100% Pass Quiz 2026 NCM-MCI-6.10: Nutanix Certified Master - Multicloud Infrastr
89
Posted at 1/10/2026 19:47:11      View159 | Replies2        Print      Only Author   [Copy Link] 1#
Test4Engine Nutanix NCM-MCI-6.10 Exam Questions And Answers provide you test preparation information with everything you need. About Nutanix NCM-MCI-6.10 exam, you can find these questions from different web sites or books, but the key is logical and connected. Our questions and answers will not only allow you effortlessly through the exam first time, but also can save your valuable time.
We are dedicated to helping you pass the next certificate exam fast. NCM-MCI-6.10 Exam Braindumps contains questions and answers, and they will be enough for you to deal with your exam. NCM-MCI-6.10 exam dumps have most of knowledge pointes of the exam. In the process of practicing, you can also improve your ability. Furthermore, we provide you with free demo for you to have a try before purchasing, so that you can have a better understanding of what you are going to buying. If you indeed have questions, just contact our online service stuff.
Trustworthy NCM-MCI-6.10 Pdf - Exam NCM-MCI-6.10 PreviewIn a busy world, managing your time is increasingly important. If you don't want to waste much time on preparing for your exam, NCM-MCI-6.10 exam braindumps files will be a shortcut for you. Good exam materials make you twice the result with half the effort. Our NCM-MCI-6.10 Exam Braindumps cover many questions and answers of the real test so that you can be familiar with the real test question. When you attend NCM-MCI-6.10 exam, it is easy for you to keep good mood and control your finishing time.
Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) Sample Questions (Q17-Q22):NEW QUESTION # 17
TASK 1
A newly created Windows VM "SQL02" is experiencing poor storage performance when compared to
"SQL01" running within the same cluster, on the same storage container.
The cluster is in a healthy state.
Create a new session named Monitor SQL02 with meaningful metrics. Right click on the session page and click Select All then paste this into Notepad and save it as Task 1.txt on the desktop.
Also, save the analysis as a report named MonitorSQL02 and send the report as a PDF on a daily basis to perf_group@ACME.org. Reports should not be retained. If any new objects need to be created, use monitovm2 in the name.
Finally, correct the issue within "SQL02".
Notes:
* Do not power on the VMs.
* While you will be creating a session, you will need to examine the VM configurations to determine the issue.
* Do not delete the VM to resolve the issue, any other destructive change is acceptable.
See the Explanation below for detailed answer.
Here is the step-by-step solution to all three tasks, performed within the Nutanix Prism interface.
Task 1: Create Monitoring Session & Save Metrics
* From the Prism Central dashboard, navigate to Operations > Analysis.
* Click the + New Session button.
* Name the session Monitor SQL02.
* In the "Entities" search box, type SQL01 and select VM: SQL01.
* In the "Entities" search box, type SQL02 and select VM: SQL02.
* Click Add Charts > New Chart.
* Title: Storage IOPS
* Metric: Storage Controller IOPS
* Click Add.
* Title: Storage Latency
* Metric: Storage Controller Latency
* Click Add.
* Title: Storage Bandwidth
* Metric: Storage Controller Bandwidth
* Click Add.
* Click Save Session.
* With the "Monitor SQL02" session open, right-click anywhere on the page and click Select All.
* Right-click again and select Copy.
* Open Notepad, paste the content, and save the file to the desktop as Task 1.txt.
(The content pasted into Task 1.txt would be the session's chart configurations, showing metrics for SQL01 and SQL02.)
Task 2: Create and Schedule the Report
* While still in the "Monitor SQL02" analysis session, click the Save as Report button (it looks like a bookmark icon).
* Name the report MonitorSQL02 and click Save.
* Navigate to Operations > Reports.
* Find the MonitorSQL02 report in the list. Select its checkbox.
* Click the Actions dropdown and select Schedule.
* Configure the schedule with the following settings:
* Schedule Name: monitovm2_daily_report
* Recurrence: Daily
* Start Time: (Set to a time, e.g., 8:00 AM)
* Repeat every: 1 day(s)
* Retention Policy: Uncheck the "Retain a copy of the report" box. (This ensures reports are not retained).
* Email Report: Check this box.
* Format: PDF
* Recipients: perf_group@ACME.org
* Click Save.
Task 3: Identify and Correct the Performance Issue
This task is performed without powering on the VMs, indicating a configuration error.
Investigation
* Navigate to VMs > Table view.
* Click on the SQL01 (the good VM) and select the Configuration tab.
* Expand the Disks section. Observe that the primary disk is attached to a SCSI bus (e.g., scsi.0). This is the high-performance standard.
* Return to the VM list and click on SQL02 (the problem VM).
Root Cause
You discover that the primary disk for SQL02 is attached to an IDE bus. The IDE bus has significant performance limitations and is not suitable for a database server, causing the poor storage performance.
Correction
* With the SQL02 VM selected, click the Update button.
* In the "Update VM" dialog, scroll down to the Disks section.
* Find the disk attached to the IDE bus. Click the Edit (pencil) icon for that disk.
