[General] FCSS_EFW_AD-7.4 Valid Test Objectives | FCSS_EFW_AD-7.4 Latest Dumps Ebook
102
【General】 FCSS_EFW_AD-7.4 Valid Test Objectives | FCSS_EFW_AD-7.4 Latest Dumps Ebook
Posted at 1/11/2026 03:02:26      View:181 | Replies:1        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Fortinet FCSS_EFW_AD-7.4 dumps are available on Google Drive shared by NewPassLeader: https://drive.google.com/open?id=15vHnV2rFLWo4LCjLLCb0Lyq3-ayzamLC
Are you still worried about you exam? If you do, then trying the FCSS_EFW_AD-7.4 exam torrent of us, we will make it easier for you to pass it successfully. FCSS_EFW_AD-7.4 exam dumps of us are not only have the quality but also have certain quantity, it will be enough for you to deal with your exam. In addition FCSS_EFW_AD-7.4 Online Test engine can record the process of your learning, and you can have a review of what you have learned. FCSS_EFW_AD-7.4 Soft test engine stimulates the real environment of the exam, and you can know what the real exam looks like through this version.
Fortinet FCSS_EFW_AD-7.4 Exam Syllabus Topics:
  • Routing: This section of the exam measures the skills of Security Administrators and covers the implementation of advanced routing protocols to manage enterprise traffic effectively. Candidates will gain expertise in configuring Open Shortest Path First (OSPF) for dynamic routing and Border Gateway Protocol (BGP) to facilitate communication between different networks, ensuring efficient traffic flow across enterprise environments.
  • System Configuration: This section of the exam measures the skills of Network Security Engineers and covers the implementation of the Fortinet Security Fabric, ensuring seamless integration across security solutions. It also includes configuring hardware acceleration on FortiGate devices to optimize performance. Candidates will learn to set up different operation modes for high-availability clusters and implement enterprise networks using VLANs and VDOMs. Additionally, it covers various use case scenarios that demonstrate how Fortinet solutions contribute to secure network environments.
  • Central Management: This section of the exam measures the skills of Security Administrators and focuses on implementing central management for Fortinet security solutions. It includes configuring and managing devices centrally to streamline network security operations. Candidates will understand how to maintain consistency in security policies and automate deployments for efficient management of large-scale enterprise environments.
  • Security Profiles: This section of the exam measures the skills of Network Security Engineers and focuses on managing security inspection profiles, including SSL and SSH inspections. Candidates will learn to apply a combination of web filtering, application control, and Internet Service Database (ISDB) to enhance network security. The section also covers integrating Intrusion Prevention Systems (IPS) to monitor and mitigate threats within enterprise networks.
Topic 5
  • VPN: This section of the exam measures the skills of Network Security Engineers and covers the implementation of secure communication tunnels for enterprise environments. Candidates will learn to configure IPsec VPN with IKE version 2 to establish encrypted connections. The section also includes the implementation of ADVPN to enable on-demand VPN tunnels between different sites, ensuring secure and dynamic connectivity.
Free PDF Quiz 2026 Reliable Fortinet FCSS_EFW_AD-7.4 Valid Test ObjectivesJust like the old saying goes, there is no royal road to success, and only those who do not dread the fatiguing climb of gaining its numinous summits. In a similar way, there is no smoothly paved road to the FCSS_EFW_AD-7.4 certification. You have to work on it and get started from now. If you want to gain the related certification, it is very necessary that you are bound to spend some time on carefully preparing for the FCSS_EFW_AD-7.4 Exam, including choosing the convenient and practical study materials, sticking to study and keep an optimistic attitude and so on.
Fortinet FCSS - Enterprise Firewall 7.4 Administrator Sample Questions (Q66-Q71):NEW QUESTION # 66
Refer to the exhibit, which shows the ADVPN network topology and partial BGP configuration.
Which two parameters must an administrator configure in the config neighbor range for spokes shown in the exhibit? (Choose two.)
  • A. set neighbor-group advpn
  • B. set max-neighbor-num 2
  • C. set prefix 172.16.1.0 255.255.255.0
  • D. set route-reflector-client enable
In the given ADVPN (Auto-Discovery VPN) topology, BGP is being used to dynamically establish routes between spokes. The neighbor-range configuration is crucial for simplifying BGP peer setup by automatically assigning neighbors based on their IP range.
# Theneighbor-groupparameter is used to apply pre-defined settings (such as AS number) to dynamically discovered BGP neighbors.
# Theadvpnneighbor-group is already defined in the configuration, and assigning it to the neighbor-range ensures consistent BGP settings for all spoke neighbors.
# This command allowsdynamic BGP peer discoveryby defining a range of potential neighbor IPs (172.16.1.1 - 172.16.1.255).
# Sinceeach spoke has a unique /32 IPwithin this subnet, this ensures that any spoke within the172.16.1.0/24 range can automatically establish a BGP session with the hub.
