Detail WGU Cloud-Deployment-and-Operations Explanation & Cloud-Deployment-an
93
Posted at 1/11/2026 08:04:12      View:147 | Replies:4        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of ExamDiscuss Cloud-Deployment-and-Operations dumps for free: https://drive.google.com/open?id=1jOJ22AyW1GEXsGF3gAxPXLbHY_E1UZY2
Whatever your professional, working towards a WGU Cloud Deployment and Operations Cloud-Deployment-and-Operations certification or designation takes a significant amount of effort and time. Once you have put all your effort, and investment and prepared well then you will be in a position to pass the WGU Cloud Deployment and Operations Cloud-Deployment-and-Operations Certification Exam. But once you get success in the WGU Cloud Deployment and Operations Cloud-Deployment-and-Operations test you’ll be eligible to avail all the personal and professional benefits associated with WGU Cloud Deployment and Operations Cloud-Deployment-and-Operations certification.
WGU Cloud-Deployment-and-Operations Exam Syllabus Topics:
  • Optimizing Cost and Performance Baselines: This section of the exam measures skills of Cloud Operations engineers and covers determining the best balance between cost and performance using AWS services. It involves selecting suitable configurations and resource types to maintain efficient operations while avoiding unnecessary spending.
  • Implementing Cloud Security and Compliance: This section of the exam measures skills of Cloud Engineers and covers the use of AWS security tools to protect data and infrastructure. Candidates must demonstrate awareness of compliance needs and the ability to apply protective controls that align with industry and organizational standards.
  • Monitoring, Logging, and Issue Remediation: This section of the exam measures skills of Cloud Engineers and covers responding to issues identified through AWS monitoring and logging tools. Candidates must show they can interpret system outputs, identify problems, and take corrective actions to maintain smooth cloud operations.
  • Configuring Cloud Network Connectivity: This section of the exam measures skills of Cloud Engineers and covers network connectivity within AWS environments, including setup, troubleshooting, and corrective actions. Candidates must show they can manage cloud networking in a way that ensures reliable communication between systems and services.
ExamDiscuss WGU Cloud-Deployment-and-Operations Different FormatsThese are WGU Cloud-Deployment-and-Operations desktop software and web-based. As the name suggests, desktop WGU Cloud-Deployment-and-Operations practice exam software works offline on Windows computers and you need an active internet connection to operate the WGU Cloud-Deployment-and-Operations web-based practice test. Both Cloud-Deployment-and-Operations practice exams mimic the WGU Cloud-Deployment-and-Operations actual test, identify your mistakes, offer customizable Cloud-Deployment-and-Operations mock tests, and help you overcome mistakes.
WGU Cloud Deployment and Operations Sample Questions (Q46-Q51):NEW QUESTION # 46
(Which component should be used to configure email notifications for a trigger by Amazon Made?)
  • A. Elastic Kubernetes Service
  • B. EventBridge
  • C. CodeDeploy
  • D. Simple Queue Service
Amazon EventBridge should be used to configure email notifications for a trigger by Amazon Made, as it can route events to targets like Amazon SNS (Simple Notification Service) for email delivery. EventBridge integrates with AWS services to handle event-driven notifications. The WGU Cloud Deployment and Operations Study Guide (Section 4.3, EventBridge) states, "EventBridge can be configured to send events from Amazon Made to SNS, enabling email notifications by subscribing an email endpoint to the SNS topic." SQS, EKS, and CodeDeploy do not support this notification configuration.
NEW QUESTION # 47
(A cloud engineer needs to notify the response team whenever a high-security web server responds with a 403 Forbidden error. Which two steps can enable this functionality? Choose 2 answers.)
  • A. Send alarms from the Lambda function using Amazon SQS
  • B. Create an alarm for the metric filter to deliver alerts using Amazon SNS
  • C. Bind a Lambda function to an Apache process
  • D. Define a metric filter for Apache logs in CloudWatch
To notify a response team when a high-security web server returns a 403 Forbidden error, two key steps are required. First, define a metric filter for Apache logs in CloudWatch to detect the 403 error code within the log data. This involves setting up a filter pattern to match "403" in the Apache access logs. Second, create an alarm for the metric filter and configure it to deliver alerts using Amazon SNS, which supports email or other notifications to the response team. The WGU Cloud Deployment and Operations Study Guide (Section 4.2, CloudWatch Logs and Alarms) confirms that metric filters and SNS-integrated alarms are the standard approach for monitoring and alerting on log-based events. Options B and D are incorrect as they involve unnecessary or unsupported configurations (e.g., binding Lambda to Apache or using SQS for alarms).
NEW QUESTION # 48
(An administrator plans to deploy a database to AWS that supports the following: multiple Availability Zones, a standby database instance that provides failover support, a database instance that allows only read-only connections. Which two database solutions should the administrator use? Choose 2 answers.)
