Training 1z0-076 Solutions, 1z0-076 Exam Introduction
Posted at 1/10/2026 23:23:40
View154
Replies2
P.S. Free 2026 Oracle 1z0-076 dumps are available on Google Drive shared by Prep4sures: https://drive.google.com/open?id=1jeD14eGzCzASVY0d-PgUCk0u_s0q0DsG
To pass the Oracle 1z0-076 exam on the first try, candidates need Oracle Database 19c: Data Guard Administration updated practice material. Preparing with real 1z0-076 exam questions is one of the finest strategies for cracking the exam in one go. Students who study with 1z0-076 Real Questions are more prepared for the exam, increasing their chances of succeeding. The 1z0-076 exam preparation calls for a strong preparation and precise Oracle 1z0-076 practice material.
Oracle 1z0-076 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Oracle Data Guard Basics: This topic covers the essential architecture and concepts of Oracle Data Guard. It includes sub-topics such as the physical and logical standby database comparison, benefits of Data Guard, and its integration with multi-tenant databases.
| | Topic 2 | - Creating a Logical Standby Database: This topic guides users through the process of creating and managing a logical standby database, including SQL Apply filtering.
| | Topic 3 | - Enhanced Client Connectivity in a Data Guard Environment: This topic focuses on enhancing client connectivity in a Data Guard setup and implementing failover procedures for seamless client redirection. It also covers application continuity to ensure uninterrupted operations during role transitions.
| | Topic 5 | - Creating a Data Guard Broker Configuration: This section delves into the practical aspects of creating and managing a Data Guard broker configuration, including command-line and Enterprise Manager approaches.
| | Topic 6 | - Performing Role Transitions: Here, the concept of database roles is explained, along with the steps for performing switchovers, failovers, and maintaining physical standby sessions during role transitions.
| | Topic 7 | - Backup and Recovery Considerations in an Oracle Data Guard Configuration: In this topic, Backup and recovery procedures in a Data Guard configuration are discussed, including RMAN backups, offloading to physical standby, and network-based recovery.
Free PDF Quiz 1z0-076 - Oracle Database 19c: Data Guard Administration Useful Training SolutionsTo eliminate the chances of mistakes and prepare well for exams you must use 1z0-076 practice test software. There are two types of Oracle Database 19c: Data Guard Administration 1z0-076 practice test software: You can install Oracle 1z0-076 practice test software on all window-based PCs. On the other hand, a web-based Oracle Database 19c: Data Guard Administration Networking Solutions 1z0-076 practice test can be used without the installation of any software. Practicing with these 1z0-076 practice exams software seems like you are taking a Real 1z0-076 Exam. This software allows you to take multiple Oracle 1z0-076 exam attempts. At the end of each Oracle Database 19c: Data Guard Administration 1z0-076 exam attempt, you can check your progress. These Oracle 1z0-076 practice tests assist you to know how to manage your time and complete the Oracle Database 19c: Data Guard Administration 1z0-076 exam within the specified time limit. Thus, Using these 1z0-076 practice tests software will be beneficial if you want to achieve the highest score in the exam.
Oracle Database 19c: Data Guard Administration Sample Questions (Q19-Q24):NEW QUESTION # 19
You created a physical standby database prodsbyi from the primary database prod using SQL and RMAN.
Which THREE are prerequisites for creating a Data Guard Broker configuration to manage these databases?
- A. The DG_BROKER_START parameter must be set to TRUE for both database instances.
- B. The primary database must have FORCE LOGGING enabled.
- C. The standby database must have supplemental logging enabled.
- D. A local net service name to enable connectivity to the PRODSBYI database instance must be defined on the primary database host.
- E. The primary database must have supplemental logging enabled.
- F. The LOG_ARCHIVE_DEST_n parameters with the service attribute set must be cleared.
