[General] Identity-and-Access-Management-Architect New Real Test | Identity-and-Access-Man
62
General Identity-and-Access-Management-Architect New Real Test | Identity-and-Access-Man
Posted at 1/11/2026 02:05:26      View379 | Replies5        Print      Only Author   [Copy Link] 1#
P.S. Free & New Identity-and-Access-Management-Architect dumps are available on Google Drive shared by GetValidTest: https://drive.google.com/open?id=1P-P_ugtwg2hDnC0aCVve5Ayp2ogZr5UP
Having a good command of professional knowledge for customers related to this Identity-and-Access-Management-Architect exam is of superior condition. However, that is not certain and sure enough to successfully pass this exam. You need efficiency and exam skills as well. Actually, a great majority of exam candidates feel abstracted at this point, wondering which one is the perfect practice material they are looking for. We have gained high appraisal for the high quality Identity-and-Access-Management-Architect Guide question and considerate serves. All content is well approved by experts who are arduous and hardworking to offer help. They eliminate banal knowledge and exam questions out of our Identity-and-Access-Management-Architect real materials and add new and essential parts into them. And they also fully analyzed your needs of Identity-and-Access-Management-Architect exam dumps all the time.
Free demo is available for Salesforce Identity-and-Access-Management-Architect training materials, so that you can have a better understanding of what you are going to buy. Free demo will represent you what the complete version is like. We suggest you try free domo before buying. In addition, Salesforce Certified Identity and Access Management Architect Identity-and-Access-Management-Architect Training Materials are high quality and accuracy, since we have a professional team to collect the latest information of the exam.
Salesforce Identity-and-Access-Management-Architect Test Book, Identity-and-Access-Management-Architect Exam PDFsimulation tests of our Identity-and-Access-Management-Architect learning materials have the functions of timing and mocking exams, which will allow you to adapt to the exam environment in advance and it will be of great benefit for subsequent exams. After you complete the learning task, the system of our Identity-and-Access-Management-Architect test prep will generate statistical reports based on your performance so that you can identify your weaknesses and conduct targeted training and develop your own learning plan. For the complex part of our Identity-and-Access-Management-Architect Exam Question, you may be too cumbersome, but our system has explained and analyzed this according to the actual situation to eliminate your doubts and make you learn better.
Salesforce Certified Identity and Access Management Architect Sample Questions (Q160-Q165):NEW QUESTION # 160
Universal Containers (UC) is considering a Customer 360 initiative to gain a single source of the truth for its customer data across disparate systems and services. UC wants to understand the primary benefits of Customer
360 Identity and how it contributes ato successful Customer 360 Truth project.
What are two are key benefits of Customer 360 Identity as it relates to Customer 360?
Choose 2 answers
  • A. Customer 360 Identity not only provides a unified sign up and sign in experience, but also tracks anonymous user activity prior to signing up so organizations can understand user activity before and after the users identify themselves.
  • B. Customer 360 Identity supports multiple brands so you can deliver centralized identity services and correlation of user activity, even if it spans multiple corporate brands and user experiences.
  • C. Customer 360 Identity automatically integrates with Customer 360 Data Manager and Customer 360 Audiences to seamlessly populate all user data.
  • D. Customer 360 Identity enables an organization to build a single login for each of its customers, giving the organization an understanding of the user's login activity across all its digital properties and applications.
NEW QUESTION # 161
Universal containers (UC) has built a custom based Two-factorAuthentication (2fa) system for their existing on-premise applications. Thru are now implementing salesforce and would like to enable a Two-factor login process for it, as well. What is the recommended solution an architect should consider?
  • A. Replace thecustom 2fa system with salesforce 2fa for on-premise application and salesforce.
  • B. Replace the custom 2fa system with an app exchange app that supports on-premise applications and salesforce.
  • C. Use the custom 2fa system for on-premise applications and native 2fa for salesforce.
  • D. Use custom login flows to connect to the existing custom 2fa system for use in salesforce.
Using custom login flows to connect to the existing custom 2fa system for use in salesforce is the recommended solution because it allows you to leverage your existing 2fa infrastructure and provide a consistent user experience across your applications. Custom login flows let you customize the authentication process by adding extra screens or logic before or after the standard login1. You can use Apex code to call your custom 2fa system and verify the user's identity2. This option also gives you moreflexibility and control over the2fa process than using native 2fa or an app exchange app3. References: 1: Customize User Authentication with Login Flows 2: Custom Login Flow Examples 3: Salesforce Multi-Factor Authentication
NEW QUESTION # 162
Universal Containers (UC) wants to integrate a third-party Reward Calculation system with Salesforce to calculate Rewards. Rewards will be calculated on a schedule basis and update back into Salesforce. The integration between Salesforce and the Reward Calculation System needs to be secure. Which are two recommended practices for using OAuth flow in this scenario. choose 2 answers
  • A. OAuth Username-Password Flow
  • B. OAuth Refresh Token FLow
  • C. OAuth JWT Bearer Token FLow
  • D. OAuth SAML Bearer Assertion FLow
OAuth is an open-standard protocol that allows a client app to access protected resources on a resource server, such as Salesforce API, by obtaining an access token from an authorization server. OAuth supports different types of flows, which are ways of obtaining an access token. For integrating a third-party Reward Calculation system with Salesforce securely, two recommended practices for using OAuth flow are:
OAuth SAML Bearer Assertion Flow, which allows the client app to use a SAML assertion issued by a trusted identity provider to request an access token from Salesforce. This flow does not require the client app to store any credentials or secrets, and leverages the existing SSO infrastructure between Salesforce and the identity provider.
