值得信賴的最新LEED-AP-Homes題庫資源和資格考試中的領先供應商和最新更新LEED-AP-Homes:LEED AP Homes (Residentia
Posted at 1/10/2026 18:34:11
Fast2testのLEED-AP-Homes考古題可以讓你輕鬆地準備考試。另外,如果你是第一次參加考試,那麼你可以使用軟體版的考古題。因為這是一個完全模擬真實考試的氛圍和形式的軟體。你可以提前感受到真實的考試。這樣你在真實的考試中就不會感到緊張。用過了軟體版的考古題,你就可以在參加考試時以一種放鬆的心態來做題,有利於你正常發揮你的水準。
USGBC LEED-AP-Homes 考試大綱:| 主題 | 簡介 | | 主題 1 | - LEED Process: This section of the exam measures the skills of a Green Building Consultant. It covers the comprehensive framework of the LEED Homes certification process, from understanding project eligibility and roles—such as green raters and quality assurance designees—to navigating certification requirements, the LEED verification process, and documentation submission to GBCI.
| | 主題 2 | - Energy and Atmosphere: This section of the exam measures the skills of a Green Building Engineer. It includes evaluating the principles of energy efficiency, performance optimization, and emissions reduction in residential design, all critical to minimizing environmental impact while meeting occupant needs.
| | 主題 3 | - Innovation: This section of the exam measures the skills of a Design Innovation Lead. It invites professionals to explore creative and exemplary strategies that surpass standard credits—such as pilot projects or pioneering sustainability solutions—demonstrating forward-thinking in residential design.
| | 主題 4 | - Indoor Environmental Quality: This section of the exam measures the skills of an Architectural Designer. It addresses indoor air health, natural light, and ventilation requirements to ensure occupant comfort and durability, reflecting a home’s capacity to provide a healthy and lasting living environment.
| | 主題 5 | - Materials & Resources: This section of the exam measures the skills of a Sustainability Specialist. It emphasizes the selection and management of eco-friendly materials, efficient usage of resources, and implementation of waste reduction strategies to support green residential construction.
LEED-AP-Homes在線題庫 - LEED-AP-Homes软件版有了目標就要勇敢的去實現。每一個選擇IT行業的人應該都不會只是安於現狀那樣簡單點的生活,現在各行各業的競爭壓力可想而知,IT行業也不例外,所以你們要是有了目標就要勇敢的去實現,其中通過 USGBC的LEED-AP-Homes考試認證也是一次不小的競爭方式之一,通過了此考試,那麼你的IT生涯將會大展宏圖,會有一幅不一樣的藍圖等著你去勾勒,而我們Fast2test網站可以提供你真實準確的培訓資料,幫助你通過考試獲得認證,從而實現你的藍圖理想。
最新的 USGBC LEED LEED-AP-Homes 免費考試真題 (Q82-Q87):問題 #82
A home has a large shower compartment of 3,750 in² (2.4 m²) with dual 1.5 gpm (5.6 lpm) shower heads.
How should the flow rate be calculated?
- A. Shower compartment size does not affect shower head flow rates for LEED compliance
- B. The flow rates are added to total 3.0 gpm (11.2 lpm)
- C. Multiple shower heads are not allowed
- D. The flow rate is calculated as two separate compartments of 1.5 gpm (5.6 lpm)
答案:C
解題說明:
TheLEED for Homes Rating System (v4)addresses shower compartments in theWater Efficiency (WE) Credit: Indoor Water Use, where the size and number of showerheads impact water use calculations.
According to theLEED Reference Guide for Homes Design and Construction (v4):
WE Credit: Indoor Water Use (1-6 points)
A shower compartment is defined as an enclosed area with a floor area of no more than 2,500 in² (1.6 m²), where all fixtures (e.g., multiple showerheads) count as a single fixture for water use calculations.
