[General] DP-300 exam dumps & DP-300 prep4sure training
45
General DP-300 exam dumps & DP-300 prep4sure training
Posted at 1/11/2026 04:19:56      View217 | Replies3        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest PDF4Test DP-300 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=194N8lOwQ-VAAvof66bFiEkQmtfpq3GNO
Though there are three versions of our DP-300 exam braindumps: the PDF, Software and APP online. When using the APP version for the first time, you need to ensure that the network is unblocked, and then our DP-300 guide questions will be automatically cached. The network is no longer needed the next time you use it. You can choose any version of our DP-300 Practice Engine that best suits your situation. It's all for you to learn better.
Our company has a professional team of experts to write DP-300 preparation materials and will constantly update it to ensure that it is synchronized with the exam content. In addition to the high quality, reasonable price and so on, we have many other reasons to make you choose our DP-300 Actual Exam. There are three versions of our DP-300 exam questions: PDF, Software and APP online which can provide you the varied study experiences.
DP-300 Reliable Exam Questions - Valid DP-300 Real TestGenius is 99% of sweat plus 1% of inspiration. You really don't need to think that you can succeed for nothing. If you still have a trace of enterprise, you really want to start working hard! Our DP-300 exam questions are the most effective helpers on your path. As the high pass rate of our DP-300 study braindumps is as 98% to 100%, you can pass the exam without any doubt. And with the DP-300 certification, you will lead a better life!
Microsoft Administering Relational Databases on Microsoft Azure Sample Questions (Q14-Q19):NEW QUESTION # 14
Your company has an Azure SQL database named pass4testdb. Below are the configuration settings set for the database for automatic tuning.
Your company has a SQL Server 2019 instance hosted on an Azure virtual machine. The machine runs Windows Server 2019. The virtual machine has 4 vCPUs and 28 GB of memory.
You now have to scale up the virtual machine to 16 vCPUs and 64 GB of memory.
You have to provide the lowest latency for the tempdb database.
You decide to create 2 data files for tempdb
Would this fulfill the requirement?
  • A. Yes
  • B. No
As per the Microsoft documentation, you should have 1 file per vCore for TempDB with a limit of 8 files.
https://docs.microsoft.com/en-us ... indows/performance- guidelines-best-practices
NEW QUESTION # 15
You have an Azure subscription that contains the resources shown in the following table.
You need to back up db1 to mysqlbackups, and then restore the backup to a new database named db2 that is hosted on SQL1. The solution must ensure that db1 is backed up to a stripe set.
Which three Transact-SQL statements should you execute in sequence? To answer, move the appropriate statements from the list of statements to the answer area and arrange them in the correct order.
1 - CREATE CREDENTIAL....
2 - BACKUP DATABASE db1....
3 - RESTORE DATABASE db2 FROM URL =....
https://docs.microsoft.com/en-us ... ew=sql-server-ver15
NEW QUESTION # 16
You are creating a managed data warehouse solution on Microsoft Azure.
You must use PolyBase to retrieve data from Azure Blob storage that resides in parquet format and load the data into a large table called FactSalesOrderDetails.
You need to configure Azure Synapse Analytics to receive the data.
Graphical user interface, text, application, chat or text message Description automatically generated
To query the data in your Hadoop data source, you must define an external table to use in Transact-SQL queries. The following steps describe how to configure the external table.
Step 1: Create a master key on database.
1. Create a master key on the database. The master key is required to encrypt the credential secret.
(Create a database scoped credential for Azure blob storage.)
Step 2: Create an external data source for Azure Blob storage.
2. Create an external data source with CREATE EXTERNAL DATA SOURCE..
Step 3: Create an external file format to map the parquet files.
3. Create an external file format with CREATE EXTERNAL FILE FORMAT.
Step 4. Create an external table FactSalesOrderDetails
4. Create an external table pointing to data stored in Azure storage with CREATE EXTERNAL TABLE.
https://docs.microsoft.com/en-us ... -azure-blob-storage
NEW QUESTION # 17
You have an Azure virtual machine named VM1 on a virtual network named VNet1. Outbound traffic from VM1 to the internet is blocked.
