[General] CMMC-CCA Testfagen & CMMC-CCA Praxisprfung
99
General CMMC-CCA Testfagen & CMMC-CCA Praxisprfung
Posted at 1/11/2026 07:01:16      View113 | Replies1        Print      Only Author   [Copy Link] 1#
Machen Sie sich noch Sorge darum, dass Sie keine enchten und zuversichtlichen Schulungsunterlagen zur Cyber AB CMMC-CCA Zertifizierungsprfung finden können? Schulungsunterlagen zur Cyber AB CMMC-CCA Zertifizierungsprfung aus It-Pruefung sind von den erfahrenen IT-Experten zusammengechlossen, sie sind kombniert von Fragen und Antworten, daher sind sie nicht vergleichbar. Ihre Genauigkeit ist auch zweifellos. Wählen Sie It-Pruefung, dann wählen Sie Erfolg.
Cyber AB CMMC-CCA Prfungsplan:
ThemaEinzelheiten
Thema 1
  • CMMC Level 2 Assessment Scoping: This section of the exam measures skills of cybersecurity assessors and revolves around determining the proper scope of a CMMC assessment. It involves analyzing and categorizing Controlled Unclassified Information (CUI) assets, interpreting the Level 2 scoping guidelines, and making accurate judgments in scenario-based exercises to define what assets and systems fall within assessment boundaries.
Thema 2
  • CMMC Assessment Process (CAP): This section of the exam measures skills of compliance professionals and tests knowledge of the full assessment lifecycle. It covers the steps needed to plan, prepare, conduct, and report on a CMMC Level 2 assessment, including the phases of execution and how to document and follow up on findings in alignment with DoD and CMMC-AB expectations.
Thema 3
  • Evaluating Organizations Seeking Certification (OSC) against CMMC Level 2 Requirements: This section of the exam measures skills of cybersecurity assessors and focuses on evaluating the environments of organizations seeking certification at CMMC Level 2. It covers understanding differences between logical and physical settings, recognizing constraints in cloud, hybrid, on-premises, single, and multi-site environments, and knowing what environmental exclusions apply for Level 2 assessments.
Thema 4
  • Assessing CMMC Level 2 Practices: This section of the exam measures skills of cybersecurity assessors in evaluating whether organizations meet the required practices of CMMC Level 2. It emphasizes applying CMMC model constructs, understanding model levels, domains, and implementation, and using evidence to determine compliance with established cybersecurity practices.
CMMC-CCA Praxisprfung, CMMC-CCA ProbesfragenHier möchte ich ber eine Kernfrage sprechen. Alle Cyber AB CMMC-CCA Zertifizierungsprfungen sind wichtig. Im Zeitalter, wo die Information hoch entwickelt ist, ist It-Pruefung nur eine der zahlreichen Websites. Warum wählen viele Leute It-Pruefung? Denn die Prfungsmaterialien von It-Pruefung werden Ihnen sicher beim Bestehen der Cyber AB CMMC-CCA Prfung helfen. It-Pruefung aktualisiert ständig seine Materialien und Trainingsinstrumente. Mit den Prfungsfragen und Antworten zur Cyber AB CMMC-CCA Zertifizierungsprfung von It-Pruefung werden Sie mehr Selbstbewusstsein fr die Prfung haben. Sie brauchen sich keine Sorgen um das Risiko der Prfung zu machen. Sie können ganz mhlos die Prfung bestehen.
Cyber AB Certified CMMC Assessor (CCA) Exam CMMC-CCA Prfungsfragen mit Lösungen (Q123-Q128):123. Frage
An OSC is undergoing a CMMC assessment by a C3PAO. The assessment team has been on-site for several days, reviewing the OSC's systems, policies, and procedures against the CMMC requirements. Each day, the assessment team holds a "daily checkpoint" meeting with the OSC's security team and representatives. This checkpoint serves an important purpose in the overall assessment process. What is the significance of the Daily Checkpoint meeting in the CMMC assessment process?
  • A. It provides an opportunity for the Assessment Team to review and verify additional evidence.
  • B. It allows the Lead Assessor to finalize the assessment findings independently.
  • C. It is solely for updating the OSC on the assessment progress.
  • D. It is optional and not necessary for the assessment process.
Antwort: A
Begrndung:
Comprehensive and Detailed in Depth Explanation:
The CAP mandates Daily Checkpoint meetings to review additional evidence and ensure assessment progress, not to finalize findings (Option A), as optional (Option B), or solely for updates (Option C). Option D reflects its core purpose.
Extract from Official Document (CAP v1.0):
* Section 2.3 - Daily Checkpoint Meetings (pg. 27):"The Daily Checkpoint meeting provides an opportunity to review and verify additional evidence presented by the OSC." References:
CMMC Assessment Process (CAP) v1.0, Section 2.3.
124. Frage
An OSC has produced two assessment scopes. When the Lead Assessor questioned the OSC PoC why, they detailed that they process, store, or transmit FCI within one assessment scope and CUI in another. Which scope will the OSC obtain a CMMC Level 2 certification for?
