1Z0-1109-25トレーニング資料、1Z0-1109-25資格試験
Posted at 1/10/2026 13:55:41
ちなみに、Xhs1991 1Z0-1109-25の一部をクラウドストレージからダウンロードできます:https://drive.google.com/open?id=1-wC5xPh1eGVNqZ7rOcXh7u0yLhcrc_8j
Xhs1991 Oracleの1Z0-1109-25試験問題集は完全な無制限のダンプが含まれていますから、Xhs1991を利用したら気楽に試験に受かることができます。製品検定合格の証明書あるいは他の人気がある身分検定によって、Xhs1991 Oracleの1Z0-1109-25試験トレーニング資料の長所を完璧に見せることができます。依頼だけでなく、指導のことも最高です。Xhs1991 Oracleの1Z0-1109-25試験トレーニング資料に含まれている問題と解答を利用して、Oracleの1Z0-1109-25認定試験に合格することができます。
Oracle 1Z0-1109-25 認定試験の出題範囲:| トピック | 出題範囲 | | トピック 1 | - Implementing Monitoring and Observability (O&M): This section evaluates the expertise of Site Reliability Engineers (SREs) and Monitoring Specialists in tracking system performance using OCI Monitoring, Logging, and Events services. It analyzes metrics, logs, and events to maintain system reliability and troubleshoot operational issues effectively.
| | トピック 2 | - Managing Containers Using Container Orchestration Engine: This part assesses the abilities of Kubernetes Administrators and Containerization Specialists in managing Oracle Container Engine for Kubernetes (OKE). It covers cluster creation, scaling, upgrades, networking, storage, and security configurations to optimize containerized applications in OCI environments.
| | トピック 3 | - Enabling DevSecOps: This domain measures the skills of Security Engineers and DevSecOps Practitioners in integrating security into DevOps workflows. It includes managing encryption keys with OCI Vault, securing CI
- CD pipelines, and ensuring container image security to align with DevSecOps best practices.
| | トピック 4 | - Understand DevOps Principles and Effectively Work with Containerization Services: This section of the exam measures the skills of DevOps Engineers and Cloud Architects in applying DevOps methodologies and containerization practices. It covers implementing a microservices architecture, creating Docker containers, and managing Oracle Cloud Infrastructure Registry (OCIR) and Container Instances to streamline application deployment and scalability.
| | トピック 5 | - Using Code and Templates for Provisioning and Configuring Infrastructure: This domain evaluates the expertise of DevOps Engineers and Infrastructure Architects in deploying infrastructure using Infrastructure as Code (IaC) tools like Terraform. It focuses on automating resource provisioning with OCI Resource Manager to ensure consistent and efficient infrastructure setups.
実用的1Z0-1109-25|ユニークな1Z0-1109-25トレーニング資料試験|試験の準備方法Oracle Cloud Infrastructure 2025 DevOps Professional資格試験Xhs1991は1Z0-1109-25認定試験に対する短期で有効な訓練を提供するウェブサイト、1Z0-1109-25認定試験が生活の変化をもたらすテストでございます。合格書を持ち方が持たない人により高い給料をもうけられます。
Oracle Cloud Infrastructure 2025 DevOps Professional 認定 1Z0-1109-25 試験問題 (Q10-Q15):質問 # 10
What are the two items required to create a rule for the Oracle Cloud Infrastructure Events Service? (Choose two.)
- A. Rule Conditions
- B. Auth Token
- C. Actions
- D. Management Agent Cloud Service
- E. Service Connector
正解:A、C
Oracle Cloud Infrastructure (OCI) Events Service allows you to create rules to automatically respond to changes in your OCI environment. To create a rule, you need the following items:
Rule Conditions: Conditions define the events that will trigger the rule. This specifies what event (e.g., instance creation, object storage bucket modification) will trigger an action.
Actions: Actions define what should happen when a condition is met. For example, the action might be to trigger an OCI Function or send a notification.
質問 # 11
You are a developer and have been asked to develop an e-commerce website for your organization. It must support a variety of clients including desktop browsers, mobile browsers and native mobile applications.
Which two approaches can you use to build the application to achieve deployment independence, easier technology upgrades, and resiliency to architecture changes? (Choose two.)
- A. Use monolithic approach to as it makes it easier to incrementally adapt to newer technology.
- B. Choose monolithic approach over microservices as it has better fault isolation capability.
