[General] Data-Engineer-Associate考題免費下載 & Data-Engineer-Associate考試大綱
82
【General】 Data-Engineer-Associate考題免費下載 & Data-Engineer-Associate考試大綱
Posted at 1/11/2026 07:02:52      View:423 | Replies:8        Print      Only Author   [Copy Link] 1#
我們Fast2test有龐大的IT精英團隊,會準確的迅速的為您提供Amazon Data-Engineer-Associate认证考試材料,也會及時的為Amazon Data-Engineer-Associate認證考試相關考試練習題和答案提供更新及裝訂,而且我們Fast2test也在很多認證行業中得到了很高的聲譽。雖然通過Amazon Data-Engineer-Associate認證考試的機率很小,但Fast2test的可靠性可以保證你能通過這個機率小的考試。
我們Fast2test Amazon的Data-Engineer-Associate考試培訓資料是最佳的培訓資料,如果你是IT人員,它將是你必選的培訓資料,不要拿你的未來來賭明天,Fast2test Amazon的Data-Engineer-Associate考試培訓資料絕對值得信賴,我們是專門給全世界的IT認證的考生提供培訓資料的,包括試題及答案,實現 Amazon的Data-Engineer-Associate考試認證,是許多IT和網路專業人士的目標,Fast2test的合格率是難以置信的高,在Fast2test,我們致力於你不斷的取得成功。
正確的Amazon Data-Engineer-Associate:AWS Certified Data Engineer - Associate (DEA-C01)考題免費下載 - 高效的Fast2test Data-Engineer-Associate考試大綱當你進入Fast2test網站,你看到每天進入Fast2test網站的人那麼多,不禁感到意外。其實這很正常的,我們Fast2test網站每天給不同的考生提供培訓資料數不勝數,他們都是利用了我們的培訓資料才順利通過考試的,說明我們的Amazon的Data-Engineer-Associate考試認證培訓資料真起到了作用,如果你也想購買,那就不要錯過我們Fast2test網站,你一定會非常滿意的。
最新的 AWS Certified Data Engineer Data-Engineer-Associate 免費考試真題 (Q128-Q133):問題 #128
A company uses AWS Step Functions to orchestrate a data pipeline. The pipeline consists of Amazon EMR jobs that ingest data from data sources and store the data in an Amazon S3 bucket. The pipeline also includes EMR jobs that load the data to Amazon Redshift.
The company's cloud infrastructure team manually built a Step Functions state machine. The cloud infrastructure team launched an EMR cluster into a VPC to support the EMR jobs. However, the deployed Step Functions state machine is not able to run the EMR jobs.
Which combination of steps should the company take to identify the reason the Step Functions state machine is not able to run the EMR jobs? (Choose two.)
  • A. Check for entries in Amazon CloudWatch for the newly created EMR cluster. Change the AWS Step Functions state machine code to use Amazon EMR on EKS. Change the IAM access policies and the security group configuration for the Step Functions state machine code to reflect inclusion of Amazon Elastic Kubernetes Service (Amazon EKS).
  • B. Verify that the Step Functions state machine code has all IAM permissions that are necessary to create and run the EMR jobs. Verify that the Step Functions state machine code also includes IAM permissions to access the Amazon S3 buckets that the EMR jobs use. Use Access Analyzer for S3 to check the S3 access properties.
  • C. Check the retry scenarios that the company configured for the EMR jobs. Increase the number of seconds in the interval between each EMR task. Validate that each fallback state has the appropriate catch for each decision state. Configure an Amazon Simple Notification Service (Amazon SNS) topic to store the error messages.
  • D. Use AWS CloudFormation to automate the Step Functions state machine deployment. Create a step to pause the state machine during the EMR jobs that fail. Configure the step to wait for a human user to send approval through an email message. Include details of the EMR task in the email message for further analysis.
  • E. Query the flow logs for the VPC. Determine whether the traffic that originates from the EMR cluster can successfully reach the data providers. Determine whether any security group that might be attached to the Amazon EMR cluster allows connections to the data source servers on the informed ports.
