[Linux] rk3566 Ubuntu 18.04
7
Linux rk3566 Ubuntu 18.04
Posted at 8/2/2021 08:38:59      View4199 | Replies2        Print      Only Author   [Copy Link] 1#
I tried to load the FIREFLY-RK3566-ROC-PC_UBUNTU18.04-GPT-20210714-1744.img
I was able to update the firmware through the SD card upgrade. But after follow the instruction of removing SD card and wait for reboot, I stuck at  the "Firefly" screen.
Then I burn another SD card with "boot  from SD card",  then I can pass the "Firefly" screen and get into Ubuntu "normally". Now facing another issue: there is NO network connectivity. Tried many option to turn on ethernet but failed....
Anyone had similar experience of loading Ubuntu 18.04 on this device? Please share your story and may be you can help me to get through the above 2 issues, in summary:
1. using update from SD card method, after successfully update, it got stuck at "Firefly" screen
2. using boot from SD card method, the ethernet is not connected
Please help. Thanks a lot.
vip
Rank: 6Rank: 6
Posted at 8/19/2021 14:39:05        Only Author  2#
I regularly observe a similar behavior on M2 (stopping the startup on the splash screen after turning on the power). A simple reboot combination Ctrl+Alt+Del helps me. After that, the system restarts and starts normally. For a detailed analysis, you need a UART console (UART log).
Posted at 12/21/2025 05:24:18        Only Author  3#
Ciao, tra lo smartworking e le faccende domestiche, il mio telefono diventato il mio strumento principale per tutto, svago compreso. Stavo risparmiando per un monitor portatile per il mio laptop, ma i soldi non bastavano mai. Provare a giocare da browser era una seccatura. Poi, cercando un'esperienza migliore, ho trovato il link per https://spino-gambino.it.com/app L'ho scaricata e ho capito subito di aver fatto la scelta giusta: velocissima e intuitiva. Una pausa pranzo, una giocata un po' pi coraggiosa fatta direttamente dall'app, e il gioco era fatto. Il monitor arrivato e ora lavoro in dual screen ovunque. Avere un'app nativa cambia completamente la qualit del tempo libero.
