[General] ANS-C01 Exam Pass Guide, ANS-C01 Valid Exam Registration
83
General ANS-C01 Exam Pass Guide, ANS-C01 Valid Exam Registration
Posted at 1/10/2026 16:32:06      View189 | Replies2        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of Pass4suresVCE ANS-C01 dumps from Cloud Storage: https://drive.google.com/open?id=1xBPtoJDZSEFZQmN4EMB85j9lZK72eW4V
To avail of all these Amazon ANS-C01 certification exam benefits you need to enroll in Amazon ANS-C01 certification exam and pass it with good scores. Are you ready for this? If your answer is right then you do not need to go anywhere. Just download Amazon ANS-C01 Dumps questions and start preparing today.
The ANS-C01 exam is a challenging and comprehensive test that covers a variety of topics related to advanced networking in the AWS cloud. This includes design and implementation of complex networking solutions, migration of on-premises networks to AWS, and optimization of network performance and security. ANS-C01 Exam also assesses candidates knowledge of AWS networking services such as Virtual Private Cloud (VPC), Direct Connect, Route 53, and Elastic Load Balancing.
ANS-C01 Valid Exam Registration - Reliable ANS-C01 Test CostOur ANS-C01 exam torrent is compiled by experts and approved by experienced professionals and updated according to the development situation in the theory and the practice. Our AWS Certified Advanced Networking Specialty Exam guide torrent can simulate the exam and boosts the timing function. The language is easy to be understood and makes the learners have no learning obstacles. So our ANS-C01 Exam Torrent can help you pass the exam with high possibility.
Amazon AWS Certified Advanced Networking Specialty Exam Sample Questions (Q171-Q176):NEW QUESTION # 171
Your VPC has a DX connection that is advertising 99 routes. You have two more prefixes to add:
10.223.1.0/24 and 10.223.2.0/24. You have several locations, so you need to be as exact as possible with your routing. How would you do this?
Response:
  • A. Summarize the routes into a 10.223.0.0/12 and advertise that route instead.
  • B. Summarize the routes into a 10.223.0.0/22 and advertise that route instead.
  • C. Contact AWS to extend the number of prefixes you are allowed to advertise.
  • D. Add the prefixes; AWS allows for as many BGP routes as you need but not static.
NEW QUESTION # 172
A company is planning to create a service that requires encryption in transit. The traffic must not be decrypted between the client and the backend of the service. The company will implement the service by using the gRPC protocol over TCP port 443. The service will scale up to thousands of simultaneous connections. The backend of the service will be hosted on an Amazon Elastic Kubernetes Service (Amazon EKS) duster with the Kubernetes Cluster Autoscaler and the Horizontal Pod Autoscaler configured. The company needs to use mutual TLS for two-way authentication between the client and the backend.
Which solution will meet these requirements?
  • A. Install the AWS Load Balancer Controller for Kubernetes. Using that controller, configure a Network Load Balancer with a TCP listener on port 443 to forward traffic to the IP addresses of the backend service Pods.
  • B. Create a target group. Add the EKS managed node group's Auto Scaling group as a target Create an Application Load Balancer with an HTTPS listener on port 443 to forward traffic to the target group.
  • C. Create a target group. Add the EKS managed node group's Auto Scaling group as a target. Create a Network Load Balancer with a TLS listener on port 443 to forward traffic to the target group.
  • D. Install the AWS Load Balancer Controller for Kubernetes. Using that controller, configure an Application Load Balancer with an HTTPS listener on port 443 to forward traffic to the IP addresses of the backend service Pods.
https://docs.aws.amazon.com/elas ... up-protocol-version https://docs.aws.amazon.com/pres ... -load-balancer.html
NEW QUESTION # 173
A network engineer is architecting a high performance computing solution on AWS. The system consists of a cluster of Amazon EC2 instances that require low-latency communications between them.
Which method will meet these requirements?
Response:
  • A. Launch Amazon EC2 instances with the largest available number of cores and RAM. Attach Amazon EBS Provisioned IOPS (PIOPS) volumes. Implement a shared memory system across all instances in the cluster.
  • B. Launch instances into a single subnet with a size equal to the number of instances required for the cluster.
  • C. Choose an Amazon EC2 instance type that offers enhanced networking. Attach a 10 Gbps non- blocking elastic network interface to the instances.
  • D. Create a cluster placement group. Launch Elastic Fabric Adapter (EFA)-enabled instances into the placement group.
NEW QUESTION # 174
Which of the following steps is necessary to ensure proper routing when terminating a Virtual Private Network (VPN) on an Amazon Elastic Compute Cloud (Amazon EC2) instance?
Response:
  • A. Disable source destination check on the Amazon EC2 instance
  • B. Enable source destination check on the Amazon EC2 instance
  • C. Enable enhanced networking mode on the Amazon EC2 instance.
  • D. Enable route propagation in a Virtual Private Cloud (VPC) subnet route table
NEW QUESTION # 175
What is unique about the main route table in a VPC?
(Choose two.)
Response:
  • A. You cannot delete the main route table
  • B. The main route table is used for all subnets by default.
  • C. You cannot replace the main route table with a custom route table
  • D. You cannot add or remove routes from the main route table
NEW QUESTION # 176
As a powerful tool for a lot of workers to walk forward a higher self-improvement, Pass4suresVCE continue to pursue our passion for advanced performance and human-centric technology. We aimed to help some candidates who have trouble in pass their ANS-C01 exam and only need few hours can grasp all content of the exam. In recent years, our ANS-C01 Test Torrent has been well received and have reached 99% pass rate with all our candidates. If you have a try on our ANS-C01 exam questions, you will be glad about the wonderful quality.
ANS-C01 Valid Exam Registration: https://www.pass4suresvce.com/ANS-C01-pass4sure-vce-dumps.html
DOWNLOAD the newest Pass4suresVCE ANS-C01 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1xBPtoJDZSEFZQmN4EMB85j9lZK72eW4V
Posted at 1/15/2026 02:51:21        Only Author  2#
I learned so much from the articleit was truly valuable. Improve your IT skills and access free Online FCP_FWF_AD-7.4 training materials. Wishing you the best of luck!
Posted at 1/30/2026 08:50:29        Only Author  3#
This article is very practical, and I have gained a lot of inspiration from it. Improve your IT skills and get free Reliable AP-211 test questions explanations. Best of luck in your studies!