- C. Implement each module as an independent service/process which can be replaced, updated, or deleted without disrupting the rest of the application.
- D. Use monolithic approach, as it allows you to easily redeploy your applications to perform frequent updates.
- E. Use microservices architecture as it eliminates any long-term commitment to a technology stack.
正解:C、E
By implementing each module as an independent service/process (which is a core feature of microservices architecture), you can replace, update, or delete services without affecting the rest of the application. This ensures deployment independence and makes it easier to adapt to architecture changes or technology upgrades without major disruptions.
Microservices architecture allows each service to be built with the best-suited technology stack for its specific function. This flexibility ensures that you are not tied to a single technology for the entire application, making future technology upgrades easier and eliminating long-term technology commitments.
質問 # 12
As a DevOps Engineer, you are tasked with securely storing and versioning your application's source code and automatically build, test, and deploy your application to Oracle Cloud Infrastructure (OCI) platform.
You are told to automate manual tasks and help software teams in managing complex environments at scale.
Which three OCI services can you choose to accomplish these tasks? (Choose three.)
- A. Oracle Cloud Infrastructure Registry
- B. Container Engine for Kubernetes
- C. Oracle APEX Application Development
- D. Oracle Cloud Logging Analytics
- E. DevOps project
正解:A、B、E
Oracle Cloud Infrastructure Registry: This service allows you to securely store container images. It is essential for managing the container images used for deployment, making it an important part of the DevOps workflow.
DevOps project: OCI DevOps project is specifically designed to manage the CI/CD pipeline. It helps in automating tasks like building, testing, and deploying applications, which are key activities for managing complex environments and promoting agility in software development.
Container Engine for Kubernetes: Oracle Container Engine for Kubernetes (OKE) is used to deploy applications in a containerized environment. It provides a robust platform for deploying, managing, and scaling containerized applications, which is essential for handling complex environments at scale.
質問 # 13
Which command creates the docker registry secret required in the application manifests for OKE to pull images from Oracle Cloud Infrastructure Registry?
To create a Docker registry secret to pull images from the Oracle Cloud Infrastructure Registry (OCIR), you need to specify the correct parameters such as the region key, namespace, OCI username, and OCI authentication token.
Chosen command is correct because:
The kubectl create secret docker-registry command creates a Docker registry secret.
The --docker-server=<region-key>.ocir.io specifies the correct endpoint for OCIR.
The --docker-username=<tenancy-namespace>/<oci-username> provides both the tenancy namespace and the OCI username, which is the required format for authentication with OCIR.
The --docker-password='<oci-auth-token>' specifies the OCI auth token, which acts as a password for authentication.
The --docker-email=<email-address> is also included.
The other commands have errors, such as missing tenancy namespace or using incorrect flags (passwd instead of secret).
質問 # 14
Which of the following statement is INCORRECT with respect to a Dockerfile?
- A. WORKDIR instruction sets the working directory for any RUN, CMD, ENTRYPOINT instructions and not for COPY and ADD instructions in the Dockerfile.
- B. The RUN instruction will execute any commands in a new layer on top of the current image and commit the results.
- C. An ENV instruction sets the environment value to the key, and it is available for the subsequent build steps and in the running container as well.
- D. If CMD instruction provides default arguments for the ENTRYPOINT instruction, both should be specified in JSON format.
The WORKDIR instruction sets the working directory for all subsequent RUN, CMD, ENTRYPOINT, COPY, and ADD instructions in the Dockerfile. This means that after specifying WORKDIR, all these instructions will use the specified directory as their current working directory.
