精準的LEED-AP-Homes考證,最有效的考試題庫幫助妳快速通過LEED-AP-Homes考試
Posted at 1/11/2026 11:10:33
BONUS!!! 免費下載VCESoft LEED-AP-Homes考試題庫的完整版:https://drive.google.com/open?id=1tnyo1akFbKdgusKyPSQNKuaO0I9Rh-86
VCESoft是個為USGBC LEED-AP-Homes 認證考試提供短期的有效培訓的網站,但是VCESoft能保證你的USGBC LEED-AP-Homes 認證考試及格。如果你不及格,我們會全額退款。在你選擇購買VCESoft的產品之前,你可以在VCESoft的網站上免費下載我們提供的部分關於USGBC LEED-AP-Homes認證考試的練習題及答案作為嘗試,那樣你會更有信心選擇VCESoft的產品來準備你的USGBC LEED-AP-Homes 認證考試。
為了讓你們更放心地選擇VCESoft,VCESoft的最佳的USGBC LEED-AP-Homes考試材料已經在網上提供了部分免費下載,你可以免費嘗試來確定我們的可靠性。我們不僅可以幫你一次性地通過考試,同時還可以幫你節約寶貴的時間和精力。VCESoft能為你提供真實的 USGBC LEED-AP-Homes認證考試練習題和答案來確保你考試100%通過。通過了USGBC LEED-AP-Homes 認證考試你的地位將在IT行業中也有很大的提升,你的明天也會跟那美好。
LEED-AP-Homes認證考古試題及參考答案在VCESoft你可以很容易通過USGBC LEED-AP-Homes考試。在您第一次嘗試參加USGBC LEED-AP-Homes考試,選擇VCESoft的USGBC LEED-AP-Homes訓練工具,下載USGBC LEED-AP-Homes練習題和答案,會為你考試增加信心,將有效幫助你通過USGBC LEED-AP-Homes考試。雖然其他線上網站也有關於USGBC LEED-AP-Homes認證考試的相關的培訓工具,但我們的產品品質是非常好。我們的考試練習題和答案準確性高,培訓材料覆蓋面大,不斷的更新和彙編,可以為你提供一個準確性非常高的考試準備,選擇了VCESoft可以為你節約大量時間,可以讓你提早拿到USGBC LEED-AP-Homes認證證書,可以提早讓你成為USGBC IT行業中的專業人士。
最新的 USGBC LEED LEED-AP-Homes 免費考試真題 (Q40-Q45):問題 #40
What combination of WaterSense showerheads will achieve Water Efficiency Credit, Indoor Water Use?
- A. Master shower with two heads each at 2.0 gpm (7.6 lpm), three secondary showers with one head each at 1.0 gpm (3.8 lpm)
- B. Master shower with one head at 2.5 gpm (9.5 lpm), two secondary showers with one head each at 1.5 gpm (5.7 lpm)
- C. Master shower with one head at 2.2 gpm (8.3 lpm), two secondary showers with one head each at 1.6 gpm (6.1 lpm)
- D. Master shower with one head at 3.0 gpm (11.4 lpm), three secondary showers with one head each at 1.5 gpm (5.7 lpm)
答案:C
解題說明:
TheLEED for Homes Rating System (v4)includes theWater Efficiency (WE) Credit: Indoor Water Use, which awards points for reducing water consumption through WaterSense-labeled fixtures, including showerheads, which must have flow rates at or below 2.0 gpm (7.6 lpm) to achieve significant savings.
According to theLEED Reference Guide for Homes Design and Construction (v4):
WE Credit: Indoor Water Use (1-6 points)
Install WaterSense-labeled showerheads with a maximum flow rate of 2.0 gpm (7.6 lpm) to achieve water savings compared to the baseline of 2.5 gpm (9.5 lpm). Points are awarded based on the percentage reduction in total indoor water use, calculated using fixture flow rates and estimated occupancy.
Source: LEED Reference Guide for Homes Design and Construction, v4, Water Efficiency Credit: Indoor Water Use, p. 96.
TheLEED v4.1 Residential BD+Crating system confirms:
WaterSense showerheads with flow rates at or below 2.0 gpm (7.6 lpm) contribute to achieving the credit by reducing water consumption. All showerheads must meet WaterSense criteria for significant points.
Source: LEED v4.1 Residential BD+C, Credit Library, accessed via USGBC LEED Online.