OAuth JWT Bearer Token Flow, which allows the client app to use a JSON Web Token (JWT) signed by a private key to request an access token from Salesforce. This flow does not require any user interaction or consent, and uses a certificate to verify the identity of the client app.
Verified References: [OAuth 2.0 SAML Bearer Assertion Flow for Server-to-Server Integration], [OAuth 2.0 JWT Bearer Token Flow for Server-to-Server Integration]
NEW QUESTION # 163
Northern Trail Outfitters (NTO) uses the Customer 360 Platform implemented on Salesforce Experience Cloud. The development team in charge has learned of a contactless user feature, which can reduce the overhead of managing customers and partners by creating users without contact information.
What is the potential impact to the architecture if NTO decides to implement this feature?
  • A. If contactless user is upgraded to Community license, the contact record is automatically created and linked to the user record, but not associated with an Account.
  • B. Contactless user feature is available only with the External Identity license, which can restrict the Experience Cloud functionality available to the user.
  • C. Passwordless authentication can not be supported because the mobile phone receiving one-time password (OTP) needs to match the number on the contact record.
  • D. Custom registration handler is needed to correctly assign External Identity or Community license for the newly registered contactless user.
NEW QUESTION # 164
A public sector agency is setting up an identity solution for its citizens using a Community built on Experience Cloud and requires the new user registration functionality to capture first name, last name, and phone number.
The phone number will be used for identity verification.
Which feature should an identity architect recommend to meet the requirements?
  • A. Integrate with social websites (Facebook, Linkedin. Twitter)
  • B. Use an external Identity Provider
  • C. Create a custom Lightning Web Component
  • D. Use Login Discovery
NEW QUESTION # 165
Identity-and-Access-Management-Architect guide materials really attach great importance to the interests of users. In the process of development, it also constantly considers the different needs of users. According to your situation, our Identity-and-Access-Management-Architect study materials will tailor-make different materials for you. And the content of the Identity-and-Access-Management-Architect Exam Questions is always the latest information contained for our technicals update the questions and answers in the first time.
Identity-and-Access-Management-Architect Test Book: https://www.getvalidtest.com/Identity-and-Access-Management-Architect-exam.html
A: Absolutely, GetValidTest is providing regular free Identity-and-Access-Management-Architect exam dumps updates for the actual Salesforce Certified Identity and Access Management Architect exam questions, Salesforce Identity-and-Access-Management-Architect New Real Test As you know the passing rate of them has come up to 98-100 percent with an increasingly trend, Salesforce Identity-and-Access-Management-Architect New Real Test All what we do is to serve you best, For well prep of Identity-and-Access-Management-Architect exam certification, you should treat Identity-and-Access-Management-Architect exam prep material seriously.
Or the product may be too complex to be made Identity-and-Access-Management-Architect in bulk with consistent high quality by employees, Moving Among Open Apps, A: Absolutely, GetValidTest is providing regular free Identity-and-Access-Management-Architect exam dumps updates for the actual Salesforce Certified Identity and Access Management Architect exam questions.
Salesforce certification Identity-and-Access-Management-Architect exam free exercises updatesAs you know the passing rate of them has come up to 98-100 percent with an increasingly trend, All what we do is to serve you best, For well prep of Identity-and-Access-Management-Architect exam certification, you should treat Identity-and-Access-Management-Architect exam prep material seriously.
BTW, DOWNLOAD part of GetValidTest Identity-and-Access-Management-Architect dumps from Cloud Storage: https://drive.google.com/open?id=1P-P_ugtwg2hDnC0aCVve5Ayp2ogZr5UP
Posted at 1/18/2026 00:31:14        Only Author  2#
I was completely taken by that article. I earned a promotion and salary increase using this Generative-AI-Leader valid exam practice. Now, Im sharing it for free. Wishing you success in your career progress!
Posted at 1/22/2026 06:58:28        Only Author  3#
Your article has made a lasting impression, thank you! Enhance your IT knowledgefree C_P2WWM_2023 latest practice exam online shared! Wishing you success!
Posted at 1/22/2026 20:54:27        Only Author  4#
Im thankful for this inspiring article, its truly motivational! The NS0-005 Actual tests exam is nearly here. Hoping for a smooth experience!
Posted at 1/26/2026 05:44:13        Only Author  5#
No hesitation, just hitting like for this great content. The DP-700 reliable dumps free download exam is around the corner. Fingers crossed for success!
Posted at 1/31/2026 16:02:20        Only Author  6#
Im in awe of this article, thank you for sharing it with us! The Latest NCP-EUC exam cram test questions are free for allyour key to a successful career!