NEW QUESTION # 67
Refer to the exhibits.
The configuration of a user's Windows PC, which has a default MTU of 1500 bytes, along with FortiGate interfaces set to an MTU of1000bytes, and the results of PC1 pinging server172.16.0.254are shown.
Why is the user in Windows PC1 unable to ping server172.16.0.254and is seeing the messageacket needs to be fragmented but DF set?
  • A. Fragmented packets must be encrypted. To connect any application successfully, the user must install the Fortinet_CA certificate in the Microsoft Management Console.
  • B. FortiGate honors the do not fragment bit and the packets are dropped. The user has to adjust the ping MTU to 972 to succeed.
  • C. Option ip.flags.mf must be set to enable on FortiGate. The user has to adjust the ping MTU to 1000 to succeed.
  • D. The user must trigger different traffic because path MTU discovery techniques do not recognize ICMP payloads.
The issue occurs because FortiGate enforces the "do not fragment" (DF) bit in the packet, and the packet size exceeds the MTU of the network path. When the Windows PC1 (with an MTU of 1500 bytes) attempts to send a 1400-byte packet, the FortiGate interface (with an MTU of 1000 bytes) needs to fragment it. However, since the DF bit is set, FortiGate drops the packet instead of fragmenting it.
To resolve this, the user should adjust the ping packet size to fit within the path MTU. In this case, reducing the packet size to972 bytes(1000 bytes MTU minus 28 bytes for the IP and ICMP headers) should allow successful transmission.
NEW QUESTION # 68
Which configuration can be used to reduce the number of BGP sessions in an IBGP network?
  • A. Route reflector
  • B. Next-hop-self
  • C. Neighbor range
  • D. Neighbor group
NEW QUESTION # 69
Which of the following steps are executed to get antivirus and IPS updates using the pull method?
(Choose three.)
  • A. FortiGate periodically queries for pending updates.
  • B. FortiGate starts sending rating queries to one of the servers in the list.
  • C. FortiGate gets a list of server IP addresses that can be contacted.
  • D. FortiGate contacts DNS to resolve update.fortiguard.net.
  • E. FortiGate registers its public IP address in FortiGuard.
Answer: A,C,D
NEW QUESTION # 70
View the following exhibit, which contains the sniffer output for a passive mode FTP request.
An administrator has created the following custom IPS signature to block all FTP requests for passive mode: F-SBID (--attack_id 1002; --name "Block.FTP "; --protocol tcp; --flow from_client; --pattern
"ASV"; --no_case;) Soon after the signature is enabled in an active IPS sensor, some false positive detections are generated.
Which option and value pair will allow more specific detection?
  • A. --service ftp
  • B. --name "Block.FTP.PASV"
  • C. --protocol ftp
  • D. --attack_id 1001
NEW QUESTION # 71
The Fortinet FCSS_EFW_AD-7.4 questions certificates are the most sought-after qualifications for those looking to further their careers in the business. To get the Fortinet FCSS_EFW_AD-7.4 exam questions credential, candidates must pass the Fortinet FCSS_EFW_AD-7.4 exam. But what should you do if you want to pass the Fortinet FCSS - Enterprise Firewall 7.4 Administrator exam questions the first time? Fortunately, NewPassLeader provides its users with the most recent and accurate Fortinet FCSS_EFW_AD-7.4 Questions to assist them in preparing for their real FCSS_EFW_AD-7.4 exam. Our Fortinet FCSS_EFW_AD-7.4 exam dumps and answers have been verified by Fortinet certified professionals in the area.
FCSS_EFW_AD-7.4 Latest Dumps Ebook: https://www.newpassleader.com/Fortinet/FCSS_EFW_AD-7.4-exam-preparation-materials.html
BTW, DOWNLOAD part of NewPassLeader FCSS_EFW_AD-7.4 dumps from Cloud Storage: https://drive.google.com/open?id=15vHnV2rFLWo4LCjLLCb0Lyq3-ayzamLC
Posted at 2/22/2026 21:12:11        Only Author  2#
ブラウジング中の支払いのセキュリティが心配ですか? Professional-Data-Engineerテストトレントは、購入プロセスのセキュリティ、製品のダウンロード、インストールを安全でウイルスのないものにすることができます。この点について疑問がある場合は、専門の担当者がインストールと使用をリモートでガイドします。 Professional-Data-Engineerテスト回答の購入プロセスは非常に簡単で、単純な人にとっては大きな恩恵です。Professional-Data-Engineer学習教材の合格率は彼らのものよりもはるかに高いことを保証できます。そしてこれが最も重要です。以前のデータによると、Professional-Data-Engineerトレーニング質問を使用する人の98%〜99%が試験に合格しました。あなたが私たちに信頼を与えてくれるなら、私たちはあなたに成功を与えます。
