[General] Exam 1z0-1054-25 Objectives Pdf - Certification 1z0-1054-25 Test Questions
92
【General】 Exam 1z0-1054-25 Objectives Pdf - Certification 1z0-1054-25 Test Questions
Posted at 1/10/2026 20:42:54      View:184 | Replies:4        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of itPass4sure 1z0-1054-25 dumps for free: https://drive.google.com/open?id=18lu0VwE9_EoOzsLzFHwFkA8ddIooBeBs
In this fast-changing world, the requirements for jobs and talents are higher, and if people want to find a job with high salary they must boost varied skills which not only include the good health but also the working abilities. But if you get the 1z0-1054-25 certification, your working abilities will be proved and you will find an ideal job. We provide you with 1z0-1054-25 Exam Materials of high quality which can help you pass the 1z0-1054-25 exam easily. It also saves your much time and energy that you only need little time to learn and prepare for 1z0-1054-25 exam.
Oracle 1z0-1054-25 Exam Syllabus Topics:
  • Implementing Enterprise and Financial Reporting Structures: This section of the exam measures skills of Oracle ERP Implementation Consultants and covers the core components used in setting up enterprise structures and reporting configurations. It assesses knowledge in defining legal entities, jurisdictions, and geographies, as well as the design and configuration of Chart of Accounts. Candidates must also demonstrate how to set up and secure chart structures and manage reporting calendars and currencies.
  • Implementing and Managing Journals: This section targets Oracle General Ledger Consultants and covers the full cycle of journal processing—from creation through approval to management. It includes configuration of journal-related objects and understanding how journals are sourced, tracked, and approved using predefined rules and workflows.
  • Configuring Financial Reports: This portion of the exam measures the abilities of Financial Reporting Analysts and includes creating and managing a range of reports using tools like the Financial Reporting Center, Web Studio, OTBI, Smart View, and Dashboards. Candidates must know how to define account groups, set up infolets, and build custom analytics tailored to user needs.
Pass Guaranteed Oracle - Reliable 1z0-1054-25 - Exam Oracle Financials Cloud: General Ledger 2025 Implementation Professional Objectives PdfThe world today is in an era dominated by knowledge. Knowledge is the most precious asset of a person. If you feel exam is a headache, don't worry. 1z0-1054-25 test answers can help you change this. 1z0-1054-25 study material is in the form of questions and answers like the real exam that help you to master knowledge in the process of practicing and help you to get rid of those drowsy descriptions in the textbook. 1z0-1054-25 Test Dumps can make you no longer feel a headache for learning, let you find fun and even let you fall in love with learning. The content of 1z0-1054-25 study material is comprehensive and targeted so that you learning is no longer blind. 1z0-1054-25 test answers help you to spend time and energy on important points of knowledge, allowing you to easily pass the exam.
Oracle Financials Cloud: General Ledger 2025 Implementation Professional Sample Questions (Q113-Q118):NEW QUESTION # 113
You have redesigned your chart of accounts and need to update your existing cross-validation rules. There is a requirement for new rules; some simply need to be updated and others need to be deleted.
What is the most efficient way to achieve this?
  • A. by using Cross-Validation Rules Import file-based data import (FBDI).
  • B. by using the Manage General Ledger Security page.
  • C. by creating Cross-Validation Rules desktop-integrated spreadsheet.
  • D. by using the Manage Cross-Validation Rules page.
According to Oracle documentation1, the most efficient way to update your existing cross-validation rules when you have redesigned your chart of accounts is to use Cross-Validation Rules Import file-based data import (FBDI). FBDI enables you to import cross-validation rules from a spreadsheet template into General Ledger. You can use FBDI to create new rules, update existing rules, or delete rules. Therefore, option C is correct. Option A is incorrect because using the Manage General Ledger Security page does not enable you to update cross-validation rules. Option B is incorrect because creating Cross-Validation Rules desktop- integrated spreadsheet does not enable you to update cross-validation rules. Option D is incorrect because using the Manage Cross-Validation Rules page does not enable you to update cross-validation rules efficiently.
According to Oracle documentation2, you should create a Data Access Set that allows access to the UK Ledger to allow users with the General Accountant job role to access the UK Ledger. A Data Access Set is a security feature that defines the ledgers and balancing segment values that a user can access. You can assign Data Access Sets to users or roles using the Manage Data Access for Users page. Therefore, option B is correct. Option A is incorrect because assigning the security context value of UK Ledger to the user/role combination does not enable access to the ledger. Option C is incorrect because assigning the General Accounting Manager role to those users does not enable access to the ledger. Option D is incorrect because assigning the UK reference set to the user/role combination does not enable access to the ledger.
NEW QUESTION # 114
You can run predefined reports to reconcile subledger application balances to General Ledger balances.
