[General] 100% Pass Quiz 2026 Cisco 100-150 Accurate Test Cram
98
General 100% Pass Quiz 2026 Cisco 100-150 Accurate Test Cram
Posted at 1/11/2026 11:08:03      View170 | Replies1        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Cisco 100-150 dumps are available on Google Drive shared by BraindumpsPass: https://drive.google.com/open?id=1ClcbF0mBQToBY4tfSBpPiJv5lA7d8Bpy
As is known to us that pass rate is one of the most important standards when candidate choose the practice materials. The pass rate is 98.95% for 100-150 training materials, and you can pass and get a certificate successfully. In addition we also pass guarantee and money back guarantee if you fail to pass the exam after using 100-150 Exam Dumps. Free update for one year is also available, namely in the following year, you can get latest information about the 100-150 training materials. We also have online and offline chat service to solve your confusions.
Cisco 100-150 valid exam simulations file can help you clear exam and regain confidence. Every year there are thousands of candidates choosing our products and obtain certifications so that our Cisco Certified Support Technician (CCST) Networking 100-150 valid exam simulations file is famous for its high passing-rate in this field. If you want to pass exam one-shot, you shouldn't miss our files.
Cisco 100-150 Test Dump - 100-150 Latest Exam NotesThe second format of Cisco 100-150 exam preparation material is the web-based Cisco Certified Support Technician (CCST) Networking (100-150) practice test. It is useful for the ones who prefer to study online. BraindumpsPass have made this format so that users don't face the hassles of installing software while preparing for the Cisco Certified Support Technician (CCST) Networking (100-150) certification. The customizable feature of this format allows you to adjust the settings of Cisco Certified Support Technician (CCST) Networking (100-150) practice exams.
Cisco Certified Support Technician (CCST) Networking Sample Questions (Q41-Q46):NEW QUESTION # 41
A user reports that a company website is not available. The help desk technician issues a tracert command to determine if the server hosting the website is reachable over the network.
The output of the command is shown as follows:
What can you tell from the command output?
  • A. The server with the address 192.168.1.10 is reachable over the network.
  • B. The router at hop 3 is not forwarding packets to the IP address 192.168.1.10.
  • C. The server address 192.168.1.10 is being blocked by a firewall on the router at hop 3.
  • D. Requests to the web server at 192.168.1.10 are being delayed and time out.
The tracert command output shows the path taken to reach the destination IP address, 192.168.1.10.
The command output indicates:
* Hops 1 and 2 are successfully reached.
* Hop 3 times out, meaning the router at hop 3 did not respond to the tracert request.
However, this does not necessarily indicate a problem with forwarding packets, as some routers may be configured to block or not respond to ICMP requests.
* Hops 4 and 5 are successfully reached, with hop 5 being the destination IP 192.168.1.10, indicating that the server is reachable.
Thus, the correct answer is C. The server with the address 192.168.1.10 is reachable over the network.
Reference: =
* Cisco Traceroute Command
* Understanding Traceroute
The tracert command output indicates that the server with the address 192.168.1.10 is reachable over the network. The asterisk (*) at hop 3 suggests that the probe sent to that hop did not return a response, which could be due to a variety of reasons such as a firewall blocking ICMP packets or the router at that hop being configured not to respond to ICMP requests. However, since the subsequent hops (4 and 5) are showing response times, it means that the packets are indeed getting through and the server is reachable12.
Reference: =
* How to Use Traceroute Command to Read Its Results
* How to Use the Tracert Command in Windows
NEW QUESTION # 42
A help desk technician receives the four trouble tickets listed below. Which ticket should receive the highest priority and be addressed first?
  • A. Ticket 3: A user reports that response time for a cloud-based application is slower than usual.
  • B. Ticket 1: A user requests relocation of a printer to a different network jack in the same office. The jack must be patched and made active.
  • C. Ticket 2: An online webinar is taking place in the conference room. The video conferencing equipment lost internet access.
  • D. Ticket 4: Two users report that wireless access in the cafeteria has been down for the last hour.
When prioritizing trouble tickets, the most critical issues affecting business operations or high-impact activities should be addressed first. Here's a breakdown of the tickets:
* Ticket 1: Relocation of a printer, while necessary, is not urgent and does not impact critical operations.
* Ticket 2: An ongoing webinar losing internet access is critical, especially if the webinar is time- sensitive and involves multiple participants.
* Ticket 3: Slower response time for a cloud-based application is important but typically not as urgent as a complete loss of internet access for a live event.
* Ticket 4: Wireless access down in the cafeteria affects users but does not have the same immediate impact as a live webinar losing connectivity.
Thus, the correct answer is B. Ticket 2: An online webinar is taking place in the conference room. The video conferencing equipment lost internet access.
References :=
* IT Help Desk Best Practices
* Prioritizing IT Support Tickets
NEW QUESTION # 43
Examine the following output:
Which two conclusions can you make from the output of the tracert command? (Choose 2.) Note: You will receive partial credit for each correct answer.
  • A. The device sending the trace has IPv6 address 2600:1408:c400:38d :: b33.
  • B. The IPv6 address associated with the www.cisco.com server is 2600:1408: c400: 38d: : b33.
  • C. The trace failed after the fourth hop.
  • D. The trace successfully reached the www.cisco.com server.
  • E. The routers at hops 5 and 6 are offline.
*Statement A: "The trace successfully reached the www.cisco.com server." This is true as indicated by the
"Trace complete" message at the end, showing that the trace has reached its destination.
*Statement C: "The IPv6 address associated with the www.cisco.com server is 2600:1408:c400:38d::b33." This is true because the final hop in the trace, which is the destination, has this IPv6 address.
