[Hardware] Exam Oracle 1Z0-1072-25 Cram Review & 1Z0-1072-25 Testking Exam Questions
75
【Hardware】 Exam Oracle 1Z0-1072-25 Cram Review & 1Z0-1072-25 Testking Exam Questions
Posted at 1/10/2026 09:29:22      View:153 | Replies:4        Print      Only Author   [Copy Link] 1#
What's more, part of that Free4Torrent 1Z0-1072-25 dumps now are free: https://drive.google.com/open?id=11HQTxYYb2K5w1wT9SpG_wPllKPYKuPrY
Oracle offers up-to-date Oracle 1Z0-1072-25 practice material consisting of three formats that will prove to be vital for you. You can easily ace the 1Z0-1072-25 exam on the first attempt if you prepare with this material. The Oracle 1Z0-1072-25 Exam Dumps have been made under the expert advice of 90,000 highly experienced professionals from around the globe. They assure that anyone who prepares from it will get Oracle 1Z0-1072-25 certified on the first attempt.
Now in such society with a galaxy of talents, stabilizing your job position is the best survival method. But stabilizing job position is not so easy. When others are fighting to improve their vocational ability, if you still making no progress and take things as they are, then you will be eliminated. In order to stabilize your job position, you need to constantly improve your 1Z0-1072-25 professional ability and keep up with the pace of others to let you not fall far behind others.
1Z0-1072-25 Testking Exam Questions - 1Z0-1072-25 Verified AnswersThe 1Z0-1072-25 Test Guide is written by lots of past materials’ rigorous analyses. The language of our study materials are easy to be understood, only with strict study, we write the latest and the specialized study materials. We want to provide you with the best service and hope you can be satisfied. It boosts your confidence for real exam and will help you remember the exam questions and answers that you will take part in. You may analyze the merits of each version carefully before you purchase our Oracle Cloud Infrastructure 2025 Architect Associate guide torrent and choose the best one.
Oracle Cloud Infrastructure 2025 Architect Associate Sample Questions (Q49-Q54):NEW QUESTION # 49
Which of the following is a valid RFC 1918 CIDR prefix that can be used for creating an Oracle Cloud Infrastructure (OCI) Virtual Cloud Network (VCN)?
  • A. 10.0.0.0/8
  • B. 192.168.0.0/16
  • C. 0.0.0.0/0
  • D. 192.268.0.0/24
RFC 1918 defines IP address ranges that are reserved for private networks, which cannot be routed on the public internet. In Oracle Cloud Infrastructure (OCI), these private IP address ranges can be used to create Virtual Cloud Networks (VCNs). The valid RFC 1918 CIDR prefixes include:
192.168.0.0/16: A private IP range often used in home networks.
10.0.0.0/8: A large private IP range commonly used in enterprise networks.
Invalid Options:
B . 0.0.0.0/0: This CIDR represents all IP addresses and is not a valid private IP range.
C . 192.268.0.0/24: This is not a valid IP address range as the octet "268" is outside the allowable range of 0-255.
Oracle Cloud Infrastructure Documentation: VCN Overview
RFC 1918: Address Allocation for Private Internets
NEW QUESTION # 50
Which TWO are key benefits of setting up Site-to-Site VPN on Oracle Cloud Infrastructure (OCI)?
  • A. When setting up Site-to-Site VPN, it creates a private connection that provides consistent network experience.
  • B. When setting up Site-to-Site VPN, OCI provisions redundant VPN tunnels.
  • C. When setting up Site-to-Site VPN, customers can expect bandwidth above 2 Gbps.
  • D. When setting up Site-to-Site VPN, customers can configure it to use static or dynamic routing (BGP).
Setting up a Site-to-Site VPN on Oracle Cloud Infrastructure offers several key benefits related to connectivity and reliability:
Static or Dynamic Routing (BGP): OCI allows customers to configure Site-to-Site VPN with either static routing or dynamic routing using Border Gateway Protocol (BGP). This flexibility enables customers to choose the routing method that best suits their network configuration and requirements.
Redundant VPN Tunnels: OCI automatically provisions redundant VPN tunnels when you set up a Site-to-Site VPN. These redundant tunnels ensure high availability and fault tolerance, so if one tunnel fails, traffic can continue to flow through the other tunnel without interruption.
Bandwidth Considerations: While the VPN provides a reliable connection, it typically does not exceed 2 Gbps in bandwidth. Higher bandwidth connections usually require FastConnect.
Private Connection: The VPN does create a secure and private connection between on-premises data centers and OCI, but it does not inherently provide a consistent network experience in the way that a dedicated connection like FastConnect does.
Relevant OCI Documentation:
Site-to-Site VPN Overview
Configuring Routing for VPNs
These references detail the benefits and technical specifications of setting up Site-to-Site VPNs on OCI.
NEW QUESTION # 51
Which statement accurately describes the key features and benefits of OCI Confidential Computing?
  • A. It provides automatic scalability and load balancing capabilities.
  • B. It optimizes network performance through advanced routing algorithms.
  • C. It encrypts and isolates in-use data and the applications processing that data.
  • D. It enables users to securely store and retrieve data by using distributed file systems.
OCI Confidential Computing is a security feature designed to protect data in use. This is particularly important for sensitive workloads where data must be secured not only when at rest or in transit but also while being processed.
Encrypts and Isolates In-Use Data: OCI Confidential Computing ensures that data and the applications processing it are isolated from the underlying infrastructure. This means that even if the infrastructure is compromised, the in-use data remains secure. The technology typically leverages secure enclaves or other hardware-based isolation mechanisms to achieve this.
