[Hardware] Top Test 220-1101 Price & Useful Materials to help you pass CompTIA 220-1101
98
【Hardware】 Top Test 220-1101 Price & Useful Materials to help you pass CompTIA 220-1101
Posted at 1/10/2026 22:08:36      View:163 | Replies:1        Print      Only Author   [Copy Link] 1#
2026 Latest PrepAwayPDF 220-1101 PDF Dumps and 220-1101 Exam Engine Free Share: https://drive.google.com/open?id=1L1wWGa4yOjV_dSPaJ4nk7C-vofGfATMT
You will need to pass the CompTIA A+ Certification Exam: Core 1 (220-1101) exam to achieve the CompTIA 220-1101 certification. Due to extremely high competition, passing the CompTIA 220-1101 exam is not easy; however, possible. You can use PrepAwayPDF products to pass the 220-1101 Exam on the first attempt. The CompTIA practice exam gives you confidence and helps you understand the criteria of the testing authority and pass the CompTIA A+ Certification Exam: Core 1 (220-1101) exam on the first attempt.
Just the same as the free demos of our 220-1101 learning quiz, we have provided three kinds of versions of our 220-1101 preparation exam, among which the PDF version is the most popular one. It is understandable that many people give their priority to use paper-based materials rather than learning on computers, and it is quite clear that the PDF version is convenient for our customers to read and print the contents in our 220-1101 Study Guide.
220-1101 Reliable Test Syllabus & 220-1101 Reliable Exam OnlineThe countless candidates have already passed their CompTIA A+ Certification Exam: Core 1 (220-1101) certification exam and they all used the real, valid, and updated 220-1101 exam questions. So, why not, take a decision right now and ace your CompTIA A+ Certification Exam: Core 1 (220-1101) exam preparation with top-notch CompTIA 220-1101 exam questions?
CompTIA A+ Certification Exam: Core 1 (220-1101) covers a broad range of topics related to computer hardware, software, and networking. 220-1101 exam focuses on the basics of computer systems, including installation, configuration, and maintenance. It also covers topics such as troubleshooting, security, and mobile device support. 220-1101 Exam consists of 90 questions, which must be completed within 90 minutes. A passing score is 675 out of 900.
CompTIA A+ Certification Exam: Core 1 Sample Questions (Q381-Q386):NEW QUESTION # 381
Which of the following is used to register inputs on a touch-screen monitor?
  • A. Inverter
  • B. Cathode-ray tube
  • C. Digitizer
  • D. OLED
NEW QUESTION # 382
A technician is setting up a video-editing workstation and the operating system is already installed on an internal M.2 drive.
The new workstation must meet the following requirements:
. Be able to edit files at the fastest speed
. Allow for disk failure without any downtime
  Have 2TB of usable space
. Ensure the most robust fault tolerance
INSTRUCTIONS
Use the drop-down menus to select the appropriate RAID level, drive types, and drive sizes based on the requirements above. For each drive type that is selected, a corresponding drive size must also be selected.
Based on the requirements, the best option for the video-editing workstation is to use RAID 10 with four SATA SSDs of 1TB each. This configuration will meet the following requirements:
Be able to edit files at the fastest speed: RAID 10 combines the advantages of RAID 0 and RAID 1, which are striping and mirroring, respectively. Striping can increase the data transfer rate by using multiple disks in parallel, while mirroring can provide redundancy and reliability by duplicating the data on another set of disks. SATA SSDs are also faster than HDDs or SSHDs, as they use flash memory instead of spinning disks, and they can offer lower latency, higher IOPS, and less noise and heat.
Allow for disk failure without any downtime: RAID 10 can withstand up to two disk failures, as long as they are not in the same mirrored pair. If one disk fails, the data can be read from or written to the other disk in the same pair, without affecting the performance or availability of the array. The failed disk can be replaced and rebuilt without interrupting the operation of the workstation.
Have 2TB of usable space: RAID 10 uses half of the total disk capacity for mirroring, so the usable space is equal to the size of two disks. By using four SATA SSDs of 1TB each, the total disk capacity is 4TB, and the usable space is 2TB, which meets the requirement.
Ensure the most robust fault tolerance: RAID 10 offers the highest level of fault tolerance among the standard RAID levels, as it can survive multiple disk failures and provide fast recovery. RAID 10 also has a low overhead, as it does not use parity or checksums, which can slow down the write performance or increase the complexity of the array.
Therefore, the technician should select the following options from the drop-down menus:
RAID level: RAID 10
Drive type 1: SATA SSD
Drive size 1: 1TB
Drive type 2: SATA SSD
Drive size 2: 1TB
Drive type 3: SATA SSD
Drive size 3: 1TB
Drive type 4: SATA SSD
Drive size 4: 1TB
Drive type 5: SATA SSD
Drive size 5: 1TB
NEW QUESTION # 383
Employees are concerned about sensitive data being printed on a shared multifunction printer located in a high-traffic hallway. Which of the following should a technician do to address this concern?
  • A. Relocate the printer to an unused office space.
  • B. Configure printing of sensitive data through a specific tray.
  • C. Schedule print jobs to be released at certain times.
  • D. Set up a PIN for user authentication at the printer.
To prevent unauthorized access to printed sensitive data on a shared printer in a high-traffic area, the best solution is to require user authentication via a PIN. This ensures that print jobs are only released when the authorized user is present at the printer, protecting sensitive information from being exposed.
NEW QUESTION # 384
A technician is troubleshooting a projector that will not display any Images. The technician has verified the computer output and cable are providing a good video signal. Which of the following should the technician do NEXT?
  • A. Calibrate the image.
  • B. Test the output resolution.
  • C. Clean the fans.
  • D. Replace the bulb.
NEW QUESTION # 385
The IT department at an insurance brokerage needs to acquire laptops that have built-in fingerprint readers in order to create a more secure environment. Which of the following would be the MOST secure way to implement the fingerprint readers?
  • A. Grant all registered employees access to each machine.
  • B. Restrict device access to only the user to whom the laptop is assigned.
  • C. Give each team member a USB drive that bypasses the reader to allow guest users lo log in.
  • D. Limit device access to departments and guest users.
The most secure way to implement fingerprint readers would be to restrict device access to only the user to whom the laptop is assigned. This ensures that only authorized personnel have access to the device, reducing the risk of unauthorized access and data breaches.
NEW QUESTION # 386
We provide you with free demo to have a try before buying 220-1101 training materials, so that you can have a better understanding of what you are going to buy. If you are content with the 220-1101 exam dumps after trying, you just need to add them to your cart, and pay for them. You will get the downloading link within ten minutes. If you don’t receive, just contact with us, we have professional stuff solve the problem for you. What’s more, 220-1101 Training Materials contain both questions and answers, and it’s convenient for you to check the answers after practicing.
220-1101 Reliable Test Syllabus: https://www.prepawaypdf.com/CompTIA/220-1101-practice-exam-dumps.html
Posted at 2/13/2026 23:43:20        Only Author  2#
すべての受験生はPRINCE2-Foundation-JPN試験に順調に合格するのを希望しますが、そんなに簡単ではありません。この試験を準備するあなたは心配する必要がありません。PassTestの提供する問題集は受験生の試験への合格を保証することができます。我々の最新の問題集を利用して、気楽でPRINCE2-Foundation-JPN試験に合格することができます。
