[General] Quiz Fire-Inspector-II - 67 - Fire Inspector II Exam Perfect Test Answers
79
General Quiz Fire-Inspector-II - 67 - Fire Inspector II Exam Perfect Test Answers
Posted at 1/10/2026 20:50:52      View407 | Replies6        Print      Only Author   [Copy Link] 1#
Considering your various purchasing behaviors, such as practice frequency. Occasion, different digital equivalents, average amount of time on our Fire-Inspector-II practice materials, we made three versions for your reference, and each has its indispensable favor respectively. All Fire-Inspector-II guide exam can cater to each type of exam candidates preferences. The three kinds are PDF & Software & APP version. Besides, we have always been exacting to our service standards to make your using experience better. We are exclusive in Fire-Inspector-II training prep area, so we professional in practice materials of the test.
You will receive an email attached with Fire-Inspector-II exam study guide within 5-10 min after you pay. It means that you do not need to wait too long to get the dumps you want. Besides, you will have free access to the updated International Code Council Fire-Inspector-II study material for one year. If there is any update, our system will send the update Fire-Inspector-II Test Torrent to your payment email automatically. Please pay attention to your payment email for the latest International Code Council Fire-Inspector-II exam dumps. If there is no any email about the update, please check your spam.
International Code Council Fire-Inspector-II Latest Study Notes - Fire-Inspector-II Exam Lab QuestionsActualTestsIT assists people in better understanding, studying, and passing more difficult certification exams. We take pride in successfully servicing industry experts by always delivering safe and dependable exam preparation materials. ActualTestsIT Fire-Inspector-II Exam Questions make it possible to appear in the 67 - Fire Inspector II Exam exam confidently without any fear of failure. ActualTestsIT has extensive experience in compiling the Fire-Inspector-II exam questions for the International Code Council exam.
International Code Council 67 - Fire Inspector II Exam Sample Questions (Q35-Q40):NEW QUESTION # 35
The minimum fire-flow for a 3,700-sq. ft. two-family dwelling of Type VB construction with a sprinkler system is ___ GPM.
  • A. 0
  • B. 1,313
  • C. 1,750
  • D. 1,000
Fire flow for residential buildings is determined based on IFC Appendix B, Table B105.1(1) - Required Fire Flow for One- and Two-Family Dwellings, Group R-3, and R-4 Buildings.
For a 3,700 sq. ft. two-family dwelling of Type VB construction:
Per Table B105.1(1), the baseline fire flow is 1,750 gpm.
If an NFPA 13D-compliant automatic sprinkler system is installed, the fire flow is reduced by 50%.
1,750 gpm 0.50 = 875 gpm, but the minimum allowed for a sprinklered dwelling is 1,000 gpm.
NEW QUESTION # 36
What is the maximum number of students permitted in a classroom that measures 20 ft. x 30 ft., and which contains four fixed 4 ft. x 8 ft. tables?
  • A. 0
  • B. 1
  • C. 2
  • D. 3
To determine the maximum number of students permitted in a classroom, we must follow the occupant load calculation based on the 2021 International Building Code (IBC) and International Fire Code (IFC).
Step 1: Calculate the Room Area
The classroom measures 20 ft. x 30 ft., so the total area is:
2030=600 sq. ft.20         imes 30 = 600         ext{ sq. ft.}2030=600 sq. ft.
Step 2: Subtract the Area Occupied by Fixed Tables
Each table measures 4 ft. x 8 ft., so its area is:
48=32 sq. ft. per table4         imes 8 = 32         ext{ sq. ft. per table}48=32 sq. ft. per table Since there are 4 tables:
324=128 sq. ft. occupied by tables32         imes 4 = 128         ext{ sq. ft. occupied by tables}
Step 3: Determine the Usable Space for Students
600#128=472 sq. ft. available600 - 128 = 472         ext{ sq. ft. available}600#128=472 sq. ft. available Step 4: Apply the Occupant Load Factor According to 2021 IBC Table 1004.5 (Occupant Load Factor), the factor for a classroom with tables and chairs is 20 sq. ft. per person.
