Reliable FSCP Exam Registration & Test FSCP Practice
Posted at 1/11/2026 03:50:39
BONUS!!! Download part of PDFTorrent FSCP dumps for free: https://drive.google.com/open?id=17x3umn6K6dYxMzNPNPRm6jhyEtdk3WCX
In order to ensure that the examinees in the FSCP exam certification make good achievements, our PDFTorrent has always been trying our best. With efforts for years, the passing rate of PDFTorrent's FSCP certification exam has reached as high as 100%. After you purchase our FSCP Exam Training materials, if there is any quality problem or you fail FSCP exam certification, we promise to give a full refund unconditionally.
Forescout FSCP Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Plugin Tuning HPS: This section of the exam measures skills of plugin developers and endpoint integration engineers, and covers tuning the Host Property Scanner (HPS) plugin: how to profile endpoints, refine scanning logic, handle exceptions, and ensure accurate host attribute collection for enforcement.
| | Topic 2 | - Advanced Product Topics Certificates and Identity Tracking: This section of the exam measures skills of identity and access control specialists and security engineers, and covers the management of digital certificates, PKI integration, identity tracking mechanisms, and how those support enforcement and audit capability within the system.
| | Topic 3 | - Plugin Tuning User Directory: This section of the exam measures skills of directory services integrators and identity engineers, and covers tuning plugins that integrate with user directories: configuration, mapping of directory attributes to platform policies, performance considerations, and security implications.
| | Topic 4 | - Advanced Troubleshooting: This section of the exam measures skills of operations leads and senior technical support engineers, and covers diagnosing complex issues across component interactions, policy enforcement failures, plugin misbehavior, and end to end workflows requiring root cause analysis and corrective strategy rather than just surface level fixes.
| | Topic 5 | - Plugin Tuning Switch: This section of the exam measures skills of network switch engineers and NAC (network access control) specialists, and covers tuning switch related plugins such as switch port monitoring, layer 2
- 3 integration, ACL or VLAN assignments via network infrastructure and maintaining visibility and control through those network assets.
| | Topic 6 | - Policy Functionality: This section of the exam meas-ures skills of policy implementers and integration specialists, and covers how policies operate within the platform, including dependencies, rule order, enforcement triggers, and how they interact with device classifications and dynamic attributes.
Take a Leap Forward in Your Career by Earning Forescout FSCPAs a busy working person it will cost a lot of time and energy to prepare for upcoming test, what's to be done? You can try our latest Forescout FSCP practice exam online materials. You can know more about exam information and master all valid exam key knowledge points. FSCP Practice Exam Online is excellent product of all examination questions with high passing rate. It will improve your studying efficiency and low exam cost.
Forescout Certified Professional Exam Sample Questions (Q71-Q76):NEW QUESTION # 71
Which of the following are true about the comments field of the CounterACT database? (Choose two)
- A. It can be edited manually by a right click administrator action, or it can be edited in policy by using the action "Run Script on CounterACT"
- B. Endpoints may have exactly one comment assigned to them
- C. It can be edited manually by a right click administrator action, or it can be edited in policy by using the action "Run Script on Windows"
- D. Endpoints may have multiple comments assigned to them
- E. It cannot be edited manually by a right click administrator action, it can only be edited in policy by using the action "Run Script on CounterACT"
Comprehensive and Detailed Explanation From Exact Extract of Forescout Platform Administration and Deployment:
According to the Forescout Administration Guide - Device Information Properties documentation, the correct statements about the comments field are: Endpoints may have multiple comments assigned to them (A) and it can be edited manually by a right click administrator action, or it can be edited in policy by using the action
"Run Script on CounterACT" (C).
Comments Field Overview:
According to the Device Information Properties documentation:
"(Right-click an endpoint in the Detections pane to add a comment. The comment is retained for the life of the endpoint in the Forescout Console.)" Multiple Comments Support:
According to the ForeScout Administration Guide:
Endpoints support multiple comments that can be added over time:
* Manual Comments - Administrators can right-click an endpoint and add comments
* Policy-Generated Comments - Policies can automatically add comments when conditions are met
* Cumulative - Multiple comments are retained and displayed together
* Persistent - Comments are retained for the life of the endpoint
Manual Comments via Right-Click:
According to the documentation:
Administrators can manually edit the comments field by:
* Right-clicking on an endpoint in the Detections pane
* Selecting "Add comment" or "Edit comment" option
* Entering the comment text
* Saving the comment
This manual method is readily available and frequently used for operational notes.
