[General] CCDAK Valid Test Fee - CCDAK Valid Dumps Files
107
General CCDAK Valid Test Fee - CCDAK Valid Dumps Files
Posted at 1/10/2026 12:45:39      View234 | Replies6        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest VCEEngine CCDAK PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1liYI7nLl_UVopG0tQbRam7NLcDDTwI_p
Many of the candidates like the Soft version of our CCDAK exam questions. The software of CCDAK guide torrent boosts varied self-learning and self-assessment functions to check the results of the learning. The software can help the learners find the weak links and deal with them. Our CCDAK Exam Questions boost timing function and the function to stimulate the exam. Our product sets the timer to stimulate the exam to adjust the speed and keep alert. So it is worthy for you to buy our CCDAK exam questions.
With the company of our CCDAK study dumps, you will find the direction of success. There is nothing more exciting than an effective and useful CCDAK question bank to study with for your coming exam. The sooner you use CCDAK Training Materials, the more chance you will pass the CCDAK exam, and the earlier you get your certificate. You definitely have to have a try and you will be satisfied without doubt.
CCDAK Valid Dumps Files & Pdf CCDAK FormatMost experts agree that the best time to ask for more dough is after you feel your CCDAK performance has really stood out. Our CCDAK guide materials provide such a learning system where you can improve your study efficiency to a great extent. During the process of using our CCDAK Study Materials, you focus yourself on the exam bank within the given time, and we will refer to the real exam time to set your CCDAK practice time, which will make you feel the actual CCDAK exam environment and build up confidence.
Confluent CCDAK (Confluent Certified Developer for Apache Kafka) Certification Examination is a comprehensive test designed to evaluate the proficiency of developers in building and maintaining Apache Kafka-based applications. CCDAK exam is targeted towards software developers, data architects, and data engineers who are looking for a way to validate their knowledge and skills in building real-time, scalable, and fault-tolerant distributed systems using Apache Kafka.
Confluent Certified Developer for Apache Kafka Certification Examination Sample Questions (Q46-Q51):NEW QUESTION # 46
Suppose you have 6 brokers and you decide to create a topic with 10 partitions and a replication factor of 3.
The brokers 0 and 1 are on rack A, the brokers 2 and 3 are on rack B, and the brokers 4 and 5 are on rack C.
If the leader for partition 0 is on broker 4, and the first replica is on broker 2, which broker can host the last replica? (select two)
  • A. 0
  • B. 1
  • C. 2
  • D. 3
  • E. 4
  • F. 5
Answer: B,E
When you create a new topic, partitions replicas are spreads across racks to maintain availability. Hence, the Rack A, which currently does not hold the topic partition, will be selected for the last replica
NEW QUESTION # 47
You are sending messages with keys to a topic. To increase throughput, you decide to increase the number of partitions of the topic. Select all that apply.
  • A. All the existing records will get rebalanced among the partitions to balance load
  • B. New records with the same key will get written to the partition where old records with that key were written
  • C. Old records will stay in their partitions
  • D. New records may get written to a different partition
Increasing the number of partition causes new messages keys to get hashed differently, and breaks the guarantee "same keys goes to the same partition". Kafka logs are immutable and the previous messages are not re-shuffled
NEW QUESTION # 48
In the Kafka consumer metrics it is observed that fetch-rate is very high and each fetch is small. What steps will you take to increase throughput?
  • A. Decrease fetch.min.bytes
  • B. Decrease fetch.max.bytes
  • C. Increase fetch.max.bytes
  • D. Increase fetch.max.wait
  • E. Increase fetch.min.bytes
Answer: E
This will allow consumers to wait and receive more bytes in each fetch request.
NEW QUESTION # 49
To transform data from a Kafka topic to another one, I should use
  • A. Kafka Connect Source
  • B. Kafka Connect Sink
  • C. Consumer + Producer
  • D. Kafka Streams
Kafka Streams is a library for building streaming applications, specifically applications that transform input Kafka topics into output Kafka topics
NEW QUESTION # 50
You have a Kafka consumer in production actively reading from a critical topic.
You need to update the offset of your consumer to start reading from the beginning of the topic.
Which action should you take?
  • A. Update the consumer configuration by setting auto.offset.reset=earliest.
  • B. Temporarily configure the topic's retention.ms parameter to 0 to empty the topic.
  • C. Update the consumer group's offset to the earliest position using the kafka-consumer-groups CLI tool.
  • D. Start a new consumer application with the same consumer group id.
To reset offsets for anexisting consumer group, you must use thekafka-consumer-groups.shtool with the -- reset-offsets and --to-earliest flags.
FromKafka Consumer Group Tool Documentation:
"You can use the kafka-consumer-groups tool to reset offsets for a consumer group. This is required if the consumer has already committed offsets."
* Setting auto.offset.reset=earliest only worksif no committed offset exists.
* Starting a new consumer with the same group won't reset offsets.
* Retention settings don't affect committed offsets.
Reference:Kafka Consumer Group CLI Tool
NEW QUESTION # 51
If you want to start your learning as quickly as possible, just choose us, we can do this for you. Our CCDAK study materials is famous for instant download, and you can get the downloading link and password within ten minutes after purchasing, if you dont receive, you can ask our service stuff for help. Besides, CCDAK Exam Dumps of us contain both questions and answers, and you can check the answer when you finish practicing. CCDAK study materials are also have certain questions and it will help you to pass the exam successfully.
CCDAK Valid Dumps Files: https://www.vceengine.com/CCDAK-vce-test-engine.html
P.S. Free & New CCDAK dumps are available on Google Drive shared by VCEEngine: https://drive.google.com/open?id=1liYI7nLl_UVopG0tQbRam7NLcDDTwI_p
Posted at 1/27/2026 00:56:07        Only Author  2#
Your article has left me speechless, thank you for sharing it! Unlock the door to promotions and salary raises with the free 200-201 valid test passing score questions!
Posted at 2/10/2026 10:44:02        Only Author  3#
Im in awe of this article, thank you for sharing it with us! Here are the New test SC-100 camp pdf questions for freeyour key to career advancement!
Posted at 2/14/2026 12:10:49        Only Author  4#
I took away so much from reading that article. Unlock the door to promotions and salary raises with the free ISO-IEC-27001-Lead-Auditor vce format questions!
Posted at 2/19/2026 17:24:20        Only Author  5#
Your article was truly inspiring, thank you for sharing it with me. Unlock your promotion with free Latest N16291GC10 vce exam simulator exam materialscareer growth is waiting!
Posted at 2/22/2026 21:24:53        Only Author  6#
By reading this article, I have gained a deeper understanding of the topic. Get free Clear CCSFP exam to improve your IT knowledge. Wishing you success!
Posted at 2/23/2026 03:29:20        Only Author  7#
What an outstanding piece of writing, I truly appreciate your sharing. Best of luck to everyone preparing for their exams! Free Sample 220-1201 questions pdf questions here!
