JN0-481 Exam Success & Valid Dumps JN0-481 Ebook
Posted at 1/10/2026 18:23:55
P.S. Free 2026 Juniper JN0-481 dumps are available on Google Drive shared by Prep4SureReview: https://drive.google.com/open?id=10LJY4xYKQEZIWTJkMUyEHXsqJ2Kjk27M
Our JN0-481 real exam dumps are specially prepared for you. Try our JN0-481 study tool and absorb new knowledge. After a period of learning, you will find that you are making progress. The knowledge you have studied on our JN0-481 exam question will enrich your life and make you wise. Do not reject challenging yourself. Your life will finally benefit from your positive changes. Let us struggle together and become better. Then you will do not need to admire others’ life. Our JN0-481 Real Exam dumps will fully change your life.
Using the JN0-481 Study Materials, you will find that you can grasp the knowledge what you need in the exam in a short time. Because users only need to spend little hours on the JN0-481 study materials, our learning materials will help users to learn all the difficulties of the test site, to help users pass the qualifying examination and obtain the qualification certificate. If you think that time is important to you, try our learning materials and it will save you a lot of time.
TOP JN0-481 Exam Success: Data Center, Specialist (JNCIS-DC) - The Best Juniper Valid Dumps JN0-481 EbookIf you Prep4SureReview, Prep4SureReview can ensure you 100% pass Juniper Certification JN0-481 Exam. If you fail to pass the exam, Prep4SureReview will full refund to you.
Juniper Data Center, Specialist (JNCIS-DC) Sample Questions (Q55-Q60):NEW QUESTION # 55
Which two statements are correct regarding a pristine configuration in Juniper Apstra? (Choose two.)
- A. It is the device's previously active configuration.
- B. It is the device's currently active configuration.
- C. It Is the configuration file on a device before acknowledgment in Apstra.
- D. It is the configuration file placed on the device when decommissioning the device.
A pristine configuration in Juniper Apstra is the configuration file that is used to onboard a device into the Apstra software application. A pristine configuration contains the minimum settings that are required for the device to communicate with the Apstra server, such as the hostname, management IP address, username, password, and SSH key. A pristine configuration has the following characteristics:
It is the configuration file placed on the device when decommissioning the device. This is because when a device is decommissioned from the Apstra software application, it is reverted back to its pristine configuration, which removes all the network configuration and services that were applied by the Apstra software application. This allows the device to be reused or repurposed for another network.
It is the configuration file on a device before acknowledgment in Apstra. This is because when a device is onboarded into the Apstra software application, it is initially in the discovery state, which means that the device is discovered by the Apstra server, but not yet acknowledged by the user.
In the discovery state, the device has the pristine configuration, which can be viewed and edited by the user. Once the user acknowledges the device, the device moves to the deployed state, which means that the device is ready to receive the network configuration and services from the Apstra software application.
NEW QUESTION # 56
You want to make a widget appear on the main dashboard in Juniper Apstr
- A. In this scenario, which statement is correct?
- B. On the blueprint dashboard, click on the Add Widget option.
- C. Widgets automatically appear on the blueprint dashboard.
- D. Set the Default toggle switch to On for the desired widget.
- E. When creating the widget, select the Add to Blueprint Dashboard option.
In Juniper Apstra, a widget is a graphical element that displays data from an intent-based analytics (IBA) probe. A widget can be used to monitor different aspects of the network and raise alerts to any anomalies. A widget can be viewed by itself or added to an analytics dashboard. A dashboard is a collection of widgets that can be customized and organized according to the user's preference. The main dashboard in Juniper Apstra is the blueprint dashboard, which is the default view that shows the network information and configuration for the active blueprint. A blueprint is a logical representation of the network design and intent. The blueprint dashboard can display the system-generated dashboards, the user-generated dashboards, and the individual widgets that are relevant to the network.
To make a widget appear on the main dashboard in Juniper Apstra, the user needs to set the Default toggle switch to On for the desired widget. This will add the widget to the blueprint dashboard, where it can be viewed along with other network information. The user can also remove the widget from the blueprint dashboard by setting the Default toggle switch to Off for the widget.