* Change the Bus Type dropdown from IDE to SCSI.
* The Device Index will automatically populate (e.g., scsi.0).
* Click Save in the "Update Disk" dialog.
* (Note: A "VirtIO SCSI Controller" will be automatically added to the VM configuration if one was not already present.)
* Click Save in the "Update VM" dialog.
The VM SQL02 is now configured to use the high-performance VirtIO-SCSI controller, which will resolve the storage performance discrepancy once the VM is powered on.
NEW QUESTION # 18
An administrator needs to perform AOS and AHV upgrades on a Nutanix cluster and wants to ensure that VM data is replicated as quickly as possible when hosts and CVMs are rebooted.
Configure Cluster 1 so that after planned host and CVM reboots, the rebuild scan starts immediately.
Note:
You will need to use SSH for this task. Ignore the fact that this is a 1-node cluster.
Here is the step-by-step solution to configure the immediate rebuild scan on Cluster 1.
This task must be performed from an SSH session connected to a CVM (Controller VM) on Cluster 1.
1. Access the Cluster 1 CVM
* From the Prism Central dashboard, navigate to Hardware > Clusters and click on Cluster 1 to open its Prism Element (PE) interface.
* In the Cluster 1 PE, navigate to Hardware > CVMs to find the IP address of any CVM in the cluster.
* Use an SSH client (like PuTTY) to connect to the CVM's IP address.
* Log in with the admin user and password.
2. Modify the Rebuild Delay Setting
By default, the cluster waits 15 minutes (900 seconds) before starting a rebuild scan after a CVM reboot. You will change this setting to 0.
* Once logged into the CVM, run the following command to set the delay to 0 seconds:
gflag --set --gflags=stargate_delayed_rebuild_scan_secs=0
* (Optional but recommended) You can verify the change took effect by running the "get" command:
gflag --get --gflags=stargate_delayed_rebuild_scan_secs
The output should now show stargate_delayed_rebuild_scan_secs=0.
NEW QUESTION # 19
Task 11
Running NCC on a cluster prior to an upgrade results in the following output FAIL: CVM System Partition /home usage at 93% (greater than threshold, 90%) Identify the CVM with the issue, remove the fil causing the storage bloat, and check the health again by running the individual disk usage health check only on the problematic CVM do not run NCC health check Note: Make sure only the individual health check is executed from the affected node
See the Explanation for step by step solution.
To identify the CVM with the issue, remove the file causing the storage bloat, and check the health again, you can follow these steps:
Log in to Prism Central and click on Entities on the left menu.
Select Virtual Machines from the drop-down menu and find the NCC health check output file from the list.
You can use the date and time information to locate the file. The file name should be something like ncc- output-YYYY-MM-DD-HH-MM-SS.log.
Open the file and look for the line that says FAIL: CVM System Partition /home usage at 93% (greater than threshold, 90%). Note down the IP address of the CVM that has this issue. It should be something like X.X.X.
X.
Log in to the CVM using SSH or console with the username and password provided.
Run the command du -sh /home/* to see the disk usage of each file and directory under /home. Identify the file that is taking up most of the space. It could be a log file, a backup file, or a temporary file. Make sure it is not a system file or a configuration file that is needed by the CVM.
Run the command rm -f /home/<filename> to remove the file causing the storage bloat. Replace <filename> with the actual name of the file.
Run the command ncc health_checks hardware_checks disk_checks disk_usage_check --cvm_list=X.X.X.
X to check the health again by running the individual disk usage health check only on the problematic CVM.
Replace X.X.X.X with the IP address of the CVM that you noted down earlier.
Verify that the output shows PASS: CVM System Partition /home usage at XX% (less than threshold, 90%).
This means that the issue has been resolved.
#access to CVM IP by Putty
allssh df -h #look for the path /dev/sdb3 and select the IP of the CVM
ssh CVM_IP
ls
cd software_downloads
ls
cd nos
ls -l -h
rm files_name
df -h
NEW QUESTION # 20
An administrator wants to increase the performance of their Database virtual machine.
Database_VM has a database that is spread across three vDisks in the volume group Database_VM. The volume group is directly attached to the virtual machine. Previous performance analysis has indicated all storage requests are going to the same node. While this test environment has 1 node, the production environment has 3 nodes.
Configure the Volume Group Database_VM so that it's optimized for the user's VM and the production environment. The virtual machine has been powered off and moved to this test cluster for the maintenance work.
Note: Do not power on the VM.
Here is the step-by-step solution to configure the Volume Group for optimized performance in the production environment.
This task is performed in Prism Central.
* From the main dashboard, navigate to Compute & Storage > Volume Groups.
* Find the Volume Group named Database_VM in the list.
* Select the checkbox next to Database_VM.
* Click the Actions dropdown menu and select Update.
* In the "Update Volume Group" dialog, scroll to the bottom of the "Basic Configuration" section.
* Find the checkbox labeled Enable Client Side Load Balancing and check it.
Note: This setting allows the iSCSI initiator within the guest VM to connect to all CVMs in the cluster, distributing the storage load from the three vDisks across all three nodes in the production environment instead of focusing all I/O on just one.