答案:B,E
解題說明:
To identify the reason why the Step Functions state machine is not able to run the EMR jobs, the company should take the following steps:
Verify that the Step Functions state machine code has all IAM permissions that are necessary to create and run the EMR jobs. The state machine code should have an IAM role that allows it to invoke the EMR APIs, such as RunJobFlow, AddJobFlowSteps, and DescribeStep. The state machine code should also have IAM permissions to access the Amazon S3 buckets that the EMR jobs use as input and output locations. The company can use Access Analyzer for S3 to check the access policies and permissions of the S3 buckets12. Therefore, option B is correct.
Query the flow logs for the VPC. The flow logs can provide information about the network traffic to and from the EMR cluster that is launched in the VPC. The company can use the flow logs to determine whether the traffic that originates from the EMR cluster can successfully reach the data providers, such as Amazon RDS, Amazon Redshift, or other external sources. The company can also determine whether any security group that might be attached to the EMR cluster allows connections to the data source servers on the informed ports. The company can use Amazon VPC Flow Logs or Amazon CloudWatch Logs Insights to query the flow logs3 . Therefore, option D is correct.
Option A is incorrect because it suggests using AWS CloudFormation to automate the Step Functions state machine deployment. While this is a good practice to ensure consistency and repeatability of the deployment, it does not help to identify the reasonwhy the state machine is not able to run the EMR jobs. Moreover, creating a step to pause the state machine during the EMR jobs that fail and wait for a human user to send approval through an email message is not a reliable way to troubleshoot the issue. The company should use the Step Functions console or API to monitor the execution history and status of the state machine, and use Amazon CloudWatch to view the logs and metrics of the EMR jobs .
Option C is incorrect because it suggests changing the AWS Step Functions state machine code to use Amazon EMR on EKS. Amazon EMR on EKS is a service that allows you to run EMR jobs on Amazon Elastic Kubernetes Service (Amazon EKS) clusters. While this service has some benefits, such as lower cost and faster execution time, it does not support all the features and integrations that EMR on EC2 does, such as EMR Notebooks, EMR Studio, and EMRFS. Therefore, changing the state machine code to use EMR on EKS may not be compatible with the existing data pipeline and may introduce new issues.
Option E is incorrect because it suggests checking the retry scenarios that the company configured for the EMR jobs. While this is a good practice to handle transient failures and errors, it does not help to identify the root cause of why the state machine is not able to run the EMR jobs. Moreover, increasing the number of seconds in the interval between each EMR task may not improve the success rate of the jobs, and may increase the execution time and cost of the state machine. Configuring an Amazon SNS topic to store the error messages may help to notify the company of any failures, but it does not provide enough information to troubleshoot the issue.
1: Manage an Amazon EMR Job - AWS Step Functions
2: Access Analyzer for S3 - Amazon Simple Storage Service
3: Working with Amazon EMR and VPC Flow Logs - Amazon EMR
[4]: Analyzing VPC Flow Logs with Amazon CloudWatch Logs Insights - Amazon Virtual Private Cloud
[5]: Monitor AWS Step Functions - AWS Step Functions
[6]: Monitor Amazon EMR clusters - Amazon EMR
[7]: Amazon EMR on Amazon EKS - Amazon EMR
問題 #129
A company receives test results from testing facilities that are located around the world. The company stores the test results in millions of 1 KB JSON files in an Amazon S3 bucket. A data engineer needs to process the files, convert them into Apache Parquet format, and load them into Amazon Redshift tables. The data engineer uses AWS Glue to process the files, AWS Step Functions to orchestrate the processes, and Amazon EventBridge to schedule jobs.
The company recently added more testing facilities. The time required to process files is increasing. The data engineer must reduce the data processing time.
Which solution will MOST reduce the data processing time?
  • A. Use Amazon EMR instead of AWS Glue to group the raw input files. Process the files in Amazon EMR. Load the files into the Amazon Redshift tables.
  • B. Use AWS Lambda to group the raw input files into larger files. Write the larger files back to Amazon S3. Use AWS Glue to process the files. Load the files into the Amazon Redshift tables.
  • C. Use the Amazon Redshift COPY command to move the raw input files from Amazon S3 directly into the Amazon Redshift tables. Process the files in Amazon Redshift.
