[General] SAP-C02 Test Torrent & SAP-C02 Learning Materials & SAP-C02 Dumps VCE
99
【General】 SAP-C02 Test Torrent & SAP-C02 Learning Materials & SAP-C02 Dumps VCE
Posted at 1/11/2026 04:12:45      View:219 | Replies:4        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Amazon SAP-C02 dumps are available on Google Drive shared by Pass4sureCert: https://drive.google.com/open?id=1A-TvI8Zy7P2jAVbrNwMbiufvezhpwI0J
Our SAP-C02 study materials are widely read and accepted by people. Through careful adaption and reorganization, all knowledge will be integrated in our SAP-C02 real exam. The explanations of our SAP-C02 exam materials also go through strict inspections. So what you have learned are absolutely correct. All in all, we have invested many efforts on compiling of the SAP-C02 Practice Guide. At last, we will arrange proofreaders to check the study materials.
To prepare for the SAP-C02 Exam, candidates should have extensive experience designing and deploying AWS solutions using AWS services. They should also have a solid understanding of AWS architecture best practices and be able to apply them to real-world scenarios. AWS offers a range of training and resources to help candidates prepare for the exam, including instructor-led courses, online training, and practice exams.
Pass Guaranteed Quiz 2026 Amazon SAP-C02: AWS Certified Solutions Architect - Professional (SAP-C02) Fantastic Exam Revision PlanEvery day is new beginning; we will have a good mood. Hot and outstanding IT certification will be a good beginning for your IT career road. Amazon SAP-C02 current exam content will be a strong helper for you. If you want to realize your dream and get a certification, Pass4sureCert provide the best valid Amazon SAP-C02 Current Exam Content materials to help you pass tests. And you will have a great progress in a short time.
Amazon AWS Certified Solutions Architect - Professional (SAP-C02) Sample Questions (Q443-Q448):NEW QUESTION # 443
How can a company patch EC2 instanceswithout internet access, using apatch source in another account, while accessing Systems Manager and S3?
  • A. Custom VPN servers
  • B. Transit Gateway + private VIFs
  • C. VPC endpoints+VPC peeringwith patch source
  • D. Network ACLs + Transit Gateway
The most secure and manageable solution is to useVPC interface endpointsforS3andSystems Manager, and establishVPC peeringto privately access the patch repo in the core account.
Systems Manager VPC setup
NEW QUESTION # 444
A company is planning to migrate workloads from its on-premises data center to Amazon EC2 instances. The workloads run on physical servers and VMware virtual servers. The company has gathered details about each on-premises server and virtual server, including server specification, CPU utilization, and memory utilization. The company has stored these details in a .csv file named onprem.csv.
Before the migration, the company must estimate the cost of running the servers on AWS and must determine recommended EC2 instance types for the servers. The company must export this information to a different .csv file.
Which solution will meet these requirements?
  • A. Upload the onprem.csv file to an Amazon S3 bucket. Configure Migration Evaluator to import the data from the S3 bucket. Generate and confirm recommendations by using Migration Evaluator Quick Insights. Export the final recommendations to a new .csv file in the S3 bucket.
  • B. Configure AWS Compute Optimizer to generate recommendations from an external source. Import the onprem.csv file. Export the Compute Optimizer recommendations to a new .csv file.
  • C. Import the onprem.csv file into AWS Migration Hub by using AWS Migration Hub import. Use EC2 instance recommendations from Migration Hub to generate recommendations. Export the recommendations to a new .csv file.
  • D. Deploy AWS Application Discovery Service Agentless Collector on premises. Use Agentless Collector to import the onprem.csv file. Send the file to AWS Migration Hub. Use EC2 instance recommendations from Migration Hub to generate recommendations. Export the recommendations to a new .csv file.
NEW QUESTION # 445
A solutions architect is reviewing an application's resilience before launch. The application runs on an Amazon EC2 instance that is deployed in a private subnet of a VPC.
The EC2 instance is provisioned by an Auto Scaling group that has a minimum capacity of I and a maximum capacity of I. The application stores data on an Amazon RDS for MySQL DB instance. The VPC has subnets configured in three Availability Zones and is configured with a single NAT gateway.
The solutions architect needs to recommend a solution to ensure that the application will operate across multiple Availability Zones.
Which solution will meet this requirement?
  • A. Deploy an additional NAT gateway in the other Availability Zones. Update the route tables with appropriate routes. Modify the RDS for MySQL DB instance to turn on automatic backups and retain the backups for 7 days. Configure the Auto Scaling group to launch instances across all subnets in the VPC. Keep the minimum capacity and the maximum capacity of the Auto Scaling group at 1.
  • B. Replace the NAT gateway with a virtual private gateway. Replace the RDS for MySQL DB instance with an Amazon Aurora MySQL DB cluster. Configure the Auto Scaling group to launch instances across all subnets in the VPC. Set the minimum capacity and maximum capacity of the Auto Scaling group to 3.
  • C. Replace the NAT gateway with a NAT instance. Migrate the RDS for MySQL DB instance to an RDS for PostgreSQL DB instance. Launch a new EC2 instance in the other Availability Zones.
  • D. Deploy an additional NAT gateway in the other Availability Zones. Update the route tables with appropriate routes. Modify the RDS for MySQL DB instance to a Multi-AZ configuration. Configure the Auto Scaling group to launch instances across Availability Zones. Set the minimum capacity and maximum capacity of the Auto Scaling group to 3.