NEW QUESTION # 57
Which of the following two statements are correct?
- A. VXLAN is a Layer 2 encapsulation protocol
- B. VXLAN encapsulation discards VNIs
- C. VXLAN is a Layer 3 encapsulation protocol
- D. VXLAN encapsulation discards VLAN IDs
NEW QUESTION # 58
Which two actions are required during Juniper Apstra's deploy phase? (Choose two.)
- A. Assign device profiles to the blueprint.
- B. Assign user roles to the blueprint.
- C. Assign resources to the blueprint.
- D. Assign interlace maps to the blueprint.
The deploy phase is the final step in the Juniper Apstra data center fabric design and deployment process. In this phase, you apply the Apstra-rendered configuration to the devices and verify the intent of the blueprint. Based on the web search results, we can infer the following actions are required during the deploy phase:
Assign device profiles to the blueprint. This action associates a specific vendor model to each logical device in the blueprint. Device profiles contain extensive hardware model details, such as form factor, ASIC, CPU, RAM, ECMP limit, and supported features. Device profiles also define how configuration is generated, how telemetry commands are rendered, and how configuration is deployed on a device. Device profiles enable the Apstra system to render and deploy the configuration according to the Apstra Reference Design. Assign resources to the blueprint. This action allocates the physical devices, IP addresses, VLANs, and ASNs to the logical devices, networks, and routing zones in the blueprint. Resources can be assigned manually or automatically by the Apstra system. Assigning resources ensures that the blueprint has all the necessary elements to generate the configuration and deploy the fabric5 . Assign user roles to the blueprint. This action is not required during the deploy phase. User roles are defined at the system level, not at the blueprint level. User roles determine the permissions and access levels of different users in the Apstra system. User roles can be system-defined or custom-defined .
Assign interface maps to the blueprint. This action is not required during the deploy phase.
Interface maps are defined at the design phase, not at the deploy phase. Interface maps are objects that map the logical interfaces of a logical device to the physical interfaces of a device profile. Interface maps enable the Apstra system to generate the correct interface configuration for each device in the fabric.
NEW QUESTION # 59
You want to add a configuration that is not supported by Juniper Apstra reference architecture using a configlet.
Which two configurations would be applicable in this scenario? (Choose two.)
- A. static route configuration
- B. policy configuration
- C. NTP configuration
- D. syslog configuration
A configlet is a configuration template that augments Apstra's reference design with non-native device configuration. They consist of one or more generators. Each generator specifies a NOS type (config style), when to render the configuration, and CLI commands (and file name as applicable).
Some applications for configlets include the following:
- Syslog
- SNMP access policy
- TACACS / RADIUS
- Management ACLs
- Control plane policing
- NTP
- Username / password
NEW QUESTION # 60
When you are struggling with those troublesome reference books; when you feel helpless to be productive during the process of preparing different exams (such as JN0-481 exam); when you have difficulty in making full use of your sporadic time and avoiding procrastination. It is time for you to realize the importance of our JN0-481 Test Prep, which can help you solve these annoyance and obtain a JN0-481 certificate in a more efficient and productive way. As long as you study with our JN0-481 exam questions for 20 to 30 hours, you will be confident to take and pass the JN0-481 exam for sure.
Valid Dumps JN0-481 Ebook: https://www.prep4surereview.com/JN0-481-latest-braindumps.html
But we can claim that our JN0-481 practice engine is high-effective, as long as you study for 20 to 30 hours, you will be able to pass the exam, Click "Upload" 4, Juniper JN0-481 Exam Success There are too numerous successful examples to enumerate and you could see it in the bottom of our website, Are you still fretting about getting through the professional skill JN0-481 exam that baffling all IT workers?
Finally, I picked up a neat expression to use as a label on many of the JN0-481 files in my office, Users of the site embraced the concept and began to create their own wikis independent of the WikiWikiWeb website.
