[General] C_ABAPD_2507日本語関連対策 & C_ABAPD_2507試験問題
102
【General】 C_ABAPD_2507日本語関連対策 & C_ABAPD_2507試験問題
Posted at 1/11/2026 02:55:16      View:167 | Replies:3        Print      Only Author   [Copy Link] 1#
P.S.JpexamがGoogle Driveで共有している無料の2026 SAP C_ABAPD_2507ダンプ:https://drive.google.com/open?id=1w9my0YmJ5UH_Mo8U1bv6_xNFzGHGsJWQ
昇進の機会を得て仕事に就きたいと考えているなら、当社からC_ABAPD_2507学習問題を選択するのが最良の選択のチャンスになります。なぜなら、C_ABAPD_2507学習教材には、あなたが自分自身を改善し、他の人よりも優れたものにするのに役立つ十分な能力があるからです。当社のC_ABAPD_2507学習教材は、多くの人々が認定を取得し、夢を実現するのに役立ちました。また、当社のC_ABAPD_2507テストガイドに連絡する機会もあります。
SAP C_ABAPD_2507 認定試験の出題範囲:
トピック出題範囲
トピック 1
  • ABAP Core Data Services and Data Modeling: This section of the exam measures skills of SAP ABAP Developers and covers the creation, definition, and use of Core Data Services (CDS) views for data modeling within SAP environments. Candidates are expected to understand annotations, data definitions, and the role of CDS in enabling advanced data processing and integration across SAP systems.
トピック 2
  • ABAP RESTful Application Programming Model: This section of the exam measures skills of SAP Application Programmers and covers the fundamentals of the ABAP RESTful Application Programming Model (RAP). It includes topics such as behavior definitions, service binding, and the use of managed and unmanaged scenarios. The focus is on building modern, scalable, and cloud-ready applications using RAP.
トピック 3
  • Object-Oriented Design: This section of the exam measures skills of SAP ABAP Developers and covers the basics of object-oriented programming in ABAP. It includes concepts such as classes, interfaces, inheritance, polymorphism, and encapsulation, all of which are necessary for building robust and scalable ABAP applications.
トピック 4
  • Core ABAP Programming: This section of the exam measures skills of SAP Application Programmers and covers foundational ABAP programming knowledge. Topics include modularization techniques, internal tables, control structures, and classical report programming. Mastery of these concepts is essential for building efficient ABAP applications.
SAP C_ABAPD_2507試験問題、C_ABAPD_2507試験合格攻略テスト用のC_ABAPD_2507認定を準備する際に、C_ABAPD_2507試験リファレンスのように高い効率と合格率を高めることができる学習教材はありません。 C_ABAPD_2507試験の練習問題では、最も信頼性の高い試験情報リソースと最も認定された専門家の検証を提供しています。テストバンクには、実際の試験に含まれる可能性のあるすべての質問と回答、および過去の試験問題の本質と要約が含まれています。最も簡単な言語を使用して、学習者にC_ABAPD_2507試験の参照を理解させ、C_ABAPD_2507試験に合格するよう努めています。
SAP Certified Associate - Back-End Developer - ABAP Cloud 認定 C_ABAPD_2507 試験問題 (Q24-Q29):質問 # 24
Setting a field to read-only in which object would make the field read-only in all applications of the RESTful Application Programming model?
  • A. Metadata extension
  • B. Projection view
  • C. Service definition
  • D. Behaviour definition
The object that can be used to set a field to read-only in all applications of the RESTful Application Programming model (RAP) is the behaviour definition. The behaviour definition is a CDS artefact that defines the business logic and the UI behaviour of a business object. A business object is a CDS entity that represents a business entity or concept, such as a customer, an order, or a product. The behaviour definition can specify the properties of the fields of a business object, such as whether they are mandatory, read-only, or transient. These properties are valid for all applications that use the business object, such as transactional, analytical, or draft-enabled apps12. For example:
The following code snippet defines a behaviour definition for a business object ZI_PB_APPLICATION. It sets the field APPLICATION to read-only for all applications that use this business object:
define behavior for ZI_PB_APPLICATION { field ( read only ) APPLICATION; ... } You cannot do any of the following:
A . Service definition: A service definition is a CDS artefact that defines the interface and the binding of a service. A service is a CDS entity that exposes the data and the functionality of one or more business objects as OData, InA, or SQL services. A service definition can specify the properties of the fields of a service, such as whether they are filterable, sortable, or aggregatable. However, these properties are only valid for the specific service that uses the business object, not for all applications that use the business object12.
C . Projection view: A projection view is a CDS artefact that defines a view on one or more data sources, such as tables, views, or associations. A projection view can select, rename, or aggregate the fields of the data sources, but it cannot change the properties of the fields, such as whether they are read-only or not. The properties of the fields are inherited from the data sources or the behaviour definitions of the business objects12.
D . Metadata extension: A metadata extension is a CDS artefact that defines additional annotations for a CDS entity, such as a business object, a service, or a projection view. A metadata extension can specify the properties of the fields of a CDS entity for UI or analytical purposes, such as whether they are visible, editable, or hidden. However, these properties are only valid for the specific UI or analytical application that uses the metadata extension, not for all applications that use the CDS entity12.