Compartments larger than 2,500 in² are considered multiple compartments, and multiple showerheads in such cases are not allowed for LEED compliance to ensure water efficiency.
Source: LEED Reference Guide for Homes Design and Construction, v4, Water Efficiency Credit: Indoor Water Use, p. 96.
TheLEED v4.1 Residential BD+Crating system confirms:
For shower compartments exceeding 2,500 in² (1.6 m²), multiple showerheads are not permitted to maintain water efficiency goals. Each compartment must be treated separately if applicable, but large compartments cannot have multiple heads.
Source: LEED v4.1 Residential BD+C, Credit Library, accessed via USGBC LEED Online.
The shower compartment is 3,750 in² (2.4 m²), exceeding the 2,500 in² limit. Therefore,multiple showerheads are not allowed(Option C), as LEED restricts multiple heads in oversized compartments to ensure water efficiency.
Why not the other options?
Reference: LEED Reference Guide for Homes Design and Construction, v4, WE Credit: Indoor Water Use, p.
96.
B). The flow rate is calculated as two separate compartments of 1.5 gpm (5.6 lpm): The compartment is one unit, and multiple heads are not allowed, not treated as separate compartments.Reference: LEED Reference Guide for Homes Design and Construction, v4, WE Credit: Indoor Water Use, p. 96.
D). Shower compartment size does not affect shower head flow rates for LEED compliance:
Compartment size directly affects whether multiple heads are allowed.Reference: LEED Reference Guide for Homes Design and Construction, v4, WE Credit: Indoor Water Use, p. 96.
TheLEED AP Homes Candidate Handbookemphasizes WE credits, including showerhead calculations, and references theLEED Reference Guide for Homes Design and Constructionas a key resource. The exam is based onLEED v4, ensuring the relevance of compartment size restrictions.
LEED Reference Guide for Homes Design and Construction, v4, USGBC, Water Efficiency Credit:
LEED v4.1 Residential BD+C, USGBC LEED Credit Library, accessed via LEED Online (https://www.
usgbc.org/credits).
LEED AP Homes Candidate Handbook, GBCI, October 2024, p. 12 (references study resources and exam scope based on LEED v4).
USGBC LEED for Homes Rating System (v4), available via USGBC website (https://www.usgbc.org
/resources/leed-homes-design-and-construction-v4).
LEED v4.1 for Homes, USGBC, accessed via LEED Online, confirming showerhead restrictions.
問題 #83
A home is constructed less than 1/4 mi. (0.4 km) from a bank, supermarket, fire station, daycare center, pharmacy, and school. How many points, if any, did this project earn in Location and Transportation Credit, Community Resources and Services?
- A. One point
- B. Zero points
- C. Three points
- D. Two points
答案:D
解題說明:
TheLEED for Homes Rating System (v4)includes theLocation and Transportation (LT) Credit:
Community Resources and Services, which awards points for locating a project near essential community services to reduce transportation-related environmental impacts.
LT Credit: Community Resources and Services (1-2 points)
Locate the project within 1/4 mile (0.4 kilometers) walking distance of at least 4 community services (e.g., bank, supermarket, fire station, daycare, pharmacy, school, etc.) for 1 point, or 8 or more services for 2 points.
The services must be publicly accessible and within the specified distance.
Source: LEED Reference Guide for Homes Design and Construction, v4, Location and Transportation Credit: Community Resources and Services, p. 56.
Earn 1 point for proximity to at least 4 community services within 1/4 mile (0.4 km), or 2 points for 8 or more services, measured by walking distance.
The project is located within 1/4 mile (0.4 km) of six services: bank, supermarket, fire station, daycare center, pharmacy, and school. Since six services exceed the threshold of four but fall short of eight, the project earns2 points(Option C).
* A. Zero points: The project meets the criteria for at least 1 point (four services), so zero points is incorrect.
* B. One point: This applies to exactly four services; six services qualify for 2 points.
