[General] High Hit Rate Authentic B2C-Commerce-Architect Exam Questions - Pass B2C-Commerc
【General】 High Hit Rate Authentic B2C-Commerce-Architect Exam Questions - Pass B2C-Commerc
Posted at 1/11/2026 08:09:21      View:119 | Replies:4        Print      Only Author   [Copy Link] 1#
P.S. Free & New B2C-Commerce-Architect dumps are available on Google Drive shared by ITCertMagic: https://drive.google.com/open?id=1SGuSBb2NJjLzyjfK07mCh1QTCeU08yah
Our B2C-Commerce-Architect study prep has inspired millions of exam candidates to pursuit their dreams and motivated them to learn more high-efficiently. Many customers get manifest improvement. B2C-Commerce-Architect simulating exam will inspire your potential. And you will be more successful with the help of our B2C-Commerce-Architect training guide. Just imagine that when you have the certification, you will have a lot of opportunities to come to the bigger companies and get a higher salary.
Generally speaking, the clients will pass the test if they have finished learning all of our B2C-Commerce-Architect Study Materials with no doubts. The odds to fail in the test are approximate to zero. But to guarantee that our clients won’t suffer the loss we will refund the clients at once if they fail in the test unexpectedly. The B2C-Commerce-Architect dump are very simple and the clients only need to send us their proofs to fail in the test and the screenshot or the scanning copies of the clients’ failure scores. The clients can consult our online customer staff about how to refund, when will the money be returned backed to them and if they can get the full refund or they can send us mails to consult these issues.
Salesforce - B2C-Commerce-Architect - Salesforce Certified B2C Commerce Architect High Hit-Rate Authentic Exam QuestionsIn addition to the PDF questions ITCertMagic offers desktop B2C-Commerce-Architect practice exam software and web-based Salesforce Certified B2C Commerce Architect (B2C-Commerce-Architect) practice exam, to help you cope with Salesforce Certified B2C Commerce Architect (B2C-Commerce-Architect) exam anxiety. These Salesforce B2C-Commerce-Architect Practice Exams simulate the actual Salesforce B2C-Commerce-Architect exam conditions and provide you with an accurate assessment of your readiness for the B2C-Commerce-Architect exam.
Salesforce Certified B2C Commerce Architect Sample Questions (Q50-Q55):NEW QUESTION # 50
A merchant has asked their development team to add a new site.
Which two tasks are essential for correct site configuration prior to launch?
Choose 2 answers
  • A. Assign a default currency.
  • B. Assign a default payment processor.
  • C. Assign a default payment method.
  • D. Assign the appropriate taxation type.
  • E. Assign a default payment type.
NEW QUESTION # 51
A client is planning to migrate its e-commerce to Salesforce Commerce Cloud. Their expectation is to increase the business volume by 300%. As an architect you decide before go-live execute a load testing in order to check that the new site will fit client expectations. This table show the results of test execution:
* 500 http error appears twice during search refinement and 404 is shown while accessing an specific PDP. According to the results shown above, how can we evaluate the load test?
  • A. Go live must be postponed until those 400/500 errors will be fixed.
  • B. In general it is pretty good, the new site will work as expected. We can proceed with the go live and after that some improvements on place order should be done.
  • C. There are two blockers. Go live must be postponed until checkout and place order average time is under 1,500 milliseconds. Otherwise a lot of purchases will be lost.
  • D. We can proceed with the go live. All key performance indicators are now better than in the old site even with 300% more volume.
NEW QUESTION # 52
A developer is checking for Cross Site Scripting (XSS) and found that the quick search is not escaped (allows inclusion of Javascript) in the following script:
How would the developer resolve this issue?
  • A. Use <isprint value="${searchPhrase}* encoding-'jshtmr />
  • B. Use <toprint value="${searchPhrase}" />
  • C. Replace ' with double Quote*
  • D. Use <isprint value='${searchPhrase} encoding-'jsblock" />
NEW QUESTION # 53
During a review of the most recent release notes, the Architect finds that Salesforce has deprecated an API that is used throughout the site. After reviewing the deprecated API usage in Business Manager, the Architect narrows down the usage of that API to a particular LINK integration cartridge. The cartridge was integrated when the site was first launched and is heavily customized for the Client.
What is the recommended way for the Architect to remove the deprecated API so the LINK integration continues to work without interruptions, and lowest level of effort'
  • A. The Architect does not need to do anything at this time, the API will continue to work with no issues for the foreseeable future.
  • B. The Architect should contact the company that created the LINK cartridge to fix the issue and provide the client with updated code.
  • C. The Architect should update all the deprecated API cats in the already integrated LINK cartridge and test thoroughly.
  • D. The Architect should check to see If the LINK cartridge has been updated already, integrate It, apply the customisations, and teat thoroughly.
When facing a deprecated API that is used in a LINK integration cartridge, the recommended approach is to check for an updated version of the cartridge that may have replaced the deprecated API with a supported one.
If an update is available:
* Integrate the updated cartridge into the site, ensuring compatibility with the current site configuration.
* Re-apply customizations that were made to the original cartridge to maintain functional consistency.