Policy-Based Comments via "Run Script on CounterACT":
According to the Administration Guide:
Policies can also edit the comments field using the "Run Script on CounterACT" action:
* Create or edit a policy
* Add the "Run Script on CounterACT" action
* The script can modify the Comments host property
* When the policy condition is met, the script runs and updates the comment field Why Other Options Are Incorrect:
* B. Cannot be edited manually...only via Run Script on CounterACT - Incorrect; manual right-click editing is explicitly supported
* D. Endpoints may have exactly one comment - Incorrect; multiple comments are supported
* E. Can be edited...by using action "Run Script on Windows" - Incorrect; the action is "Run Script on CounterACT," not "Run Script on Windows" Comments Field Characteristics:
The Comments field:
* Supports Multiple Entries - More than one comment can be added
* Manually Editable - Right-click administrative action available
* Policy Editable - "Run Script on CounterACT" action can modify it
* Persistent - Retained for the life of the endpoint
* Searchable - Comments can be used in policy conditions
* Audit Trail - Provides documentation of endpoint history
Usage Examples:
Manual Comments:
* "Device moved to Building C - 2024-10-15"
* "User reported software issue"
* "Awaiting quarantine release approval"
Policy-Generated Comments:
* Vulnerability compliance policy: "Failed patch compliance check"
* Security policy: "Detected unauthorized application"
* Remediation policy: "Scheduled for antivirus update"
Multiple such comments can accumulate on a single endpoint over time.
Referenced Documentation:
* Forescout Administration Guide - Device Information Properties
* ForeScout CounterACT Administration Guide - Comments field section
NEW QUESTION # 72
Which of the following requires secure connector to resolve?
- A. Signed-In status
- B. HTTP login user
- C. Authentication login
- D. Authentication certificate status
- E. Authentication login (advanced)
According to the Forescout HPS Inspection Engine Configuration Guide and Remote Inspection Feature Support documentation, "Authentication login" requires SecureConnector to resolve.
Authentication Login Property:
According to the Remote Inspection and SecureConnector Feature Support documentation:
The "Authentication login" property requires SecureConnector because:
* Interactive User Information - Requires access to active user session data
* Real-Time Verification - Must check current login status
* Endpoint Agent Needed - Cannot be determined via passive network monitoring or remote registry
* SecureConnector Required - Installed agent must report login status
SecureConnector vs. Remote Inspection:
According to the HPS Inspection Engine guide:
Some properties require different capabilities:
Property
Remote Inspection (MS-WMI/RPC)
SecureConnector
#No
# Yes
#No
# Yes
Signed-In status
#No
# Yes
HTTP login user
#No
# Yes
#Yes
#Yes
* A. Authentication login (advanced) - While this also requires SecureConnector, the base
"Authentication login" is the more accurate answer
* B. Authentication certificate status - This can be resolved via Remote Inspection using certificate stores
* C. HTTP login user - This is resolved by SecureConnector, but not listed as requiring it in the same way
* E. Signed-In status - While this requires SecureConnector, the more specific answer is "Authentication login" SecureConnector Capabilities:
SecureConnector resolves endpoint properties that require:
* Active user session information
* Real-time application/browser monitoring
* Deep endpoint inspection
* Interactive user credentials
* Remote Inspection and SecureConnector - Feature Support
* Using Certificates to Authenticate the SecureConnector Connection
NEW QUESTION # 73
Which of the following switch actions cannot both be used concurrently on the same switch?
- A. Endpoint Address ACL & Assign to VLAN
- B. Switch Block & Assign to VLAN
- C. Access Port ACL & Assign to VLAN
- D. Access Port ACL & Endpoint Address ACL
- E. Access Port ACL & Switch Block
According to the Forescout Switch Plugin Configuration Guide, Access Port ACL and Endpoint Address ACL cannot both be used concurrently on the same endpoint. These two actions are mutually exclusive because they both apply ACL rules to control traffic, but through different mechanisms, and attempting to apply both simultaneously creates a conflict.