You have an Azure SQL database named SqlDb1 on a logical server named SqlSrv1.
You need to implement connectivity between VM1 and SqlDb1 to meet the following requirements:
Ensure that VM1 cannot connect to any Azure SQL Server other than SqlSrv1.
Restrict network connectivity to SqlSrv1.
What should you create on VNet1?
  • A. a service endpoint
  • B. a private link
  • C. a VPN gateway
  • D. an ExpressRoute gateway
Azure Private Link enables you to access Azure PaaS Services (for example, Azure Storage and SQL Database) and Azure hosted customer-owned/partner services over a private endpoint in your virtual network.
Traffic between your virtual network and the service travels the Microsoft backbone network. Exposing your service to the public internet is no longer necessary.
https://docs.microsoft.com/en-us ... ivate-link-overview Monitor and Optimize Operational Resources Testlet 1 Case study This is a case study. Case studies are not timed separately. You can use as much exam time as you would like to complete each case. However, there may be additional case studies and sections on this exam. You must manage your time to ensure that you are able to complete all questions included on this exam in the time provided.
To answer the questions included in a case study, you will need to reference information that is provided in the case study. Case studies might contain exhibits and other resources that provide more information about the scenario that is described in the case study. Each question is independent of the other questions in this case study.
At the end of this case study, a review screen will appear. This screen allows you to review your answers and to make changes before you move to the next section of the exam. After you begin a new section, you cannot return to this section.
To start the case study
To display the first question in this case study, click the Next button. Use the buttons in the left pane to explore the content of the case study before you answer the questions. Clicking these buttons displays information such as business requirements, existing environment, and problem statements. If the case study has an All Information tab, note that the information displayed is identical to the information displayed on the subsequent tabs. When you are ready to answer a question, click the Question button to return to the question.
Overview
Existing Environment
Contoso, Ltd. is a financial data company that has 100 employees. The company delivers financial data to customers.
Active Directory
Contoso has a hybrid Azure Active Directory (Azure AD) deployment that syncs to on-premises Active Directory.
Database Environment
Contoso has SQL Server 2017 on Azure virtual machines shown in the following table.
SQL1 and SQL2 are in an Always On availability group and are actively queried. SQL3 runs jobs, provides historical data, and handles the delivery of data to customers.
The on-premises datacenter contains a PostgreSQL server that has a 50-TB database.
Current Business Model
Contoso uses Microsoft SQL Server Integration Services (SSIS) to create flat files for customers. The customers receive the files by using FTP.
Requirements
Planned Changes
Contoso plans to move to a model in which they deliver data to customer databases that run as platform as a service (PaaS) offerings. When a customer establishes a service agreement with Contoso, a separate resource group that contains an Azure SQL database will be provisioned for the customer. The database will have a complete copy of the financial data. The data to which each customer will have access will depend on the service agreement tier. The customers can change tiers by changing their service agreement.
The estimated size of each PaaS database is 1 TB.
Contoso plans to implement the following changes:
* Move the PostgreSQL database to Azure Database for PostgreSQL during the next six months.
* Upgrade SQL1, SQL2, and SQL3 to SQL Server 2019 during the next few months.
* Start onboarding customers to the new PaaS solution within six months.
Business Goals
Contoso identifies the following business requirements:
* Use built-in Azure features whenever possible.
* Minimize development effort whenever possible.
* Minimize the compute costs of the PaaS solutions.
* Provide all the customers with their own copy of the database by using the PaaS solution.
* Provide the customers with different table and row access based on the customer's service agreement.
* In the event of an Azure regional outage, ensure that the customers can access the PaaS solution with minimal downtime. The solution must provide automatic failover.
* Ensure that users of the PaaS solution can create their own database objects but he prevented from modifying any of the existing database objects supplied by Contoso.
