[General] Reliable VMware 2V0-21.23 Exam Preparation & 2V0-21.23 Real Exam
78
【General】 Reliable VMware 2V0-21.23 Exam Preparation & 2V0-21.23 Real Exam
Posted at 1/10/2026 23:28:28      View:166 | Replies:2        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest PassTorrent 2V0-21.23 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1tDd9hE_V-UOGh8gork_KLXQU5jQontI1
Many candidates may take the price into consideration while buying 2V0-21.23 exam materials. The price of 2V0-21.23 exam materials is quite reasonable, you can afford it no matter you are students or the employees in the company. Furthermore the 2V0-21.23 Exam Materials is high-quality, so that it can help you to pass the exam just one time, we will never let your money gets nothing returns. If you indeed fail the exam, money back will be guaranteed.
To prepare for the VMware 2V0-21.23 Exam, VMware recommends taking their VMware vSphere: Install, Configure, Manage [V8.x] course. This course provides an in-depth understanding of the VMware vSphere 8.x platform and its associated technologies, and prepares you for the exam. Additionally, VMware provides a range of study materials, including books, practice exams, and online courses, to help you prepare for the exam.
2V0-21.23 Real Exam | 2V0-21.23 Valid Dumps FilesAnd you can also use the VMware 2V0-21.23 PDF on smart devices like smartphones, laptops, and tablets. The second one is the web-based VMware 2V0-21.23 practice exam which can be accessed through the browsers like Firefox, Safari, and VMware Chrome. The customers don't need to download or install excessive plugins or software to get the full advantage from web-based 2V0-21.23 Practice Tests.
VMware vSphere 8.x Professional Sample Questions (Q104-Q109):NEW QUESTION # 104
An administrator is tasked with configuring an appropriate Single Sign-On (SSO) solution for VMware vCenter based on the following criteria:
* The solution should support the creation of Enhanced Link Mode groups.
* All user accounts are stored within a single Active Directory domain and the solution must support only this Active Directory domain as the identity source.
* All user account password and account lockout policies must be managed within the Active Directory domain.
* The solution should support token-based authentication.
Which SSO solution should the administrator choose based on the criteria?
  • A. vCenter Single Sign-On with Active Directory (Windows Integrated Authentication) as the identity source
  • B. vCenter Identity Provider Federation with Active Directory Federation Services as the identity provider
  • C. vCenter Single Sign-On with Active Directory over LDAP as the identity source
  • D. vCenter Identity Provider Federation with Active Directory over LDAP as the identity provider
In vCenter Server Identity Provider Federation, vCenter Server uses the OpenID Connect (OIDC) protocol to receive an identity token that authenticates the user with vCenter Server." Integrated Windows Authentication is deprecated since vSphere 7.0
https://docs.vmware.com/en/VMwar ... oc/GUID-157188E3-53
NEW QUESTION # 105
An administrator has a host profile named Standard-Config. The administrator wants to change the other host profiles to use only the storage configuration settings that are defined in the Standard-Config host profile.
What should the administrator do to make this change?
  • A. Export the Standard-Config host profile and attach it to the other hosts.
  • B. Export host customizations and import them to the other host profiles.
  • C. Duplicate the Standard-Config host profile and only modify the storage configuration settings.
  • D. Copy the storage settings from Standard-Config to all other host profiles.
Option B is correct because it allows the administrator to copy the storage settings from Standard-Config host profile to all other host profiles without affecting other settings. Option A is incorrect because it only exports host customizations and not host profile settings. Option C is incorrect because it creates a new host profile instead of modifying the existing ones. Option D is incorrect because it attaches the Standard-Config host profile to the other hosts instead of changing their host profiles. Reference: https://docs.vmware.com/en/VMwar ... 7-B2D2F7C6E9AF.html
NEW QUESTION # 106
Which VMware offering will allow an administrator to manage the lifecycle of multiple vCenter Server instances in a single software as a service (SaaS)-based solution to help drive operational efficiency?
