[General] Free PDF ServiceNow CIS-Discovery - Certified Implementation Specialist - Discov
64
General Free PDF ServiceNow CIS-Discovery - Certified Implementation Specialist - Discov
Posted at 1/10/2026 13:35:33      View254 | Replies1        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 ServiceNow CIS-Discovery dumps are available on Google Drive shared by RealExamFree: https://drive.google.com/open?id=106INaIRrS_jfj-GwkEnjgfRaeIfQs4Rs
It is not easy to absorb the knowledge we learn, so, we often forget these information. When you choose our ServiceNow CIS-Discovery Practice Test, you will know that it is your necessity and you have to purchase it. You can easily pass the exam. To trust in RealExamFree, it will help you to open a new prospect.
The CIS-Discovery certification exam covers a range of topics such as Discovery Architecture, Discovery Classification, and Discovery Patterns. It also covers the integration of Discovery with other ServiceNow applications such as CMDB, Asset Management, and Service Mapping. CIS-Discovery Exam consists of 60 multiple-choice questions, which need to be completed within 90 minutes. The passing score is 70%, and candidates can retake the exam if needed.
Find Success In Exam With ServiceNow CIS-Discovery PDF QuestionsThere is plenty of skilled and motivated staff to help you obtain the Certified Implementation Specialist - Discovery exam certificate that you are looking forward. We have faith in our professional team and our CIS-Discovery Study Tool, and we also wish you trust us wholeheartedly. Because of this function, you can easily grasp how the practice system operates and be able to get hold of the core knowledge about the Certified Implementation Specialist - Discovery exam. In addition, when you are in the real exam environment, you can learn to control your speed and quality in answering questions and form a good habit of doing exercise, so that youre going to be fine in the Certified Implementation Specialist - Discovery exam.
ServiceNow Certified Implementation Specialist - Discovery Sample Questions (Q27-Q32):NEW QUESTION # 27
There can be ______ CI Identifier(s) configured per CI Class.
Response:
  • A. 0
  • B. 1
  • C. 2
  • D. 3
NEW QUESTION # 28
What related list on a classifier dictates which Horizontal Pattern probe is launched?
  • A. Triggers probes
  • B. Discovery Log
  • C. Classification Criteria
  • D. Pattern probes
A classifier is a set of rules that identifies a device type based on the results of a probe. A classifier can have one or more related lists that define the classification criteria, the pattern probes, and the triggers probes. The pattern probes related list specifies which horizontal discovery pattern to run for the device type. The triggers probes related list specifies which probes to run after the device is classified, and before the horizontal discovery pattern is executed. The triggers probes can be used to gather additional information or credentials that are needed for the horizontal discovery pattern12.
* 1: ServiceNow Discovery Overview, page 9
* 2: ServiceNow Discovery Documentation, Classifiers section
NEW QUESTION # 29
Which choices are necessary to launch any pattern?(Choose two.)
  • A. CI Classification
  • B. CI Serial Number Attribute
  • C. CI Type
  • D. Data Certification
To launch any pattern, you need to specify the CI classification and the CI type. The CI classification determines the table where the discovered CI is stored in the CMDB, and the CI type defines the specific attributes and relationships of the CI. For example, if you want to discover a Windows server, you need to select the CI classification as cmdb_ci_win_server and the CI type as Windows Server. These choices are mandatory for any pattern, as they enable Discovery to identify and classify the CIs correctly.
1: Patterns and horizontal discovery, Available discovery patterns
Reference: https://docs.servicenow.com/bund ... ontalDiscovery.html
NEW QUESTION # 30
A network device has both an SSH port and an SNMP port open. Discovery tries the SSH probe first and it fails. This triggers the SNMP probe, which succeeds. Discovery uses SNMP first for subsequent discoveries on that device.
What discovery functionality allows the above to happen?
  • A. MID Server affinity
  • B. Credential affinity
  • C. IP service affinity
  • D. Classification
Credential affinity is an association between a set of credentials and a device on your network. When Discovery or Orchestration first attempts to access a device, they try all available credentials until a valid one is found. Once a valid credential is found, it is recorded in the dscy_credentials_affinity table, and further discovery processes rely on this information. If the credentials are modified or changed, the process will be repeated until a valid credential is found and updated in the same table. Credential affinity allows Discovery to use the most efficient and successful credential for each device, and avoid unnecessary credential failures.
1: Credential affinity for Discovery and Orchestration, Credential Management in ServiceNow discovery
NEW QUESTION # 31
A is a series of operations that tell Discovery which Cls to find on your network, what credentials to use, and what tables to populate in the CMDB.
Response:
  • A. Classifier
  • B. Explorer
  • C. Pattern
  • D. Identifier
NEW QUESTION # 32
Free demo is available for CIS-Discovery training materials, so that you can have a deeper understanding of what you are going to buy. We also recommend you to have a try. In addition, CIS-Discovery training materials are compiled by experienced experts, and they are quite familiar with the exam center, and if you choose us, you can know the latest information for the CIS-Discovery Exam Dumps. We offer you free update for one year after buying CIS-Discovery exam materials from us, and our system will send the latest version to your email automatically. So you just need to check your email, and change the your learning ways in accordance with new changes.
Reliable CIS-Discovery Exam Pdf: https://www.realexamfree.com/CIS-Discovery-real-exam-dumps.html
P.S. Free & New CIS-Discovery dumps are available on Google Drive shared by RealExamFree: https://drive.google.com/open?id=106INaIRrS_jfj-GwkEnjgfRaeIfQs4Rs
Posted at 2/2/2026 01:34:24        Only Author  2#
This article is truly top-notch, thank you for sharing it with me. The Exam dumps PMI-ACP free exam is nearly here. Hoping for a smooth experience!
