[Hardware] 高效的DP-420測試題庫和資格考試的領先材料供應商和最佳的DP-420在線題庫
71
【Hardware】 高效的DP-420測試題庫和資格考試的領先材料供應商和最佳的DP-420在線題庫
Posted at 1/11/2026 07:08:08      View:169 | Replies:1        Print      Only Author   [Copy Link] 1#
P.S. NewDumps在Google Drive上分享了免費的、最新的DP-420考試題庫:https://drive.google.com/open?id=1opSqBXbgwSq1n72K3cUroJxQGM3bHl_q
患難可以試驗一個人的品格,非常的境遇方才可以顯出非常的氣節;風平浪靜的海面,所有的船隻都可以並驅競勝。命運的鐵拳擊中要害的時候,只有大勇大智的人才能夠處之泰然。 你是大智大勇的人嗎?如果你的IT認證考試沒有做好考前準備,你還處之泰然嗎?當然,因為你有 NewDumps Microsoft的DP-420考試培訓資料在手上,任何考試困難都不會將你打到。
Microsoft DP-420 考試大綱:
主題簡介
主題 1
  • Design and Implement Data Models: This topic equips Microsoft developers to design and implement non-relational data models for Azure Cosmos DB for NoSQL, emphasizing partitioning strategies, database sizing, and scaling. Developers master connectivity using the Azure Cosmos DB SDK and SQL language for NoSQL, ensuring seamless data access. Additionally, server-side programming with JavaScript empowers robust solutions tailored to specific application needs.
主題 2
  • Integrate an Azure Cosmos DB Solution: This topic focuses on enabling analytical workloads and integrating Azure Cosmos DB across services. Developers learn to leverage cross-service integrations for cohesive solutions, driving advanced analytics and operational efficiency in cloud-native applications.
主題 3
  • Maintain an Azure Cosmos DB Solution: This section covers monitoring, troubleshooting, and securing Azure Cosmos DB solutions. Developers master backup and restore procedures, implement data movement, and streamline processes using DevOps. These skills ensure operational reliability and safeguard data integrity in production environments.
主題 4
  • Optimize an Azure Cosmos DB Solution: Developers gain expertise in optimizing query performance using Azure Cosmos DB for NoSQL APIs, implementing change feeds, and crafting effective indexing strategies. This topic ensures solutions are performant, scalable, and adaptive to evolving data requirements, enhancing application responsiveness.
主題 5
  • Design and Implement Data Distribution: Microsoft developers delve into designing replication strategies and implementing multi-region writes for Azure Cosmos DB. These skills ensure high availability, fault tolerance, and enhanced global performance for distributed applications, making them vital for enterprise-grade solutions.
微軟DP-420考試旨在增強專業人士在使用Microsoft Azure Cosmos DB設計和實施雲原生應用程序方面的技能。該認證對於希望在雲計算和數據庫管理方面追求職業生涯的個人非常理想。考試旨在測試考生對與雲原生應用程序開發相關的不同概念,工具和技術的知識和理解能力。
DP-420測試題庫-最新考試題庫幫助妳壹次性通過考試DP-420:Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DBNewDumps確保廣大考生獲得最好和最新的Microsoft DP-420題庫學習資料,您可以隨時隨地的訪問我們網站尋找您需要的考古題。我們提供所有熱門認證考試學習資料,其中包含PDF電子版本和軟件版本的DP-420題庫,還有APP在線版本支持離線使用,方便考生選擇使用。并且我們的DP-420考古題包含實際考試中可能出現的所有問題,是您的DP-420考試合格的最佳復習資料,幫助您輕松通過測試。
Microsoft DP-420 認證考試旨在測試您在使用 Microsoft Azure Cosmos DB 設計和實施基於雲的應用程序方面的技能和知識。這項考試適合尋求展示自己在使用 Cosmos DB 開發可擴展、高可用且安全的基於雲的應用程序方面的專業知識的專業人士。在這項考試中,您需要展示您設計、開發和部署基於雲的應用程序以及實施安全和災難恢復解決方案的能力。
最新的 Azure Cosmos DB Developer Specialty DP-420 免費考試真題 (Q41-Q46):問題 #41
You have an Azure subscription that contains a resource group named RG1. RG1 contains an Azure Cosmos DB for NoSQL account named account1.
You plan to audit changes to the control plane of account1.
You need to ensure that audit events include the details of the security principal that performs each control plane change.
How should you complete the az command? To answer select the appropriate options in the answer area.
答案:
解題說明:
問題 #42
You plan to implement con-iot1 and con-iot2.
You need to configure the default Time to Live setting for each container. The solution must meet the loT telemetry requirements.
What should you configure? To answer, select the appropriate options in the answer NOTE: Each correct selection is worth one point.
