[General] 1Z0-083 Certification Test Answers - Reliable 1Z0-083 Braindumps Free
86
General 1Z0-083 Certification Test Answers - Reliable 1Z0-083 Braindumps Free
Posted at 1/10/2026 10:22:52      View228 | Replies3        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest Real4Prep 1Z0-083 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1rmkZa2jUNa10YcgH3d9jtEOu3TtmBBpU
We have three versions of our 1Z0-083 certification guide, and they are PDF version, software version and online version. With the PDF version, you can print our materials onto paper and learn our 1Z0-083 exam study guide in a more handy way as you can take notes whenever you want to, and you can mark out whatever you need to review later. With the software version, you are allowed to install our 1Z0-083 Guide Torrent that operate in windows system. With the online version, you can study the 1Z0-083 guide torrent wherever you like as it can used on all kinds of eletronic devices.
Oracle 1Z0-083, also known as the Oracle Database Administration II exam, is a certification exam designed for individuals who have a strong knowledge and experience in Oracle database administration. 1Z0-083 exam is one of the advanced-level certification exams offered by Oracle and is intended for professionals who wish to validate their skills and knowledge in managing complex Oracle database systems.
Oracle 1Z0-083 Exam Syllabus Topics:
  • Perform Backup and Recover CDBs and PDBs
  • Create a new PDB from the CDB seed
  • Clone PDBs and Application containers
  • Configure and use Oracle Restart to manage components
  • Perform Full and Incremental Backups and Recoveries
  • Compress and Encrypt RMAN Backups
  • Explore the structure of PDBs
  • Backup non database files
  • Employ the best Oracle Database recovery technology for your failure situation
  • Install, upgrade and Patch applications
Topic 5
  • Create multi-section backups of very large files
  • Create and administer Application PDBS
  • Detect and repair database and database block corruption
Topic 6
  • Define and create application PDBs
  • Configure  your Database  to support Flashback
  • Perform flashback operations
To prepare for the Oracle 1Z0-083 Exam, candidates can take advantage of a variety of resources, including official Oracle documentation, training courses, practice exams, and study guides. It is also recommended that candidates gain hands-on experience working with Oracle databases, as this can help them better understand and apply the concepts covered in the exam.
Free PDF Quiz The Best Oracle - 1Z0-083 Certification Test AnswersDo you feel Oracle 1Z0-083 exam preparation is tough? Real4Prep desktop and web-based online Oracle 1Z0-083 practice test software will give you a clear idea about the final 1Z0-083 Test Pattern. Practicing with the Oracle 1Z0-083 practice test, you can evaluate your Oracle 1Z0-083 exam preparation.
Oracle Database Administration II Sample Questions (Q195-Q200):NEW QUESTION # 195
Choose three. Which three are true about block media recovery?
  • A. The target database for which one or more blocks are to be recovered must be in the OPEN state.
  • B. It can be performed on noncorrupt blocks.
  • C. It cannot repair logical corruption.
  • D. To use it, Flashback Database must be enabled.
  • E. The data file containing the block being recovered remains online.
  • F. A block being recovered is not accessible.
Answer: C,E,F
NEW QUESTION # 196
Which two are true about RMAN duplexed backup sets? (Choose two.)
  • A. A duplexed backup set always uses twice as many SBT channels as a non-duplexed backup set for the same number of files.
  • B. A duplexed backup set uses the same number of SBT channels as a non-duplexed backup set for the same number of files.
  • C. A non-duplexed backup set written to disk can be duplexed to tape by backing up the backup set that is already on disk.
  • D. A non-duplexed backup set written to disk can be duplexed to disk by backing up the backup set that is already on disk.
  • E. A non-duplexed backup set written to SBT can be duplexed to tape by backing up the backup set that is already on tape.
  • F. A non-duplexed backup set written to SBT can be duplexed to disk by backing up the backup set that is already on tape.
NEW QUESTION # 197
Choose two. Which two are true about RMAN Multisection backups when a very large data file is divided into four sections?
  • A. The four sections can be created in parallel.
  • B. The four sections can be created serially.
  • C. The four sections must be contained in backup sets.
  • D. Each of the file sections must be processed serially.
  • E. The four sections must be image copies.
NEW QUESTION # 198
Examine this configuration:
1. CDB1 is a container database.
2. PDB1 and PDB2 are pluggable databases in CDB1.
3. PDB1 and PDB2 are open in read write mode.
You execute these commands successfully:
Which two are true?
  • A. Uncommitted transactions in CDB1 and pdbi have been rolled back.
  • B. CDB1 is in mount state
  • C. CDB1 is shut down.
  • D. Uncommitted transactions in PDB1 have been rolled back.
  • E. PDB1 is closed.
NEW QUESTION # 199
17.CDB1is an Oracle Database 12c Release 2 container database (CDB).
18.PDB1and PDB2are two pluggable databases (PDBs) in CDB1.
After successfully performing all the preupgrade tasks, you execute these commands from the Oracle Database 18c environment:
What is the outcome?
  • A. Only CDB$ROOT, PDB$SEED, and PDB1 are upgraded.
  • B. It fails because PDB2 is not in UPGRADE state.
  • C. CDB$ROOT, PDB$SEED, PDB1, and PDB2 are upgraded.
  • D. It fails because PDB$SEED is in MIGRATE state.
  • E. Only CDB$ROOT, PDB$SEED, and PDB2 are upgraded.
  • F. Only CDB$ROOT and PDB$SEED are upgraded.
https://docs.oracle.com/en/datab ... upgrading-parallel- upgrade-utility-catctl-pl.html#GUID-C667B51C-058F-48B6-86FE-12E9D82FDDBD
NEW QUESTION # 200
As is known to us, our company is professional brand established for compiling the 1Z0-083 exam materials for all candidates. The 1Z0-083 guide files from our company are designed by a lot of experts and professors of our company in the field. We can promise that the 1Z0-083 certification preparation materials of our company have the absolute authority in the study materials market. We believe that the study materials designed by our company will be the most suitable choice for you. You can totally depend on the 1Z0-083 Guide files of our company when you are preparing for the exam.
Reliable 1Z0-083 Braindumps Free: https://www.real4prep.com/1Z0-083-exam.html
P.S. Free & New 1Z0-083 dumps are available on Google Drive shared by Real4Prep: https://drive.google.com/open?id=1rmkZa2jUNa10YcgH3d9jtEOu3TtmBBpU
Posted at 1/23/2026 05:57:30        Only Author  2#
I appreciate your article deeply, it left a strong impression on me. The TDA-C01 latest exam pdf materials are freeyour key to climbing the career ladder and earning more!
Posted at 2/9/2026 03:56:51        Only Author  3#
The article was incredibly valuable to me. Sharing the C_S4CS_2508 detailed study plan test that was a key factor in my promotion and salary increase. Its free for you todayhope you achieve your professional dreams!
Posted at 2/23/2026 01:34:15        Only Author  4#
What a powerful and inspiring article, thanks for sharing! Free New APP CPIM-8.0 simulations exam papers available. Best of luck to everyone!
