Valid ANS-C01 Test Online | ANS-C01 Valid Test Prep
Posted at 1/11/2026 00:41:21
View201
Replies4
P.S. Free 2026 Amazon ANS-C01 dumps are available on Google Drive shared by GetValidTest: https://drive.google.com/open?id=1p-s4GmAWo7KYFI6BViF71Wf91Inv8_s7
Our ANS-C01 exam questions are famous for the good performance and stale operation. Customers usually attach great importance on the function of a product. So after a long period of research and development, our ANS-C01 learning prep has been optimized greatly. We can promise that all of your operation is totally flexible. Even if we come across much technology problems, we have never given up. Also, we take our customers suggestions of the ANS-C01 Actual Test guide seriously. Sometimes, we will receive some good suggestions from our users. Once our researchers regard it possible to realize, we will try our best to perfect the details of the ANS-C01 learning prep. We are keeping advancing with you. You will regret if you do not choose our study materials.
We will definitely not live up to the trust of users in our ANS-C01 study materials. As you know, the users of our ANS-C01 exam questions are all over the world. We have also been demanding ourselves with the highest international standards to support our ANS-C01 training guide in every aspect. First of all, our system is very advanced and will not let your information leak out. It is totally safe to visit our website and buy our ANS-C01 learning prep. You won't worry anything with our services.
ANS-C01 Valid Test Prep - ANS-C01 Reliable Exam BookANS-C01 exam dumps provided by GetValidTest are tested through practice, and are the most correct and the newest practical ANS-C01 test dumps. Our GetValidTest can provide accurate ANS-C01 certification training questions based on extensive research and the experience of real world to make you pass ANS-C01 Certification Exam in a short time. If you purchase our ANS-C01 exam dumps, we will offer free update service within one year.
Amazon AWS Certified Advanced Networking Specialty Exam Sample Questions (Q116-Q121):NEW QUESTION # 116
A company operates its IT services through a multi-site hybrid infrastructure. The company deploys resources on AWS in the us-east-1 Region and in the eu-west-2 Region. The company also deploys resources in its own data centers that are located in the United States (US) and in the United Kingdom (UK). In both AWS Regions, the company uses a transit gateway to connect 15 VPCs to each other. The company has created a transit gateway peering connection between the two transit gateways. The VPC CIDR blocks do not overlap with each other or with IP addresses used within the data centers. The VPC CIDR prefixes can also be aggregated either on a Regional level or for the company's entire AWS environment.
The data centers are connected to each other by a private WAN connection. IP routing information is exchanged dynamically through Interior BGP (iBGP) sessions. The data centers maintain connectivity to AWS through one AWS Direct Connect connection in the US and one Direct Connect connection in the UK.
Each Direct Connect connection is terminated on a Direct Connect gateway and is associated with a local transit gateway through a transit VIF.
Traffic follows the shortest geographical path from source to destination. For example, packets from the UK data center that are targeted to resources in eu-west-2 travel across the local Direct Connect connection. In cases of cross-Region data transfers, such as from the UK data center to VPCs in us-east-1, the private WAN connection must be used to minimize costs on AWS. A network engineer has configured each transit gateway association on the Direct Connect gateway to advertise VPC-specific CIDR IP prefixes only from the local Region. The routes toward the other Region must be learned through BGP from the routers in the other data center in the original, non-aggregated form.
The company recently experienced a problem with cross-Region data transfers because of issues with its private WAN connection. The network engineer needs to modify the routing setup to prevent similar interruptions in the future. The solution cannot modify the original traffic routing goal when the network is operating normally.
Which modifications will meet these requirements? (Choose two.)
- A. Remove all the VPC CIDR prefixes from the list of subnets advertised through the local Direct Connect connection. Add both Regional aggregate IP prefixes to the list of subnets advertised through the Direct Connect connection on both sides of the network. Configure data center routers to make routing decisions based on the BGP communities received.
- B. Add the aggregate IP prefix for the other Region and the local VPC CIDR blocks to the list of subnets advertised through the local Direct Connect connection.
- C. Remove all the VPC CIDR prefixes from the list of subnets advertised through the local Direct Connect connection. Add the company's entire AWS environment aggregate route to the list of subnets advertised through the local Direct Connect connection.
- D. Add the CIDR prefixes from the other Region VPCs and the local VPC CIDR blocks to the list of subnets advertised through the local Direct Connect connection. Configure data center routers to make routing decisions based on the BGP communities received.
- E. Add the aggregate IP prefix for the company's entire AWS environment and the local VPC CIDR blocks to the list of subnets advertised through the local Direct Connect connection.
