[Hardware] Reliable FCP_FGT_AD-7.6 Test Topics | FCP_FGT_AD-7.6 Reliable Dumps Sheet
82
Hardware Reliable FCP_FGT_AD-7.6 Test Topics | FCP_FGT_AD-7.6 Reliable Dumps Sheet
Posted at 1/11/2026 05:07:37      View115 | Replies0        Print      Only Author   [Copy Link] 1#
2026 Latest PracticeVCE FCP_FGT_AD-7.6 PDF Dumps and FCP_FGT_AD-7.6 Exam Engine Free Share: https://drive.google.com/open?id=1dSlvVo1LXduTcrsPDiSnihbobocwQ8MU
You can use this Fortinet simulation software without an internet connection after installation. Tracking and reporting features of our FCP - FortiGate 7.6 Administrator FCP_FGT_AD-7.6 Practice Exam software makes it easier for you to identify and overcome mistakes. Customization feature of this format allows you to change time limits and questions numbers of mock exams.
If you are already determined to obtain an international certificate, you must immediately purchase our FCP_FGT_AD-7.6 exam practice. Our products have been certified as the highest quality products in the industry. If you know FCP_FGT_AD-7.6 training materials through acquaintance introduction, then you must also know the advantages of FCP_FGT_AD-7.6. Our content and design have laid a good reputation for us. Our users are willing to volunteer for us. You can imagine this is a great product! Next, I will introduce you to the most representative advantages of FCP_FGT_AD-7.6 real exam. You can think about whether these advantages are what you need!
Reliable FCP_FGT_AD-7.6 Test Topics - 100% Marvelous Questions PoolFor everyone, time is money and life. Are you still hesitant about selecting what kind of FCP_FGT_AD-7.6 exam materials? We have a high reputation on the career to help our customers pass their exams and get their desired certifications. There is no exaggeration to say that you can pass the FCP_FGT_AD-7.6 Exam with ease after studying with our FCP_FGT_AD-7.6 practice guide for 20 to 30 hours. Numerous of the candidates have been benefited from our exam torrent and they obtained the achievements just as they wanted.
Fortinet FCP - FortiGate 7.6 Administrator Sample Questions (Q45-Q50):NEW QUESTION # 45
A network administrator is troubleshooting an IPsec tunnel between two FortiGate devices. The administrator has determined that phase 1 failed to come up. The administrator has also re- entered the pre-shared key on both FortiGate devices to make sure they match.
Based on the phase 1 configuration and the diagram shown in the exhibit, which two configuration changes can the administrator make to bring phase 1 up? (Choose two.)
  • A. On HQ-FortiGate, disable Diffie-Helman group 2.
  • B. On HQ-FortiGate, set IKE mode to Main (ID protection).
  • C. On both FortiGate devices, set Dead Peer Detection to On Demand.
  • D. On Remote-FortiGate, set port2 as Interface.
On the HQ-FortiGate the IKE phase 1 mode is set to Aggressive, while on the Remote-FortiGate it is set to Main (ID protection). Both sides must use the same IKE mode for phase 1 to come up, so changing HQ-FortiGate to Main mode resolves this mismatch.
On the Remote-FortiGate, the phase 1 Interface is configured as port1, but according to the diagram the WAN-facing interface with IP 10.10.200.10 is port2. The local interface in the IPsec configuration must match the physical WAN interface, so changing it to port2 is required for the tunnel to establish.
NEW QUESTION # 46
A network administrator has configured an SSL/SSH inspection profile defined for full SSL inspection and set with a private CA certificate. The firewall policy that allows the traffic uses this profile for SSL inspection and performs web filtering. When visiting any HTTPS websites, the browser reports certificate warning errors.
What is the reason for the certificate warning errors?
  • A. The certificate used by FortiGate for SSL inspection does not contain the required certificate extensions.
  • B. The browser does not recognize the certificate in use as signed by a trusted CA.
  • C. The SSL cipher compliance option is not enabled on the SSL inspection profile. This setting is required when the SSL inspection profile is defined with a private CA certificate.
  • D. With full SSL inspection it is not possible to avoid certificate warning errors at the browser level.
The certificate warning errors occur because the SSL inspection profile is configured to use a private CA certificate that is not recognized by the browser as being signed by a trusted CA. For the browser to trust the FortiGate's re-signed certificates, the CA certificate used by FortiGate for SSL inspection must be installed in the browser's trusted certificate store. Until the browser recognizes the certificate authority (CA) as trusted, it will continue to display warning errors when accessing HTTPS websites.
