Fortinet NSE7_OTS-7.2YϡNSE7_OTS-7.2ӢZ
Posted at 1/11/2026 05:34:05
View194
Replies1
P.S. JpexamGoogle DriveǹФƤoϤ¤NSE7_OTS-7.2ףhttps://drive.google.com/open?id=1klU8IBsiyjJreqCHRDn8v-BNFM6Nlfr-
Jpexamṩ}ʹäITI픵εһiȤƤȤƤҪʵλˤʤޤΉ1i˽ʤޤYϤṩǤʤFortinetNSE7_OTS-7.2ԇYһΟoϥåץǩ`ȤˤʤäƤޤ
Fortinet NSE7_OTS-7.2JԇYYYäˤϡaߤϥͥåȥ`ȥƥλA⤷ƤҪꡢOTƥȥͥåȥ`ǤIUY֤äƤҪޤޤԇYǥƥȤҪʥȥԥåȥץȤЩ`Fortinet NSE 7 - OTƥ7.2ȥ`˥`ˤҪޤ
Fortinet NSE7_OTS-7.2ԇYϡϸˤϸ߶ȤʌT֪RҪʤᡢЩ`ƥIyԇYһĤȿƤޤԇY˺ϸ뤳ȤǡOTƥθʾOThȫĄĤ˹뤿˱ҪʥäȤ^ޤJϡߤu졢`ХJ֪Ƥ뤿ᡢЩ`ƥΥꥢMTҤˤȤäƁΤYbȤʤޤ
NSE7_OTS-7.2Yϣ100ѥ¤|LΥީ`ƥͨơNSE7_OTS-7.2¤Jɤ϶यΤ͘Υݩ`Ȥ@äƤޤפʥǩ`ϡuƷ졩ˉӤƤ뤳ȤǤꡢuƷ_kΤǤΤ褦ʴʳɹ_ɤ뤿δŬǤޤYϤθ¤оϤǷdz¤ޤˡNSE7_OTS-7.2ΌgHNSE7_OTS-7.2ѧɽ̲ĤƷ|ϡ̎ˤäƅܤ˹Ƥޤ顢˽xkŤƤޤNSE7_OTS-7.2ѧ̲ĤˤĤ|ϤϡՄ
Fortinet NSE7_OTS-7.2J@ä뤳ȤϡOTƥθߤ٥ΌT֪RʾTҤꥢMΤޤJ줿ˤϡηҰΌTҤȤJRƤꡢȫOTͥåȥ`OӋgװޤJ^ϡOTƥ_Щ`{鱣oȤߥåȥȤg^褦ȤMˤȤäƤFؤYbǤ
Fortinet NSE 7 - OT Security 7.2 J NSE7_OTS-7.2 ԇY} (Q10-Q15):| # 10
Refer to the exhibit. From your analysis of the output, which statement about the output is true?
- A. This is a sample of an SNMP temperature control event log.
- B. This is a sample of a FortiAnalyzer system interface event log.
- C. This is a sample of FortiGate interface statistics.
- D. This is a sample of a PAM event type.
⣺D
h
ph_dev_mon is a PAM event. Hostname is WIN2K8DC (a win server) not Fortigate.
| # 11
The IPS profile is added on all of the security policies on FortiGate.
For an OT network, which statement of the IPS profile is true?
- A. FortiGate has no IPS industrial signature database enabled.
- B. All IPS signatures are overridden and must block traffic match signature patterns.
- C. The listed IPS signatures are classified as SCADA equipment.
- D. The IPS profile inspects only traffic originating from SCADA equipment.
⣺C
| # 12
Refer to the exhibit. An operational technology rule is created and successfully activated to monitor the Modbus protocol on FortiSIEM. However, the rule does not trigger incidents despite Modbus traffic and application logs being received correctly by FortiSIEM.
Which statement correctly describes the issue on the rule configuration?
- A. The first condition on the SubPattern filter must use the OR logical operator.
- B. The Aggregate attribute COUNT expression is incompatible with the filters.
- C. The SubPattern is missing the filter to match the Modbus protocol.
- D. The attributes in the Group By section must match the ones in Fitters section.
⣺C
h
The subpattern only filters on TCP/UDP ports (group "OT Ports"); it never specifies Modbus.
Without a protocol (or specific Modbus port) filter, FortiSIEM won't match Modbus events, so no incidents are triggered.
| # 13
An organization has deployed an entry-level FortiGate device in their operational technology (OT) network. The administrator is looking for a simple solution to detect and block all network intrusions in that specific part of the network without any false positive activities.
Which solution should the administrator use to achieve this goal?
- A. Enable intrusion prevention system (IPS) and use the regular signature database.
- B. Block all foreign inbound traffic.
- C. Enable the industrial signature database in the IPS global setting.
- D. Configure a local-in firewall policy.
