Order-Management-Administrator Latest Exam Questions - Real Order-Management-Adm
Posted at 1/11/2026 06:23:52
BONUS!!! Download part of TrainingQuiz Order-Management-Administrator dumps for free: https://drive.google.com/open?id=1hSjoJAuGFXyaF5l5kOdMYF3AtZ0HFMUe
With the Order-Management-Administrator exam, you will harvest many points of theories that others ignore and can offer strong prove for managers. So the Order-Management-Administrator exam is a great beginning. However, since there was lots of competition in this industry, the smartest way to win the battle is improving the quality of our Order-Management-Administrator Learning Materials, which we did a great job. With passing rate up to 98 to 100 percent, you will get through the Order-Management-Administrator exam with ease.
Salesforce Order-Management-Administrator Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Order Management Basics: In this topic, the Salesforce Order Management Administrator Consultant learns to position Order Management effectively within Salesforce's core architecture. By articulating the extensible platform capabilities, the ability to integrate with third-party systems, and the overall value proposition, this knowledge helps highlight Order Management's seamless adaptability and efficiency. These insights are crucial for demonstrating business value during client engagements.
| | Topic 2 | - Process Automation and Integrations: This section helps the Salesforce Order Management Administrator Consultant demonstrate the capability to deliver business value by integrating Order Management with external systems using clicks rather than code. Mastery of navigation within Order Management processes, connecting nodes, and integrating systems efficiently ensures understanding of how to implement effective solutions.
| | Topic 3 | - User Experience and Customization: This section emphasizes leveraging Salesforce's Lightning UI to enhance user experiences. The Salesforce Order Management Administrator Consultant will customize experiences for users and managers through tools like the Lightning Page Editor, Report Builder, and out-of-the-box components. Success in this area ensures optimized workflows and improved operational efficiency.
Real Order-Management-Administrator Question, Reliable Order-Management-Administrator Exam BookIn order to help you get Order-Management-Administrator certification, many experts have worked hard for several years to formulate Order-Management-Administrator exam torrent for all examiners. In such a way, our Order-Management-Administrator study materials not only target but also cover all knowledge points. Our Order-Management-Administrator practice materials also have a statistical analysis function to help you find out the deficiency in the learning process of Order-Management-Administrator practice materials, so that you can strengthen the training for weak links. In this way, you can more confident for your success since you have improved your ability.
Salesforce Order Management Administrator Accredited Professional Sample Questions (Q71-Q76):NEW QUESTION # 71
How can an administrator quickly examine the relationships between several objects?
- A. Download it from the Partner Community
- B. Generate an Entity Relationship Diagram by going to Data in Setup
- C. File a support case asking for a data relationship diagram
- D. Go to Schema Builder and check the boxes next to the object names
The best way for an administrator to quickly examine the relationships between several objects is to go to Schema Builder and check the boxes next to the object names. Schema Builder is a tool that allows administrators to view and modify the data model of their org in a graphical interface. Schema Builder shows the objects and fields in the org, as well as the relationships between them. The administrator can use Schema Builder to select the objects that they want to examine, and see how they are connected to each other. Verified Reference: https://help.salesforce.com/s/ar ... lder.htm&type=5
NEW QUESTION # 72
An administrator is attempting to deploy aChange Set from a development org to a test org but the test org is not available in the list of target organizations. What are two reasons that could cause this issue?
- A. The development org has not been approved to upload Change Sets from within the test org
- B. ChangeSets can only be deployed from a sandbox org to a production org, not another sandbox org.
- C. The components in the Change set could not be found within the test org
- D. The development org and test org are not associated with the same production org.
Two reasons that could cause the issue of not being able to deploy a Change Set from a development org to a test org are:
The development org has not been approved to upload Change Sets from within the test org. To deploy ChangeSets between two sandbox orgs, the administrator needs to establish a deployment connection between them. A deployment connection allows one org to send outbound Change Sets and another org to receive inbound Change Sets. The administrator can create a deployment connection request from the development org and approve it from the test org.
The development org and test org are not associated with the same production org. To deploy Change Sets between two sandbox orgs, they must be linked to the same production org. A production org is an org that contains live data and business processes. A sandbox org is a copy of a production org that is used for development, testing, or training purposes. Sandbox orgs inherit the deployment connections of their source production orgs. References: Deploy Using Change Sets, Deploy a Change Set
NEW QUESTION # 73
A company has an external system that stores client accounting data but they want to be able to search for this data within Salesforce. What three steps should the administrator take to implement this functionality?
- A. Create an automated data capture (or the external system
- B. Create an External Data Source pointing to the external system's database
- C. Create an Indirect Lookup field to connect to the Account
- D. Create an automated import of the external data using the Job Scheduler
- E. Create an External Object for each fable of accounting data in the external system
Answer: B,C,E
Three steps that the administrator should take to implement this functionality are:
Create an External Data Source pointing to the external system's database. An External Data Source is a type of metadata that defines the connection and authentication information for an external system that stores data outside of Salesforce. The administrator can create an External Data Source using the Lightning Connect OData 2.0 or 4.0 adapters, which support read-only access to data in relational databases.
Create an External Object for each table of accounting data in the external system. An External Object is a type of custom object that maps to a table in an external system. The administrator can create an External Object for each table of accounting data that they want to access from Salesforce, and define its fields and relationships accordingly.
Create an Indirect Lookup field to connect to the Account. An Indirect Lookup field is a type of custom field that links a child External Object record to a parent standard or custom object record. The administrator can create an Indirect Lookup field on the External Object that references the Account object, and specify the external column name and value that match the Account ID.