  • D. Use the AWS Glue dynamic frame file-grouping option to ingest the raw input files. Process the files. Load the files into the Amazon Redshift tables.
答案:D
解題說明:
Problem Analysis:
Millions of 1 KB JSON files in S3 are being processed and converted to Apache Parquet format using AWS Glue.
Processing time is increasing due to the additional testing facilities.
The goal is to reduce processing time while using the existing AWS Glue framework.
Key Considerations:
AWS Glue offers the dynamic frame file-grouping feature, which consolidates small files into larger, more efficient datasets during processing.
Grouping smaller files reduces overhead and speeds up processing.
Solution Analysis:
Option A: Lambda for File Grouping
Using Lambda to group files would add complexity and operational overhead. Glue already offers built-in grouping functionality.
Option B: AWS Glue Dynamic Frame File-Grouping
This option directly addresses the issue by grouping small files during Glue job execution.
Minimizes data processing time with no extra overhead.
Option C: Redshift COPY Command
COPY directly loads raw files but is not designed for pre-processing (conversion to Parquet).
Option D: Amazon EMR
While EMR is powerful, replacing Glue with EMR increases operational complexity.
Final Recommendation:
Use AWS Glue dynamic frame file-grouping for optimized data ingestion and processing.
AWS Glue Dynamic Frames
Optimizing Glue Performance
問題 #130
A media company wants to improve a system that recommends media content to customer based on user behavior and preferences. To improve the recommendation system, the company needs to incorporate insights from third-party datasets into the company's existing analytics platform.
The company wants to minimize the effort and time required to incorporate third-party datasets.
Which solution will meet these requirements with the LEAST operational overhead?
  • A. Use API calls to access and integrate third-party datasets from AWS Data Exchange.
  • B. Use Amazon Kinesis Data Streams to access and integrate third-party datasets from Amazon Elastic Container Registry (Amazon ECR).
  • C. Use API calls to access and integrate third-party datasets from AWS
  • D. Use Amazon Kinesis Data Streams to access and integrate third-party datasets from AWS CodeCommit repositories.
答案:A
解題說明:
AWS Data Exchange is a service that makes it easy to find, subscribe to, and use third-party data in the cloud.
It provides a secure and reliable way to access and integrate data from various sources, such as data providers, public datasets, or AWS services. Using AWS Data Exchange, you can browse and subscribe to data products that suit your needs, and then use API calls or the AWS Management Console to export the data to Amazon S3, where you can use it with your existing analytics platform. This solution minimizes the effort and time required to incorporate third-party datasets, as you do not need to set up and manage data pipelines, storage, or access controls. You also benefit from the data quality and freshness provided by the data providers, who can update their data products as frequently as needed12.
The other options are not optimal for the following reasons:
* B. Use API calls to access and integrate third-party datasets from AWS. This option is vague and does not specify which AWS service or feature is used to access and integrate third-party datasets. AWS offers a variety of services and features that can help with data ingestion, processing, and analysis, but not all of them are suitable for the given scenario. For example, AWS Glue is a serverless data integration service that can help you discover, prepare, and combine data from various sources, but it requires you to create and run data extraction, transformation, and loading (ETL) jobs, which can add operational overhead3.
* C. Use Amazon Kinesis Data Streams to access and integrate third-party datasets from AWS CodeCommit repositories. This option is not feasible, as AWS CodeCommit is a source control service that hosts secure Git-based repositories, not a data source that can be accessed by Amazon Kinesis Data Streams. Amazon Kinesis Data Streams is a service that enables you to capture, process, and analyze data streams in real time, such as clickstream data, application logs, or IoT telemetry. It does not support accessing and integrating data from AWS CodeCommit repositories, which are meant for storing and managing code, not data .
* D. Use Amazon Kinesis Data Streams to access and integrate third-party datasets from Amazon Elastic Container Registry (Amazon ECR). This option is also not feasible, as Amazon ECR is a fully managed container registry service that stores, manages, and deploys container images, not a data source that can be accessed by Amazon Kinesis Data Streams. Amazon Kinesis Data Streams does not support accessing and integrating data from Amazon ECR, which is meant for storing and managing container images, not data .