Reference: LEED Reference Guide for Homes Design and Construction, v4, LT Credit: Community Resources and Services, p. 56.
TheLEED AP Homes Candidate Handbookemphasizes LT credits, including Community Resources and Services, and references theLEED Reference Guide for Homes Design and Constructionas a key resource.
The exam is based onLEED v4, ensuring the relevance of the service proximity criteria.
LEED Reference Guide for Homes Design and Construction, v4, USGBC, Location and Transportation Credit: Community Resources and Services, p. 56.
usgbc.org/credits).
LEED v4.1 for Homes, USGBC, accessed via LEED Online, confirming community services criteria.
問題 #84
For a project to earn one point for Materials and Resources Credit, Environmentally Preferable Products, what must occur?
- A. Meet both Option 1: Local Production and Option 2: Environmentally Preferable Products
- B. Meet more than two or more of the criteria under Option 2: Environmentally Preferable Products
- C. Achieve more than 95% of the component by weight or volume that meets Option 2: Environmentally Preferable Products
- D. Achieve more than 95% of the component by weight or volume that meets Option 1: Local Production
答案:B
解題說明:
TheLEED for Homes Rating System (v4)outlines the requirements for theMaterials and Resources (MR) Credit: Environmentally Preferable Products, which encourages the use of sustainable materials. The credit has two options:Option 1: Local Production(materials sourced within 100 miles) andOption 2:
Environmentally Preferable Products(materials with attributes like recycled content, FSC-certified wood, or low emissions).
MR Credit: Environmentally Preferable Products (1-4 points)
Earn points by meeting the following:
* Option 2: Environmentally Preferable Products: Use products that meet one or more of the following criteria for at least 25% (1 point), 50% (2 points), or 90% (3-4 points) by cost of the total materials:
* Recycled content
* FSC-certified wood
* Bio-based materials
* Low-emission products (e.g., low-VOC paints)To earn 1 point, at least 25% of the materials (by cost) must meet two or more of these criteria.Source: LEED Reference Guide for Homes Design and Construction, v4, Materials and Resources Credit: Environmentally Preferable Products, p.
160-161.
For 1 point, use products that meet two or more environmentally preferable criteria (e.g., recycled content, FSC-certified) for at least 25% of the total material cost.
To earnone pointunder Option 2, the project must use materials that collectively meettwo or moreof the environmentally preferable criteria (e.g., a product with both recycled content and low emissions) for at least
25% of the total material cost. This makesOption Bthe correct answer.
Reference: LEED Reference Guide for Homes Design and Construction, v4, MR Credit: Environmentally Preferable Products, p. 161.
C). Achieve more than 95% of the component by weight or volume that meets Option 1: Local Production: Option 1 focuses on local production (within 100 miles), not environmentally preferable attributes, and uses cost, not weight or volume. It is a separate compliance path.Reference: LEED Reference Guide for Homes Design and Construction, v4, MR Credit: Environmentally Preferable Products, p. 160.
D). Meet both Option 1: Local Production and Option 2: Environmentally Preferable Products: The credit allows projects to pursue either Option 1 or Option 2 independently. Meeting both is not required for one point.Reference: LEED Reference Guide for Homes Design and Construction, v4, MR Credit:
TheLEED AP Homes Candidate Handbookemphasizes MR credits, including Environmentally Preferable Products, and references theLEED Reference Guide for Homes Design and Constructionas a key resource.
The exam is based onLEED v4, ensuring the relevance of Option 2's criteria.
LEED Reference Guide for Homes Design and Construction, v4, USGBC, Materials and Resources Credit: Environmentally Preferable Products, p. 160-161.
usgbc.org/credits).
LEED v4.1 for Homes, USGBC, accessed via LEED Online, confirming criteria for one point.
問題 #85
A developer is planning to build 40 single-family homes on a two-acre (0.8 hectare) site. Under the Location and Transportation Credit, Compact Development, what is the maximum number of points that the developer can achieve?
