[General] Pass Guaranteed 2026 Confluent CCAAK Perfect Valid Exam Experience
88
General Pass Guaranteed 2026 Confluent CCAAK Perfect Valid Exam Experience
Posted at 1/10/2026 11:14:29      View196 | Replies3        Print      Only Author   [Copy Link] 1#
P.S. Free & New CCAAK dumps are available on Google Drive shared by PDF4Test: https://drive.google.com/open?id=1rpCw6uvcnQIyGSVS7CHOrNbftEFC_jue
Desktop-based practice exam software CCAAK is the first format that PDF4Test provides to its customers. It helps track the progress of the candidate from beginning to end and provides a progress report that is easily accessible. This Confluent CCAAK Practice Questions is customizable and mimics the real exam, with the same format, and is easy to use on Windows-based computers. The product support staff is available to assist with any issues that may arise.
Each of us expects to have a well-paid job, with their own hands to fight their own future. But many people are not confident, because they lack the ability to stand out among many competitors. Now, our latest CCAAK exam dump can help you. It can let users in the shortest possible time to master the most important test difficulties, improve learning efficiency. Also, by studying hard, passing a qualifying examination and obtaining a CCAAK certificate is no longer a dream. With these conditions, you will be able to stand out from the interview and get the job you've been waiting for. However, in the real time employment process, users also need to continue to learn to enrich themselves. To learn our CCAAK practice materials, victory is at hand.
Pass Guaranteed Quiz 2026 Confluent - CCAAK - Valid Confluent Certified Administrator for Apache Kafka Exam ExperienceThe moment you choose to go with our CCAAK study materials, your dream will be more clearly presented to you. Next, through my introduction, I hope you can have a deeper understanding of our CCAAK learning quiz. We really hope that our CCAAK Practice Engine will give you some help. In fact, our CCAAK exam questions have helped tens of thousands of our customers successfully achieve their certification.
Confluent Certified Administrator for Apache Kafka Sample Questions (Q24-Q29):NEW QUESTION # 24
Kafka broker supports which Simple Authentication and Security Layer (SASL) mechanisms for authentication? (Choose three.)
  • A. SASL/PLAIN
  • B. SASL/SAML20
  • C. SASL/OTP
  • D. SASL/GSSAPI (Kerberos)
  • E. SASL/OAUTHBEARER
Answer: A,D,E
SASL/PLAIN - A simple username/password mechanism supported by Kafka.
SASL/GSSAPI (Kerberos) - Kafka supports Kerberos authentication through the GSSAPI mechanism.
SASL/OAUTHBEARER - Kafka supports OAUTHBEARER for token-based authentication.
NEW QUESTION # 25
A Kafka administrator notices that their consumers of Topic X are starting to fall behind. The administrator sees that Topic X has four partitions, and the consumer group has two consumers.
Which change can increase the performance of the Consumer Group?
  • A. Decrease the consumer acknowledgment property to increase throughput.
  • B. Increase the number of consumers in the consumer group.
  • C. Increase the partitions in Topic X.
  • D. Create a new consumer group for Topic X containing two (2) consumers.
With 4 partitions and only 2 consumers, some consumers are handling multiple partitions, which may cause lag if processing is slow. By increasing the number of consumers in the group (up to 4), Kafka can assign one partition per consumer, improving parallelism and throughput.
NEW QUESTION # 26
Which tool is used for scalably and reliably streaming data between Kafka and other data systems?
  • A. Kafka Connect
  • B. Kafka Schema Registry
  • C. Kafka REST Proxy
  • D. Kafka Streams
Kafka Connect is the tool designed for scalable and reliable integration between Kafka and external data systems (e.g., databases, cloud storage, key-value stores). It supports source connectors (to pull data into Kafka) and sink connectors (to push data from Kafka).
NEW QUESTION # 27
A developer is working for a company with internal best practices that dictate that there is no single point of failure for all data stored.
What is the best approach to make sure the developer is complying with this best practice when creating Kafka topics?
  • A. Set 'min.insync.replicas' to 1.
  • B. Use the parameter --partitions=3 when creating the topic.
