Web-Based Practice Tests: The Key to Pegasystems PEGACPRSA22V1 Exam Success
Posted at 1/11/2026 06:06:34
What's more, part of that Test4Engine PEGACPRSA22V1 dumps now are free: https://drive.google.com/open?id=1ebieXRfXyfKjOzuPWQcqi6O_6qC6zcL3
If you don't have an electronic product around you, or you don't have a network, you can use a printed PDF version of our PEGACPRSA22V1 training materials. We also strongly recommend that you print a copy of the PDF version of your PEGACPRSA22V1 study materials in advance so that you can use it as you like. And you can also take notes on the printale PEGACPRSA22V1 Exam Questions whenever you had a better understanding. Of course, which kind of equipment to choose to study will ultimately depend on your own preference.
The PEGACPRSA22V1 Certification Exam is an advanced-level exam that is intended for experienced RPA professionals who have a deep understanding of the Pega platform. Candidates who pass PEGACPRSA22V1 exam demonstrate their expertise in designing, building, and deploying Pega Robotics solutions. They are also recognized as experts in using Pega's RPA technology to automate complex business processes, improve operational efficiency, and reduce costs.
The Pega Robotics System Architect exam is a challenging and comprehensive exam that tests the candidate's understanding of Pega Robotics technology and its applications. PEGACPRSA22V1 Exam covers a wide range of topics, including Pega Robotics architecture, design and development of Pega Robotics solutions, runtime components, and deployment and management of robotic processes. Candidates who pass the PEGACPRSA22V1 exam are recognized as certified Pega Robotics System Architects, and they are well-equipped to design and deploy Pega Robotics solutions that drive business value.
PEGACPRSA22V1 Latest Exam Practice & Test PEGACPRSA22V1 Dumps PdfOur professionals are specialized in providing our customers with the most reliable and accurate PEGACPRSA22V1 exam guide and help them pass their exams by achieve their satisfied scores. You can refer to the warm feedbacks on our website, our customers all passed the PEGACPRSA22V1 Exam with high scores. Not only because that our PEGACPRSA22V1 study materials can work as the guarantee to help them pass, but also because that our PEGACPRSA22V1 learning questions are high effective according to their accuracy.
The Certified Pega Robotics System Architect 22 certification is designed for professionals who work with Pega Robotics System Architect or those who are interested in pursuing a career in the field. Certified Pega Robotics System Architect 22 certification exam will validate the skills required to design, develop, and deploy intelligent automation solutions using Pega Robotics technology.
Pegasystems Certified Pega Robotics System Architect 22 Sample Questions (Q72-Q77):NEW QUESTION # 72
In a Java application, you click a button to load a grid. The grid loads as a separate process under the Java application.
Which property allows you to interrogate the grid?
- A. EnableMatchInProcess
- B. IgnoreMainBrowser
- C. HookChildProcesses
- D. TargetPath
Comprehensive and Detailed Explanation From Pega Robotics System Exact Extract:
In Pega Robot Studio, when interrogating Java applications, sometimes a child process is created separately from the main application process. In such cases, controls in the child process cannot be detected unless the adapter is configured to attach to child processes as well.
According to the Pega Robotics System Design and Implementation Guide, in the section "Java Application Integration and Child Processes":
"For Java applications that spawn additional processes, set the HookChildProcesses property of the adapter to True.
This enables the adapter to attach to both the main process and any child processes created by the parent application, allowing interrogation and automation of controls within those secondary windows." Detailed Reasoning:
* HookChildProcesses ensures that when a Java application spawns a new process (such as a popup or a grid), Pega Robotics attaches to and monitors that process.
* Without enabling this property, the adapter would only recognize the primary Java process, leaving controls in secondary processes unrecognized.
Option Analysis:
* A. HookChildProcesses: Correct. Allows interrogation of child processes.
* B. EnableMatchInProcess: Incorrect. Used for controlling object matching within the same process context.
* C. TargetPath: Incorrect. Defines executable location for adapters.
* D. IgnoreMainBrowser: Incorrect. Related to web adapters, not Java applications.
Reference:Extracted and verified from Pega Robotics System Design and Implementation Guide, Java Adapter Configuration and HookChildProcesses Property section (Pega Robotics 19.1 and later).
NEW QUESTION # 73
While setting up Start My Day, the user makes some changes in the Manage Applications window to prioritize and manage the applications that are configured to launch using the Start My Day functionality.
Which of the following applications does the user see on the desktop after using the Start My Day functionality?
- A. CRM, Notepad, BankerInsight
- B. CRM, BankerInsight
- C. Pega Finance, Notepad, BankerInsight
- D. Pega Finance, CRM, Notepad, BankerInsight
In Pega Robot Studio, the Start My Day (SMD) functionality allows a user to define and launch all required applications at once when starting work. The configuration of these applications is performed in the Manage Applications window, where each application can be individually enabled or disabled for automatic startup.
According to the Pega Robotics System Design and Implementation Guide, in the section "Start My Day Configuration and Manage Applications", the documentation specifies the following:
"Applications configured for Start My Day will launch automatically when the Start My Day feature is invoked.
