[General] Looking to Advance Your IT Career? Try HP HPE6-A85 Exam Questions
70
【General】 Looking to Advance Your IT Career? Try HP HPE6-A85 Exam Questions
Posted at 1/11/2026 08:55:35      View:185 | Replies:4        Print      Only Author   [Copy Link] 1#
P.S. Free & New HPE6-A85 dumps are available on Google Drive shared by Dumpcollection: https://drive.google.com/open?id=1i6xNLmrPDzAstP-r7WlqSCPCXhQIEyO-
Before you really attend the HPE6-A85 exam and choose your materials, we want to remind you of the importance of holding a certificate like this one. Obtaining a HPE6-A85 certificate likes this one can help you master a lot of agreeable outcomes in the future, like higher salary, the opportunities to promotion and being trusted by the superiors and colleagues. Our HPE6-A85 Exam Questions can help you achieve all of your dreams.
HPE6-A85 exam covers a wide range of topics related to Aruba wireless networks, including ArubaOS, radio frequency (RF) fundamentals, wireless LAN (WLAN) design, security, and troubleshooting. Candidates who pass the exam will demonstrate their ability to configure and deploy Aruba wireless networks, troubleshoot common network issues, and implement best practices for network security.
HP HPE6-A85 (Aruba Campus Access Associate) Exam is a certification program offered by Hewlett-Packard Enterprise (HPE) that is designed to test an individual's understanding of Aruba Campus Access solutions. HPE6-A85 Exam covers a broad range of topics including the implementation, configuration, and management of Aruba wireless and wired networks. It is intended for IT professionals who are responsible for deploying and managing Aruba network solutions in a corporate or enterprise environment.
Correct HP Exam HPE6-A85 Quick Prep With Interarctive Test Engine & Professional HPE6-A85 Latest QuestionsDumpcollection believes in customer satisfaction and strives hard to make the entire HP HPE6-A85 exam preparation process simple, smart, and successful. To achieve this objective the Dumpcollection is offering the top-rated and real HPE6-A85 exam questions in three different HPE6-A85 Exam study material formats. These HPE6-A85 exam questions formats are HP HPE6-A85 PDF dumps files, desktop practice test software, and web-based practice test software.
HP HPE6-A85 (Aruba Campus Access Associate) Certification Exam is a certification exam that is designed to test the skills and knowledge of IT professionals in the area of Aruba networking technologies. HPE6-A85 exam is intended for individuals who want to demonstrate their expertise in installing, configuring and managing Aruba wireless networks in campus environments. Passing HPE6-A85 Exam confirms that the candidate has the foundational knowledge and skills required to work with Aruba access points, switches, controllers, and other network infrastructure components.
HP Aruba Campus Access Associate Exam Sample Questions (Q96-Q101):NEW QUESTION # 96
You are configuring a network with a stacked pair of 6300M switches used for distribution and layer 3 services. You create a new VLAN for users that will be used on multiple access stacks of CX6200 switches connected downstream of the distribution stack You will be creating multiple VLANs/subnets similar to this will be utilized in multiple access stacks What is the correct way to configure the routable interface for the subnet to be associated with this VLAN?
  • A. Create a physically routed interface in the subnet on the 6300M stack for each downstream switch.
  • B. Create an SVl in the subnet on the 6300M stack.
  • C. Create an SVl in the subnet on each downstream switch
  • D. Create an SVl in the subnet on the 6300M stack, and assign the management address of each downstream switch stack to a different IP address in the same subnet
The correct way to configure the routable interface for the subnet to be associated with this VLAN is to create an SVI Switched Virtual Interface (SVI) Switched Virtual Interface (SVI) is a virtual interface on a switch that represents a VLAN and provides Layer 3 routing functions for that VLAN . SVIs are used to enable inter-VLAN routing , provide gateway addresses for hosts in VLANs , apply ACLs or QoS policies to VLANs , etc . SVIs have some advantages over physical routed interfaces such as saving interface ports , reducing cable costs , simplifying network design , etc . SVIs are usually numbered according to their VLAN IDs (e.g., vlan 10) and assigned IP addresses within the subnet of their VLANs . SVIs can be created and configured by using commands such as interface vlan , ip address , no shutdown , etc . SVIs can be verified by using commands such as show ip interface brief , show vlan , show ip route , etc . in the subnet on the 6300M stack. An SVI is a virtual interface on a switch that represents a VLAN and provides Layer 3 routing functions for that VLAN. Creating an SVI in the subnet on the 6300M stack allows the switch to act as a gateway for the users in that VLAN and enable inter-VLAN routing between different subnets. Creating an SVI in the subnet on the 6300M stack also simplifies network design and management by reducing the number of physical interfaces and cables required for routing.
The other options are not correct ways to configure the routable interface for the subnet to be associated with this VLAN because:
Create a physically routed interface in the subnet on the 6300M stack for each downstream switch: This option is incorrect because creating a physically routed interface in the subnet on the 6300M stack for each downstream switch would require using one physical port and cable per downstream switch, which would consume interface resources and increase cable costs. Creating a physically routed interface in the subnet on the 6300M stack for each downstream switch would also complicate network design and management by requiring separate routing configurations and policies for each interface.
Create an SVl in the subnet on each downstream switch: This option is incorrect because creating an SVI in the subnet on each downstream switch would not enable inter-VLAN routing between different subnets, as each downstream switch would act as a gateway for its own VLAN only. Creating an SVI in the subnet on each downstream switch would also create duplicate IP addresses in the same subnet, which would cause IP conflicts and routing errors.