* 1: AWS Data Exchange User Guide
* 2: AWS Data Exchange FAQs
* 3: AWS Glue Developer Guide
* : AWS CodeCommit User Guide
* : Amazon Kinesis Data Streams Developer Guide
* : Amazon Elastic Container Registry User Guide
* : Build a Continuous Delivery Pipeline for Your Container Images with Amazon ECR as Source
問題 #131
A transportation company wants to track vehicle movements by capturing geolocation records. The records are 10 bytes in size. The company receives up to 10,000 records every second. Data transmission delays of a few minutes are acceptable because of unreliable network conditions.
The transportation company wants to use Amazon Kinesis Data Streams to ingest the geolocation data. The company needs a reliable mechanism to send data to Kinesis Data Streams. The company needs to maximize the throughput efficiency of the Kinesis shards.
Which solution will meet these requirements in the MOST operationally efficient way?
  • A. Kinesis Producer Library (KPL)
  • B. Amazon Data Firehose
  • C. Kinesis Agent
  • D. Kinesis SDK
答案:A
解題說明:
Problem Analysis:
The company ingests geolocation records (10 bytes each) at 10,000 records per second into Kinesis Data Streams.
Data transmission delays are acceptable, but the solution must maximize throughput efficiency.
Key Considerations:
The Kinesis Producer Library (KPL) batches records and uses aggregation to optimize shard throughput.
Efficiently handles high-throughput scenarios with minimal operational overhead.
Solution Analysis:
Option A: Kinesis Agent
Designed for file-based ingestion; not optimized for geolocation records.
Option B: KPL
Aggregates records into larger payloads, significantly improving shard throughput.
Suitable for applications generating small, high-frequency records.
Option C: Kinesis Firehose
Firehose is for delivery to destinations like S3 or Redshift and is not optimized for direct ingestion to Kinesis Data Streams.
Option D: Kinesis SDK
The SDK lacks advanced features like aggregation, resulting in lower throughput efficiency.
Use Kinesis Producer Library (KPL) for its built-in aggregation and batching capabilities.
Kinesis Producer Library (KPL) Overview
Best Practices for Amazon Kinesis
問題 #132
A data engineer is designing a new data lake architecture for a company. The data engineer plans to use Apache Iceberg tables and AWS Glue Data Catalog to achieve fast query performance and enhanced metadata handling. The data engineer needs to query historical data for trend analysis and optimize storage costs for a large volume of event data.
Which solution will meet these requirements with the LEAST development effort?
  • A. Use AWS Glue Data Catalog to automatically optimize Iceberg storage.
  • B. Define partitioning schemes based on event type and event date.
  • C. Run a custom AWS Glue job to compact Iceberg table data files.
  • D. Store Iceberg table data files in Amazon S3 Intelligent-Tiering.
答案:D
解題說明:
Amazon S3 Intelligent-Tiering is designed to optimize storage costs by automatically moving objects between access tiers based on access patterns. Since Apache Iceberg works with S3 storage, using Intelligent-Tiering provides cost-efficiency without the need for custom development or jobs.
* Option B improves performance but doesn't optimize cost automatically.
* Option C is not a real AWS Glue feature - Glue does not automatically optimize Iceberg storage.
* Option D requires custom development effort, which is contrary to the requirement.
