[General] Certificate 300-425 Exam | New 300-425 Test Topics
【General】 Certificate 300-425 Exam | New 300-425 Test Topics
Posted at 1/11/2026 04:17:24      View:134 | Replies:1        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of PassLeaderVCE 300-425 dumps for free: https://drive.google.com/open?id=1R8UFQoS4Z_Cb8eMVhGUG24b6pqe1i-CL
Our 300-425 study materials are compiled by domestic first-rate experts and senior lecturer and the contents of them contain all the important information about the test and all the possible answers of the questions which maybe appear in the test. You can use the practice test software to check your learning outcomes. Our 300-425 study materials’ self-learning and self-evaluation functions, the statistics report function, the timing function and the function of stimulating the test could assist you to find your weak links, check your level, adjust the speed and have a warming up for the real exam. You will feel your choice to buy 300-425 Study Materials are too right.
WLAN High AvailabilityThe questions from this section cover 20% of the entire content and are dedicated to evaluating the following abilities of the candidates:
  • Design high availability for APs, including fall-back (primary, secondary, and assigning tertiary) and AP prioritization.
  • Design high availability for various controllers, including network availability through LAG, stateful switchover, as well as anchor controller priority & redundancy;
Avoid Exam Failure With Cisco 300-425 PDF QuestionsAs we know, our products can be recognized as the most helpful and the greatest 300-425 study engine across the globe. Even though you are happy to hear this good news, you may think our price is higher than others. We can guarantee that we will keep the most appropriate price because we want to expand our reputation of 300-425 Preparation dumps in this line and create a global brand. What’s more, we will often offer abundant discounts of 300-425 study guide to express our gratitude to our customers.
Cisco 300-425 Exam covers a range of topics, including wireless site surveys, WLAN high availability, advanced location services, and wireless security. 300-425 exam also evaluates the candidates' ability to design and implement Cisco wireless infrastructure, including controllers, access points, and network management tools. Additionally, the exam includes questions on the integration of wireless networks with wired networks and other advanced technologies like IoT, SDN, and cloud-based solutions.
Cisco Designing Cisco Enterprise Wireless Networks Sample Questions (Q329-Q334):NEW QUESTION # 329
A hospital wireless environment was designed with these characteristics:
* RF coverage
* better than -67 dBm in the 5 GHz spectrum
* RRM be used for DCA and TPC in the 2.4 GHz band
* RRM be used for DCA and TPC in the 5 GHz band
After deployment, why do many of the legacy 802.11b/g devices have difficulty maintaining connectivity?
  • A. TPC drastically increases Tx power in the 2.4 GHz band.
  • B. Excessive overlapping channels in the 2.4 GHz band exists.
  • C. TPC drastically reduces Tx power in the 2.4 GHz band.
  • D. Excessive co-channel interference in the 2.4 GHz band exists.
The Cisco Aironet 3800 Series APs support mGig, which allows for higher throughput over existing cabling.
However, the maximum cable length that supports 5G operation is limited by the quality of the cable and signal attenuation. Category 5e cabling can support 5G operation up to a length of 130 meters, which is within the acceptable range for maintaining the required signal integrity for 5G speeds.
NEW QUESTION # 330
Which three pieces of equipment are needed to conduct a fully measured wireless survey? (Choose three.)
  • A. tall tripod
  • B. ladder
  • C. PoE battery
  • D. goggles
  • E. access point
  • F. spirit level
Answer: B,C,E
A fully measured wireless survey requires tools that support the active functioning of the network and allow for physical access to install and measure equipment. A PoE (Power over Ethernet) battery is necessary to power the access point during the survey. The access point itself is essential for broadcasting the signal. A ladder is needed to reach high places for proper access point placement and to measure coverage areas effectively.
https://www.cisco.com/c/en/us/td ... n_and_Planning.html
NEW QUESTION # 331
An engineer in a branch office that does not have a wired backhaul must ensure that local clients can be switched locally and authenticated centrally. In which mode must the AP be configured?
  • A. Cisco FlexConnect
  • B. RAP
  • C. Flex+Bridge
  • D. MAP
Cisco FlexConnect mode is designed for branch offices that lack a wired backhaul. It allows APs to switch client data traffic locally while still performing client authentication centrally. This mode provides the flexibility needed for branch deployments, ensuring that client traffic is handled efficiently even if the WAN link to the central site is down. References: Cisco FlexConnect technical documentation and Designing Cisco Enterprise Wireless Networks (ENWLSD) training.
NEW QUESTION # 332
During a wireless network design, a customer requires wireless coverage on the perimeter of a building but also wants to minimize signal leakage from the wireless network. Which antenna should be used to accomplish this design?
  • A. Omnidirectional
  • B. Dipole
  • C. Patch
  • D. Monopole
https://www.cisco.com/c/en/us/td ... ustrial-routers-and
NEW QUESTION # 333
A network engineer is designing a new wireless network. The network needs to have these characteristics:
* support high client concentration
* optimize client performance
* avoid interference
Which approach should be taken?
  • A. Deploy APs near each other for 5 GHz coverage, and enable me 2.4 GHz radios for all APs.
  • B. Deploy APs near each other for 2 4 GHz coverage and disable the 5 GHz radios for all APs
  • C. Deploy APs near each other for 2 4 GHz coverage, and disable the 5 GHz radios for some APs
  • D. Deploy APs near each other for 5 GHz coverage, and disable the 2 4 GHz radios for some APs
https://www.cisco.com/c/en/us/td ... Best_Practices.html
NEW QUESTION # 334
New 300-425 Test Topics: https://www.passleadervce.com/CCNP-Enterprise/reliable-300-425-exam-learning-guide.html
P.S. Free & New 300-425 dumps are available on Google Drive shared by PassLeaderVCE: https://drive.google.com/open?id=1R8UFQoS4Z_Cb8eMVhGUG24b6pqe1i-CL
Posted at 2/5/2026 02:50:55        Only Author  2#
Amazon認証に伴って、この認証の重要性を発見する人が多くなっています。最近仕事を探すのは難しいですが、SOA-C02-JPN認証を取得して、あなたの就職チャンスを増加することができます。あなたは試験に合格したいなら、我々のSOA-C02-JPN問題集を利用することができます。