Answer: A,D,E
When setting up a Data Guard Broker configuration for a primary database and its physical standby, the following prerequisites must be met:
* A: Oracle Net connectivity must be defined on both the primary and standby hosts to enable the respective database instances to communicate with each other.
* B: Supplemental logging is required on the primary database because it provides additional logging necessary for the standby database to be able to apply changes from the primary database accurately.
* F: The DG_BROKER_START parameter must be set to TRUE for both the primary and standby
* database instances. This parameter is used to start the Data Guard Broker process which manages the configuration.
Options C and D are not prerequisites for creating a Data Guard Broker configuration. Additionally, while FORCE LOGGING mode (option E) is recommended as a best practice to prevent possible data inconsistencies during media recovery, it is not a strict prerequisite for creating a Data Guard Broker configuration.
References: This guidance is based on Oracle's best practices for setting up Data Guard configurations, as found in the Oracle Data Guard Broker documentation and the Oracle Data Guard Concepts and Administration guide.
NEW QUESTION # 20
Which three actions are performed by the START PLAN procedure of the DBMS ROLLING package?
- A. building a LogMiner dictionary on the primary database instance
- B. switching the primary database to the logical standby role
- C. creating a guaranteed restore point on the primary database
- D. converting the designated physical standby database into a logical standby database
- E. starting media recovery on all the Leading Group Standby databases
- F. creating a guaranteed restore point on the standby databases
Answer: A,C,F
The DBMS_ROLLING package facilitates a rolling upgrade process across a Data Guard configuration. The START PLAN procedure in particular handles several critical actions, including:
Creating a guaranteed restore point on the standby databases (B): This ensures that the standby databases can be reverted to their state before the rolling upgrade process in case of any issues.
Building a LogMiner dictionary on the primary database instance (C): This is necessary for logical standby databases to interpret redo data during the SQL Apply process.
Creating a guaranteed restore point on the primary database (D): Similar to the standby databases, this ensures that the primary database can be reverted to a known good state if necessary.
Oracle Database PL/SQL Packages and Types Reference
Oracle Data Guard Concepts and Administration Guide
NEW QUESTION # 21
Your Data Guard environment has two remote physical standby databases.
Client applications use the local naming method to define connectivity to the primary database instance.
Which will automatically redirect clients to the new primary database in case of a switchover or failover?
- A. Set the LOCAL_LISTENER parameter for all the database instances, to register services with the default listener on the primary database host.
- B. Create a database service on the standby databases; automate the start of the service after a role change, and modify the connection descriptor on the clients to use that service.
- C. Set the DB_NAME parameter identically on all databases; modify the connection descriptor on the clients to use DB_NAME to connect to the primary database instance.
- D. Configure a PRIMARY role service on the Primary and Standby and modify the Client connect descriptor to include both the Primary and the Standby.
NEW QUESTION # 22
Which three statements are true about redo transport?
- A. With synchronous redo transport, LGWR ships redo directly to RFS processes on the standby database instances and waits for an acknowledgment.
- B. With asynchronous redo transport, TTnn processes may read redo from the log buffer or from standby redo logs on the primary database.
- C. Multiple RFS processes may receive redo on one standby database instance.
- D. An RFS process on a standby database instance may receive redo from an archiver process on the primary database instance to perform archive gap resolution.
- E. Multiple RFS processes may receive redo on one far sync instance.
Answer: A,C,D
NEW QUESTION # 23
Which three statements are true about Data Guard database modes and states?
- A. Databases in a Data Guard Configuration need not operate in Flashback Logging mode.
- B. Force Logging Mode is not required for a primary database but is recommended.
- C. The Primary Database can operate in noarchivelog mode.
- D. A primary database may ship redo directly to more than nine standby databases.
- E. A Logical Standby Database can be in MOUNT state while applying changes.
