[General] SDS Latest Exam Question | New SDS Braindumps
103
General SDS Latest Exam Question | New SDS Braindumps
Posted at 1/10/2026 19:09:28      View147 | Replies1        Print      Only Author   [Copy Link] 1#
What's more, part of that VerifiedDumps SDS dumps now are free: https://drive.google.com/open?id=15N8d-RebyW2amHsgGaMQZqBNpanYB0ye
Our SDS exam braindumps will give you a feeling that they will really make you satisfied. I know that we don't say much better than letting you experience it yourself. We very much welcome you to download the trial version of our SDS practice engine. Our ability to provide users with free trial versions of our SDS Study Materials is enough to prove our sincerity and confidence. Just free download the SDS learning guide, you will love it for sure!
The VerifiedDumps believes in customer satisfaction and strives hard to make the entire certification DASCA SDS exam journey the easiest and most successful. To meet this goal the VerifiedDumps is offering the real, updated, and error-free Senior Data Scientist (SDS) Questions in three different but easy-to-use formats. These VerifiedDumps SDS exam questions formats are web-based practice test software, desktop practice test software and Senior Data Scientist (SDS) PDF dumps files.
Cost-Effective DASCA SDS Exam [2026]While making revisions and modifications to the DASCA SDS practice exam, our team takes reports from over 90,000 professionals worldwide to make the DASCA SDS Exam Questions foolproof. To make you capable of preparing for the SDS exam smoothly, we provide actual DASCA SDS exam dumps.
DASCA Senior Data Scientist Sample Questions (Q41-Q46):NEW QUESTION # 41
Spark is written in:
  • A. Python
  • B. Scala
  • C. C++
  • D. Java
  • E. C
Apache Spark is an open-source distributed computing framework widely used for big data processing and machine learning pipelines.
The core implementation of Spark is written in Scala (Option A), which runs on the JVM (Java Virtual Machine).
Spark also provides APIs for Java, Python (PySpark), R, and SQL, but its native language is Scala.
Options C (C) and D (C++) are incorrect; Spark is not written in these languages.
Python (Option E) is a supported API, but Spark itself is not written in Python.
Thus, the correct answer is Scala (Option A).
DASCA Data Scientist Knowledge Framework (DSKF) - Programming Tools for Big Data & Distributed Computing.
NEW QUESTION # 42
OCR (Optical Character Recognition) is an application used for:
  • A. Data mining
  • B. Machine learning
  • C. MapReduce
  • D. Big Data Analytics
Optical Character Recognition (OCR) is the process of automatically recognizing and converting different types of documents - such as scanned paper documents, PDFs, or images - into editable and searchable text.
OCR systems use Machine Learning (ML) and Computer Vision techniques to detect and classify patterns of characters in images.
Algorithms like Convolutional Neural Networks (CNNs) are commonly used for image-based OCR.
While OCR may indirectly contribute to data mining or big data workflows, the core application is based on machine learning, where models are trained to classify and recognize text patterns.
Thus, OCR is primarily a Machine Learning application, making Option B correct.
DASCA Data Scientist Knowledge Framework (DSKF) - Applications of Machine Learning: OCR and Pattern Recognition.
NEW QUESTION # 43
Which of the following architectural techniques is used for parallel processing?
  • A. The SuperVector Technique
  • B. Both A and B
  • C. Very Long Instruction Words (VLIW) Technique
  • D. The Superscalar Technique
  • E. Both B and C
Parallel processing architectures are designed to execute multiple instructions or operations simultaneously:
Superscalar Technique (Option A): Uses multiple execution units so that several instructions can be issued and executed in parallel within a single CPU cycle.
VLIW Technique (Option B): Uses very long instruction words, where multiple operations are encoded into a single instruction and executed in parallel.
SuperVector (Option C): Refers to vector processors, which process large arrays of data but is not classified as a mainstream architectural parallel technique in modern CPU design.
Therefore, the primary architectural techniques for parallel processing are Superscalar and VLIW, making Option D (Both A and B) correct.
DASCA Data Scientist Knowledge Framework (DSKF) - Data Engineering Architectures: Parallel and Distributed Processing.
NEW QUESTION # 44
What is the agenda of discussion at a "stand up" meeting of an Agile team?
  • A. Both A and B
  • B. What they are planning to do today
  • C. All of the above
  • D. What they accomplished the previous day
  • E. Any roadblocks they are running into
A daily stand-up meeting (also called a daily Scrum) is a short meeting (usually 15 minutes) that Agile teams hold to synchronize progress. Its agenda is structured around three key questions:
What was accomplished yesterday? (Progress review).
What is planned for today? (Work alignment).
What impediments or roadblocks exist? (Barriers identification).
This process enhances transparency, communication, and accountability, ensuring the team can quickly address obstacles and stay aligned with sprint goals.
Option A: Correct - yesterday's work is discussed.
Option B: Correct - today's planned tasks are outlined.
Option C: Correct - roadblocks are highlighted.
Option D: Incomplete since it misses C.
Option E: Correct - covers all agenda items.
Thus, the correct answer is Option E (All of the above).
DASCA Data Scientist Knowledge Framework (DSKF) - Agile Practices in Data Science Projects.
NEW QUESTION # 45
What is DevOps?
  • A. Software Operations
  • B. Quality Assurance
  • C. All
  • D. Software Development
DevOps is not just about coding (development) or system administration (operations). It is a holistic cultural and technical practice that unifies:
Software Development (Option A): Writing and building applications.
Software Operations (Option B): Deploying, monitoring, and maintaining systems in production.
Quality Assurance (Option C): Ensuring the reliability, security, and performance of applications through testing and automation.
Thus, DevOps encompasses all three dimensions, making the correct answer Option D (All).
DASCA Data Scientist Knowledge Framework (DSKF) - Business Applications of Data Science: DevOps & Continuous Delivery.
NEW QUESTION # 46
For years our team has built a top-ranking brand with mighty and main which bears a high reputation both at home and abroad. The sales volume of the SDS study materials we sell has far exceeded the same industry and favorable rate about our products is approximate to 100%. Why the clients speak highly of our SDS Study Materials? Our dedicated service, high quality and passing rate and diversified functions contribute greatly to the high prestige of our products.
New SDS Braindumps: https://www.verifieddumps.com/SDS-valid-exam-braindumps.html
In addition, we have a professional team to collect the latest information about the SDS exam materials, we can ensure you that what you get is the latest version we have, You can use VerifiedDumps's DASCA SDS exam training materials, Your task is to understand the key knowledge and do exercises on the SDS exam dump, You can adjust your study guide plan according to the test result after each SDS exam practice test.
A major research study conducted for an association of colleges and universities SDS found that a significant majority of respondents cited skills learned and perfected in networking as the most important skills employers look for in new hires.
My Review On DASCA SDS Exam QuestionsDevelop rapport and empathy, In addition, we have a professional team to collect the latest information about the SDS Exam Materials, we can ensure you that what you get is the latest version we have.
You can use VerifiedDumps's DASCA SDS exam training materials, Your task is to understand the key knowledge and do exercises on the SDS exam dump.
You can adjust your study guide plan according to the test result after each SDS exam practice test, Most people define SDS study tool as regular books and imagine that the more you buy, the higher your grade may be.
Posted at 2/14/2026 14:41:17        Only Author  2#
Your article took my breath away, thank you for sharing! This is the SC-100 valid test discount test that helped me achieve a promotion and raise. It's available to you for free today, and I wish you success in reaching your career goals.