- A. Three points
- B. One point
- C. Zero points
- D. Two points
答案:A
解題說明:
Compact Development, which awards points for higher-density development to reduce environmental impacts and promote efficient land use.
LT Credit: Compact Development (1-3 points)
Achieve the following dwelling unit densities (units per acre of buildable land):
* 1 point: # 7 units per acre.
* 2 points: # 12 units per acre.
* 3 points: # 20 units per acre.Calculate density by dividing the number of dwelling units by the buildable land area (in acres).Source: LEED Reference Guide for Homes Design and Construction, v4, Location and Transportation Credit: Compact Development, p. 57.
For single-family homes, achieve 3 points by developing at least 20 dwelling units per acre on buildable land.
Calculation:
* Site area: 2 acres (0.8 hectare).
* Number of homes: 40 single-family homes.
* Density: 40 units ÷ 2 acres =20 units per acre.
* This meets the threshold for3 points(# 20 units per acre).
The correct answer isthree points(Option D), as the density of 20 units per acre qualifies for the maximum points under the credit.
* A. Zero points: The density (20 units/acre) far exceeds the minimum threshold (7 units/acre).
* B. One point: This applies to # 7 units/acre, below the project's density.
Reference: LEED Reference Guide for Homes Design and Construction, v4, LT Credit: Compact Development, p. 57.
TheLEED AP Homes Candidate Handbookemphasizes LT credits, including compact development, and references theLEED Reference Guide for Homes Design and Constructionas a key resource. The exam is based onLEED v4, ensuring the relevance of density calculations.
LEED Reference Guide for Homes Design and Construction, v4, USGBC, Location and Transportation Credit: Compact Development, p. 57.
usgbc.org/credits).
LEED v4.1 for Homes, USGBC, accessed via LEED Online, confirming compact development points.
問題 #86
Who of the following may submit to Green Business Certification Inc. a LEED for Homes project for certification?
- A. The Green Rater
- B. The Quality Assurance Designee
- C. The Owner or designated project team member
- D. The Energy Rater
答案:C
解題說明:
TheLEED for Homes Rating System (v4)outlines the certification process, including who is authorized to submit a project to the Green Business Certification Inc. (GBCI) for LEED certification.
Certification Process
The project owner or a designated project team member (e.g., the project manager or LEED AP) is responsible for submitting the LEED for Homes project to GBCI for certification, coordinating with the LEED Green Rater for documentation and verification.
Source: LEED Reference Guide for Homes Design and Construction, v4, Introduction, p. 28.
The owner or a designated project team member submits the project to GBCI for certification, supported by the Green Rater's verification reports and documentation.
The correct answer isthe Owner or designated project team member(Option D), as they are authorized to submit the project to GBCI.
* A. The Green Rater: The Green Rater conducts field inspections and prepares verification reports but does not submit the project.
* B. The Energy Rater: The Energy Rater focuses on energy performance (e.g., HERS Index) and does not handle submission.
Reference: LEED Reference Guide for Homes Design and Construction, v4, Introduction, p. 28.
TheLEED AP Homes Candidate Handbookemphasizes the certification process, including submission roles, and references theLEED Reference Guide for Homes Design and Constructionas a key resource.
The exam is based onLEED v4, ensuring the relevance of owner submission.
LEED Reference Guide for Homes Design and Construction, v4, USGBC, Introduction, p. 28.
usgbc.org/credits).
LEED v4.1 for Homes, USGBC, accessed via LEED Online, confirming submission roles.