Answer: A,B,E
NEW QUESTION # 24
Our 1z0-076 study tool boost three versions for you to choose and they include PDF version, PC version and APP online version. Each version is suitable for different situation and equipment and you can choose the most convenient method to learn our 1z0-076 test torrent. For example, APP online version is printable and boosts instant access to download. You can study the 1z0-076 Guide Torrent at any time and any place. The PC version of 1z0-076 study tool can stimulate the real exam's scenarios. We provide 365-days free update and free demo available.
1z0-076 Exam Introduction: https://www.prep4sures.top/1z0-076-exam-dumps-torrent.html
- Free PDF 2026 Oracle 1z0-076 CTrustable Training Solutions 🌮 Immediately open [url]www.troytecdumps.com and search for ➤ 1z0-076 ⮘ to obtain a free download 😟Latest 1z0-076 Braindumps Sheet[/url]
- 1z0-076 Valid Test Answers ⚜ Training 1z0-076 Pdf 🚥 Latest 1z0-076 Test Question 🤣 Immediately open ▛ [url]www.pdfvce.com ▟ and search for ➤ 1z0-076 ⮘ to obtain a free download 🤢
ractice 1z0-076 Exams Free[/url] - Updates to Oracle 1z0-076 Exam Questions Are Free For 1 year 🤍 Immediately open [url]www.prepawayexam.com and search for ➥ 1z0-076 🡄 to obtain a free download ⏯1z0-076 Latest Test Bootcamp[/url]
- Free PDF 2026 Latest 1z0-076: Training Oracle Database 19c: Data Guard Administration Solutions 🎐 ⏩ [url]www.pdfvce.com ⏪ is best website to obtain 1z0-076 for free download 🏇1z0-076 Latest Test Bootcamp[/url]
- 1z0-076 Latest Test Bootcamp 🎋 Latest 1z0-076 Braindumps Sheet 🧪 Top 1z0-076 Dumps 👊 Open ☀ [url]www.examcollectionpass.com ️☀️ enter ☀ 1z0-076 ️☀️ and obtain a free download 🎬
ractice 1z0-076 Exams Free[/url] - Practice 1z0-076 Exams Free 🤍 1z0-076 Exam Introduction ⛺ Top 1z0-076 Dumps 🙋 Open website ➡ [url]www.pdfvce.com ️⬅️ and search for ➥ 1z0-076 🡄 for free download 🚄Exam Sample 1z0-076 Online[/url]
- Pass your 1z0-076 exam in 2026 Smoothly! 👻 Enter [ [url]www.practicevce.com ] and search for ⮆ 1z0-076 ⮄ to download for free 🔅Top 1z0-076 Dumps[/url]
- Pass Guaranteed 2026 Oracle Unparalleled 1z0-076: Training Oracle Database 19c: Data Guard Administration Solutions 📀 Immediately open ⇛ [url]www.pdfvce.com ⇚ and search for { 1z0-076 } to obtain a free download 🛩Exam 1z0-076 Score[/url]
- Free PDF 2026 Oracle 1z0-076 CTrustable Training Solutions 🐅 Open ➠ [url]www.prep4away.com 🠰 and search for ⇛ 1z0-076 ⇚ to download exam materials for free ☢1z0-076 Valid Vce[/url]
- Exam 1z0-076 Score I Training 1z0-076 Pdf 🧪 1z0-076 Exam Introduction 👸 Go to website { [url]www.pdfvce.com } open and search for ➡ 1z0-076 ️⬅️ to download for free 🦒Exam Sample 1z0-076 Online[/url]
- Free PDF 2026 Latest 1z0-076: Training Oracle Database 19c: Data Guard Administration Solutions 🧴 Search for ▛ 1z0-076 ▟ and easily obtain a free download on { [url]www.examdiscuss.com } 🔅Sample 1z0-076 Questions Pdf[/url]
- bbs.t-firefly.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.myvrgame.cn, stackblitz.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.300300.net, Disposable vapes
DOWNLOAD the newest Prep4sures 1z0-076 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1jeD14eGzCzASVY0d-PgUCk0u_s0q0DsG
