Salesforce Salesforce-MuleSoft-Developer-I Practice Exams For Self-Assessment (W
75
Posted at 1/11/2026 00:19:15      View137 | Replies1        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of ExamsReviews Salesforce-MuleSoft-Developer-I dumps for free: https://drive.google.com/open?id=14AE22yCWPppt0cxmzIWw7YoEc9_KQuXO
ExamsReviews offers a free trial for all the products and give you an open chance to test its various features. If you are satisfied with the demo so, you can buy Salesforce-MuleSoft-Developer-I exam questions PDF or Practice software. We updated our product frequently, our determined team is always ready to make certain alterations as and when Salesforce-MuleSoft-Developer-I announce any changing.
Salesforce Salesforce-MuleSoft-Developer-I Exam Syllabus Topics:
  • Deploying and Managing APIs and Integrations: It includes packaging Mule applications for deployment and deploying them to CloudHub. This topic also involves using CloudHub properties, creating and deploying API proxies, connecting an API implementation to API Manager, and applying policies to secure an API.
  • Transforming Data with DataWeave: It involves writing DataWeave scripts and using DataWeave functions. This topic also includes defining and using DataWeave variables, functions, and modules, and applying correct syntax.
  • Routing Events: It focuses on using the Choice router for conditional logic and the Scatter-Gather router to multicast events. This topic also involves validating data by using the Validation module.
  • Using Connectors: It focuses on retrieving data from REST services using HTTP Request or REST Connector. Moreover, the topic covers using a Web Service Consumer connector for SOAP web services and the Transform Message component.
Topic 5
  • Designing APIs: Designing APIs involves describing the lifecycle of the modern API and using RAML to define various aspects of an API. It includes identifying when to use query parameters vs URI parameters, and defining API parameters.
Topic 6
  • Building API Implementation Interfaces: This topic involves manually creating a RESTful interface for a Mule application and generating a REST Connector from a RAML specification. It also includes describing the features and benefits of APIkit.
Topic 7
  • Handling Errors: Handling errors includes describing default error handling in Mule applications and defining custom global default error handlers. It involves comparing On Error Continue and On Error Propagate scopes, creating error handlers for a flow, using the Try scope, and mapping errors to custom application errors.
Topic 8
  • Accessing and Modifying Mule Events: It describes the Mule event data structure. Moreover, the topic focuses on usage of transformers and enriching Mule events.
Topic 9
  • Debugging and Troubleshooting Mule Applications: Using breakpoints to inspect a Mule event during runtime, installing missing Maven dependencies, and reading and deciphering Mule log error messages are sub-topics of this topic.
Topic 10
  • Creating Application Networks: The topic of creating Application Networks encompasses understanding MuleSofts proposal for closing the IT delivery gap and describing the role and characteristics of the modern API. It also includes the purpose and roles of a Center for Enablement (C4E), and the benefits of API-led.
Topic 11
  • Structuring Mule Applications: Structuring Mule applications covers parameterizing an application and defining and reusing global configurations. It includes breaking an application into multiple flows using private flows, subflows, and the Flow Reference component.
Salesforce Certified MuleSoft Developer (Mule-Dev-201) exam training dumps & Salesforce-MuleSoft-Developer-I valid test questions & Salesforce Certified MuleSoft Developer (Mule-Dev-201) test vce torrentWith the quick development of the eletronic products, more and more eletronic devices are designed to apply to our life. Accordingly there are huge changes on the study models of our Salesforce-MuleSoft-Developer-I exam dumps as well. There are three different versions of our Salesforce-MuleSoft-Developer-I Study Guide designed by our specialists in order to satisfy varied groups of people. They are version of the PDF,the Software and the APP online. All these versions of Salesforce-MuleSoft-Developer-I pratice materials are easy and convenient to use.
Salesforce Certified MuleSoft Developer (Mule-Dev-201) Sample Questions (Q213-Q218):NEW QUESTION # 213
Refer to the exhibits.
A JSON payload is set in the Set Payload transformer.
What is logged by the Logger?
  • A. "Object"
  • B. "JSON"
  • C. "String"
  • D. "Array"
NEW QUESTION # 214
What Database expression transforms the input to the output?
  • A.
  • B.
  • C.
  • D.
This kind of questions are best solved with filtering technique. Key thing to note here is XML attributes are always access by @ notation. So in this example orderId can be accessed as @OrderId which makes option 3 and option 4 false. Now difference in optin and option 2 is in mapping of lineItemPrice. Correct syntax to format a String in Numbse is value.price as Number. Hence option 2 is correct
NEW QUESTION # 215
Refer to the exhibits. APIKit router is used to generate the flow components for RAML specification.
The Mule application must be available to REST clients using the two URL's
http://localhost:8081/internal
and http://localhost:8081/external
How many APIKit Router components are generated to handle requests to every endpoint defined in RAML specification?
1.Library.raml
2./books
3.get:
4.post:
5./order:
6.get
7.patch
8./members
9.get:
  • A. 0
  • B. 1
  • C. 2
  • D. 3
NEW QUESTION # 216
In the execution of scatter gather, the"sleep 2 sec" Flow Reference takes about 2 sec to complete, and the
"sleep 8 sec" Flow Reference takes about 8 sec to complete.
About how many sec does it take from the Scatter-Gather is called until the "Set Payload" transformer is called?
  • A. 0
  • B. 1
  • C. 2
  • D. 3
Correct answer is 8 as events are processed in parallel in case of scatter gather router
NEW QUESTION # 217
A company has an API to manage departments, with each department identified by a unique deptld. The API was built with RAML according to MuleSoft best practices.
What isvalid RAML to specify a method to update the details for a specific department?
  • A.
  • B.
  • C.
  • D.
URI parameter is basically used to identify a specific resource or resources
* Here we want toupdate details about specific department, so question is asking 'How to use URI parameter' in RAML
* Correct answer is
/departments:
/{deptId}:
patch:
Reference:https://docs.mulesoft.com/design ... on-problems-raml-10
NEW QUESTION # 218
As the famous saying goes, time is life. Time is so important to everyone because we have to use our limited time to do many things. Especially for candidates to take the Salesforce-MuleSoft-Developer-I exam, time is very precious. They must grasp every minute and every second to prepare for it. From the point of view of all the candidates, our Salesforce-MuleSoft-Developer-I Study Materials give full consideration to this problem. We can send you a link within 5 to 10 minutes after your payment.
Test Salesforce-MuleSoft-Developer-I Preparation: https://www.examsreviews.com/Salesforce-MuleSoft-Developer-I-pass4sure-exam-review.html
What's more, part of that ExamsReviews Salesforce-MuleSoft-Developer-I dumps now are free: https://drive.google.com/open?id=14AE22yCWPppt0cxmzIWw7YoEc9_KQuXO
Posted at 2/4/2026 11:28:46        Only Author  2#
H19-619_V1.0ѧɤϡ99Ϥκϸ^Jpshikenṩޤ ơΤͬ͘褦H19-619_V1.0ԇY˺ϸ񤹤ŤƤޤ ͬrˡѧAϤϡH19-619_V1.0ɥȥȤ1ڤΟoϥåץǩ`Ȥ1ϤθΥåȤṩޤ ޤǤgŤͤȤơΌƥuƷُ뤹뤫ȴH19-619_V1.0ѧƥȤ¤A뤫ɤˤयΥåȤHCSP-Presales-Government Public Services V1.0ܤǤޤ