Technical Requirements
Contoso identifies the following technical requirements:
* Users of the PaaS solution must be able to sign in by using their own corporate Azure AD credentials or have Azure AD credentials supplied to them by Contoso. The solution must avoid using the internal Azure AD of Contoso to minimize guest users.
* All customers must have their own resource group, Azure SQL server, and Azure SQL database. The deployment of resources for each customer must be done in a consistent fashion.
* Users must be able to review the queries issued against the PaaS databases and identify any new objects created.
* Downtime during the PostgreSQL database migration must be minimized.
Monitoring Requirements
Contoso identifies the following monitoring requirements:
* Notify administrators when a PaaS database has a higher than average CPU usage.
* Use a single dashboard to review security and audit data for all the PaaS databases.
* Use a single dashboard to monitor query performance and bottlenecks across all the PaaS databases.
* Monitor the PaaS databases to identify poorly performing queries and resolve query performance issues automatically whenever possible.
PaaS Prototype
During prototyping of the PaaS solution in Azure, you record the compute utilization of a customer's Azure SQL database as shown in the following exhibit.
Role Assignments
For each customer's Azure SQL Database server, you plan to assign the roles shown in the following exhibit.
NEW QUESTION # 18
You Save an Azure SCX database named DB1.
You need to query the fragmentation information of data and indexes for the tables in D61.
Which command should you run?
  • A.
  • B.
  • C.
  • D.
NEW QUESTION # 19
Probably youve never imagined that preparing for your upcoming DP-300 Exam could be easy. The good news is that our DP-300 exam braindumps can help you pass the exam and achieve the certification withe the least time and efforts. The excellent DP-300 learning questions are the product created by those professionals who have extensive experience of designing exam study material. Just remind you that we have engaged in the career for over ten years and we have became the leader in this field.
DP-300 Reliable Exam Questions: https://www.pdf4test.com/DP-300-dump-torrent.html
You can avail these Microsoft DP-300 changes for free up to 90 days, Microsoft Study Guide DP-300 Pdf So their perfection is unquestionable, Our professional experts who did exhaustive work are diligently keeping eyes on accuracy and efficiency of DP-300 practice materials for years, Money & Information guaranteed Firstly, DP-300 exam dumps can save a lot of money and time, The answer is no because our DP-300 VCE torrent files are the greatest learning material in the world.
Following that, we will study several examples of function DP-300 implementations and applications, Suppose Chrysler had never surveyed its Jeep Cherokee Manufacture-Product what.
You can avail these Microsoft DP-300 changes for free up to 90 days, So their perfection is unquestionable, Our professional experts who did exhaustive work are diligently keeping eyes on accuracy and efficiency of DP-300 practice materials for years.
Microsoft DP-300 PDF Dumps - Pass Your Exam In First Attempt [Updated-2026] Money & Information guaranteed Firstly, DP-300 exam dumps can save a lot of money and time, The answer is no because our DP-300 VCE torrent files are the greatest learning material in the world.
P.S. Free 2026 Microsoft DP-300 dumps are available on Google Drive shared by PDF4Test: https://drive.google.com/open?id=194N8lOwQ-VAAvof66bFiEkQmtfpq3GNO
Posted at 1/13/2026 01:50:02        Only Author  2#
Im truly grateful for your article, it made an unforgettable impact. The INST1-V8 positive feedback test that helped me earn a promotion and salary raise is free for you today. Best of luck reaching your career goals!
Posted at 1/17/2026 06:51:47        Only Author  3#
This article is simply breathtaking, thank you for sharing it with us! Improve your IT abilities and access free Free C-THR87-2505 test questions. Best of luck with your exams!
Posted at 1/26/2026 17:51:44        Only Author  4#
I really appreciate your article, it opened my eyes to new possibilities. This is the Latest test MS-102 duration test that helped me achieve a promotion and raise. It's available to you for free today, and I wish you success in reaching your career goals.