Hot JN0-481 Exam Success & Useful Tips to help you pass Juniper JN0-481But we can claim that our JN0-481 Practice Engine is high-effective, as long as you study for 20 to 30 hours, you will be able to pass the exam, Click "Upload" 4.
Good beginning is half success.
- JN0-481 Updated Demo 💉 JN0-481 Reliable Test Cram ❤ JN0-481 Test Discount Voucher ✳ ➤ [url]www.pdfdumps.com ⮘ is best website to obtain 「 JN0-481 」 for free download 🌀JN0-481 Exam Pass4sure[/url]
- JN0-481 Authentic Exam Hub 🤐 Dumps JN0-481 Cost 🐴 Exam JN0-481 Dump 📘 Search for ➥ JN0-481 🡄 and download it for free immediately on ⏩ [url]www.pdfvce.com ⏪ 🥦Dumps JN0-481 Cost[/url]
- JN0-481 Exam Pass4sure 🧧 JN0-481 Reliable Exam Guide 😌 JN0-481 Latest Test Simulator 😗 Search for ➥ JN0-481 🡄 and download it for free immediately on ➡ [url]www.prepawayete.com ️⬅️ 🤵Exam JN0-481 Dump[/url]
- Trustable Juniper JN0-481 Exam Success - JN0-481 Free Download 🧲 Search for { JN0-481 } and download it for free on [ [url]www.pdfvce.com ] website 🦧JN0-481 Reliable Exam Guide[/url]
- Juniper - Accurate JN0-481 Exam Success 🟨 Search for ▷ JN0-481 ◁ on ▷ [url]www.examdiscuss.com ◁ immediately to obtain a free download 💍JN0-481 Exam Pass4sure[/url]
- JN0-481 Test Discount Voucher 🛐 JN0-481 Authentic Exam Hub 🥡 JN0-481 Free Download Pdf 🎾 Easily obtain ➠ JN0-481 🠰 for free download through ➥ [url]www.pdfvce.com 🡄 🈺JN0-481 Authentic Exam Hub[/url]
- Free PDF Quiz Juniper - JN0-481 - Data Center, Specialist (JNCIS-DC) –Reliable Exam Success 📗 Download ⮆ JN0-481 ⮄ for free by simply entering ⇛ [url]www.prepawaypdf.com ⇚ website 🕳New JN0-481 Test Objectives[/url]
- Prominent Features of Pdfvce Juniper JN0-481 Exam Questions 🛑 Enter ⮆ [url]www.pdfvce.com ⮄ and search for ⮆ JN0-481 ⮄ to download for free 🧮Test JN0-481 Questions Vce[/url]
- Test JN0-481 Guide 🥱 JN0-481 Updated Demo ⛳ Exam JN0-481 Pass4sure 💋 Search for ➥ JN0-481 🡄 and download exam materials for free through ➥ [url]www.prepawaypdf.com 🡄 🚞JN0-481 Reliable Exam Guide[/url]
- JN0-481 Latest Exam Review 🧢 JN0-481 Valid Braindumps Questions ⤴ JN0-481 Authentic Exam Hub 🦝 Easily obtain free download of ▶ JN0-481 ◀ by searching on ☀ [url]www.pdfvce.com ️☀️ 📥New JN0-481 Test Objectives[/url]
- Free PDF Quiz Juniper - JN0-481 - Data Center, Specialist (JNCIS-DC) –Reliable Exam Success 🔻 Search on ( [url]www.torrentvce.com ) for ➤ JN0-481 ⮘ to obtain exam materials for free download 🦋100% JN0-481 Exam Coverage[/url]
- rdcvw.q711.myverydz.cn, ddy.hackp.net, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, disqus.com, www.stes.tyc.edu.tw, proverac.com, www.stes.tyc.edu.tw, bicyclebuysell.com, www.stes.tyc.edu.tw, bbs.t-firefly.com, Disposable vapes
BTW, DOWNLOAD part of Prep4SureReview JN0-481 dumps from Cloud Storage: https://drive.google.com/open?id=10LJY4xYKQEZIWTJkMUyEHXsqJ2Kjk27M