*Statement B: "The trace failed after the fourth hop." This is incorrect as the trace continues beyond the fourth hop, despite some intermediate timeouts.
*Statement D: "The routers at hops 5 and 6 are offline." This is not necessarily true. The routers might be configured to not respond to traceroute requests.
*Statement E: "The device sending the trace has IPv6 address 2600:1408:c400:38d::b33." This is incorrect; this address belongs to the destination server, not the sender.
*Understanding Traceroute: Traceroute Guide
NEW QUESTION # 44
An engineer configured a new VLAN named VLAN2 for the Data Center team. When the team tries to ping addresses outside VLAN2 from a computer in VLAN2, they are unable to reach them.
What should the engineer configure?
  • A. Additional VLAN
  • B. Default gateway
  • C. Default route
  • D. Static route
When devices within a VLAN are unable to reach addresses outside their VLAN, it typically indicates that they do not have a configured path to external networks. The engineer should configure a default gateway for VLAN2. The default gateway is the IP address of the router's interface that is connected to the VLAN, which will route traffic from the VLAN to other networks12.
Reference: =
* Understanding and Configuring VLAN Routing and Bridging on a Router Using the IRB Feature
* VLAN 2 not able to ping gateway - Cisco Community
* VLANs: Virtual Local Area Networks (VLANs) logically segment network traffic to improve security and performance. Devices within the same VLAN can communicate directly.
* Default Gateway: For devices in VLAN2 to communicate with devices outside their VLAN, they need a default gateway configured. The default gateway is typically a router or Layer 3 switch that routes traffic between different VLANs and subnets.
* Additional VLAN: Not needed in this scenario as the issue is related to routing traffic outside VLAN2, not creating another VLAN.
* Default Route: While a default route on the router may be necessary, the primary issue for devices within VLAN2 is to have a configured default gateway.
* Static Route: This is used on routers to manually specify routes to specific networks but does not address the need for a default gateway on the client devices.
* Cisco VLAN Configuration Guide: Cisco VLAN Configuration
* Understanding and Configuring VLANs: VLANs Guide
NEW QUESTION # 45
Which protocol allows you to securely upload files to another computer on the internet?
  • A. HTTP
  • B. NTP
  • C. SFTP
  • D. ICMP
SFTP, or Secure File Transfer Protocol, is a protocol that allows for secure file transfer capabilities between networked hosts. It is a secure extension of the File Transfer Protocol (FTP). SFTP encrypts both commands and data, preventing passwords and sensitive information from being transmitted openly over the network. It is typically used for secure file transfers over the internet and is built on the Secure Shell (SSH) protocol1.
References :=
*What Is SFTP? (Secure File Transfer Protocol)
*How to Use SFTP to Safely Transfer Files: A Step-by-Step Guide
*Secure File Transfers: Best Practices, Protocols And Tools
The Secure File Transfer Protocol (SFTP) is a secure version of the File Transfer Protocol (FTP) that uses SSH (Secure Shell) to encrypt all commands and data. This ensures that sensitive information, such as usernames, passwords, and files being transferred, are securely transmitted over the network.
*ICMP (Internet Control Message Protocol) is used for network diagnostics and is not designed for file transfer.
*NTP (Network Time Protocol) is used to synchronize clocks between computer systems and is not related to file transfer.
*HTTP (HyperText Transfer Protocol) is used for transmitting web pages over the internet and does not inherently provide secure file transfer capabilities.
Thus, the correct protocol that allows secure uploading of files to another computer on the internet is SFTP.
References :=
*Cisco Learning Network
*SFTP Overview (Cisco)
NEW QUESTION # 46
Our website is here to provide you with the accurate 100-150 real dumps in PDF and test engine mode. Using our latest 100-150 training materials is the only fast way to clear the actual test because our test answers are approved by our experts. The content of our 100-150 Braindumps Torrent is easy to understand that adapted to any level of candidates. It just needs few hours to your success.
100-150 Test Dump: https://www.braindumpspass.com/Cisco/100-150-practice-exam-dumps.html
So know more about our 100-150 study guide right now, simulation tests of our 100-150 learning materials have the functions of timing and mocking exams, which will allow you to adapt to the exam environment in advance and it will be of great benefit for subsequent exams, Cisco Test 100-150 Cram We are the leader in the market and master the most advanced technology, Cisco Test 100-150 Cram Comparing with the traditional learning ways, there are more convenient and multiple methods that your options can be based on your real needs and conditions.
Masks promiscuous mode so administrator cannot detect sniffer on 100-150 the local system, This prevents all of the devices in the network from requiring external network access to accurately keep time.
100% Pass Quiz Cisco - Test 100-150 CramSo know more about our 100-150 Study Guide right now, simulation tests of our 100-150 learning materials have the functions of timing and mocking exams, which will allow you to adapt 100-150 Test Dumps Pdf to the exam environment in advance and it will be of great benefit for subsequent exams.
We are the leader in the market and master the most advanced technology, Comparing 100-150 Latest Exam Notes with the traditional learning ways, there are more convenient and multiple methods that your options can be based on your real needs and conditions.
What's more, you are able to attain 100-150 practice materials with both economic price and discount during the unregularly special activity.
DOWNLOAD the newest BraindumpsPass 100-150 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1ClcbF0mBQToBY4tfSBpPiJv5lA7d8Bpy
Posted at 2/5/2026 16:15:39        Only Author  2#
Thank you for sharing such an impressive article; it really made an impact. The New 1z1-809 exam simulator fee exam is upon me. Hope I pass it with ease!
