[General] New Microsoft AZ-305 Test Cost, Examcollection AZ-305 Dumps Torrent
90
【General】 New Microsoft AZ-305 Test Cost, Examcollection AZ-305 Dumps Torrent
Posted at 1/11/2026 06:39:18      View:186 | Replies:2        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of PassTestking AZ-305 dumps from Cloud Storage: https://drive.google.com/open?id=1sRFhr_UC1l86WhejwUkJFnq-Sjy8d6Z8
Our passing rate is 99% and our product boosts high hit rate. Our AZ-305 test torrents are compiled by professionals and the answers and the questions we provide are based on the real exam. The content of our AZ-305 exam questions is simple to be understood and mastered. To let you get well preparation for the exam, our software provides the function to stimulate the real exam and the timing function to help you adjust the speed. Based on those merits of our AZ-305 Guide Torrent you can pass the exam with high possibility.
Once certified, professionals with the Microsoft AZ-305 credential can demonstrate their ability to design and implement Azure infrastructure solutions that meet the needs of their organization. They can also enhance their career prospects and demonstrate their commitment to ongoing professional development. Overall, the Microsoft AZ-305 Exam is an excellent way for professionals to validate their skills and knowledge of Azure infrastructure solutions and gain a competitive edge in the industry.
Examcollection AZ-305 Dumps Torrent - AZ-305 Test Guide OnlineMost IT workers prefer to choose our online test engine for their AZ-305 exam prep because online version is more flexible and convenient. With the help of our online version, you can not only practice our AZ-305 Exam PDF in any electronic equipment, but also make you feel the atmosphere of AZ-305 actual test. The exam simulation will mark your mistakes and help you play well in AZ-305 practice test.
Microsoft Designing Microsoft Azure Infrastructure Solutions Sample Questions (Q194-Q199):NEW QUESTION # 194
You need to recommend a solution that meets the file storage requirements for App2.
What should you deploy to the Azure subscription and the on-premises network? To answer, drag the appropriate services to the correct locations. Each service may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content.
https://docs.microsoft.com/en-us ... nc-deployment-guide
NEW QUESTION # 195
You have an Azure subscription that contains the resources shown in the following table.
VNet1. VNet2. and VNet3 each has multiple virtual machines connected. The virtual machines use the Azure DNS service for name resolution.
You need to recommend an Azure Monitor log routing solution that meets the following requirements:
* Ensures that the logs collected from the virtual machines and sent to Workspace1 are routed over the Microsoft backbone network
* Minimizes administrative effort
What should you include in the recommendation? To answer, select the appropriate options in the answer area. NOTE: Each correct selection is worth one point.
NEW QUESTION # 196
You have two on-premises Microsoft SQL Server 2017 instances that host an Always On availability group named AG1. AG1 contains a single database named DB1.
You have an Azure subscription that contains a virtual machine named VM1VM1 runs Linux and contains a SQL Server 2019 instance.
You need to migrate DB1 to VMI. The solution must minimize downtime on DBI. What should you do? To answer, select the appropriate options in the answer area.
NEW QUESTION # 197
You need to design a highly available Azure SQL database that meets the following requirements:
* Failover between replicas of the database must occur without any data loss.
* The database must remain available in the event of a zone outage.
* Costs must be minimized.
Which deployment option should you use?
  • A. Azure SQL Database Business Critical
  • B. Azure SQL Database Standard
  • C. Azure SQL Database Managed Instance Business Critical
  • D. Azure SQL Database Hyperscale
General Purpose / Standard prevents data loss through high available storage https://docs.microsoft.com/en-us ... pose?view=azuresql. This architectural model relies on high availability and reliability of Azure Blob storage that transparently replicates database files and guarantees no data loss if underlying infrastructure failure happens. General Purpose / Standard support Zone Redundancy For General Purpose tier the zone-redundant configuration is Generally Available in the following regions: https://docs.microsoft.com/en-us ... bs=azure-powershell Without any information regarding the usage pattern, serverless is possible. Other option is D https://docs.microsoft.com/en-us ... rview?view=azuresql
NEW QUESTION # 198
You need to recommend a strategy for the web tier of WebApp1.
The solution must minimize.
What should you recommend?
  • A. Configure the Scale Up settings for a web app.
  • B. Deploy a virtual machine scale set that scales out on a 75 percent CPU threshold.
  • C. Configure the Scale Out settings for a web app.
  • D. Create a runbook that resizes virtual machines automatically to a smaller size outside of business hours.
NEW QUESTION # 199
With our AZ-305 study materials, all your agreeable outcomes are no longer dreams for you. And with the aid of our AZ-305 exam preparation to improve your grade and change your states of life and get amazing changes in career, everything is possible. It all starts from our AZ-305 learning questions. Come and buy our AZ-305 practice engine, you will be confident and satisfied with it and have a brighter future.
Examcollection AZ-305 Dumps Torrent: https://www.passtestking.com/Microsoft/AZ-305-practice-exam-dumps.html
P.S. Free 2026 Microsoft AZ-305 dumps are available on Google Drive shared by PassTestking: https://drive.google.com/open?id=1sRFhr_UC1l86WhejwUkJFnq-Sjy8d6Z8
Posted at 1/30/2026 05:18:58        Only Author  2#
I love the content, so it’s an instant like for me. I’m sharing the Health-Cloud-Accredited-Professional test dumps demo questions that helped me get promoted and earn more—grab them for free!
Posted at 2/4/2026 07:17:03        Only Author  3#
I’m so thankful for your article, it really made me think. Free AD0-E137 valid exam collection free shared to elevate your IT skills. Wishing you success in your exams!