Answer: C,E
NEW QUESTION # 117
A company has deployed an AWS Network Firewall firewall into a VPC. A network engineer needs to implement a solution to deliver Network Firewall flow logs to the company's Amazon OpenSearch Service (Amazon Elasticsearch Service) cluster in the shortest possible time.
Which solution will meet these requirements?
- A. Create an Amazon Kinesis data stream that includes the Amazon OpenSearch Service (Amazon Elasticsearch Service) cluster as the destination. Configure flow logs for the firewall. Set the Kinesis data stream as the destination for the Network Firewall flow logs.
- B. Create an Amazon S3 bucket. Create an AWS Lambda function to load logs into the Amazon OpenSearch Service (Amazon Elasticsearch Service) cluster. Enable Amazon Simple Notification Service (Amazon SNS) notifications on the S3 bucket to invoke the Lambda function. Configure flow logs for the firewall. Set the S3 bucket as the destination.
- C. Configure flow logs for the firewall. Set the Amazon OpenSearch Service (Amazon Elasticsearch Service) cluster as the destination for the Network Firewall flow logs.
- D. Create an Amazon Kinesis Data Firehose delivery stream that includes the Amazon OpenSearch Service (Amazon Elasticsearch Service) cluster as the destination. Configure flow logs for the firewall Set the Kinesis Data Firehose delivery stream as the destination for the Network Firewall flow logs.
https://aws.amazon.com/blogs/net ... rch-service-part-1/
NEW QUESTION # 118
A company is deploying a non-web application on an AWS load balancer. All targets are servers located on-premises that can be accessed by using AWS Direct Connect. The company wants to ensure that the source IP addresses of clients connecting to the application are passed all the way to the end server.
How can this requirement be achieved?
Response:
- A. Use a Network Load Balancer to automatically preserve the source IP address.
- B. Use a Network Load Balancer and enable the Proxy Protocol v2 attribute.
- C. Use a Network Load Balancer and enable the X-Forwarded-For attribute.
- D. Use an Application Load Balancer to automatically preserve the source IP address in the X-Forwarded- For header.
NEW QUESTION # 119
An insurance company is planning the migration of workloads from its on-premises data center to the AWS Cloud. The company requires end-to-end domain name resolution. Bi-directional DNS resolution between AWS and the existing on-premises environments must be established. The workloads will be migrated into multiple VPCs. The workloads also have dependencies on each other, and not all the workloads will be migrated at the same time.
Which solution meets these requirements?
- A. Configure a public hosted zone for each application VPC, and create the requisite records. Create a set of Amazon Route 53 Resolver inbound and outbound endpoints in an egress VPC. Define Route 53 Resolver rules to forward requests for the on-premises domains to the on-premises DNS resolver. Associate the application VPC private hosted zones with the egress VPC. and share the Route 53 Resolver rules with the application accounts by using AWS Resource Access Manager. Configure the on-premises DNS servers to forward the cloud domains to the Route 53 inbound endpoints.
- B. Configure a private hosted zone for each application VPC, and create the requisite records. Create a set of Amazon Route 53 Resolver inbound and outbound endpoints in an egress VPC. Define Route 53 Resolver rules to forward requests for the on-premises domains to the on-premises DNS resolver. Associate the application VPC private hosted zones with the egress VPC, and share the Route 53 Resolver rules with the application accounts by using AWS Resource Access Manager. Configure the on-premises DNS servers to forward the cloud domains to the Route 53 inbound endpoints.
- C. Configure a private hosted zone for each application VPC, and create the requisite records. Create a set of Amazon Route 53 Resolver inbound and outbound endpoints in an egress VPDefine Route 53 Resolver rules to forward requests for the on-premises domains to the on-premises DNS resolver. Associate the application VPC private hosted zones with the egress VPand s
Creating a private hosted zone for each application VPC and creating the requisite records would enable end-to-end domain name resolution for the resources. Creating a set of Amazon Route 53 Resolver inbound and outbound endpoints in an egress VPC would enable bi-directional DNS resolution between AWS and the existing on-premises environments. Defining Route 53 Resolver rules to forward requests for the on-premises domains to the on-premises DNS resolver would enable DNS queries from AWS resources to on-premises resources. Associating the application VPC private hosted zones with the egress VPC and sharing the Route 53 Resolver rules with the application accounts by using AWS Resource Access Manager would enable DNS queries among different VPCs and accounts. Configuring the on-premises DNS servers to forward the cloud domains to the Route 53 inbound endpoints would enable DNS queries from on-premises resources to AWS resources1.
NEW QUESTION # 120
True or false: A VPC contains multiple subnets, where each subnet can span multiple Availability Zones.
Response:
- A. This is true.
- B. This is false.
- C. This is true only for US regions.
- D. This is true only if requested during the set-up of VPC.