47220=23.6472 div 20 = 23.647220=23.6
Since the occupant load must be rounded down, the maximum number of students is 24.
Reference to Fire Inspector Documentation:
1. 2021 International Building Code (IBC) - Table 1004.5 (Occupant Load Factor) A classroom with tables and chairs requires 20 sq. ft. per occupant.
This method ensures compliance with egress and fire safety requirements.
2. 2021 International Fire Code (IFC) - Section 1004.1 (Occupant Load Determination) The IFC states that occupant load is based on net usable floor area and must follow IBC Table 1004.5.
Detailed Explanation of Answer Choices:
Option A (Incorrect): 12 students would be too low based on the calculations.
Option B (Correct): 24 students is the accurate calculation following IBC 1004.5.
Option C (Incorrect): 30 students would exceed the available space per code.
Option D (Incorrect): 40 students is far above the allowed maximum.
Thus, the correct and verified answer is: B. 24.
NEW QUESTION # 37
Which of the following situations requires securing of an operational permit from the code official prior to commencing the related activity?
  • A. Fruit ripening operations using carbon dioxide gas.
  • B. Inside storage of 100 cu. ft. of baled cotton.
  • C. Storing 85,000 bd. ft. of lumber.
  • D. Organic coating production facility producing 2 gallons per day.
IFC Section 105.6 lists activities requiring operational permits. For A, lumber storage exceeding 100,000 board feet (bd. ft.) indoors or outdoors requires a permit (Section 105.6.28, Lumber Yards), but local thresholds may be lower-85,000 bd. ft. is close to this limit and likely exceeds typical exempt amounts, triggering a permit in many jurisdictions. For B, IFC Table 3206.2 allows small quantities of combustible commodities like baled cotton (100 cu. ft. is minimal) without a permit unless part of a larger high-piled storage operation. For C, fruit ripening with CO2 (Section 105.6.13) requires a permit only for specific flammable gases, not CO2 alone, which is nonflammable. For D, organic coating production (Section
105.6.33) requires a permit only above 1 gallon per day, but 2 gallons is still small-scale and context- dependent-lumber storage is the clearer permit trigger here. Thus, A is the best answer.
Reference: IFC 2021, Section 105.6 (Required Operational Permits), Section 3206.2 (High-Piled Storage).
NEW QUESTION # 38
What fire-resistance rating is required for interior nonbearing walls and partitions in Type IV construction?
  • A. 2 hours
  • B. 1-1/2 hours
  • C. 0 hours
  • D. 1 hour
Fire-Resistance Rating for Nonbearing Walls in Type IV Construction
Type IV (Heavy Timber) construction, as defined by the International Building Code (IBC) 2021, Section
602.4, consists of large, solid or laminated wood members.
Interior nonbearing walls and partitions in Type IV construction are not required to have a fire-resistance rating (0 hours) unless they separate different occupancies or are specifically mandated by another code provision.
2. Why Type IV Does Not Require a Rating for Nonbearing Walls
The heavy timber components inherently provide fire resistance due to their large cross-section, which chars on the surface and slows fire penetration.
IBC Table 601 confirms that interior nonbearing walls in Type IV construction do not have a required fire- resistance rating.
3. Verification of Other Options
Option B (1 hour) - Incorrect, as Type IV does not require a 1-hour rating for interior nonbearing walls unless specific conditions apply.
Option C (1-1/2 hours) - Incorrect, as there is no code requirement for this level of rating in Type IV nonbearing walls.
Option D (2 hours) - Incorrect, as Type IV walls are not rated unless separating occupancies.
