Exam Topics CCAAK Pdf & CCAAK Study Guide
Posted at 1/11/2026 08:43:50
View171
Replies2
BONUS!!! Download part of TroytecDumps CCAAK dumps for free: https://drive.google.com/open?id=105IFGFc-2XFkSkDjZPDrilAujUUYLmSI
Now it is a society of abundant capable people, and there are still a lot of industry is lack of talent, such as the IT industry is quite lack of technical talents. Confluent certification CCAAK exam is one of testing IT technology certification exams. TroytecDumps is a website which provide you a training about Confluent Certification CCAAK Exam related technical knowledge.
Our desktop software Confluent CCAAK practice exam software provides a simulated scenario in which you may pick the Confluent CCAAK exam questions and schedule them to replicate an actual Confluent exam-like situation. With each attempt of the Confluent CCAAK Practice Exam in this manner, your score is saved.
CCAAK Study Guide, CCAAK Pass RateAs a market leader, our company is able to attract quality staffs, it actively seeks out those who are energetic, persistent, and professional to various CCAAK certificate and good communicator. And we strongly believe that the key of our company's success is its people, skills, knowledge and experience. The successful selection, development and CCAAK training of personnel are critical to our company's ability to provide a high standard of service to our customers and to respond their needs on our CCAAK exam questions.
Confluent Certified Administrator for Apache Kafka Sample Questions (Q29-Q34):NEW QUESTION # 29
A Kafka cluster with three brokers has a topic with 10 partitions and a replication factor set to three. Each partition stores 25 GB data per day and data retention is set to 24 hours.
How much storage will be consumed by the topic on each broker?
- A. 300 GB
- B. 75 GB
- C. 250 GB
- D. 750 GB
10 partitions 25 GB/day = 250 GB total per day for the topic (primary data).
With a replication factor of 3, there are 3 full copies of the data: 250 GB 3 = 750 GB total across the entire cluster.
The cluster has 3 brokers, and Kafka tries to distribute replicas evenly among them: 750 GB 3 brokers = 250 GB per broker on average.
However, due to replication, some partitions have leaders and followers, so there's some overlap and not-perfect distribution. Each broker stores approximately 2/3 of the total topic data (since each broker holds replicas for around 2/3 of the partitions).
2/3 750 GB = 500 GB, but this is shared, so each broker ends up storing ~300 GB of replicated data, including its share of leaders and followers.
NEW QUESTION # 30
An employee in the reporting department needs assistance because their data feed is slowing down. You start by quickly checking the consumer lag for the clients on the data stream.
Which command will allow you to quickly check for lag on the consumers?
- A. bin/kafka-consumer-group-throughput.sh
- B. bin/kafka-consumer-groups.sh
- C. bin/kafka-reassign-partitions.sh
- D. bin/kafka-consumer-lag.sh
The kafka-consumer-groups.sh script is used to inspect consumer group details, including consumer lag, which indicates how far behind a consumer is from the latest data in the partition.
The typical usage is bin/kafka-consumer-groups.sh --bootstrap-server <broker> --describe --group <group_id>
NEW QUESTION # 31
When a broker goes down, what will the Controller do?
- A. Trigger a leader election among the remaining followers to distribute leadership.
- B. Automatically elect the least loaded broker to become the leader for every orphan's partitions.
- C. Become the leader for the topic/partition that needs a leader, pending the broker return in the cluster.
- D. Wait for a follower to take the lead.
When a broker goes down, the Controller detects the failure and triggers a leader election for all partitions that had their leader on the failed broker. The leader is chosen from the in-sync replicas (ISRs) of each partition.
NEW QUESTION # 32
Which statements are correct about partitions? (Choose two.)
- A. A partition size is determined after the largest segment on a disk.
- B. A partition in Kafka will be represented by a single segment on a disk.
- C. A partition is comprised of one or more segments on a disk.
- D. All partition segments reside in a single directory on a broker disk.
NEW QUESTION # 33
How can authentication for both internal component traffic and external client traffic be accomplished?
- A. Configure multiple listeners on the broker.
- B. Configure multiple security protocols on the same listener.
- C. Configure multiple brokers.
- D. Configure LoadBalancer.
Kafka supports multiple listeners, each with its own port, hostname, and security protocol. This allows you to:
* Use one listener for internal communication (e.g., brokers, ZooKeeper, Connect, etc.) with one type of authentication (e.g., PLAINTEXT or SASL).
* Use a separate listener for external clients (e.g., producers and consumers) with a different protocol (e.g., SSL or SASL_SSL).
NEW QUESTION # 34
Education degree does not equal strength, and it does not mean ability. Education degree just mean that you have this learning experience only. And the real ability is exercised in practice, it is not necessarily linked with the academic qualifications. Do not feel that you have no ability, and don't doubt yourself. When you choose to participate in the Confluent CCAAK Exam, it is necessary to pass it. If you are concerned about the test, however, you can choose TroytecDumps's Confluent CCAAK exam training materials. No matter how low your qualifications, you can easily understand the content of the training materials. And you can pass the exam successfully.
