE4_FGT_AD-7.6 Experience 🧤 Immediately open 「 [url]www.testkingpass.com 」 and search for ➡ NSE4_FGT_AD-7.6 ️⬅️ to obtain a free download 👠NSE4_FGT_AD-7.6 Exam Engine[/url]
- Latest NSE4_FGT_AD-7.6 Study Materials 🐜 New Exam NSE4_FGT_AD-7.6 Braindumps ☮ Exam NSE4_FGT_AD-7.6 Overview 🕸 Search for ⇛ NSE4_FGT_AD-7.6 ⇚ and download it for free immediately on ▛ [url]www.pdfvce.com ▟ 🙉Exam NSE4_FGT_AD-7.6 Experience[/url]
- NSE4_FGT_AD-7.6 exam torrent - NSE4_FGT_AD-7.6 reliable study vce - NSE4_FGT_AD-7.6 test dumps 🏏 Search for 《 NSE4_FGT_AD-7.6 》 and obtain a free download on ▶ [url]www.practicevce.com ◀ 🎌NSE4_FGT_AD-7.6 100% Correct Answers[/url]
- Latest NSE4_FGT_AD-7.6 Exam Testking 🙀 NSE4_FGT_AD-7.6 Valid Exam Pdf 🍘 Training NSE4_FGT_AD-7.6 Pdf 🔗 Easily obtain free download of ▷ NSE4_FGT_AD-7.6 ◁ by searching on ✔ [url]www.pdfvce.com ️✔️ 🥝Cost Effective NSE4_FGT_AD-7.6 Dumps[/url]
- New Exam NSE4_FGT_AD-7.6 Braindumps ❤ NSE4_FGT_AD-7.6 Exam Engine 🦕 NSE4_FGT_AD-7.6 Valid Exam Pdf 🤓 Download ➤ NSE4_FGT_AD-7.6 ⮘ for free by simply searching on 【 [url]www.dumpsmaterials.com 】 🥤Valid NSE4_FGT_AD-7.6 Exam Camp[/url]
- Professional NSE4_FGT_AD-7.6 Exam Sample Questions Offers Candidates The Best Actual Fortinet Fortinet NSE 4 - FortiOS 7.6 Administrator Exam Products 😗 Simply search for ⮆ NSE4_FGT_AD-7.6 ⮄ for free download on ( [url]www.pdfvce.com ) 👇NSE4_FGT_AD-7.6 Exam Cram Pdf[/url]
- NSE4_FGT_AD-7.6 Certification Test Questions 🌔 Exam NSE4_FGT_AD-7.6 Experience 💗 NSE4_FGT_AD-7.6 100% Correct Answers 🤪 Search on “ [url]www.practicevce.com ” for ➽ NSE4_FGT_AD-7.6 🢪 to obtain exam materials for free download 🦟NSE4_FGT_AD-7.6 Valid Exam Pdf[/url]
- Professional NSE4_FGT_AD-7.6 Exam Sample Questions Offers Candidates The Best Actual Fortinet Fortinet NSE 4 - FortiOS 7.6 Administrator Exam Products 🥜 Enter ➡ [url]www.pdfvce.com ️⬅️ and search for ➤ NSE4_FGT_AD-7.6 ⮘ to download for free 🤕Exam NSE4_FGT_AD-7.6 Fees[/url]
- New Release Fortinet NSE4_FGT_AD-7.6 Dumps [2026] 👑 Easily obtain free download of “ NSE4_FGT_AD-7.6 ” by searching on ☀ [url]www.verifieddumps.com ️☀️ ❣NSE4_FGT_AD-7.6 New Guide Files[/url]
- yiwnhua.com, www.soulcreative.online, www.stes.tyc.edu.tw, onlyfans.com, portal.mathtutorofflorida.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, bbs.t-firefly.com, cocoasr18.blogspot.com, Disposable vapes
DOWNLOAD the newest SurePassExams NSE4_FGT_AD-7.6 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1L6fBdsY0fWOP4WWadBnp01bVvrXs_Io2