  • A. Amazon RDS Multi-AZ DB cluster
  • B. Amazon Aurora DB cluster with multi-master replication
  • C. Amazon RDS Multi-AZ DB instance
  • D. Amazon Aurora DB instance with Aurora Replica
To meet the requirements, the administrator should use an Amazon RDS Multi-AZ DB instance for multiple Availability Zones and failover support, and an Amazon Aurora DB instance with Aurora Replica for a read- only connection. The RDS Multi-AZ configuration automatically provisions a standby instance in a different AZ for failover, while Aurora Replicas provide read-only instances for scaling read traffic. The WGU Cloud Deployment and Operations Study Guide (Section 7.1, RDS and Aurora) states, "RDS Multi-AZ deploys a standby instance across AZs for failover, and Aurora Replicas are read-only instances that enhance performance by offloading read traffic from the primary instance." Options A and D are incorrect as multi- master replication and Multi-AZ clusters do not align with the read-only requirement.
NEW QUESTION # 49
(What is the role of a patch baseline in Patch Manager?)
  • A. Defines patches that should and should not be installed on EC2 instances
  • B. Installs all patch updates as they become available by default
  • C. Assigns an IAM role for services that can auto-approve patches upon release
  • D. Notifies Config of any patch updates that need to be performed
A patch baseline in Patch Manager defines the patches that should and should not be installed on EC2 instances, specifying approval rules for security updates, other updates, and exclusions. This ensures controlled and compliant patching. The WGU Cloud Deployment and Operations Study Guide (Section 5.2, Patch Manager) states, "A patch baseline specifies which patches are approved for installation and which are excluded, allowing customization of patch deployment (e.g., approving only critical security updates)." Options A, B, and D misrepresent the baseline's role, as it does not auto-install, assign IAM roles, or notify Config directly.
NEW QUESTION # 50
(Which service should be used to horizontally scale Amazon EC2 instances?)
  • A. Elastic IPs
  • B. Elastic Beanstalk
  • C. Elastic Load Balancing
  • D. Elastic network interface
Elastic Load Balancing (ELB) should be used to horizontally scale Amazon EC2 instances by distributing incoming traffic across multiple instances, improving availability and fault tolerance. ELB works in conjunction with Auto Scaling groups to add or remove instances based on demand. The WGU Cloud Deployment and Operations Study Guide (Section 3.2, Elastic Load Balancing) notes, "Elastic Load Balancing distributes traffic across EC2 instances, enabling horizontal scaling as part of an Auto Scaling group to handle increased load efficiently." Elastic IPs, elastic network interfaces, and Elastic Beanstalk do not provide this scaling functionality.
NEW QUESTION # 51
Cloud-Deployment-and-Operations exam braindumps can prove your ability to let more big company to attention you. Cloud-Deployment-and-Operations exam guide will help you get a good job. Cloud-Deployment-and-Operations test prep can help you in a very short period of time to prove yourself perfectly and efficiently. With tens of thousands of our customers proved that, if you study with our Cloud-Deployment-and-Operations Exam Questions for twenty to thirty hours, then you will be more confident and capable to pass the Cloud-Deployment-and-Operations exam and get the according cetification.
Cloud-Deployment-and-Operations Exam Details: https://www.examdiscuss.com/WGU/exam/Cloud-Deployment-and-Operations/
Posted at 1/16/2026 02:03:09        Only Author  2#
Your article is awe-inducing, I’m grateful for your sharing! The Test CCM vce test questions are free! Wishing you success in your exam preparations!
Posted at 1/24/2026 22:07:26        Only Author  3#
Fast2test的Apple DEP-2025 認證考試的考試練習題和答案是由我們的專家團隊利用他們的豐富的知識和經驗研究出來的,能充分滿足參加Apple DEP-2025 認證考試的考生的需求。你可能從相關的網站或書籍上也看到部分相關培訓材料,但是我們Fast2test的Apple DEP-2025 認證考試的相關資料是擁最全面的,可以給你最好的保障。參加Apple DEP-2025 認證考試的考生請選擇Fast2test為你提供的考試練習題和答案,因為它是你的最佳選擇。
Posted at 2/24/2026 14:10:06        Only Author  4#
クライアントはDP-300試験問題を学習し、テストの準備をするのに20〜30時間しかかかりません。多くの人は、DP-300テストの準備が必要だと不満を言うかもしれませんが、一方でPass4Test、仕事、学習、家族などの最も重要なことにほとんどの時間を費やさなければなりません。ただし、DP-300学習ガイドを購入すると、テストの準備に時間と労力がほとんどかからないため、最も重要なことをうまくやり、DP-300テストに簡単に合格できます。
Posted at 3/6/2026 01:26:01        Only Author  5#
我們NewDumps Citrix的1Y0-342考試認證培訓資料可以實現你的夢想,因為它包含了一切需要通過的Citrix的1Y0-342考試認證,有了NewDumps,你們將風雨無阻,全身心投入應戰。有了我們NewDumps的提供的高品質高品質的培訓資料,保證你通過考試,給你準備一個光明的未來。