CCAAK Study Guide: https://www.troytecdumps.com/CCAAK-troytec-exam-dumps.html
There are three files for you, if you want to do marks on papers, the CCAAK PDF file are the best for you, In order to let you have a deep understanding of our CCAAK learning guide, our company designed the free demos for our customers, Now we have PDF version, windows software and online engine of the CCAAK certification materials, If you are satisfied with our CCAAK exam questions, you can make a choice to purchase them.
Working with Private Mode, Saving a Custom Workspace, There are three files for you, if you want to do marks on papers, the CCAAK PDF file are the best for you.
In order to let you have a deep understanding of our CCAAK learning guide, our company designed the free demos for our customers, Now we have PDF version, windows software and online engine of the CCAAK certification materials.
Newest Exam Topics CCAAK Pdf & Latest Confluent Certification Training - High Pass-Rate Confluent Confluent Certified Administrator for Apache KafkaIf you are satisfied with our CCAAK exam questions, you can make a choice to purchase them, The CCAAK Exam Prep subscriptions have the following benefits.
- Exam Topics CCAAK Pdf - Valid Confluent CCAAK Study Guide: Confluent Certified Administrator for Apache Kafka 🍝 Search for [ CCAAK ] on ➽ [url]www.pass4test.com 🢪 immediately to obtain a free download 🧺Brain CCAAK Exam[/url]
- CCAAK Valid Test Format 🛕 CCAAK Reliable Braindumps Sheet 😧 Latest CCAAK Exam Topics 👰 The page for free download of ➽ CCAAK 🢪 on ➥ [url]www.pdfvce.com 🡄 will open immediately 🤗Test CCAAK Dumps Demo[/url]
- Brain CCAAK Exam 🐰 CCAAK New Braindumps Ebook 🥉 Brain CCAAK Exam ↩ Download ☀ CCAAK ️☀️ for free by simply searching on ⮆ [url]www.vceengine.com ⮄ 🥍CCAAK Real Question[/url]
- Free PDF Quiz 2026 Confluent CCAAK: Authoritative Exam Topics Confluent Certified Administrator for Apache Kafka Pdf 💍 Simply search for ⇛ CCAAK ⇚ for free download on ☀ [url]www.pdfvce.com ️☀️ 🥖Test CCAAK Dumps Demo[/url]
- Get Authoritative Exam Topics CCAAK Pdf and Useful CCAAK Study Guide ♻ Search for ⮆ CCAAK ⮄ on ⏩ [url]www.practicevce.com ⏪ immediately to obtain a free download 🎻Updated CCAAK Demo[/url]
- New CCAAK Test Camp 🕉 Associate CCAAK Level Exam ⏰ CCAAK Latest Version 🦰 Download CCAAK for free by simply searching on [ [url]www.pdfvce.com ] 🧎New CCAAK Test Pass4sure[/url]
- Fantastic Exam Topics CCAAK Pdf - Win Your Confluent Certificate with Top Score 🔢 Search for CCAAK and easily obtain a free download on ➠ [url]www.dumpsquestion.com 🠰 🔁CCAAK Latest Exam Answers[/url]
- Newest Confluent Exam Topics CCAAK Pdf Are Leading Materials - Authoritative CCAAK: Confluent Certified Administrator for Apache Kafka 🛬 Search for ✔ CCAAK ️✔️ on { [url]www.pdfvce.com } immediately to obtain a free download 🍳CCAAK Reliable Braindumps Sheet[/url]
- CCAAK New Exam Braindumps 👌 Test CCAAK Dumps Demo 🧘 CCAAK Latest Exam Answers 😐 Download ➽ CCAAK 🢪 for free by simply entering ➽ [url]www.troytecdumps.com 🢪 website 👙CCAAK Latest Version[/url]
- Dump CCAAK Check 🌰 Dump CCAAK Check 🚔 New CCAAK Test Pass4sure 😛 Download ➡ CCAAK ️⬅️ for free by simply searching on ☀ [url]www.pdfvce.com ️☀️ 💛CCAAK New Braindumps Sheet[/url]
- Latest CCAAK Exam Topics 👟 New CCAAK Test Pass4sure 🌖 Test CCAAK Dumps Demo 🏵 Search for ⮆ CCAAK ⮄ and download exam materials for free through [url]www.troytecdumps.com 🤾New CCAAK Test Camp[/url]
- bbs.t-firefly.com, pct.edu.pk, learn.csisafety.com.au, www.stes.tyc.edu.tw, gsean.lvziku.cn, gettr.com, www.stes.tyc.edu.tw, www.gtcm.info, www.stes.tyc.edu.tw, forum.phuongnamedu.vn, Disposable vapes
P.S. Free 2026 Confluent CCAAK dumps are available on Google Drive shared by TroytecDumps: https://drive.google.com/open?id=105IFGFc-2XFkSkDjZPDrilAujUUYLmSI