Create an SVl in the subnet on the 6300M stack, and assign the management address of each downstream switch stack to a different IP address in the same subnet: This option is incorrect because creating an SVI in the subnet on the 6300M stack, and assigning the management address of each downstream switch stack to a different IP address in the same subnet would not enable inter-VLAN routing between different subnets, as each downstream switch would still act as a gateway for its own VLAN only. Creating an SVI in the subnet on the 6300M stack, and assigning the management address of each downstream switch stack to a different IP address in the same subnet would also create unnecessary IP addresses in the same subnet, which would waste IP space and complicate network management.
NEW QUESTION # 97
Which are valid steps in troubleshooting Aruba Wireless Access Point connection issues? (Choose three)
  • A. Verify network cable integrity from the AP to the switch.
  • B. Reset the AP to factory default settings.
  • C. Check the power settings on the physical switch port connected to the AP.
  • D. Ensure that the AP is in compliance with the latest firmware updates.
Answer: A,C,D
NEW QUESTION # 98
Refer to Exhibit.
Which server will receive the smallest quantity of data?
  • A. 10.99.26.25
  • B. 172.17.17.43
  • C. 192.168.0.56
  • D. 10.100.100.25
Based on the exhibit showing the logging server configurations, server 172.17.17.43 will receive the smallest quantity of data because it is set to the "Warning" event log level. This means it will only log events that are categorized as warnings or higher severity, which are typically less frequent than lower severity levels such as
"Information," "Debug," or "Emergency."
NEW QUESTION # 99
What is used by network devices to send error and operational information related to IP communications?
  • A. Cyclic Redundancy Check (CRC)
  • B. User Datagram Protocol (UDP)
  • C. Frame Check Sequence (FCS)
  • D. Internet Control Message Protocol (ICMP)
ICMP (Internet Control Message Protocol) is used by network devices to send error and operational information related to IP communications. It is used to send messages like "destination unreachable" or
"time exceeded" when there are issues in IP communication
NEW QUESTION # 100
After having configured the edge switch uplink as requested your colleague says that they have failed to ping the core You ask your colleague to verify the connection is plugged in and the switch is powered on They confirm that both are correct You attempt to ping the core switch and confirm that the ping is failing.
Knowing the nature of this deployment, what commands might you use to troubleshoot this issued
  • A. Show run - to view the running configuration of the switch Show run | begin 20 "vlan 20" - to ensure VLAN 20 was correctly added to the database show run | begin 20 'interface vlan 20' - to view the L3 SVI configuration Show run interface 1/1/51.1/1/52 - to ensure the physical interfaces are no shut and were added as members of LAG 1 Show run int lag 1 - to verify LACP mode active was configured to eliminate LACP blocking states
  • B. Ping 10.1.1.1 - ping the core to attempt to verify connectivity show lacp agg - to verify which link aggregations are currently configured using which physical ports show lacp int - to verify the LACP status and whether any links are blocking in your topology show lldp neighors - to verify whether you are able to see the Core as an L2 neighbor to verify if the correct links are plugged in to the correct ports show run interface 1/1/51.1/1/52-to ensure the physical interfaces are no-shut and members of the lag show run interface lag 1 - to ensure the correct vlan trunking configuration is applied to the logical interface show run int vlan 20 - to ensure you have the L3 SVI no shut and configured in the correct subnet
  • C. diagnostic diag cable-diag 1/1/51 diag cable-diag 1/1/52 - to view diagnostic information for the physical link to get a status on any interruptions to Layer 1 connectivity, show ip route - to verify that the default gateway is present in the routing table show ip ospf - to check whether there is a layer 3 routing protocol enabled show ip dns - to view whether there is a valid dns source
  • D. Ping 10.11 1 - ping the core to attempt to verify connectivity Show trunk - to verify if the LAG interface was correctly added to the switch Show spanning tree - to check for spanning-tree blocked states Show port-access clients interface all - to view any port-access blocking states or failed authentication attempts on all interfaces Show run interface vlan20 - to double check the layer 3 svi configuration is correct for l_3 connectivity Show lldp neighors - to verify whether you are able to see the Core as an L2 neighbor to verify if the correct links are plugged in to the correct ports
These commands might help troubleshoot this issue as they check various aspects of the connectivity between the edge switch and the core switch, such as Layer 3 reachability, Layer 2 adjacency, LACP configuration and status, VLAN trunking configuration, and interface status.
References:https://www.arubanetworks.com/te ... E7E8B-0F4B-4A3C-AE7
NEW QUESTION # 101
HPE6-A85 Latest Questions: https://www.dumpcollection.com/HPE6-A85_braindumps.html
Posted at 1/13/2026 21:06:29        Only Author  2#
What an incredible article, thank you for sharing this inspiration! The Intereactive H12-411_V2.0 testing engine resources are free and very helpful.
Posted at 2/3/2026 16:54:54        Only Author  3#
MicrosoftのDP-700J認定試験は競争が激しい今のIT業界中でいよいよ人気があって、受験者が増え一方で難度が低くなくて結局専門知識と情報技術能力の要求が高い試験なので、普通の人がMicrosoft認証試験に合格するのが必要な時間とエネルギーをかからなければなりません。
Posted at 2/6/2026 07:30:18        Only Author  4#
Your article is absolutely wonderful, I really appreciate it! With the CMT-Level-I valid exam review, I advanced in my career and earned a salary increase. Now, it's free for everyone. Wishing you quick promotions!
Posted at 2/16/2026 17:06:28        Only Author  5#
Your article is truly stunning, thank you for sharing! The CV0-004 exam simulator test that helped me earn a promotion and salary raise is free for you today. Best of luck reaching your career goals!