  • A. VMware Cloud Foundation
  • B. VMware vSphere+
  • C. VMware Aria Suite Lifecycle
  • D. VMware vSphere with Tanzu
VCF includes the management domain and multiple workload domains. While VCF does use LCM to manage vCenter lifecycle, it is on-prem only (for now) and is not SaaS based. That only leave vSphere+. See the video in this link about upgrading remote vCenters managed by vSphere+.
https://www.vmware.com/products/vsphere/vsphere-plus.html
NEW QUESTION # 107
Given the configuration shown in the exhibit, what must the administrator do to delete only the latest version of the template?
  • A. In the SA-template folder, rename App-Libtemplate (2) to App-LibTemplate
  • B. Delete App-LibTemplete(3) from the SA-Templates folder.
  • C. Revert to APP-LibTemplate (2) and delete App-LibTemplate (3).
  • D. Check out AppLibTemplate (3) and delete the template from the SA-Templates folder.
Option D is correct because it allows the administrator to delete only the latest version of the template by reverting to the previous version and then deleting the current version. Option A is incorrect because it deletes the entire template and not just the latest version. Option B is incorrect because it renames the previous version to the current version and does not delete anything. Option C is incorrect because it checks out the latest version and deletes it from the folder, but not from the library. Reference: https://docs.vmware.com/en/VMwar ... C-3F8E5F6B4E9D.html
NEW QUESTION # 108
A vSphere cluster has the following vSphere Distributed Resource Scheduler (DRS) group configuration:
* Virtual machine (VM) group named DB
* Host groups named PROD11 and PROD55
The administrator wants to force the VMs in the DB group to run on the hosts in the PROD11 group.
However, if all the hosts in PROD55.
Which VM/Host rule must the administrator create to ensure that these requirements are met?
  • A. A required rule between the DB group and the PROD11 group
  • B. A preferential rule between the DB group and PROD11 group
  • C. A preferential rule between the DB group and the PROD55 group
  • D. A preferential rule between the DB group and the PROD55 group
Option A is correct because it allows the administrator to create a preferential rule between the DB group and PROD11 group, which will force the VMs in the DB group to run on the hosts in the PROD11 group if possible, but will allow them to run on the hosts in PROD55 group if necessary. Option B is incorrect because it will create a preferential rule between the DB group and PROD55 group, which will force the VMs in the DB group to run on the hosts in PROD55 group if possible, which is not what the administrator wants. Option C is incorrect because it is the same as option B. Option D is incorrect because it will create a required rule between the DB group and PROD11 group, which will force the VMs in the DB group to run only on the hosts in PROD11 group and not allow them to run on the hosts in PROD55 group if needed. References:
https://docs.vmware.com/en/VMwar ... UID-60077B40-66FF-4
NEW QUESTION # 109
Our 2V0-21.23 study practice guide boosts the function to stimulate the real exam. The clients can use our software to stimulate the real exam to be familiar with the speed, environment and pressure of the real 2V0-21.23 exam and get a well preparation for the real exam. Under the virtual exam environment the clients can adjust their speeds to answer the 2V0-21.23 Questions, train their actual combat abilities and be adjusted to the pressure of the real test. They can also have an understanding of their mastery degree of our 2V0-21.23 study practice guide.
2V0-21.23 Real Exam: https://www.passtorrent.com/2V0-21.23-latest-torrent.html
BTW, DOWNLOAD part of PassTorrent 2V0-21.23 dumps from Cloud Storage: https://drive.google.com/open?id=1tDd9hE_V-UOGh8gork_KLXQU5jQontI1
Posted at 1/20/2026 14:32:39        Only Author  2#
Thank you so much for your article, it really struck me. Access the comprehensive content of Valid exam MB-280 questions and answers for free—aimed at helping you.
Posted at 2/4/2026 10:12:06        Only Author  3#
It was an incredibly rewarding read. Enhance your IT knowledge with free Questions FCP_FAZ_AN-7.4 exam. Wishing you the best in all your exams!
