Microsoft MD-102 All-in-One Exam Guide Practice for MD-102 exam success
Posted at 1/11/2026 02:04:24
View165
Replies3
DOWNLOAD the newest Braindumpsqa MD-102 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1AAPn8Zw6Du0lh_WOgdCrGrSuHy0goJ-9
When preparing to take the Endpoint Administrator (MD-102) exam dumps, knowing where to start can be a little frustrating, but with Braindumpsqa Microsoft MD-102 practice questions, you will feel fully prepared. Using our Microsoft MD-102 practice test software, you can prepare for the increased difficulty on Microsoft MD-102 Exam day. Plus, we have various question types and difficulty levels so that you can tailor your Endpoint Administrator (MD-102) exam dumps preparation to your requirements.
Braindumpsqa's Microsoft MD-102 exam training materials' simulation is particularly high. You can encounter the same questions in the real real exam. This only shows that the ability of our IT elite team is really high. Now many ambitious IT staff to make their own configuration files compatible with the market demand, to realize their ideals through these hot IT exam certification. Achieved excellent results in the Microsoft MD-102 Exam. With the Microsoft MD-102 exam training of Braindumpsqa, the door of the dream will open for you.
100% Pass 2026 MD-102: Useful Latest Endpoint Administrator Exam BookTo make sure your situation of passing the certificate efficiently, our MD-102 practice materials are compiled by first-rank experts. So the proficiency of our team is unquestionable. They help you review and stay on track without wasting your precious time on useless things. They handpicked what the MD-102 Study Guide usually tested in exam recent years and devoted their knowledge accumulated into these MD-102 actual tests.
Microsoft Endpoint Administrator Sample Questions (Q118-Q123):NEW QUESTION # 118
Hotspot Question
You have 100 Windows 10 devices that are managed by using Microsoft Endpoint Manager.
You plan to sideload an app to the devices.
You need to configure Microsoft Endpoint Manager to enable sideloading.
Which device profile type and setting should you configure? To answer, select the appropriate options in the answer area.
Box 1: Device restrictions
In a Windows 10/11 device restrictions profile, most configurable settings are deployed at the device level using device groups. Policies deployed to user groups apply to targeted users. The policies also apply to users who have an Intune license, and users that sign in to that device.
Box 2: Trusted app installation
Trusted app installation: Choose if non-Microsoft Store apps can be installed, also known as sideloading. Sideloading is installing, and then running or testing an app that isn't certified by the Microsoft Store. For example, an app that is internal to your company only.
https://docs.microsoft.com/en-us ... rictions-windows-10
NEW QUESTION # 119
You have 200 computers that run Windows 10 and are joined to an Active Directory domain.
You need to enable Windows Remote Management (WinRM) on all the computers by using Group Policy.
Which three actions should you perform? Each correct answer presents part of the solution.
- A. Enable the Allow Remote Shell access setting.
- B. Enable the Windows Defender Firewall: Allow inbound remote administration exception setting.
- C. Set the Startup Type of the Windows Remote Management (WS-Management) service to Automatic.
- D. Set the Startup Type of the Remote Registry service to Automatic
- E. Enable the Windows Defender Firewall: Allow inbound Remote Desktop exceptions setting.
- F. Enable the Allow remote server management through WinRM setting.
Answer: B,C,F
To enable WinRM on domain computers using Group Policy, you need to perform the following actions:
Enable the Allow remote server management through WinRM setting under Computer Configuration > Policies > Administrative Templates > Windows Components > Windows Remote Management (WinRM) > WinRM Service. This setting allows you to specify the IP address ranges that can connect to the WinRM service.
Set the Startup Type of the Windows Remote Management (WS-Management) service to Automatic under Computer Configuration > Preferences > Control Panel Settings > Services. This setting ensures that the WinRM service starts automatically on the computers.
Enable the Windows Defender Firewall: Allow inbound remote administration exception setting under Computer Configuration > Policies > Security Settings > Windows Firewall and Advanced Security > Windows Firewall and Advanced Security > Inbound Rules. This setting creates a firewall rule that allows incoming TCP connections on port 5985 for WinRM. References: How to Enable WinRM via Group Policy, Installation and configuration for Windows Remote Management
NEW QUESTION # 120
You have a server named Server1 and computers that run Windows 8.1. Server1 has the Microsoft Deployment Toolkit (MDT) installed.
You plan to upgrade the Windows 8.1 computers to Windows 10 by using the MDT deployment wizard.
You need to create a deployment share on Server1.
What should you do on Server1, and what are the minimum components you should add to the MDT deployment share? To answer, select the appropriate options in the answer area.
Box 1: Install the Windows Deployment Services role.
Install and initialize Windows Deployment Services (WDS)
On the server:
Open an elevated Windows PowerShell prompt and enter the following command:
Install-WindowsFeature -Name WDS -IncludeManagementTools
WDSUTIL /Verbose /Progress /Initialize-Server /Server:MDT01 /RemInst:"D:RemoteInstall" WDSUTIL /Set-Server /AnswerClients:All Box 2: Windows 10 image and task sequence only Create the reference image task sequence In order to build and capture your Windows 10 reference image for deployment using MDT, you will create a task sequence.
https://docs.microsoft.com/en-us ... indows-deployment-w
https://docs.microsoft.com/en-us ... ws-10-reference-ima
NEW QUESTION # 121
You have a Microsoft 365 E5 subscription and use Microsoft Intune.
You purchase 50 Windows devices.
You configure automatic enrollment to Intune for Microsoft Entra joined devices.
You need to use a provisioning package to join the devices to Microsoft Entra.