  • A. The OSC cannot be certified at Level 2 because they haven't met Level 1 requirements
  • B. The scope that processes, transmits, or stores FCI
  • C. The scope that transmits, processes, or stores CUI
  • D. For both assessment scopes
Antwort: C
Begrndung:
The CMMC framework allows separate scopes for FCI (Level 1) and CUI (Level 2). Level 2 certification applies only to environments handling CUI, as it requires all 110 practices, whereas Level 1 (17 practices) suffices for FCI alone. The OSC's CUI scope qualifies for Level 2, while the FCI scope aligns with Level 1 (or a self-assessment). Option C is incorrect, as Level 2 doesn't apply to FCI-only scopes. Option D lacks evidence of Level 1 non-compliance. B is correct per the scoping guide.
CMMC Assessment Scope - Level 2, Section 1.1 (Level Applicability), p. 2: "Level 2 certification applies to CUI-handling environments."
125. Frage
In your assessment of an OSC's information systems, you realize that the OSC has been having issues determining what is and isn't CUI. One of the employees asks for your help identifying CUI so that they can take measures to protect it. They also request that you recommend a resource where they can understand the national CUI policy. Which of the following is the BEST resource they should visit to understand what CUI is and the national CUI policy?
  • A. 48 CFR 52.204-21 and NIST SP 800-171
  • B. DFARS 252.204-7012 and ISOO CUI Registry
  • C. 22 CFR Part 120-130
  • D. 32 CFR Part 2002 and ISOO CUI Registry
Antwort: D
Begrndung:
Comprehensive and Detailed In-Depth Explanation:
32 CFR Part 2002defines CUI and establishes the national policy, while theISOO CUI Registrycategorizes CUI types-together providing the authoritative resource for understanding CUI. Other options (A, B) are contract-specific or implementation-focused, and 22 CFR (D) relates to ITAR, not CUI policy. The CMMC guide references these sources.
Extract from Official CMMC Documentation:
* CMMC Assessment Guide Level 2 (v2.0): "Refer to 32 CFR Part 2002 and ISOO Registry for CUI definition."
* 32 CFR 2002.4(h): "CUI defined."
Resources:
* https://dodcio.defense.gov/Porta ... AG_Level2_MasterV2.
0_FINAL_202112016_508.pdf
126. Frage
During a CMMC assessment, an OSC employee asks the CCA if their current security measures are "good enough" to pass the assessment. The CCA responds by saying, "I can't tell you that, but here's what the CMMC requires for this practice." What principle of the CoPC does this response uphold?
  • A. Information Integrity
  • B. Objectivity
  • C. Confidentiality
  • D. Professionalism
Antwort: B
Begrndung:
By avoiding judgment and focusing on requirements, the CCA upholds Objectivity (Option C). Options A, B, and D are not directly relevant here.
Extract from Official Document (CoPC):
* Paragraph 2.2 - Objectivity (pg. 5):"Maintain objectivity by not providing opinions or recommendations during assessments." References:
CMMC Code of Professional Conduct, Paragraph 2.2.
127. Frage
You are a CCA on an Assessment Team conducting a CMMC Level 2 assessment. The OSC provides evidence for a practice that includes a log file, but the file is corrupted and cannot be opened. The OSC claims the log proves compliance but cannot provide a readable copy during the assessment. What should you do?
  • A. Score the practice as "NOT MET" due to the lack of readable evidence.
  • B. Document the corrupted file as an evidence gap and assess the practice based on other available evidence.
  • C. Accept the OSC's claim and score the practice as "MET" based on their assurance.
  • D. Request the OSC to recover the log file and provide a readable copy before continuing.
Antwort: B
Begrndung:
The CAP requires documenting unavailable evidence like a corrupted file as a gap and assessing based on other evidence (Option B). Option A lacks verification, Option C is premature, and Option D involves directing OSC actions, which is not allowed.
* Section 2.2 - Conduct Assessment (pg. 25):"Document unavailable or unreadable evidence as an evidence gap and proceed with assessment based on other evidence." References:
CMMC Assessment Process (CAP) v1.0, Section 2.2.
128. Frage
Sie können im Internet kostenlos die Software und Prfungsfragen und Antworten zur Cyber AB CMMC-CCA Zertifizierungsprfung als Probe herunterladen. It-Pruefung wird Ihnen helfen, die Cyber AB CMMC-CCA Zertifizierungsprfung zu bestehen. Wenn Sie unvorsichtigerweise in der Prfung durchfallen, erstatten wir Ihnen Ihre an uns geleistene Zahlung.
CMMC-CCA Praxisprfung: https://www.it-pruefung.com/CMMC-CCA.html
Posted at 1/19/2026 15:05:48        Only Author  2#
Im truly amazed by your article, thank you for your generosity! This C1000-189 reliable test camp free helped me get promoted and receive a salary increase. Now, its free for everyone. Wishing you success in your career journey!
