[General] 100% Pass Quiz 2026 Oracle 1Z0-083¨CMarvelous Test Objectives Pdf
59
¡¾General¡¿ 100% Pass Quiz 2026 Oracle 1Z0-083¨CMarvelous Test Objectives Pdf
Posted at 1/11/2026 08:53:10      View£º195 | Replies£º0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest TestkingPass 1Z0-083 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1mSX4SVWkpm70Ql525ncTkEO9MqrdEjpk
If you cannot fully believe our 1Z0-083 exam prep, you can refer to the real comments from our customers on our official website before making a decision. There are some real feelings after they have bought our study materials. Almost all of our customers have highly praised our 1Z0-083 exam guide because they have successfully obtained the certificate. What¡¯s more, all contents are designed carefully according to the exam outline. As you can see, the quality of our 1Z0-083 Exam Torrent can stand up to the test. Your learning will be a pleasant process.
The 1Z0-083 exam is a comprehensive exam that covers a wide range of topics related to Oracle database administration. This includes advanced topics such as database performance tuning, backup and recovery, high availability, and security management. Passing 1Z0-083 Exam demonstrates that the candidate has a deep understanding of Oracle database administration concepts and is capable of performing complex tasks related to database management.
New 1Z0-083 Test Testking & Latest 1Z0-083 Test BlueprintGenerally speaking, reviewing what you have learned is important, since it will help you have a good command of the knowledge points. 1Z0-083 Online test engine has testing history and performance review, so that you can have a general review of what you have learned before next learning. In addition, 1Z0-083 exam dumps is convenient and easy to study, it supports all web browsers and Android and iOS etc. You can also practice offline if you like. We provide you with free update for 365 days for 1Z0-083 Exam Materials, so that you can get the latest information for the exam timely. And the latest information for 1Z0-083 exam dumps will be auto sent to you.
Oracle 1Z1-083 (Oracle Database Administration II) exam is designed for database administrators who want to validate their knowledge and skills in managing and maintaining Oracle databases. 1Z0-083 exam is a part of the Oracle Certified Professional (OCP) certification track, which is a globally recognized benchmark for database professionals. Passing 1Z0-083 Exam demonstrates your expertise in advanced database administration tasks, including performance tuning, backup and recovery, security management, and troubleshooting.
Oracle Database Administration II Sample Questions (Q151-Q156):NEW QUESTION # 151
Which two are true about Oracle Grid Infrastructure for a Standalone Server?
  • A. It allows Oracle Restart binaries to be installed without installing ASM.
  • B. It must be installed after Oracle Database software is installed.
  • C. It allows ASM binaries to be installed without installing Oracle Restart.
  • D. Oracle Restart can be used without using ASM for databases.
  • E. Oracle Restart can attempt to restart a failed ASM instance automatically.
  • F. It must be installed before Oracle Database software is installed.
Answer: D,E
NEW QUESTION # 152
Which three are true about RMAN persistent configuration settings, administration, and their effects? (Choose three.)
  • A. The V$RMAN_CONFIGURATION view displays only settings with values that have been modified.
  • B. A target database's persistent RMAN configuration settings are always stored in the target's control file
  • C. Backup older than the recovery window retention policy are always deleted automatically if the backup location has insufficient space.
  • D. The RMAN SHOW ALL command displays only settings with nondefault values.
  • E. Backups written to the fast recovery area (FRA) that are oboslete based on the redundancy retention policy can be deleted automatically to free space.
  • F. A DBA must specify either a redundancy retention policy or a recovery window retention policy.
  • G. A target database's persistent RMAN configuration settings are always synchronized automatically with the RMAN catalog.
Answer: A,B,E
NEW QUESTION # 153
Which are three of the steps taken by Database Configuration Assistant (DBCA) to clone a remote pluggable database (PBD) starting from Oracle 19c? (Choose three.)
  • A. creating a database link from CDB$ROOT in the remote database to the PDB in the local database
  • B. creating a database link from CDB$ROOT in the remote database to be cloned to CDB$ROOT in the local database
  • C. creating a new empty PDB in the local database from PDB$SEED
  • D. automatically dropping the database link to the remote database if it already exists
  • E. opening the cloned PDB
  • F. creating a database link from CDB$ROOT in the local database to CDB$ROOT in the remote system that is to be cloned
  • G. creating a database link from CDB$ROOT in the local database to the PDB in the remote system that is to be cloned
Answer: D,E,F
https://docs.oracle.com/en/datab ... ng-a-pdb.html#GUID-
13FF2CE2-532C-4816-8E88-7A5A6E16A279
About Cloning a Remote PDB
When the source is a PDB is in a remote CDB, you must use a database link to clone the PDB into the local CDB.
The database link must exist in the local CDB (not the remote CDB). When you issue the CREATE PLUGGABLE DATABASE statement from the root of the local CDB, you must specify a database link to the remote CDB that contains the PDB being cloned in the FROM clause. The database link connects from the local CDB to either to the root of the remote CDB or to the remote source PDB.
The following figure illustrates how this technique creates a new PDB when the source PDB is remote.
32AE49B1-13A7-4A4D-AB43-BA781ECA99D6
NEW QUESTION # 154
Which two are true about Oracle Grid Infrastructure for a Standalone Server? (Choose two.)
  • A. It requires Oracle Automatic Storage Management (ASM) components to be installed separately.
  • B. It must be installed before the Oracle database software is installed.
  • C. It can manage database resources on the server where it is installed or on a different server.
  • D. It supports volume management, file system, and automatic restart capabilities.
  • E. The CSS daemon runs from the Grid Infrastructure home.
NEW QUESTION # 155
Which three are true about RMAN archival backups with the RESTORE POINT clause? (Choose three.)
  • A. The ARCHIVAL attribute for a backup overrides the RMAN retention policy.
  • B. They are never considered obsolete by RMAN.
  • C. Archive logs are retained if they are necessary to allow the database to be recovered to a consistent state when an archival backup is restored.
  • D. All archive logs are retained after an archival backup is taken, until the next archival backup is taken of the same database.
  • E. Use of a recovery catalog is always required to support the creation and use of archival backups.
  • F. The SPFILE is included in the archival backup.
  • G. They can optionally be written to a fast recovery area (FRA).
Answer: A,C,F
NEW QUESTION # 156
New 1Z0-083 Test Testking: https://www.testkingpass.com/1Z0-083-testking-dumps.html