  • C. Make sure the topics are created with linger.ms=0 so data is written immediately and not held in batch.
  • D. Set the topic replication factor to 3.
Replication factor determines how many copies of each partition exist across different brokers. A replication factor of 3 ensures that even if one or two brokers fail, the data is still available, thus eliminating a single point of failure.
NEW QUESTION # 28
Your organization has a mission-critical Kafka cluster that must be highly available. A Disaster Recovery (DR) cluster has been set up using Replicator, and data is continuously being replicated from source cluster to the DR cluster. However, you notice that the message on offset 1002 on source cluster does not seem to match with offset 1002 on the destination DR cluster.
Which statement is correct?
  • A. The DR cluster is lagging behind updates; once the DR cluster catches up, the messages will match.
  • B. The message was updated on source cluster, but the update did not flow into destination DR cluster and errored.
  • C. The message on DR cluster got over-written accidently by another application.
  • D. The offsets for the messages on the source, destination cluster may not match.
When using Confluent Replicator (or MirrorMaker), offsets are not preserved between the source and destination Kafka clusters. Messages are replicated based on content, but they are assigned new offsets in the DR (destination) cluster. Therefore, offset 1002 on the source and offset 1002 on the DR cluster likely refer to different messages, which is expected behavior.
NEW QUESTION # 29
Their updated Confluent Certified Administrator for Apache Kafka (CCAAK) practice test material includes the latest and real CCAAK questions that are very similar to those given in the actual Confluent Certified Administrator for Apache Kafka (CCAAK) exam. Additionally, the Confluent Certified Administrator for Apache Kafka (CCAAK) practice test software creates a realistic CCAAK exam environment for users, and it also helps you in your preparation for the actual Confluent Certified Administrator for Apache Kafka (CCAAK) test. PDF4Test offers the latest CCAAK exam questions in multiple formats for convenience. These formats include Confluent Certified Administrator for Apache Kafka (CCAAK) PDF dumps, CCAAK Practice Test (web-based), and CCAAK Practice Exam Software (Desktop-Based).
Exam CCAAK Pattern: https://www.pdf4test.com/CCAAK-dump-torrent.html
PDF4Test.com gives you Confluent CCAAK dumps questions with pdf questions and APP test engine software, Confluent Valid CCAAK Exam Experience You can totally relay on us, Confluent Valid CCAAK Exam Experience If perchance, you lose your exam, DumpsPedia refunds your money in full without any deduction, Confluent Exam CCAAK Pattern Exam CCAAK Pattern practice exams are just the beginning.
Business cards can be powerful selling tools, marketing weapons that set you Reliable CCAAK Exam Papers apart from your competition, Then other collectors who follow me repin that item to their own boards, where it's seen by their followers  and on and on.
100% Pass Quiz 2026 Updated Confluent Valid CCAAK Exam ExperiencePDF4Test.com gives you Confluent CCAAK Dumps Questions with pdf questions and APP test engine software, You can totally relay on us, If perchance, you lose your exam, DumpsPedia refunds your money in full without any deduction.
Confluent Confluent Certified Administrator practice exams are just the beginning, CCAAK Nowadays, with the development of Internet, our information security has been threatened.
DOWNLOAD the newest PDF4Test CCAAK PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1rpCw6uvcnQIyGSVS7CHOrNbftEFC_jue
Posted at 1/10/2026 17:29:20        Only Author  2#
This is so good, a like is mandatory. Best of luck on your exam! Free DAA-C01 latest test camp materials materials are shared here.
Posted at 1/11/2026 11:18:50        Only Author  3#
What a phenomenal article, I appreciate you sharing it with us! The C_THR81_2505 reliable exam questions answers exam questions are available for freeyour ticket to a promotion and salary increase!
Posted at 1/23/2026 06:57:35        Only Author  4#
This is such a brilliant article, thank you for providing it. New CInP associate level test has outstanding content, and I hope it helps you, at no cost.
Posted at 2/23/2026 08:29:19        Only Author  5#
Your article had such a strong effect on me, Im really thankful. Free access to Exam CTS-D flashcards materials for allgood luck!