The Manage Applications dialog lists all project applications and determines which ones are launched using the 'Enabled' checkbox.
Only applications marked as enabled will be started when the user initiates Start My Day. Applications that are listed but not enabled remain closed." The screenshot in the question shows the following configuration under the Manage Applications window:
Application
Enabled
Type
Path
Pega Finance
Yes
Adapter
BankerInsight
Yes
Adapter
C rogram Files (x86)CRM SetupCRM.exe
CRM
No
Exe
Notepad
Yes
Exe
C:Windowsotepad.exe
From this configuration, the Enabled column indicates that the following applications will start automatically when Start My Day is triggered:
* Pega Finance
* BankerInsight
* Notepad
The CRM application is not enabled and therefore will not launch.
Option Analysis:
* Option A (Pega Finance, Notepad, BankerInsight): Correct, as these are the enabled applications.
* Option B (CRM, BankerInsight): Incorrect, because CRM is not enabled.
* Option C (CRM, Notepad, BankerInsight): Incorrect, because CRM is not enabled.
* Option D (Pega Finance, CRM, Notepad, BankerInsight): Incorrect, because CRM is not enabled.
Therefore, the correct answer is A. Pega Finance, Notepad, BankerInsight.
Reference:Extracted and verified from Pega Robotics System Design and Implementation Guide, Start My Day (SMD) Configuration and Application Management section (Pega Robotics 19.1 and later).
NEW QUESTION # 74
Deploying a robotic project to Pega Robot Manager requires configuring the Pega server and credentials.
The server connectivity settings can be set up or adjusted in several ways.
Which three of the following options are methods to set up or adjust the Pega Server settings? (Choose Three)
- A. Rerun the Pega Robot Studio installation and configure the server settings.
- B. Edit the Change Server fields during the deployment process.
- C. Edit the Server Connectivity settings in the Tools menu in Pega Robot Studio.
- D. Manually edit the PegaStudioConfig.xml file from the Tools menu in Pega Robot Studio.
- E. Configure the server settings during the initial installation of Pega Robot Studio.
Answer: B,C,E
Pega Robot Studio provides multiple ways to configure or modify Pega Server connectivity settings used for Robot Manager deployment. These settings define the server URL, operator credentials, and authentication method.
According to the Pega Robotics System Design and Implementation Guide, section "Configuring Pega Server Connectivity":
"Server connectivity settings can be specified in multiple ways within Pega Robot Studio:
* During the initial installation process, when prompted to enter Robot Manager URL and credentials.
* By navigating to the Tools # Options # Server Connectivity menu to edit or test server details.
* By adjusting the Change Server fields that appear during the deployment process to override existing configurations.Manual editing of XML files is not recommended for changing server connectivity settings." Detailed Reasoning:
* A. Edit the Change Server fields during the deployment process - Correct. The deployment wizard allows adjusting or overriding existing server settings.
* B. Configure the server settings during the initial installation of Pega Robot Studio - Correct. The installation wizard prompts for server setup.
* C. Rerun the Pega Robot Studio installation and configure the server settings - Not necessary unless reinstallation is required.
* D. Manually edit the PegaStudioConfig.xml file - Not recommended or supported for changing connectivity.
* E. Edit the Server Connectivity settings in the Tools menu in Pega Robot Studio - Correct. This is the standard interface to modify or test connection settings.
Reference:Extracted and verified from Pega Robotics System Design and Implementation Guide, Server Connectivity and Deployment Configuration section (Pega Robotics 19.1 and later).
NEW QUESTION # 75
The Adapter Match Rules tab provides the developer the access to resolve match rule issues during interrogation of an application and during maintenance of the solution. The Match Rules tab contains four areas.
Drag each Area on the left to the correct Area Description.
NEW QUESTION # 76
When maintaining a robotic project, you encounter two separate issues with matching. In the first issue, the hierarchy of a web page has changed, and the control no longer matches. In the other issue, the control has multiple match rules, and one fails to match the control. Which two of the following interrogation methods can you use to resolve the matching issues in the project? (Choose Two)
- A. Debug Control
- B. Replace Control
- C. Replace Matching
- D. Debug Matching
- E. Refresh Matching
Answer: D,E
According to Pega Robotics Studio - Matching and Interrogation Tools Documentation:
"Matching defines how a control is identified at runtime. When application hierarchies change or specific match rules fail, Robot Studio provides diagnostic tools to reestablish and verify the correct control associations." The guide specifies the following tools and their purpose:
* Refresh Matching
"Refresh Matching updates the control's properties and hierarchy information based on the current application structure without re-interrogating the control. This tool is useful when an application's DOM or hierarchy has changed."
* Debug Matching
"Debug Matching opens the Match Rules Diagnostics window and evaluates each match rule in real-time to show which rules pass or fail. It assists in identifying which match rule must be corrected or replaced." By contrast:
* Replace Matching - Recreates the match rules from scratch (not the preferred first step).