質問 # 25
In the assignment, data (gv_result) = 1/8. what will be the data type of gv_result?
  • A. TYPE DEFLOAT 16
  • B. OTYPE I
  • C. TYPE P DECIMALS 3
  • D. TYPE P DECIMALS 2
The data type of gv_result in the assignment data (gv_result) = 1/8 will be TYPE DECFLOAT 16. This is because the assignment operator (=) in ABAP performs an implicit type conversion from the source type to the target type, according to the following rules12:
If the target type is specified explicitly, the source value is converted to the target type.
If the target type is not specified explicitly, the source type is used as the target type, unless the source type is a literal or an expression, in which case the target type is determined by the following priority order: DECFLOAT34, DECFLOAT16, P, F, I, C, N, X, STRING, XSTRING.
In this case, the target type is not specified explicitly, and the source type is an expression (1/8). Therefore, the target type is determined by the priority order, and the first matching type is DECFLOAT16, which is a decimal floating point type with 16 digits of precision12.
質問 # 26
Which of the following types of Core Data Services Views can be used at the consumption layer? Note: There are 3 correct answers to this question.
  • A. Transactional Interface
  • B. Transactional Query
  • C. Hierarchy
  • D. Table Function
  • E. Analytical Query
正解:C、D、E
質問 # 27
Given the following Core Data Service View Entity Data Definition,
when you attempt to activate the definition, what will be the response?
  • A. Activation successful
  • B. Activation error because the field types of the union do not match
  • C. Activation error because the field names of the union do not match
  • D. Activation error because the key fields of the union do not match
質問 # 28
Which of the following are parts of answers to this question.
  • A. Extension
  • B. Field list
  • C. Semantic table attributes
  • D. Partitioning attributes
正解:A、B
A CDS view is a data definition that defines a data structure and a data selection from one or more data sources. A CDS view consists of several parts, but two of them are:
Extension: An extension is an optional clause that allows a CDS view to extend another CDS view by adding new elements, annotations, or associations. The extension clause has the syntax EXTEND VIEW view_name WITH view_name. The first view_name is the name of the CDS view that is being extended, and the second view_name is the name of the CDS view that is doing the extension1.
Field list: A field list is a mandatory clause that specifies the elements of the CDS view. The field list has the syntax SELECT FROM data_source { element_list }. The data_source is the name of the data source that the CDS view selects data from, and the element_list is a comma-separated list of elements that the CDS view exposes. The elements can be fields of the data source, expressions, associations, or annotations2.
The following example shows a CDS view that extends another CDS view and defines a field list:
@AbapCatalog.sqlViewName: 'ZCDS_EXT' define view Z_CDS_Extension extend view Z_CDS_Base with Z_CDS_Extension as select from ztable { // field list key ztable.id as ID, ztable.name as Name, ztable.age as Age, // extension @Semantics.currencyCode: true ztable.currency as Currency } The other options are not parts of a CDS view, but rather related concepts:
Partitioning attributes: Partitioning attributes are attributes that are used to partition a table into smaller subsets of data. Partitioning attributes are defined in the ABAP Dictionary for transparent tables and can improve the performance and scalability of data access. Partitioning attributes are not part of the CDS view definition, but rather the underlying table definition3.
Semantic table attributes: Semantic table attributes are attributes that provide additional information about the meaning and usage of a table. Semantic table attributes are defined in the ABAP Dictionary for transparent tables and can be used to enhance the data modeling and consumption of the table. Semantic table attributes are not part of the CDS view definition, but rather the underlying table definition4.
質問 # 29
JpexamはIT認定試験を受験した多くの人々を助けました。また、受験生からいろいろな良い評価を得ています。JpexamのC_ABAPD_2507問題集の合格率が100%に達することも数え切れない受験生に証明された事実です。もし試験の準備をするために大変を感じているとしたら、ぜひJpexamのC_ABAPD_2507問題集を見逃さないでください。これは試験の準備をするために非常に効率的なツールですから。この問題集はあなたが少ない労力で最高の結果を取得することができます。
C_ABAPD_2507試験問題: https://www.jpexam.com/C_ABAPD_2507_exam.html
2026年Jpexamの最新C_ABAPD_2507 PDFダンプおよびC_ABAPD_2507試験エンジンの無料共有:https://drive.google.com/open?id=1w9my0YmJ5UH_Mo8U1bv6_xNFzGHGsJWQ
Posted at 1/11/2026 08:35:16        Only Author  2#
Thank you for this amazing article, it left a profound impression on me. Here’s the free Study CWNA-109 Notes test content. Wishing you success!
Posted at 1/18/2026 04:25:46        Only Author  3#
Thank you for your article, it truly left me stunned! I’m offering the Valid test 1Z0-1145-1 fee exam that helped me land my promotion and pay raise. It’s free today—good luck achieving your career goals!
Posted at 2/2/2026 01:50:34        Only Author  4#
That article was a real treasure trove of knowledge. Thanks to the Introduction-to-Biology reliable test objectives pdf, I moved up in my career and got a raise. Now, it’s free for you all. Wishing you promotions ahead!