Reference Sources:
International Building Code (IBC) 2021 - Section 602.4 (Type IV Construction Requirements) IBC Table 601 (Fire-Resistance Ratings for Building Elements) ICC Fire Inspector II Study Guide (2021)
NEW QUESTION # 39
Horizontal exits shall not comprise more than ___ of the required exits from any floor area in a Group I-2 occupancy.
  • A. 2/3
  • B. 1/3
  • C. 1/2
  • D. 3/4
For Group I-2 occupancies (such as hospitals, nursing homes, and similar healthcare facilities), horizontal exits are used to improve fire safety by allowing occupants to move to a safer area without using stairs or elevators.
IFC 2021, Section 1026.1 (Horizontal Exits - General Requirements) states that:
Horizontal exits shall not comprise more than one-half (1/2) of the required exits from any floor area in a Group I-2 occupancy.
This ensures that at least 50% of the required exits remain traditional vertical or exterior exits, maintaining a balance between horizontal and traditional egress routes.
NEW QUESTION # 40
With the assist of International Code Council practice demo, your goals to get the Fire-Inspector-II certification will be very easy to accomplish and 100% guaranteed. Before you choose our Fire-Inspector-II study material, you can try our Fire-Inspector-II free demo for assessment. For a better idea you can also read Fire-Inspector-II testimonials from our previous customers at the bottom of our product page to judge the validity. Our updated and useful Fire-Inspector-II will be the best tool for your success.
Fire-Inspector-II Latest Study Notes: https://www.actualtestsit.com/International-Code-Council/Fire-Inspector-II-exam-prep-dumps.html
International Code Council Fire-Inspector-II Test Answers These values guide every decision we make, everywhere we make them, International Code Council Fire-Inspector-II Test Answers If you pay attention on our exam study guide after purchasing, you should not worry too much, our products will assist you to clear exam easily, Therefore, how to pass International Code Council Fire-Inspector-II exam and gain a certificate successfully is of great importance to people, International Code Council Fire-Inspector-II Test Answers According to our investigation, 99% people have passed the exam for the first time.
You cannot select the shapes until you choose Object > Unlock All, ActualTestsIT Fire-Inspector-II Exam Lab Questions provides exam dumps designed by experts to ensure that the candidates' success, These values guide every decision we make, everywhere we make them.
Newest International Code Council - Fire-Inspector-II - 67 - Fire Inspector II Exam Test AnswersIf you pay attention on our exam study guide Fire-Inspector-II after purchasing, you should not worry too much, our products will assist you to clearexam easily, Therefore, how to pass International Code Council Fire-Inspector-II exam and gain a certificate successfully is of great importance to people.
According to our investigation, 99% people have passed the exam for the first time, ActualTestsIT International Code Council Fire-Inspector-II study material is available in three formats.
Posted at 1/19/2026 15:53:07        Only Author  2#
Amazing stuff here, definitely hitting that like. The Valid C-SEC-2405 exam papers content is excellent, and you can get it without any cost.
Posted at 1/22/2026 08:55:47        Only Author  3#
This article has provided me with many valuable insights. New F5CAB3 test notes has great content, and its provided to you without any fees.
Posted at 1/26/2026 06:09:09        Only Author  4#
Such great content, no hesitation at all in liking it. The ServSafe-Manager free exam dumps helped me land a promotion and salary boost. Now its free for all. Wishing you success in your career!
Posted at 1/27/2026 13:44:40        Only Author  5#
The article is written with great depth, and I have learned a lot of practical knowledge. Get free C-P2WBW-2505 accurate prep material to improve your IT knowledge. Wishing you success!
Posted at 1/31/2026 17:48:31        Only Author  6#
That piece of writing really expanded my mind. Sharpen your IT knowledge with free Exam C_ARSUM_2508 dump. Best of luck to you!
Posted at 2/16/2026 23:08:13        Only Author  7#
Your article has really expanded my perspective, thank you. Free AP-203 reliable test cost to boost your IT knowledge. Best wishes for your journey!