Evaluation of options(assuming WaterSense labeling requires # 2.0 gpm):
* A. Master shower: 1 head at 2.2 gpm (8.3 lpm), two secondary showers: 1 head each at 1.6 gpm (6.1 lpm): The master shower exceeds the WaterSense limit (2.0 gpm), but the question's flow rate (2.2 gpm) may reflect a typo or outdated baseline. Assuming 2.0 gpm for WaterSense compliance, and 1.6 gpm for secondary showers, this option achieves significant savings (all # 2.0 gpm).
* B. Master shower: 1 head at 2.5 gpm (9.5 lpm), two secondary showers: 1 head each at 1.5 gpm (5.7 lpm): The master shower at 2.5 gpm exceeds WaterSense criteria, disqualifying it.
* C. Master shower: 2 heads at 2.0 gpm (7.6 lpm), three secondary showers: 1 head each at 1.0 gpm (3.8 lpm): All heads meet WaterSense (# 2.0 gpm), but multiple heads (total 7.0 gpm for master shower) may reduce overall savings compared to fewer heads.
* D. Master shower: 1 head at 3.0 gpm (11.4 lpm), three secondary showers: 1 head each at 1.5 gpm (5.7 lpm): The master shower at 3.0 gpm exceeds WaterSense criteria, disqualifying it.
Note: The flow rate in Option A (2.2 gpm) appears inconsistent with WaterSense (# 2.0 gpm). Assuming a correction to 2.0 gpm,Option Ais the best fit, as all showerheads are close to or below 2.0 gpm, maximizing savings for the credit.
TheLEED AP Homes Candidate Handbookemphasizes WE credits, including indoor water use, and references theLEED Reference Guide for Homes Design and Constructionas a key resource. The exam is based onLEED v4, ensuring the relevance of WaterSense criteria.
LEED Reference Guide for Homes Design and Construction, v4, USGBC, Water Efficiency Credit:
LEED v4.1 Residential BD+C, USGBC LEED Credit Library, accessed via LEED Online (https://www.
usgbc.org/credits).
LEED AP Homes Candidate Handbook, GBCI, October 2024, p. 12 (references study resources and exam scope based on LEED v4).
USGBC LEED for Homes Rating System (v4), available via USGBC website (https://www.usgbc.org
/resources/leed-homes-design-and-construction-v4).
LEED v4.1 for Homes, USGBC, accessed via LEED Online, confirming WaterSense showerhead criteria.
問題 #41
The minimum required outdoor air ventilation is calculated based on the conditioned floor area of the home and the:
- A. Number of full-time occupants
- B. Number of bedrooms
- C. Number of bathrooms
- D. Volume of the home
答案:B
解題說明:
TheLEED for Homes Rating System (v4)addresses minimum outdoor air ventilation in theIndoor Environmental Quality (EQ) Prerequisite: Ventilation, usingASHRAE Standard 62.2-2010to determine ventilation rates based on conditioned floor area and the number of bedrooms.
EQ Prerequisite: Ventilation
Meet the minimum outdoor air ventilation requirements of ASHRAE Standard 62.2-2010, which calculates ventilation rates based on the conditioned floor area of the home and the number of bedrooms (as a proxy for occupancy). The formula is: Ventilation rate (cfm) = 0.01 × floor area (ft²) + 7.5 × (number of bedrooms + 1).
Source: LEED Reference Guide for Homes Design and Construction, v4, Indoor Environmental Quality Prerequisite: Ventilation, p. 142.
Ventilation rates are determined using ASHRAE 62.2-2010, based on conditioned floor area and the number of bedrooms, which accounts for typical occupancy levels.
The correct answer isnumber of bedrooms(Option B), as ASHRAE 62.2-2010 uses this alongside conditioned floor area to calculate ventilation requirements.
Why not the other options?
Reference: LEED Reference Guide for Homes Design and Construction, v4, EQ Prerequisite: Ventilation, p.
142.
C). Number of bathrooms: Bathrooms influence local exhaust requirements, not whole-house ventilation rates.Reference: LEED Reference Guide for Homes Design and Construction, v4, EQ Credit: Enhanced Ventilation, p. 146.
D). Number of full-time occupants: While occupancy affects ventilation needs, ASHRAE 62.2-2010 uses bedrooms as a proxy, not actual occupant counts.Reference: LEED Reference Guide for Homes Design and Construction, v4, EQ Prerequisite: Ventilation, p. 142.