NEW QUESTION # 446
A solutions architect needs to implement a client-side encryption mechanism for objects that will be stored in a new Amazon S3 bucket. The solutions architect created a CMK that is stored in AWS Key Management Service (AWS KMS) for this purpose.
The solutions architect created the following IAM policy and attached it to an IAM role:
During tests, me solutions architect was able to successfully get existing test objects m the S3 bucket However, attempts to upload a new object resulted in an error message. The error message stated that me action was forbidden.
Which action must me solutions architect add to the IAM policy to meet all the requirements?
  • A. KmsGetKeyPolpcy
  • B. kms:SKjn
  • C. Kms:GenerateDataKey
  • D. kmsGetPubKKey
NEW QUESTION # 447
A solutions architect must provide a secure way for a team of cloud engineers to use the AWS CLI to upload objects into an Amazon S3 bucket Each cloud engineer has an IAM user. IAM access keys and a virtual multi-factor authentication (MFA) device The IAM users for the cloud engineers are in a group that is named S3-access The cloud engineers must use MFA to perform any actions in Amazon S3 Which solution will meet these requirements?
  • A. Attach a policy to the S3-access group to deny all S3 actions unless MFA is present Request temporary credentials from AWS Security Token Service (AWS STS) Attach the temporary credentials in a profile that Amazon S3 will reference when the user performs actions in Amazon S3
  • B. Update the trust policy for the S3-access group to require principals to use MFA when principals assume the group Use 1AM access keys with the AWS CLI to call Amazon S3
  • C. Attach a policy to the S3-access group to deny all S3 actions unless MFA is present Use 1AM access keys with the AWS CLI to call Amazon S3
  • D. Attach a policy to the S3 bucket to prompt the 1AM user for an MFA code when the 1AM user performs actions on the S3 bucket Use 1AM access keys with the AWS CLI to call Amazon S3
This option meets the requirement by attaching a policy to the S3-access group to deny all S3 actions unless MFA is present. This ensures that the cloud engineers must use their MFA device when performing any actions in Amazon S3. Additionally, it also requests temporary credentials from AWS STS, which are short-lived credentials that are generated on-demand, and attaches them in a profile that Amazon S3 will reference when the user performs actions in Amazon S3, this will provide an extra layer of security and protection against any misuse of the access keys. Reference :
https://docs.aws.amazon.com/IAM/ ... s_temp_request.html You could use AWS CLI with the temporary credentials to call Amazon S3 and perform the necessary actions. Reference:
https://aws.amazon.com/cli/
NEW QUESTION # 448
These practice exams are customizable and help you counter exam anxiety. You can use Amazon SAP-C02 desktop practice test software and web-based practice test software to assess your knowledge, test-taking skills, and readiness for the actual SAP-C02 exam. With both SAP-C02 exam practice test software you can familiarize yourself with the types of questions, and overall exam environment and improve your exam time management skills. So choose your desired SAP-C02 Exam Practice test software and start exam preparation today. The desktop software runs on Windows computers and the web-based is supported by all operating systems.
Valid Test SAP-C02 Bootcamp: https://www.pass4surecert.com/Amazon/SAP-C02-practice-exam-dumps.html
Posted at 1/16/2026 03:36:48        Only Author  2#
Itcertkr 의 엘리트는 다년간 IT업계에 종사한 노하우로 높은 적중율을 자랑하는 Workday Workday-Pro-HCM-Core덤프를 연구제작하였습니다. 한국어 온라인서비스가 가능하기에 Workday Workday-Pro-HCM-Core덤프에 관하여 궁금한 점이 있으신 분은 구매전 문의하시면 됩니다. Workday Workday-Pro-HCM-Core덤프로 시험에서 좋은 성적 받고 자격증 취득하시길 바랍니다.
Posted at 1/20/2026 01:20:12        Only Author  3#
This article is a real eye-opener, thanks for sharing! CIS-Discovery Practice exam pdf has great content, and it’s provided to you without any fees.
Posted at 1/25/2026 04:20:03        Only Author  4#
Machen Sie sich noch Sorgen um die SAP C-TB120-2504 Zertifizierungsprüfung? Warten Sie noch mühlos auf die neuesten Materialien zur SAP C-TB120-2504 Zertifizierungsprüfung? ITZert hat neulich die neuesten Materialien zur SAP C-TB120-2504 Zertifizierungsprüfung bearbeitet. Wollen Sie die SAP C-TB120-2504 Zertifizierungsprüfung bestehen? Bitte schicken Sie doch schnell die Fragen und Antworten zur SAP C-TB120-2504 Zertifizierungsprüfung in den Warenkorb! Sie können kostenlos die Demo auf der Website ITZert.de herunterladen, um unsere Zuverlässigkeit zu bestätigen. Wir versprechen, dass wir Ihnen die gesammte Summe zurückerstatten werden, falls Sie mit unseren Prüfungsmaterialien in der SAP C-TB120-2504 (SAP Certified Associate - SAP Business One) Zertifizierungsprüfung durchfallen.
Posted at 2/7/2026 05:12:17        Only Author  5#
Your article is truly inspiring, thank you for sharing such brilliance! This D-PST-DY-23 Original Questions helped me climb the career ladder and secure a raise. Now, it’s free for everyone. Wishing you all success in your careers!