質問 # 15
1Z0-1109-25試験問題のさまざまなバージョンを知りたい場合があります。まず、PDFバージョンは読みやすく、印刷しやすいです。次に、ソフトウェアバージョンは実際の1Z0-1109-25実際のテストガイドをシミュレートしますが、Windowsオペレーティングシステムでのみ実行できます。第三に、オンライン版はあらゆる電子機器をサポートし、オフライン使用もサポートします。初めて、オンライン環境で1Z0-1109-25試験問題を開く必要があり、それをオフラインで使用できます。全体として、受験者が試験に合格するのを支援することが常に求められています。 1Z0-1109-25実際のテストガイドが最適です。
1Z0-1109-25資格試験: https://www.xhs1991.com/1Z0-1109-25.html
- 完璧なOracle 1Z0-1109-25トレーニング資料 - 合格スムーズ1Z0-1109-25資格試験 | 信頼的な1Z0-1109-25日本語版トレーリング 📑 今すぐ➠ [url]www.xhs1991.com 🠰で✔ 1Z0-1109-25 ️✔️を検索して、無料でダウンロードしてください1Z0-1109-25資格認証攻略[/url]
- 1Z0-1109-25認定テキスト 🌖 1Z0-1109-25予想試験 💳 1Z0-1109-25認定テキスト 🍠 ウェブサイト⇛ [url]www.goshiken.com ⇚から▛ 1Z0-1109-25 ▟を開いて検索し、無料でダウンロードしてください1Z0-1109-25模擬試験最新版[/url]
- 1Z0-1109-25練習問題集 🤨 1Z0-1109-25模擬試験最新版 🐂 1Z0-1109-25テスト対策書 🚉 Open Webサイト⏩ [url]www.passtest.jp ⏪検索⏩ 1Z0-1109-25 ⏪無料ダウンロード1Z0-1109-25資格認証攻略[/url]
- 検証する1Z0-1109-25トレーニング資料試験-試験の準備方法-真実的な1Z0-1109-25資格試験 ✅ “ [url]www.goshiken.com ”は、[ 1Z0-1109-25 ]を無料でダウンロードするのに最適なサイトです1Z0-1109-25日本語版トレーリング[/url]
- 1Z0-1109-25専門試験 🌴 1Z0-1109-25最新試験 🥪 1Z0-1109-25資格受験料 🧜 ➠ [url]www.xhs1991.com 🠰から➽ 1Z0-1109-25 🢪を検索して、試験資料を無料でダウンロードしてください1Z0-1109-25認定テキスト[/url]
- 完璧なOracle 1Z0-1109-25トレーニング資料 は主要材料 - 信頼できる1Z0-1109-25資格試験 🎹 URL 「 [url]www.goshiken.com 」をコピーして開き、▷ 1Z0-1109-25 ◁を検索して無料でダウンロードしてください1Z0-1109-25資格認証攻略[/url]
- 検証する1Z0-1109-25トレーニング資料試験-試験の準備方法-真実的な1Z0-1109-25資格試験 🧖 { [url]www.passtest.jp }にて限定無料の▶ 1Z0-1109-25 ◀問題集をダウンロードせよ1Z0-1109-25資格受験料[/url]
- Oracle Cloud Infrastructure 2025 DevOps Professionalに合格するプロフェッショナル1Z0-1109-25トレーニング資料 - エキスパートによる推奨 😋 サイト✔ [url]www.goshiken.com ️✔️で➤ 1Z0-1109-25 ⮘問題集をダウンロード1Z0-1109-25勉強ガイド[/url]
- 有難い1Z0-1109-25トレーニング資料 - 合格スムーズ1Z0-1109-25資格試験 | 認定する1Z0-1109-25日本語版トレーリング Oracle Cloud Infrastructure 2025 DevOps Professional 🚨 ➥ [url]www.xhs1991.com 🡄には無料の[ 1Z0-1109-25 ]問題集があります1Z0-1109-25日本語版トレーリング[/url]
- Oracle Cloud Infrastructure 2025 DevOps Professionalに合格するプロフェッショナル1Z0-1109-25トレーニング資料 - エキスパートによる推奨 🥟 最新【 1Z0-1109-25 】問題集ファイルは▷ [url]www.goshiken.com ◁にて検索1Z0-1109-25学習関連題[/url]
- 有難い1Z0-1109-25トレーニング資料 - 合格スムーズ1Z0-1109-25資格試験 | 認定する1Z0-1109-25日本語版トレーリング Oracle Cloud Infrastructure 2025 DevOps Professional 🕋 ➡ jp.fast2test.com ️⬅️に移動し、▷ 1Z0-1109-25 ◁を検索して、無料でダウンロード可能な試験資料を探します1Z0-1109-25認定テキスト
- myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, mprees.alboompro.com, notefolio.net, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, wp.azdnsu.com, app.parler.com, k12.instructure.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, Disposable vapes
さらに、Xhs1991 1Z0-1109-25ダンプの一部が現在無料で提供されています:https://drive.google.com/open?id=1-wC5xPh1eGVNqZ7rOcXh7u0yLhcrc_8j