Click Save.
NEW QUESTION # 21
Task 12
The application team is reporting performance degradation for a business-critical application that runs processes all day on Saturdays.
The team is requesting monitoring or processor, memory and storage utilization for the three VMs that make up the database cluster for the application: ORA01, ORA02 and ORA03.
The report should contain tables for the following:
At the cluster level, only for the current cluster:
The maximum percentage of CPU used
At the VM level, including any future VM with the prefix ORA:
The maximum time taken to process I/O Read requests
The Maximum percentage of time a VM waits to use physical CPU, out of the local CPU time allotted to the VM.
The report should run on Sundays at 12:00 AM for the previous 24 hours. The report should be emailed to appdev@cyberdyne.net when competed.
Create a report named Weekends that meets these requirements
Note: You must name the report Weekends to receive any credit. Any other objects needed can be named as you see fit. SMTP is not configured.
To create a report named Weekends that meets the requirements, you can follow these steps:
Select Virtual Machines from the drop-down menu and click on Create Report.
Enter Weekends as the report name and a description if required. Click Next.
Under the Custom Views section, select Data Table. Click Next.
Under the Entity Type option, select Cluster. Click Next.
Under the Custom Columns option, add the following variable: CPU Usage (%). Click Next.
Under the Aggregation option for CPU Usage (%), select Max. Click Next.
Under the Filter option, select Current Cluster from the drop-down menu. Click Next.
Click on Add to add this custom view to your report. Click Next.
Under the Custom Views section, select Data Table again. Click Next.
Under the Entity Type option, select VM. Click Next.
Under the Custom Columns option, add the following variables: Name, I/O Read Latency (ms), VM Ready Time (%). Click Next.
Under the Aggregation option for I/O Read Latency (ms) and VM Ready Time (%), select Max. Click Next.
Under the Filter option, enter ORA* in the Name field. This will include any future VM with the prefix ORA.
Click Next.
Under the Report Settings option, select Weekly from the Schedule drop-down menu and choose Sunday as the day of week. Enter 12:00 AM as the time of day. Enter appdev@cyberdyne.net as the Email Recipient.
Select CSV as the Report Output Format. Click Next.
Review the report details and click Finish.
NEW QUESTION # 22
Almost no one likes boring study. Teachers and educationist have tried many ways to solve this problem. Arousing the interest might be the most effective method. So our company is focused on reforming preparation ways of the NCM-MCI-6.10 exam. Rigid memory is torturous and useless. Our NCM-MCI-6.10 Study Materials combine the knowledge with the new technology, which could greatly inspire your motivation. And if you click on our NCM-MCI-6.10 practice questions, you will feel the convenience.
Trustworthy NCM-MCI-6.10 Pdf: https://www.test4engine.com/NCM-MCI-6.10_exam-latest-braindumps.html
It's critical to have mobile access to Nutanix Trustworthy NCM-MCI-6.10 Pdf practice questions in the fast-paced world of today, Nutanix Exam NCM-MCI-6.10 Cram This is so feasible and convenient for people all around the globe, Test4Engine exam product is in every manner best for NCM-MCI-6.10 exam candidates, Nutanix Exam NCM-MCI-6.10 Cram Both of them can help you pass the exam if you master all questions and answer of dumps.
She has published numerous books and articles Trustworthy NCM-MCI-6.10 Pdf and sits on the editorial boards of a number of leading journals in the entrepreneurial andmanagement fields, The result is a book that Exam NCM-MCI-6.10 Preview should appeal to a wide range of people whose shared goal is improving team communications.
100% Pass Quiz 2026 High-quality Nutanix NCM-MCI-6.10: Exam Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) CramIt's critical to have mobile access to Nutanix Practice NCM-MCI-6.10 Questions in the fast-paced world of today, This is so feasible and convenient for people all around the globe.
Test4Engine exam product is in every manner best for NCM-MCI-6.10 exam candidates, Both of them can help you pass the exam if you master all questions and answer of dumps.
You may doubt whether the end of examination means the end of our cooperation.
Posted at 1/12/2026 21:42:42        Only Author  2#
I was really impressed with how much I learned from the article. Wishing you all the best in your examsC_THR82_2505 reliable exam questions pdf test questions are free to download!
Posted at 1/31/2026 08:59:26        Only Author  3#
Das Prfungszertifikat fr SAP C-P2WAB-2507 wird immer wichtiger in dieser schärf konkurrierten IT-Branche als denn je. Wählen Sie PrfungFrage, garantiern wir Ihnen, dass Sie die SAP C-P2WAB-2507 Prfung einmalig zu bestehen. Wir werden Ihnen alle Ihren bezahlten Summe zurckgeben, entweder Sie die SAP C-P2WAB-2507 Prfung nicht bestehen, oder die Testaufgaben von SAP C-P2WAB-2507 irgend ein Qualitätsproblem haben. Worauf warten Sie noch? Fr Ihren IT-Traum bitte ergreifen Sie schnell Maßnahmen.