Which attribute must you set up on the Manage Values page for chart of accounts segment values so that you can run the Payables to General Ledger Reconciliation report or Receivables to General Ledger Reconciliation report?'
  • A. Start Date
  • B. Third Party Control Account
  • C. Reconcile
  • D. End Date
  • E. Financial Category
Answer: E
NEW QUESTION # 115
You entered users who are bothemployees and contingent workers. You want an automated way toassign, reassign, and remove rolesfrom users. What feature do you use?
  • A. Role Mappings
  • B. You cannot reassign contingent workers
  • C. Data Roles
  • D. Oracle Identity Manager Roles Assignment
  • E. Access Policy Manager's Role Generation
NEW QUESTION # 116
Your company wants to change theCumulative Translation Adjustment (CTA) accountto record gains/losses from varying currency rates.
What steps must you perform to achieve this objective without causing data corruption?
  • A. Define a new ledger and accounting configuration. The CTA account cannot be updated after the ledger has been in use.
  • B. Purge all translated balances, change the CTA account in the Ledger page, and rerun Translation for all periods required.
  • C. Open the Ledgers page and update the CTA account and then rerun Translation for all periods required.The system will automatically update the translated balances.
  • D. Query the Translation journals and delete all of them, then change the CTA account in the Ledger page, and rerun Translation for all periods required.
NEW QUESTION # 117
You are capturing rental costs for a building in a corporate cost center. At month end, you want to allocate those costs to the cost centers in the building based on the floor area occupied. A statistical journal has been entered to record the floor area. You use Calculation Manager to create the allocation.
Where do you reference the statistical balance within the allocation component?
  • A. Allocation Range
  • B. Source
  • C. Basis
  • D. Offset
  • E. Target
The source is where you specify the amount to be allocated. You can use various sources, such as account balances, fixed amounts, or statistical balances. In this case, you want to use the statistical balance of the floor area as the source of the allocation. The basis is where you specify the driver or factor that determines how the source amount is distributed among the targets. The target is where you specify the destination accounts that receive the allocated amount. The offset is where you specify the account that records the opposite side of the allocation entry. The allocation range is where you specify the scope of the allocation, such as the ledger, balancing segment, or legal entity. References:
Oracle Financials Cloud Implementing Enterprise Structures and General Ledger, Chapter 3: Allocations and Periodic Entries, Allocation Components Oracle Financials Cloud Using General Ledger, Chapter 3: Allocations and Periodic Entries, Overview
NEW QUESTION # 118
Our product’s passing rate is 99% which means that you almost can pass the test with no doubts. The reasons why our 1z0-1054-25 study materials’ passing rate is so high are varied. Firstly, our test bank includes two forms and they are the PDF test questions which are selected by the senior lecturer, published authors and professional experts and the practice test software which can test your mastery degree of our 1z0-1054-25 Study Materials at any time. The two forms cover the syllabus of the entire test. Our questions and answers include all the questions which may appear in the exam and all the approaches to answer the questions. So we provide the strong backing to help clients to help them pass the test.
Certification 1z0-1054-25 Test Questions: https://www.itpass4sure.com/1z0-1054-25-practice-exam.html
P.S. Free 2026 Oracle 1z0-1054-25 dumps are available on Google Drive shared by itPass4sure: https://drive.google.com/open?id=18lu0VwE9_EoOzsLzFHwFkA8ddIooBeBs
Posted at 1/31/2026 13:24:00        Only Author  2#
Your article is a masterpiece, thank you for sharing it! Sharing the GAFRB free questions and answers questions for free, the key to your career growth!
Posted at 2/8/2026 14:18:55        Only Author  3#
The article gave me so many new ideas. Sharpen your IT knowledge with free Reliable KCSA test online. Best of luck to you!
Posted at 2/18/2026 11:57:49        Only Author  4#
아무런 노력을 하지 않고 승진이나 연봉인상을 꿈꾸고 있는 분이라면 이 글을 검색해낼수 없었을것입니다. 승진이나 연봉인상을 꿈꾸면 승진과 연봉인상을 시켜주는 회사에 능력을 과시해야 합니다. IT인증시험은 국제적으로 승인해주는 자격증을 취득하는 시험입니다. PassTIP의Microsoft인증 MS-102-KR덤프의 도움으로 Microsoft인증 MS-102-KR시험을 패스하여 자격증을 취득하면 승진이나 연봉인상의 꿈이 이루어집니다. 결코 꿈은 이루어질것입니다.
Posted at 2/21/2026 21:02:13        Only Author  5#
This article has helped me see things from different angles, encouraging deeper reflection. This is the Valid SecOps-Generalist exam sims exam I took for my promotion and salary increase. It’s free for you today—wishing you all success in your careers!