Other Options:
Optimizing Network Performance (A), Automatic Scalability and Load Balancing (B), and Secure Data Storage (D) are important features, but they are not related to the core capabilities of Confidential Computing, which focuses on in-use data protection.
OCI Confidential Computing Overview
This documentation provides a detailed explanation of how OCI Confidential Computing works and its benefits for securing sensitive data during processing.
NEW QUESTION # 52
By default, OCI IAM policies follow the principle of least privilege. What does this principle mean in the context of policy creation?
  • A. Policies should provide only the minimum set of permissions required for users to perform their tasks effectively.
  • B. Policies should grant all possible permissions to simplify access control.
  • C. Policies should be written in a complex and technical manner to enhance security.
  • D. Policies should be identical for all users within a tenancy.
The principle of least privilege is a security best practice that dictates that users should only be granted the minimum set of permissions necessary to perform their tasks. This principle helps to minimize the risk of accidental or malicious actions that could compromise security.
IAM Policies in OCI: When creating IAM policies in OCI, you should carefully evaluate the required permissions and only grant those that are absolutely necessary for the users or groups to perform their specific roles. This helps to reduce the attack surface and prevent unauthorized access to sensitive resources.
Oracle Cloud Infrastructure Documentation: Identity and Access Management (IAM) Best Practices
NEW QUESTION # 53
What is a key advantage of utilizing administrator roles for access control within OCI IAM identity domains?
  • A. Provide granular control over user access to specific compartments
  • B. Offer a wider range of permission combinations
  • C. Simplify access management by eliminating policy creation
  • D. Can be used to grant access to resources outside the identity domain
In Oracle Cloud Infrastructure (OCI) Identity and Access Management (IAM), administrator roles play a significant role in managing access:
Simplification of Access Management: Utilizing administrator roles allows you to simplify access management by eliminating the need to create complex IAM policies manually. These roles come with predefined permissions that cover common administrative tasks, reducing the effort needed to manage access controls.
Granular Control: While administrator roles provide a broad range of permissions, they may not offer the same level of granularity as custom policies.
Other Benefits:
Offer a wider range of permission combinations (A): While custom policies can offer more specific combinations, administrator roles are designed to cover a broad range of tasks.
Granting Access Outside Identity Domain (C): Administrator roles are generally scoped to their identity domain and do not provide cross-domain access.
Granular Control (D): Although administrator roles simplify management, custom policies are typically used when granular control over specific compartments or resources is needed.
OCI IAM Roles Overview
This resource provides detailed information on how roles and policies are used in OCI to manage access.
NEW QUESTION # 54
I believe that after you use our 1Z0-1072-25 study materials for a while, we will understand why we have a 99% pass rate. Our company has been pursuing the quality of our products. And our professional experts are the most specialized people in this career to help us pass the 1Z0-1072-25 Exam. They have studied and done reseach on the design of our 1Z0-1072-25 practice guide for over ten years. So every detail of our 1Z0-1072-25 exam questions is perfect.
1Z0-1072-25 Testking Exam Questions: https://www.free4torrent.com/1Z0-1072-25-braindumps-torrent.html
Our study materials can give the user confidence and strongly rely on feeling, lets the user in the reference appendix not alone on the road, because we are to accompany the examinee on 1Z0-1072-25 exam, candidates need to not only learning content of teaching, but also share his arduous difficult helper, so believe us, we are so professional company, Free demo for 1Z0-1072-25 exam dumps are available, we recommend you to have a try before buying, so that you can have a deeper understanding of what you are going to buy.
Together, they became the dominant player in their industry in the world, Are you trying to pass the 1Z0-1072-25 exam to get the longing 1Z0-1072-25 certification?
Our study materials can give the user confidence and strongly 1Z0-1072-25 rely on feeling, lets the user in the reference appendix not alone on the road, because we are to accompany the examinee on 1Z0-1072-25 Exam, candidates need to not only learning content of teaching, but also share his arduous difficult helper, so believe us, we are so professional company.
Free PDF Quiz Valid Oracle - 1Z0-1072-25 - Exam Oracle Cloud Infrastructure 2025 Architect Associate Cram ReviewFree demo for 1Z0-1072-25 exam dumps are available, we recommend you to have a try before buying, so that you can have a deeper understanding of what you are going to buy.
The customization feature of these Oracle Cloud Infrastructure 2025 Architect Associate (1Z0-1072-25) practice questions (desktop or web-based) allows users to change the settings of their mock exams as per their preferences.
Our 1Z0-1072-25 questions and answers with high quality and passing rate can bolster hour confidence to clear exam more certainly, If you want to pass your Oracle 1Z0-1072-25 actual test at first attempt, 1Z0-1072-25 exam practice vce is your best choice.
Posted at 1/15/2026 17:30:58        Only Author  2#
Your article is truly outstanding, thank you for sharing it with us! Get the C-S4CCO-2506 reliable test answers exam materials now—free and essential for your career and salary growth!
Posted at 1/30/2026 18:14:46        Only Author  3#
It opened my mind in ways I didn’t expect. The Test NCREC-Broker-N review content is very good, and it’s available to everyone for free.
Posted at 2/8/2026 16:40:24        Only Author  4#
I’m so thankful for your article, it really made me think. The Latest NSE5_FNC_AD_7.6 study plan questions are free—unlock your promotion and salary raise!
Posted at 2/23/2026 03:40:39        Only Author  5#
Thank you for sharing this eye-opening article! The Brain dump DEA-C01 free helped me secure a promotion and raise. Now it’s free to everyone. Wishing you all a bright future in your careers!