"S3 Intelligent-Tiering is ideal for data lakes and analytics use cases that access data irregularly." Reference: AWS Documentation - S3 Intelligent-Tiering
問題 #133
雖然Data-Engineer-Associate考古題學習資料非常受歡迎,但是我們還是為客戶提供了免費的Amazon Data-Engineer-Associate試用DEMO,供考生體驗,我們也將不斷發布更多新版的題庫,以滿足IT行業日益增長的需求。我們將為您提供最新的Amazon Data-Engineer-Associate題庫資料來準備考試,所有的題庫都可以在這里獲得,使通過Data-Engineer-Associate考試變得更加容易。Fast2test將是您獲得認證的最好選擇,我們保證您100%可以通過Data-Engineer-Associate認證考試。
Data-Engineer-Associate考試大綱: https://tw.fast2test.com/Data-Engineer-Associate-premium-file.html
Data-Engineer-Associate 題庫資料肯定是您見過的最好的學習資料,Amazon Data-Engineer-Associate考題免費下載 上個月買的這的考題,今天上午去考的,你很快就可以獲得Amazon Data-Engineer-Associate 認證考試的證書,我們承諾,如果你使用了Fast2test的最新的Amazon Data-Engineer-Associate 認證考試練習題和答案卻考試失敗,Fast2test將會全額退款給你,Amazon Data-Engineer-Associate考題免費下載 另外,如果你是第一次參加考試,那麼你可以使用軟體版的考古題,這是為什麼呢,因為有Fast2test Amazon的Data-Engineer-Associate考試培訓資料在手,Fast2test Amazon的Data-Engineer-Associate考試培訓資料是IT認證最好的培訓資料,它以最全最新,通過率最高而聞名,而且省時又省力,有了它,你將輕鬆的通過考試,Fast2test Data-Engineer-Associate 考試大綱幫助過許多參加IT認定考試的人。
然而,品酒之人此時的感受卻與壹般人不同,娛樂圈裏那些楊立捐、範陰陽和這壹比,都特麽去吃屎去吧,Data-Engineer-Associate 題庫資料肯定是您見過的最好的學習資料,上個月買的這的考題,今天上午去考的,你很快就可以獲得Amazon Data-Engineer-Associate 認證考試的證書。
有效的Data-Engineer-Associate考題免費下載和資格考試的領導者和有口皆碑的Data-Engineer-Associate:AWS Certified Data Engineer - Associate (DEA-C01)我們承諾,如果你使用了Fast2test的最新的Amazon Data-Engineer-Associate 認證考試練習題和答案卻考試失敗,Fast2test將會全額退款給你,另外,如果你是第一次參加考試,那麼你可以使用軟體版的考古題。
Posted at 1/12/2026 07:00:44        Only Author  2#
Thank you for sharing such an insightful and uplifting article! Here’s the C-THR88-2505 pass leader dumps test that led to my promotion and salary raise, and it’s free for you today. Best of luck achieving your career goals!
Posted at 1/12/2026 22:33:32        Only Author  3#
Thank you for your article; it really opened my eyes! The rich resources in 1Z0-1133-24 reliable test test are provided at no cost to enhance your understanding.
Posted at 1/13/2026 07:18:36        Only Author  4#
Can’t stop myself from liking this amazing content. Take advantage of Valid GH-100 test pass4sure, full of valuable content, available for free.
Posted at 1/16/2026 10:27:48        Only Author  5#
I took away so much from reading that article. The C-P2WFI-2023 latest test cost content is impressive, and it's available to you at no cost.
Posted at 1/18/2026 00:36:45        Only Author  6#
The article gave me so much to think about. This CGOA new exam camp sheet was instrumental in my promotion and pay raise. It’s now free to everyone. Wishing you success in your promotions!
Posted at 1/19/2026 18:50:08        Only Author  7#
当社JPTestKingの専門家のほとんどは、長年プロの分野で勉強しており、PL-400練習問題で多くの経験を蓄積しています。当社は、才能の選択にかなり慎重であり、常に専門知識とスキルのある従業員を雇用しています。専門家と作業スタッフの全員が高い責任感を維持しているため、PL-400試験の資料を選択して長期的なパートナーになる人が非常に多くいます。
Posted at 4/20/2026 03:00:56        Only Author  8#
如果你購買KaoGuTi提供的Esri EUNA_2024 認證考試練習題和答案,你不僅可以成功通過Esri EUNA_2024 認證考試,而且享受一年的免費更新服務。如果你考試失敗,KaoGuTi將全額退款給你。你可以在KaoGuTi的網站上免費下載部分關於Esri EUNA_2024 認證考試的練習題和答案作為嘗試,從而檢驗KaoGuTi的產品的可靠性。
Posted at 5/13/2026 11:22:03        Only Author  9#
I can’t stop thinking about that article. Ready to face the Reliable C_ARCIG_2508 test tips exam! Pray for good results!