* Thorough testing should be conducted to ensure that the integration works seamlessly without causing disruptions in the site's functionality.
This approach minimizes effort by leveraging updates provided by the cartridge vendor while ensuring the site remains functional and compliant with current API standards.
NEW QUESTION # 54
The Client wants to offer custom made container products on its new B2C Commerce storefront. TheClient provided two business requirements.
* Customer can specify container length, width, and height.
* Customer can specify the material that the container is made of.
The Client also provided the Architect a current data schema (shown below) for reference while preparing the technical documentation.
Which two gaps between the requirements and the data schema should the Architect discuss with the Client?
Choose 2 answers
  • A. The data schema includes unique identifiers for material and color fields,but neither are reflected in the business requirements.
  • B. The data schema includes a Color_ID field, but there isn't a business requirement to allow the customer to specify container color.
  • C. The data schema includes a material Price_Markup field, but there Isn't a business requirement to factor the material cost Into the final price calculation.
  • D. The data schema includes an implied structure that the customer's choices should be captured as custom objects, but there isn't a business requirement to do so
The provided data schema includes several fields that do not match the stated business requirements, which focus on the custom dimensions and materials of the containers:
* Option A: The inclusion of unique identifiers for materials and color fields in the data schema suggests a level of detail and structure around these attributes that is not reflected in the business requirements. If the business does not require tracking or differentiating materials beyond just naming them, this might be unnecessarily complex.
* Option D: The data schema includes a Color_ID field, which implies the ability to specify the color of the container. However, the business requirements do not mention color as a customization option available to customers. This discrepancy needs to be addressed to ensure that the database design aligns with actual business needs.
NEW QUESTION # 55
Nowadays, using computer-aided software to pass the B2C-Commerce-Architect exam has become a new trend. Because the new technology enjoys a distinct advantage, that is convenient and comprehensive. In order to follow this trend, our company product such a B2C-Commerce-Architect exam questions that can bring you the combination of traditional and novel ways of studying. The passing rate of our study material is up to 99%. If you are not fortune enough to acquire the B2C-Commerce-Architect Certification at once, you can unlimitedly use our B2C-Commerce-Architect product at different discounts until you reach your goal and let your dream comes true.
Reliable B2C-Commerce-Architect Braindumps Questions: https://www.itcertmagic.com/Salesforce/real-B2C-Commerce-Architect-exam-prep-dumps.html
The point of every question in our B2C-Commerce-Architect exam braindumps is set separately, This trend also impacts the Salesforce B2C-Commerce-Architect certification exam topics, Salesforce Authentic B2C-Commerce-Architect Exam Questions There will be surprise waiting for you, It's human nature that everyone wants to pass the Salesforce B2C-Commerce-Architect exam at once, Valid B2C-Commerce-Architect answers real questions will help you clear exam at the first time, it will be fast for you to obtain certifications and achieve your dream.
Now that virtually every laptop on the planet B2C-Commerce-Architect has an IrDA interface on it, and Bluetooth is getting strong support from many of the world's leading technology companies, Reliable B2C-Commerce-Architect Braindumps Questions the question rises about which is best for use in Windows XP Professional.
Free PDF 2026 Salesforce Accurate Authentic B2C-Commerce-Architect Exam QuestionsDesign cost-effective tests, The point of every question in our B2C-Commerce-Architect Exam Braindumps is set separately, This trend also impacts the Salesforce B2C-Commerce-Architect certification exam topics.
There will be surprise waiting for you, It's human nature that everyone wants to pass the Salesforce B2C-Commerce-Architect exam at once, Valid B2C-Commerce-Architect answers real questions will help you clear exam Reliable B2C-Commerce-Architect Test Braindumps at the first time, it will be fast for you to obtain certifications and achieve your dream.
P.S. Free 2026 Salesforce B2C-Commerce-Architect dumps are available on Google Drive shared by ITCertMagic: https://drive.google.com/open?id=1SGuSBb2NJjLzyjfK07mCh1QTCeU08yah
Posted at 1/30/2026 22:00:12        Only Author  2#
私たちに知られているように、適切な学習計画はすべての人々にとって非常に重要です。競争力を高めるために、学習計画を立てる必要があります。 DP-900の実際の試験は、優れた学習計画の作成に役立つと考えています。 DP-900学習教材を使用して、限られた時間でモデルテストを行うことができます。モデルテストを完了すると、システムがパフォーマンスに応じてレポートを生成します。あなたがマスターしていない知識ポイントを知ることができます。 DP-900調査の質問からのレポートによる。そうすれば、DP-900試験に簡単に合格できます。
Posted at 2/8/2026 18:59:13        Only Author  3#
The content of this article is thought-provoking, thank you for sharing! Level up your IT skills by grabbing free Arch-303 valid free study questions. Best of luck on your exams!
Posted at 2/12/2026 00:58:49        Only Author  4#
I was really impressed by the depth and breadth of the article. The Sales-101 Original Questions questions were a key part of my success—promotion and salary raise—and today, I’m sharing them for free!
Posted at 2/18/2026 21:51:43        Only Author  5#
This article truly broadened my horizons; thank you for sharing! Best of luck with your exams—free GH-300 exam questions and answers exam papers are available now!