Switch Restrict Actions Overview:
The Forescout Switch Plugin provides several restrict actions that can be applied to endpoints:
* Access Port ACL - Applies an operator-defined ACL to the access port of an endpoint
* Endpoint Address ACL - Applies an operator-defined ACL based on the endpoint's address (MAC or IP)
* Assign to VLAN - Assigns the endpoint to a specific VLAN
* Switch Block - Completely isolates endpoints by turning off their switch port Action Compatibility Rules:
According to the Switch Plugin Configuration Guide:
* Endpoint Address ACL vs Access Port ACL - These CANNOT be used together on the same endpoint because:
* Both actions modify switch filtering rules
* Both actions can conflict when applied simultaneously
* The Switch Plugin cannot determine priority between conflicting ACL configurations
* Applying both would create ambiguous filtering logic on the switch
Actions That CAN Be Used Together:
* Access Port ACL + Assign to VLAN -#Can be used concurrently
* Endpoint Address ACL + Assign to VLAN -#Can be used concurrently
* Switch Block + Assign to VLAN - This is semantically redundant (blocking takes precedence) but is allowed
* Access Port ACL + Switch Block -#Can be used concurrently (though Block takes precedence) Why Other Options Are Incorrect:
* A. Access Port ACL & Switch Block - These CAN be used concurrently; Switch Block would take precedence
* B. Switch Block & Assign to VLAN - These CAN be used concurrently (though redundant)
* C. Endpoint Address ACL & Assign to VLAN - These CAN be used concurrently
* E. Access Port ACL & Assign to VLAN - These CAN be used concurrently; they work on different aspects of port management ACL Action Definition:
* Access Port ACL - "Use the Access Port ACL action to define an ACL that addresses one or more than one access control scenario, which is then applied to an endpoint's switch port"
* Endpoint Address ACL - "Use the Endpoint Address ACL action to apply an operator-defined ACL, addressing one or more than one access control scenario, which is applied to an endpoint's address" Referenced Documentation:
* Forescout CounterACT Switch Plugin Configuration Guide Version 8.12
* Switch Plugin Configuration Guide v8.14.2
* Switch Restrict Actions documentation
NEW QUESTION # 74
When using the "Assign to VLAN action," why might it be useful to have a policy to record the original VLAN?
Select one:
- A. Since CounterACT reads the startup config to find the original VLAN, network administrators saving configuration changes to switches could overwrite this VLAN information
- B. Since CounterACT reads the startup config to find the original VLAN, network administrators making changes to switch running configs could overwrite this VLAN information
- C. Since CounterACT reads the running config to find the original VLAN, network administrators saving configuration changes to switches could overwrite this VLAN information
- D. Since CounterACT reads the running config to find the original VLAN, any changes to switch running configs could overwrite this VLAN information
- E. Since CounterACT reads the running config to find the original VLAN, network administrators making changes to switch running configs could overwrite this VLAN information
According to the Forescout Switch Plugin documentation, the correct answer is: "Since CounterACT reads the running config to find the original VLAN, any changes to switch running configs could overwrite this VLAN information".
Why Recording Original VLAN is Important:
When CounterACT assigns an endpoint to a quarantine VLAN:
* Reading Original VLAN - CounterACT reads the switch running configuration to determine the original VLAN
* Temporary Change - The endpoint is moved to the quarantine VLAN
* Restoration Issue - If network administrators save configuration changes to the running config, CounterACT's reference to the original VLAN may be overwritten
* Solution - Recording the original VLAN in a policy ensures you have a backup reference Why Option D is the Most Accurate:
Option D states the key issue clearly: "any changes to switch running configs could overwrite this VLAN information." This is the most comprehensive and accurate statement because it acknowledges that ANY changes (not just those by administrators specifically) could cause the issue.
NEW QUESTION # 75
Which of the following are included in System backups?
- A. Wireless Plugin version 1.4.0 and above
- B. Policies
- C. Hostname and IP address
- D. Failover Clustering plugin
- E. Switch Plugin version 8.7.0 and above
According to the Forescout Upgrade Guide and System Backup documentation, Policies are included in System backups.
What System Backups Include:
According to the official documentation:
"Each backup saves all Forescout Platform device and Console settings. This data includes the following:
* Configuration
* License
* Operating System settings
* Policies
* Profiles
* Reports
* Administrator accounts
* And other system data"
System Backup Contents:
According to the backup documentation:
System backups include:
* Policies - All configured policies and policy templates
* Configuration - System configuration settings
* License Information - License keys and licensing data
* Administrator Accounts - User accounts and access controls
* Reports - Scheduled and saved reports
* System Settings - Mail, network, and other system configurations
* Profiles - User profiles and system profiles
What System Backups DO NOT Include:
System backups are encrypted using AES-256 and include most system data but are separate from:
* Appliance-specific firmware - May require separate backup
* Component-specific backups - Some modules have separate backup procedures
* Log files - Not typically included in system backups
* A. Switch Plugin version 8.7.0 and above - Plugin versions are not individually backed up; plugins are part of the module installation, not system configuration backup
* C. Hostname and IP address - While these are part of system configuration, they are covered under
"Configuration" not listed separately in backup contents
* D. Failover Clustering plugin - Plugin software itself is not backed up; configuration related to plugins is backed up
* E. Wireless Plugin version 1.4.0 and above - Plugin versions are installed separately; backups contain configuration, not plugin versions Policy Backup Importance:
Policies are one of the most critical items included in system backups because:
* Restore Capability - After system recovery, policies are restored automatically
* Business Continuity - Restoring policies ensures the same security posture
* Compliance - Policies contain compliance rules that must be preserved
* Operational Continuity - Restores endpoint management immediately after recovery System vs. Component Backups:
* System Backup - Includes policies, configuration, licenses, administrator accounts, etc.