問題 #87
最近,Fast2test開始提供給大家很多關於IT認證考試的最新的資料。比如LEED-AP-Homes考古題都是根據最新版的IT認證考試研發出來的。可以告訴大家最新的與考試相關的消息。考試的大綱有什麼變化,以及考試中可能會出現的新題型,這些內容都包括在了資料中。所以,如果你想參加IT考試,最好利用Fast2test的資料。因為只有這樣你才能更好地準備考試。
LEED-AP-Homes在線題庫: https://tw.fast2test.com/LEED-AP-Homes-premium-file.html
- LEED-AP-Homes認證指南 👠 最新LEED-AP-Homes題庫資源 🌛 LEED-AP-Homes考試大綱 👖 立即打開“ [url]www.newdumpspdf.com ”並搜索⮆ LEED-AP-Homes ⮄以獲取免費下載LEED-AP-Homes考題資訊[/url]
- 只有最好的最新LEED-AP-Homes題庫資源才能提供LEED AP Homes (Residential) Exam的最高通過率 🆕 透過「 [url]www.newdumpspdf.com 」搜索[ LEED-AP-Homes ]免費下載考試資料LEED-AP-Homes熱門考古題[/url]
- LEED-AP-Homes考題免費下載 🍡 LEED-AP-Homes認證考試解析 🧴 LEED-AP-Homes考試大綱 🧧 ( tw.fast2test.com )上的“ LEED-AP-Homes ”免費下載只需搜尋最新LEED-AP-Homes題庫
- LEED-AP-Homes考題套裝 🧀 LEED-AP-Homes資訊 🧲 最新LEED-AP-Homes題庫 👞 進入“ [url]www.newdumpspdf.com ”搜尋【 LEED-AP-Homes 】免費下載LEED-AP-Homes證照[/url]
- LEED-AP-Homes考試大綱 🥉 LEED-AP-Homes證照 🧚 LEED-AP-Homes最新考題 ⚠ 透過▷ tw.fast2test.com ◁輕鬆獲取[ LEED-AP-Homes ]免費下載LEED-AP-Homes熱門考古題
- 最受推薦的最新LEED-AP-Homes題庫資源,免費下載LEED-AP-Homes考試題庫得到妳想要的USGBC證書 👈 打開▶ [url]www.newdumpspdf.com ◀搜尋▛ LEED-AP-Homes ▟以免費下載考試資料LEED-AP-Homes考試證照綜述[/url]
- LEED-AP-Homes考試證照綜述 😂 LEED-AP-Homes題庫 🥋 LEED-AP-Homes認證考試解析 🚍 ➤ [url]www.newdumpspdf.com ⮘上搜索⇛ LEED-AP-Homes ⇚輕鬆獲取免費下載LEED-AP-Homes熱門考古題[/url]
- LEED-AP-Homes考古題 🦕 LEED-AP-Homes題庫 🤬 LEED-AP-Homes認證考試解析 😾 在➥ [url]www.newdumpspdf.com 🡄網站上查找⮆ LEED-AP-Homes ⮄的最新題庫LEED-AP-Homes認證指南[/url]
- 正確的最新LEED-AP-Homes題庫資源&保證USGBC LEED-AP-Homes考試成功與可靠的LEED-AP-Homes在線題庫 ⏳ ⮆ [url]www.vcesoft.com ⮄上搜索▛ LEED-AP-Homes ▟輕鬆獲取免費下載LEED-AP-Homes證照[/url]
- 確保通過的最新LEED-AP-Homes題庫資源 |高通過率的考試材料|有用的LEED-AP-Homes在線題庫 🏔 在《 [url]www.newdumpspdf.com 》網站上免費搜索▷ LEED-AP-Homes ◁題庫最新LEED-AP-Homes題庫[/url]
- 確保通過的最新LEED-AP-Homes題庫資源 |高通過率的考試材料|有用的LEED-AP-Homes在線題庫 🍽 複製網址➥ tw.fast2test.com 🡄打開並搜索“ LEED-AP-Homes ”免費下載LEED-AP-Homes考題免費下載
- giphy.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.dhm.com.ng, bbs.t-firefly.com, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.cudigitalneza.com, learn.idlsofts.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, Disposable vapes