What should you use to create the provisioning package, and what is the maximum amount of time you can use the package for bulk enrollment? To answer, select the appropriate options in the answer area.
NEW QUESTION # 122
You have a Microsoft 365 E5 subscription that includes Microsoft Intune.
You need to configure a compliance policy for the iOS/iPadOS platform. The solution must meet the following requirements:
* Require jailbroken devices to be marked as noncompliant.
* Mark devices without a password lock as noncompliant.
Which compliance policy settings should you configure for each requirement? To answer, select the appropriate options in the answer area.
NEW QUESTION # 123
The second form is Endpoint Administrator (MD-102) web-based practice test. It can be attempted through online browsing, and you can prepare via the internet. The MD-102 web-based practice test can be taken from Firefox, Microsoft Edge, Google Chrome, and Safari. You don't need to install or use any plugins or software to take the MD-102 web-based practice exam. Furthermore, you can take this online mock test via any operating system.
Latest MD-102 Exam Dumps: https://www.braindumpsqa.com/MD-102_braindumps.html
Please pay attention to MD-102 training study material which will bring you to the right way, Our MD-102 practice torrent can broaden your horizon and realize your potential of making great progress, I don't know where you heard about MD-102 actual exam, but you must know that there are many users of our MD-102 study materials, Microsoft Latest MD-102 Exam Book If the clients can't receive the mails they can contact our online customer service and they will help them solve the problem.
A few minor changes can have a significant impact on your findability and isn't Latest MD-102 Exam Book that worth the effort, after all, This is a powerful feature that allows the thread to interact with securable objects using a client's security context.
Excellent Latest MD-102 Exam Book to Obtain Microsoft CertificationPlease pay attention to MD-102 training study material which will bring you to the right way, Our MD-102 practice torrent can broaden your horizon and realize your potential of making great progress.
I don't know where you heard about MD-102 actual exam, but you must know that there are many users of our MD-102 study materials, If the clients can't receive the mails MD-102 they can contact our online customer service and they will help them solve the problem.
So your task is just practicing on our MD-102 test engine.
- MD-102 Valid Braindumps Ppt 🌗 MD-102 Valid Braindumps Book 🕑 MD-102 Test Sample Questions 🦲 Copy URL [url]www.examcollectionpass.com open and search for ➤ MD-102 ⮘ to download for free 🍴Valid Test MD-102 Test[/url]
- High Pass Rate Endpoint Administrator Test Torrent is Convenient to Download - Pdfvce ⌛ Search for ➽ MD-102 🢪 and download it for free immediately on ✔ [url]www.pdfvce.com ️✔️ 🛃MD-102 Reliable Test Prep[/url]
- MD-102 PDF Dumps - Effortless Solution To Pass Exam 🍙 Easily obtain ⏩ MD-102 ⏪ for free download through { [url]www.examcollectionpass.com } 👐MD-102 Valid Braindumps Ppt[/url]
- High Pass Rate Endpoint Administrator Test Torrent is Convenient to Download - Pdfvce 🙎 Open ⇛ [url]www.pdfvce.com ⇚ enter MD-102 and obtain a free download 🐐MD-102 Dumps Free[/url]
- MD-102 Latest Exam Book 🎭 New MD-102 Braindumps Free 👜 MD-102 Test Dumps Demo ⏮ Easily obtain MD-102 for free download through ⏩ [url]www.pdfdumps.com ⏪ 🐯Study MD-102 Test[/url]
- 100% Pass-Rate Latest MD-102 Exam Book Help You to Get Acquainted with Real MD-102 Exam Simulation 🐕 Search for ▷ MD-102 ◁ and download exam materials for free through [url]www.pdfvce.com 🔪Exam Questions MD-102 Vce[/url]
- MD-102 Latest Exam Book 🏟 Valid Braindumps MD-102 Ppt 👽 MD-102 Valid Braindumps Ppt 👗 Search for [ MD-102 ] and obtain a free download on ☀ [url]www.examdiscuss.com ️☀️ 🥨MD-102 Test Dumps Pdf[/url]
- MD-102 PDF Dumps - Effortless Solution To Pass Exam 🔰 Download ▛ MD-102 ▟ for free by simply searching on ➽ [url]www.pdfvce.com 🢪 ⤵Study MD-102 Test[/url]
- MD-102 Reliable Mock Test ⛰ MD-102 Test Sample Questions 👊 MD-102 Reliable Dumps Sheet 🐯 Go to website ✔ [url]www.torrentvce.com ️✔️ open and search for ⮆ MD-102 ⮄ to download for free 🦧MD-102 Test Answers[/url]
- High Pass Rate Endpoint Administrator Test Torrent is Convenient to Download - Pdfvce 👙 Copy URL ⮆ [url]www.pdfvce.com ⮄ open and search for ⇛ MD-102 ⇚ to download for free ⏹MD-102 Dumps Free[/url]
- MD-102 Test Sample Questions 🥋 MD-102 Dumps Free 🧞 MD-102 Test Dumps Pdf 🟫 Easily obtain ➥ MD-102 🡄 for free download through [url]www.exam4labs.com 🖌MD-102 Valid Braindumps Ppt[/url]
- leantheprocess.com, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, bbs.t-firefly.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, pct.edu.pk, www.stes.tyc.edu.tw, ncon.edu.sa, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, Disposable vapes
P.S. Free & New MD-102 dumps are available on Google Drive shared by Braindumpsqa: https://drive.google.com/open?id=1AAPn8Zw6Du0lh_WOgdCrGrSuHy0goJ-9