Verified Reference: https://help.salesforce.com/s/ar ... view.htm&type=5 https://help.salesforce.com/s/ar ... hips.htm&type=5
NEW QUESTION # 74
At minimum, a custom attribute must be created on which objects for the values to automap in Order Management from B2C Commerce Cloud at the Order item level?
- A. Order, Order Summary, Change Order and Fulfillment Order
- B. Order Item and Order Item Summary
- C. Order, Order Summary, Order Item and Order Item Summary
- D. Order and Order Summary
NEW QUESTION # 75
A customer orders two shirts and one jacket in B2C Commerce. The Order is ingested into Order Management. However, the customer decides to cancel the order prior to fulfillment. What object is created and linked to the Order Summary?
- A. Return Order
- B. Cancel Order
- C. Change Order
- D. Suspend Order
NEW QUESTION # 76
Customers of TrainingQuiz will also get up to 90 days of Salesforce Certified ICT Expert Order-Management-Administrator free real questions updates as a bonus perk. TrainingQuiz not only provides the updated Salesforce Order-Management-Administrator practice questions but also offers these excellent offers that make them the best option in the market. Don't wait anymore. Buy TrainingQuiz's Salesforce Order Management Administrator Accredited Professional (Order-Management-Administrator) updated practice material today!
Real Order-Management-Administrator Question: https://www.trainingquiz.com/Order-Management-Administrator-practice-quiz.html
- Order-Management-Administrator Test Braindumps 📯 Order-Management-Administrator Reliable Braindumps Pdf 🥽 Order-Management-Administrator Free Pdf Guide 🏖 Search for ⮆ Order-Management-Administrator ⮄ on { [url]www.examcollectionpass.com } immediately to obtain a free download 🙊Test Order-Management-Administrator Lab Questions[/url]
- Order-Management-Administrator Exam Braindumps 🪁 Valid Exam Order-Management-Administrator Blueprint 🥪 Test Order-Management-Administrator Lab Questions 🚺 Easily obtain free download of ➡ Order-Management-Administrator ️⬅️ by searching on ➽ [url]www.pdfvce.com 🢪 🍗Order-Management-Administrator Test Braindumps[/url]
- Order-Management-Administrator Exam Braindumps 🔓 Order-Management-Administrator Vce Exam 🦇 Order-Management-Administrator Vce Exam 🔸 Enter 【 [url]www.examcollectionpass.com 】 and search for 【 Order-Management-Administrator 】 to download for free 🐖Order-Management-Administrator Online Test[/url]
- Order-Management-Administrator Test Braindumps 🏳 Reliable Order-Management-Administrator Dumps Ebook 😼 Valid Order-Management-Administrator Test Notes 🍎 Simply search for ➤ Order-Management-Administrator ⮘ for free download on ➥ [url]www.pdfvce.com 🡄 🦞Reliable Order-Management-Administrator Test Tutorial[/url]
- Order-Management-Administrator Latest Exam Questions | Reliable Real Order-Management-Administrator Question: Salesforce Order Management Administrator Accredited Professional 🌜 Download 【 Order-Management-Administrator 】 for free by simply searching on “ [url]www.examcollectionpass.com ” 🐒Order-Management-Administrator Exam Braindumps[/url]
- Is Using Salesforce Order-Management-Administrator Exam Dumps Important To Pass The Exam? 🧀 Search for ⇛ Order-Management-Administrator ⇚ and easily obtain a free download on ➤ [url]www.pdfvce.com ⮘ 🦉Order-Management-Administrator Study Reference[/url]
- Pass Guaranteed 2026 Order-Management-Administrator: Salesforce Order Management Administrator Accredited Professional Latest Exam Questions 🐐 Download ☀ Order-Management-Administrator ️☀️ for free by simply entering ☀ [url]www.troytecdumps.com ️☀️ website 🤡Order-Management-Administrator Online Test[/url]
- Valid Braindumps Order-Management-Administrator Pdf ❣ Order-Management-Administrator Study Reference 🥞 Order-Management-Administrator Test Braindumps 🌂 Search for ▛ Order-Management-Administrator ▟ on 【 [url]www.pdfvce.com 】 immediately to obtain a free download 🚋Order-Management-Administrator Exam Course[/url]
- Valid Order-Management-Administrator Test Notes 🧊 Order-Management-Administrator Free Pdf Guide 😥 Order-Management-Administrator Actual Dump 📁 Search for ➡ Order-Management-Administrator ️⬅️ and download it for free immediately on ▷ [url]www.testkingpass.com ◁ 🔩Order-Management-Administrator Exam Braindumps[/url]
- Free PDF Quiz Useful Salesforce - Order-Management-Administrator - Salesforce Order Management Administrator Accredited Professional Latest Exam Questions ⚓ The page for free download of ➡ Order-Management-Administrator ️⬅️ on ▷ [url]www.pdfvce.com ◁ will open immediately ❓Valid Braindumps Order-Management-Administrator Pdf[/url]
- Introducing [url]www.verifieddumps.com: Your Path to Order-Management-Administrator Success 🏞 The page for free download of [ Order-Management-Administrator ] on 【 www.verifieddumps.com 】 will open immediately 😌Test Order-Management-Administrator King[/url]
- gtayou.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.4shared.com, myspace.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, bbs.t-firefly.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, github.com, proverac.com, Disposable vapes
P.S. Free & New Order-Management-Administrator dumps are available on Google Drive shared by TrainingQuiz: https://drive.google.com/open?id=1hSjoJAuGFXyaF5l5kOdMYF3AtZ0HFMUe