⣺C
h
Enabling the IPS industrial signature database focuses detection on OT/ICS protocols and known attack patterns, giving accurate blocking with minimal false positives on an entry-level FortiGate.
| # 14
An OT network architect needs to secure control area zones with a single network access policy to provision devices to any number of different networks.
On which device can this be accomplished?
- A. FortiNAC
- B. FortiSwitch
- C. FortiEDR
- D. FortiGate
⣺D
h
An OT network architect can accomplish the goal of securing control area zones with a single network access policy to provision devices to any number of different networks on a FortiGate device.
| # 15
NSE7_OTS-7.2ӢZ: https://www.jpexam.com/NSE7_OTS-7.2_exam.html
- Fortinet NSE7_OTS-7.2JԇYm}Lj 🦱 ▷ [url]www.japancert.com ◁Οoϥ`▷ NSE7_OTS-7.2 ◁ک`_ޤNSE7_OTS-7.2֪R[/url]
- NSE7_OTS-7.2ԇYΜʂ䷽ΤNSE7_OTS-7.2YԇYϥѥ`ȤFortinet NSE 7 - OT Security 7.2ӢZ 🪂 ⮆ [url]www.goshiken.com ⮄ƄӤ☀ NSE7_OTS-7.2 ️☀️ƟoϤǥ`ɤƤNSE7_OTS-7.2Y[/url]
- g-ϥѥ`ȤNSE7_OTS-7.2YԇY-ԇYΜʂ䷽NSE7_OTS-7.2ӢZ 😩 ֥ȣ [url]www.jpshiken.com _{ NSE7_OTS-7.2 }ƟoϤǥ`ɤƤNSE7_OTS-7.2}[/url]
- NSE7_OTS-7.2ԇYΜʂ䷽ؔNSE7_OTS-7.2YԇYyFortinet NSE 7 - OT Security 7.2ӢZ 🚖 ⮆ [url]www.goshiken.com ⮄麆gˡ NSE7_OTS-7.2 oϤǥ`ɤǤޤNSE7_OTS-7.2Y[/url]
- NSE7_OTS-7.2ձZ౾ 🥊 NSE7_OTS-7.2ձZ౾ 🛩 NSE7_OTS-7.2ձZ౾ 🏮 ➠ [url]www.shikenpass.com 🠰麆g⏩ NSE7_OTS-7.2 ⏪oϤǥ`ɤǤޤNSE7_OTS-7.2Y[/url]
- ԇYΜʂ䷽-gHĤNSE7_OTS-7.2YԇY-¤NSE7_OTS-7.2ӢZ 🦂 ▷ [url]www.goshiken.com ◁ƄӤ NSE7_OTS-7.2 ƟoϤǥ`ɤƤNSE7_OTS-7.2ձZh[/url]
- NSE7_OTS-7.2ģMȥ` 🌊 NSE7_OTS-7.2ԇYh} I NSE7_OTS-7.2Y 🗻 [url]www.xhs1991.com 麆g{ NSE7_OTS-7.2 }oϤǥ`ɤǤޤNSE7_OTS-7.2Y[/url]
- NSE7_OTS-7.2ԇYΜʂ䷽ΤNSE7_OTS-7.2YԇYϥѥ`ȤFortinet NSE 7 - OT Security 7.2ӢZ 🏙 ➥ [url]www.goshiken.com 🡄➥ NSE7_OTS-7.2 🡄ơoϤǥ`ɤƤNSE7_OTS-7.2Y[/url]
- NSE7_OTS-7.2ٺϸ 🌯 NSE7_OTS-7.2ձZYȡ ⏭ NSE7_OTS-7.2ģM 🍸 URL ⏩ [url]www.goshiken.com ⏪ԩ`_ NSE7_OTS-7.2 ƟoϤǥ`ɤƤNSE7_OTS-7.2ԇY[/url]
- ԇYΜʂ䷽-gHĤNSE7_OTS-7.2YԇY-_ĤNSE7_OTS-7.2ӢZ 💄 ֥ȡ [url]www.goshiken.com _⇛ NSE7_OTS-7.2 ⇚ƟoϤǥ`ɤƤNSE7_OTS-7.2J^Y[/url]
- NSE7_OTS-7.2Y 🐺 NSE7_OTS-7.2Y 🍪 NSE7_OTS-7.2Y 🛄 ➥ [url]www.passtest.jp 🡄Ȥ[ NSE7_OTS-7.2 ]}ʹNSE7_OTS-7.2ԇY[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, solymaracademy.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, bbs.t-firefly.com, bbs.t-firefly.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.51tee.cc, Disposable vapes
P.S.JpexamGoogle DriveǹФƤoϤ2026 Fortinet NSE7_OTS-7.2ףhttps://drive.google.com/open?id=1klU8IBsiyjJreqCHRDn8v-BNFM6Nlfr-