答案:
解題說明:
Box 1 = On (no default)For con-iot1, you need to configure the default TTL setting to On (no default), which means that items in this container do not expire by default, but you can override the TTL value on a per-item basis. This meets the requirement of retaining all telemetry data unless overridden1.
Box 2 = On (3600 seconds)For con-iot2, you need to configure the default TTL setting to On (3600 seconds), which means that items in this container will expire 3600 seconds (one hour) after their last modified time. This meets the requirement of deleting all telemetry data older than one hour1.
問題 #43
The following is a sample of a document in orders.
The orders container uses customer as the partition key.
You need to provide a report of the total items ordered per month by item type. The solution must meet the following requirements:
Ensure that the report can run as quickly as possible.
Minimize the consumption of request units (RUs).
What should you do?
  • A. Configure the report to query orders by using a SQL query through a dedicated gateway.
  • B. Configure the report to query orders by using a SQL query.
  • C. Configure the report to query a new aggregate container. Populate the aggregates by using the change feed.
  • D. Configure the report to query a new aggregate container. Populate the aggregates by using SQL queries that run daily.
答案:C
解題說明:
You can facilitate aggregate data by using Change Feed and Azure Functions, and then use it for reporting.
問題 #44
You have a container named container1 in an Azure Cosmos DB Core (SQL) API account. The container1 container has 120 GB of data.
The following is a sample of a document in container1.
The orderId property is used as the partition key.
答案:
解題說明:
Box 1: Yes
Records with different OrderIDs will match.
Box 2: Yes
Box 3: No
Only records with one specific OrderId will match
問題 #45
You configure a backup for an Azure Cosmos DB for NoSQL account as shown in the following exhibit.
答案:
解題說明:
Box 1 = The current backup policy provides protection for: 2 Hours
Azure Cosmos DB automatically takes backups of your data at regular intervals. The backup interval and the retention period can be configured from the Azure portal. You can also choose between two backup modes:
periodic backup mode and continuous backup mode. Periodic backup mode is the default mode for all existing accounts and it takes a full backup of your database every 4 hours by default. Continuous backup mode is a new mode that allows you to restore to any point of time within either 7 or 30 days1.
For your scenario, based on the exhibit, you have configured a backup for an Azure Cosmos DB for NoSQL account using the periodic backup mode with a backup interval of 1 hour and a retention period of 2 hours.
This means that Azure Cosmos DB will take a fullbackup of your database every hour and keep only the latest two backups. Therefore, the current backup policy provides protection for 2 hours.
Box 2: In case of emergency, you must (answer choice) to restore the backup = create a support ticket Azure Cosmos DB automatically takes backups of your data at regular intervals. You can configure the backup interval and the retention period from the Azure portal. You can also choose between two backup modes: periodic backup mode and continuous backup mode. Periodic backup mode is the default mode for all existing accounts and it takes a full backup of your database every 4 hours by default. Continuous backup mode is a new mode that allows you to restore to any point of time within either 7 or 30 days1.
This means that Azure Cosmos DB will take a full backup of your database every hour and keep only the latest two backups. In case of emergency, you must create a support ticket to restore the backup. This is the answer to your question.
To restore data from a periodic backup, you need to create a support request with Azure Cosmos DB team and provide the following information:
* The name of your Azure Cosmos DB account
* The name of the database or container that you want to restore
* The date and time (in UTC) that you want to restore from
* The name of the target Azure Cosmos DB account where you want to restore the data
* The name of the target resource group where you want to restore the data The Azure Cosmos DB team will then initiate the restore process and notify you when it is completed2.
問題 #46
DP-420在線題庫: https://www.newdumpspdf.com/DP-420-exam-new-dumps.html
從Google Drive中免費下載最新的NewDumps DP-420 PDF版考試題庫:https://drive.google.com/open?id=1opSqBXbgwSq1n72K3cUroJxQGM3bHl_q
Posted at 1/20/2026 03:00:19        Only Author  2#
主要な環境では、人々はより多くの仕事のプレッシャーに直面しています。そのため、彼らはHP認証を一般の群れよりも高めたいと考えています。有効で効率的なHPE7-A06ガイドトレントを選択する方法は、ほとんどの候補者が懸念する可能性のある重要なトピックです。だから今、それは正しいです、あなたは私たちのところに来ます。当社は、特にHP認定試験に関するこの分野の高品質なHPE7-A06試験問題で有名です。試験のためにHPE7-A06学習教材を実践している数千人の受験者に受け入れられています。
Posted at 2/1/2026 03:08:09        Only Author  3#
I’m left in awe by your article, thank you for sharing this treasure! Free access to SPLK-1003 reliable new test format’s extensive content is offered, with the aim of supporting you.