NEW QUESTION # 47
What are two features of collector agent advanced mode? (Choose two.)
  • A. In advanced mode, FortiGate can be configured as an LDAP client and group filters can be configured on FortiGate.
  • B. In advanced mode, security profiles can be applied only to user groups, not individual users.
  • C. Advanced mode supports nested or inherited groups.
  • D. Advanced mode uses the Windows convention -NetBios: DomainUsername.
Also, advanced mode supports nested or inherited groups; that is, users can be members of subgroups that belong to monitored parent groups.
In advanced mode, you can configure FortiGate as an LDAP client and configure the group filters on FortiGate. You can also configure group filters on the collector agent.
NEW QUESTION # 48
You have configured the below commands on a FortiGate.
What would be the impact of this configuration on FortiGate?
  • A. The global configuration will take precedence and FortiGate will enable strict RPF on all interfaces.
  • B. Port1 will be enabled with flexible RPF, and all other interfaces will be enabled for strict RPF
  • C. FortiGate will enable strict RPF on ail its interfaces and port1 will be enable for asymmetric routing.
  • D. FortiGate will enable strict RPF on all its interfaces and port1 will be exempted from RPF checks.
The global setting enables strict source checking (RPF) on all interfaces by default. The per-interface setting disables the source check on port1, exempting it from strict RPF enforcement.
NEW QUESTION # 49
Refer to the exhibit, which shows an SD-WAN zone configuration on the FortiGate GUI.
Based on the exhibit, which statement is true?
  • A. The virtual-wan-link and overlay zones can be deleted.
  • B. port2 and port3 are not assigned to a zone.
  • C. The Underlay zone is the zone by default.
  • D. The Underlay zone contains no member.
The Underlay zone is the default SD-WAN zone, typically representing the physical interfaces in the SD- WAN configuration before overlay or virtual links are added.
NEW QUESTION # 50
If you are occupied with your study or work and have little time to prepare for your exam, then you can choose us. FCP_FGT_AD-7.6 training materials are edited by skilled professional experts, and therefore they are high-quality. You just need to spend about 48 to 72 hours on study, you can pass the exam. We are pass guarantee and money back guarantee for FCP_FGT_AD-7.6 Exam Materials, if you fail to pass the exam, you just need to send us your failure scanned to us, we will give you full refund, and no other questions will be asked. Online and offline service is available, if you have any questions for FCP_FGT_AD-7.6 exam materials, dont hesitate to consult us.
FCP_FGT_AD-7.6 Reliable Dumps Sheet: https://www.practicevce.com/Fortinet/FCP_FGT_AD-7.6-practice-exam-dumps.html
Fortinet Reliable FCP_FGT_AD-7.6 Test Topics These practice exam save progress report of each attempt so you can assess it to find and overcome mistakes, The very reason for this selection of PracticeVCE FCP - FortiGate 7.6 Administrator (FCP_FGT_AD-7.6) exam questions is that they are real and updated, The names of these FCP - FortiGate 7.6 Administrator (FCP_FGT_AD-7.6) exam questions formats are PDF files, desktop practice test software, and web-based FCP_FGT_AD-7.6 practice test software, On condition that you are uncertain about its content, there are parts of free FCP_FGT_AD-7.6 demos for your reference.
But there may be exceptions sometimes, Evan Burchard provides FCP_FGT_AD-7.6 that, too, These practice exam save progress report of each attempt so you can assess it to find and overcome mistakes.
The very reason for this selection of PracticeVCE FCP - FortiGate 7.6 Administrator (FCP_FGT_AD-7.6) exam questions is that they are real and updated, The names of these FCP - FortiGate 7.6 Administrator (FCP_FGT_AD-7.6) exam questions formats are PDF files, desktop practice test software, and web-based FCP_FGT_AD-7.6 practice test software.
Fortinet's Exam Questions for FCP_FGT_AD-7.6 Ensure 100% Success on Your First AttemptOn condition that you are uncertain about its content, there are parts of free FCP_FGT_AD-7.6 demos for your reference, The FCP - FortiGate 7.6 Administrator Latest Test Book PC test engine & FCP - FortiGate 7.6 Administrator Latest Study FCP_FGT_AD-7.6 Test online test engine are all VCE format and can simulate the actual test environment.
P.S. Free 2026 Fortinet FCP_FGT_AD-7.6 dumps are available on Google Drive shared by PracticeVCE: https://drive.google.com/open?id=1dSlvVo1LXduTcrsPDiSnihbobocwQ8MU