* Replace Control - Reinterrogates the entire control and removes existing references (used only when the control is entirely invalid).
* Debug Control - Analyzes properties but not matching logic.
Thus, the two correct tools to address the described issues are:
Refresh Matching (for hierarchy change)
Debug Matching (for failed rule troubleshooting)
References (Exact Extract Source):
* Pega Robotics Studio - Matching Diagnostics and Interrogation Guide
* Pega Robotics System Architect Training - Debugging and Refresh Matching Modules
* Pega Robotics Help - Managing Match Rules in Chrome/Edge/Web Adapters Final Verified answer: A, C
NEW QUESTION # 77
PEGACPRSA22V1 Latest Exam Practice: https://www.test4engine.com/PEGACPRSA22V1_exam-latest-braindumps.html
- Latest PEGACPRSA22V1 Test Prep 🐦 Mock PEGACPRSA22V1 Exam ✋ PEGACPRSA22V1 Online Test 🐨 Search for ✔ PEGACPRSA22V1 ️✔️ and easily obtain a free download on ▛ [url]www.testkingpass.com ▟ 🐼New PEGACPRSA22V1 Dumps Sheet[/url]
- High Pass-Rate PEGACPRSA22V1 Instant Download - 100% Pass PEGACPRSA22V1 Exam 🤽 Open ( [url]www.pdfvce.com ) and search for ☀ PEGACPRSA22V1 ️☀️ to download exam materials for free 🏹
EGACPRSA22V1 Online Test[/url] - High Pass-Rate PEGACPRSA22V1 Instant Download - 100% Pass PEGACPRSA22V1 Exam ⏫ The page for free download of 【 PEGACPRSA22V1 】 on ⏩ [url]www.practicevce.com ⏪ will open immediately 🏈Online PEGACPRSA22V1 Tests[/url]
- Pass Guaranteed 2026 PEGACPRSA22V1: Certified Pega Robotics System Architect 22 Latest Instant Download 🔼 Copy URL ▷ [url]www.pdfvce.com ◁ open and search for ☀ PEGACPRSA22V1 ️☀️ to download for free 📜Latest PEGACPRSA22V1 Test Prep[/url]
- Newest PEGACPRSA22V1 Instant Download - Leading Offer in Qualification Exams - Authoritative PEGACPRSA22V1 Latest Exam Practice 🐫 Simply search for “ PEGACPRSA22V1 ” for free download on ☀ [url]www.testkingpass.com ️☀️ 🙀Test PEGACPRSA22V1 Sample Questions[/url]
- High Pass-Rate PEGACPRSA22V1 Instant Download - 100% Pass PEGACPRSA22V1 Exam 🕸 Simply search for ➡ PEGACPRSA22V1 ️⬅️ for free download on 「 [url]www.pdfvce.com 」 🍕Reliable PEGACPRSA22V1 Exam Online[/url]
- PEGACPRSA22V1 Customizable Exam Mode 😺 PEGACPRSA22V1 Online Test 👒 Reliable PEGACPRSA22V1 Braindumps Ebook 🥋 Go to website ▷ [url]www.prep4sures.top ◁ open and search for ▷ PEGACPRSA22V1 ◁ to download for free 🔛Real PEGACPRSA22V1 Testing Environment[/url]
- Reliable PEGACPRSA22V1 Exam Questions 🛣 New PEGACPRSA22V1 Dumps Free 🥭 Exam PEGACPRSA22V1 Introduction 🍒 Easily obtain ▶ PEGACPRSA22V1 ◀ for free download through ☀ [url]www.pdfvce.com ️☀️ 🌆
ass PEGACPRSA22V1 Rate[/url] - High Pass-Rate PEGACPRSA22V1 Instant Download - 100% Pass PEGACPRSA22V1 Exam 👔 Immediately open ➤ [url]www.easy4engine.com ⮘ and search for ▶ PEGACPRSA22V1 ◀ to obtain a free download 🖤
EGACPRSA22V1 Customizable Exam Mode[/url] - Reliable PEGACPRSA22V1 Exam Online ✌ Reliable Exam PEGACPRSA22V1 Pass4sure ☸ Reliable PEGACPRSA22V1 Exam Online 🐃 Simply search for ( PEGACPRSA22V1 ) for free download on ▶ [url]www.pdfvce.com ◀ 🐴
EGACPRSA22V1 Customizable Exam Mode[/url] - Online PEGACPRSA22V1 Tests 📁 PEGACPRSA22V1 Online Test ⛺ Exam PEGACPRSA22V1 Introduction 🖋 Search for ➥ PEGACPRSA22V1 🡄 on { [url]www.practicevce.com } immediately to obtain a free download 🕳Test PEGACPRSA22V1 Sample Questions[/url]
- www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, lb.abcbbk.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.74ax.com, appos-wp.edalytics.com, Disposable vapes
P.S. Free 2026 Pegasystems PEGACPRSA22V1 dumps are available on Google Drive shared by Test4Engine: https://drive.google.com/open?id=1ebieXRfXyfKjOzuPWQcqi6O_6qC6zcL3