NEW QUESTION # 121
The chance to examine the content of the ANS-C01 practice material before purchasing it will give you peace of mind. So, try a free demo to evaluate the authenticity of the Amazon ANS-C01 Exam product. GetValidTest forewarns you that the topics of the Amazon ANS-C01 test change from time to time.
ANS-C01 Valid Test Prep: https://www.getvalidtest.com/ANS-C01-exam.html
Amazon Valid ANS-C01 Test Online It won't happen if you name them and we don't have them, And you will receive the downloading link and password within ten minutes after purchasing the ANS-C01 exam dumps, Amazon ANS-C01 certification exams play a significant role to verify skills, experience, and knowledge in a specific technology, So do not hesitate and hurry to buy our ANS-C01 study materials!
Framing the Challenges, Part of the IT Best ANS-C01 Practices Microsoft Press series, It won't happen if you name them and we don't have them, And you will receive the downloading link and password within ten minutes after purchasing the ANS-C01 Exam Dumps.
User-Friendly Amazon ANS-C01 Exam Questions in PDF FormatAmazon ANS-C01 certification exams play a significant role to verify skills, experience, and knowledge in a specific technology, So do not hesitate and hurry to buy our ANS-C01 study materials!
We have already prepared our ANS-C01 training materials for you.
- 2026 Amazon Authoritative Valid ANS-C01 Test Online 🌽 Search for { ANS-C01 } and download it for free immediately on ⏩ [url]www.prep4sures.top ⏪ 🌑ANS-C01 Reliable Exam Braindumps[/url]
- Mock ANS-C01 Exam 🔅 ANS-C01 Real Sheets 🏋 ANS-C01 Pass Exam 📜 Search for ➠ ANS-C01 🠰 and obtain a free download on { [url]www.pdfvce.com } 📩ANS-C01 Test Simulator Free[/url]
- Pass Guaranteed Quiz Amazon - Accurate Valid ANS-C01 Test Online 🍇 Search for ✔ ANS-C01 ️✔️ and obtain a free download on [url]www.practicevce.com 🕌ANS-C01 Exam Registration[/url]
- 2026 Amazon Authoritative Valid ANS-C01 Test Online 🚊 Search for { ANS-C01 } and download exam materials for free through ✔ [url]www.pdfvce.com ️✔️ 🚘Reliable ANS-C01 Test Review[/url]
- Pass Guaranteed Quiz Amazon - Accurate Valid ANS-C01 Test Online 🥱 Search for ☀ ANS-C01 ️☀️ and easily obtain a free download on { [url]www.pass4test.com } ☯ANS-C01 Pass Exam[/url]
- ANS-C01 Exam Registration 🥙 Exam ANS-C01 Learning 🌐 Mock ANS-C01 Exam 📀 Open [url]www.pdfvce.com enter ANS-C01 and obtain a free download 🎐ANS-C01 Current Exam Content[/url]
- ANS-C01 Prep Torrent - ANS-C01 Latest Questions - ANS-C01 Vce Guide 🔲 Search for ▛ ANS-C01 ▟ and obtain a free download on { [url]www.prep4sures.top } 🌃ANS-C01 Current Exam Content[/url]
- Valid ANS-C01 Test Online - AWS Certified Advanced Networking Specialty Exam Realistic Valid Test Prep Pass Guaranteed Quiz 🏡 Search for ➡ ANS-C01 ️⬅️ and download it for free on [url]www.pdfvce.com website 😹ANS-C01 Pdf Braindumps[/url]
- ANS-C01 Exam Registration 🐳 Latest ANS-C01 Mock Exam 🚰 ANS-C01 Latest Braindumps Ppt 🍸 Open ⇛ [url]www.practicevce.com ⇚ and search for ⏩ ANS-C01 ⏪ to download exam materials for free 💃Reliable ANS-C01 Test Review[/url]
- Amazon ANS-C01 Dumps - Hassle-Free Accomplishment ⛅ Search for ANS-C01 and download exam materials for free through ➤ [url]www.pdfvce.com ⮘ 👘ANS-C01 Latest Braindumps Ppt[/url]
- ANS-C01 Latest Braindumps Ppt 🐇 ANS-C01 Latest Braindumps Ppt 🍞 ANS-C01 Trustworthy Exam Content 🦟 Simply search for ☀ ANS-C01 ️☀️ for free download on ⮆ [url]www.examcollectionpass.com ⮄ 🚂Exam ANS-C01 Learning[/url]
- myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, stackblitz.com, www.stes.tyc.edu.tw, lms.treasurehall.net, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, Disposable vapes
2026 Latest GetValidTest ANS-C01 PDF Dumps and ANS-C01 Exam Engine Free Share: https://drive.google.com/open?id=1p-s4GmAWo7KYFI6BViF71Wf91Inv8_s7