* Component Backup - Specific modules may have additional backup capabilities
* Both backup types - Both are encrypted with AES-256 for security
Backup Encryption:
"Both system and component backup files, backed up either manually or via a schedule, are encrypted using AES-256 to protect sensitive file data." This ensures that backed-up policies and other sensitive configuration remain secure.
* Back Up your Enterprise Manager and/or Appliances - v8.4
* Back Up your Enterprise Manager and/or Appliances - v8.5.1
* Backing Up System and Component Settings - v8.4
* Backing Up Forescout Platform System and Component Settings - v8.5.1
NEW QUESTION # 76
The easy to learn format of these amazing FSCP exam questions will prove one of the most exciting exam preparation experiences of your life! When you are visiting on our website, you can find that every button is easy to use and has a swift response. And there are three varied versions of our FSCP learning guide: the PDF, Software and APP online. Every version of our FSCP simulating exam is auto installed if you buy and study with them. They are perfect in every detail.
Test FSCP Practice: https://www.pdftorrent.com/FSCP-exam-prep-dumps.html
- FSCP Valid Test Objectives 🌮 FSCP Training Online 🅱 FSCP Valid Test Materials 🥖 Open “ [url]www.prepawaypdf.com ” enter ➠ FSCP 🠰 and obtain a free download 🌳Reliable FSCP Exam Practice[/url]
- Utilizing Reliable FSCP Exam Registration - Get Rid Of Forescout Certified Professional Exam 🔋 The page for free download of 【 FSCP 】 on ➽ [url]www.pdfvce.com 🢪 will open immediately 🌠FSCP Valid Test Objectives[/url]
- Forescout FSCP Questions To Gain Brilliant Result [2026] 🍼 Enter ➤ [url]www.prepawayete.com ⮘ and search for { FSCP } to download for free 💷FSCP Reliable Test Pdf[/url]
- FSCP Latest Braindumps Questions 🔋 Reliable FSCP Mock Test 🎮 FSCP Latest Materials 🌕 Search on ➡ [url]www.pdfvce.com ️⬅️ for ➠ FSCP 🠰 to obtain exam materials for free download 🧽Reliable FSCP Mock Test[/url]
- Free PDF Quiz FSCP - Forescout Certified Professional Exam –Professional Reliable Exam Registration 🥝 Go to website ➡ [url]www.prepawayexam.com ️⬅️ open and search for [ FSCP ] to download for free 😵FSCP Training Online[/url]
- Passing FSCP Score Feedback 🈺 FSCP Latest Braindumps Questions 📣 Exam FSCP Pattern 🏺 Search for ➡ FSCP ️⬅️ and obtain a free download on “ [url]www.pdfvce.com ” 🧂FSCP Free Pdf Guide[/url]
- FSCP Pass Exam 🛐 FSCP Free Pdf Guide 💳 FSCP Training Online ◀ Open website ⏩ [url]www.torrentvce.com ⏪ and search for ➥ FSCP 🡄 for free download 📯
ass Leader FSCP Dumps[/url] - FSCP Valid Test Objectives 🚝 FSCP Valid Test Objectives 📻 FSCP Training Online 📔 Search for ➥ FSCP 🡄 and easily obtain a free download on ▛ [url]www.pdfvce.com ▟ 🌝FSCP New Test Bootcamp[/url]
- FSCP Valid Test Objectives 💁 Reliable FSCP Exam Bootcamp 🔈 FSCP Valid Test Materials 😝 Search for 「 FSCP 」 and download exam materials for free through ▶ [url]www.vce4dumps.com ◀ ⏰FSCP New Test Bootcamp[/url]
- High-quality Reliable FSCP Exam Registration - Useful Test FSCP Practice Ensure You a High Passing Rate ⬆ Search for ➤ FSCP ⮘ and easily obtain a free download on ➡ [url]www.pdfvce.com ️⬅️ 🎫FSCP Latest Braindumps Questions[/url]
- Reliable FSCP Exam Registration - Pass Guaranteed Quiz 2026 FSCP: First-grade Test Forescout Certified Professional Exam Practice 📴 Search for ➽ FSCP 🢪 and download it for free immediately on ⇛ [url]www.verifieddumps.com ⇚ 👑Exam FSCP Blueprint[/url]
- www.stes.tyc.edu.tw, www.posteezy.com, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, ycs.instructure.com, www.rockemd.com:8080, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, zenwriting.net, Disposable vapes
P.S. Free & New FSCP dumps are available on Google Drive shared by PDFTorrent: https://drive.google.com/open?id=17x3umn6K6dYxMzNPNPRm6jhyEtdk3WCX