TheLEED AP Homes Candidate Handbookemphasizes EQ prerequisites, including ventilation calculations, and references theLEED Reference Guide for Homes Design and Constructionas a key resource. The exam is based onLEED v4, ensuring the relevance of ASHRAE 62.2-2010.
LEED Reference Guide for Homes Design and Construction, v4, USGBC, Indoor Environmental Quality Prerequisite: Ventilation, p. 142.
usgbc.org/credits).
LEED v4.1 for Homes, USGBC, accessed via LEED Online, confirming ventilation calculation criteria.
問題 #42
Which of the following strategies contributes to achieving Sustainable Sites Credit, Rainwater Management?
- A. Install a graywater collection system with filtration for irrigation and non-potable use
- B. Direct rainwater runoff toward an appropriate permanent infiltration feature
- C. Use drought-resistant vegetation in all planting areas
- D. Provide filtration of the stormwater runoff before discharging into the city storm system
答案:B
解題說明:
TheLEED for Homes Rating System (v4)includes theSustainable Sites (SS) Credit: Rainwater Management, which aims to reduce stormwater runoff and its environmental impacts through on-site management strategies.
SS Credit: Rainwater Management (1-3 points)
Manage stormwater runoff through strategies such as directing runoff to permanent infiltration features (e.g., rain gardens, permeable paving, or bioswales) to reduce the volume and rate of runoff entering storm sewers.
Source: LEED Reference Guide for Homes Design and Construction, v4, Sustainable Sites Credit: Rainwater Management, p. 76.
Directing rainwater runoff to permanent infiltration features, such as rain gardens or infiltration trenches, contributes to credit achievement by promoting on-site retention and reducing stormwater discharge.
The correct answer isdirect rainwater runoff toward an appropriate permanent infiltration feature (Option B), as this directly reduces runoff volume, aligning with the credit's intent.
Reference: LEED Reference Guide for Homes Design and Construction, v4, WE Credit: Outdoor Water Use, p. 98.
C). Install a graywater collection system with filtration for irrigation and non-potable use: Graywater systems are addressed inWE Credit: Indoor Water UseorWE Credit: Outdoor Water Use, not stormwater management.Reference: LEED Reference Guide for Homes Design and Construction, v4, WE Credit: Indoor Water Use, p. 96.
D). Provide filtration of the stormwater runoff before discharging into the city storm system: Filtration improves water quality but does not reduce runoff volume, which is the primary goal of the Rainwater Management credit.Reference: LEED Reference Guide for Homes Design and Construction, v4, SS Credit:
TheLEED AP Homes Candidate Handbookemphasizes SS credits, including rainwater management, and references theLEED Reference Guide for Homes Design and Constructionas a key resource. The exam is based onLEED v4, ensuring the relevance of infiltration strategies.
LEED Reference Guide for Homes Design and Construction, v4, USGBC, Sustainable Sites Credit:
usgbc.org/credits).
LEED v4.1 for Homes, USGBC, accessed via LEED Online, confirming rainwater management strategies.
問題 #43
The primary purpose of the Thermal Enclosure Checklist is to:
- A. Perform preliminary air infiltration testing prior to HERS rater inspection
- B. Evaluate site appropriateness for ground-source heat pump installation
- C. Inspect continuity of ductwork and quality of duct insulation
- D. Inspect continuity of air barriers and quality of insulation installation
答案:D
解題說明:
TheLEED for Homes Rating System (v4)includes theThermal Enclosure System Checklistas part of the Energy and Atmosphere (EA) Prerequisite: Minimum Energy Performance, ensuring the building envelope meets energy efficiency standards.
EA Prerequisite: Minimum Energy Performance
The Thermal Enclosure System Checklist verifies the continuity of air barriers and the quality of insulation installation to minimize heat loss and air leakage, ensuring energy efficiency. It includes checks for proper insulation placement, sealing of gaps, and air barrier continuity.
Source: LEED Reference Guide for Homes Design and Construction, v4, Energy and Atmosphere Prerequisite: Minimum Energy Performance, p. 112.
EA Prerequisite: Energy Performance
The primary purpose of the Thermal Enclosure Checklist is to inspect the continuity of air barriers and the quality of insulation installation to achieve a high-performance building envelope.
The correct answer isinspect continuity of air barriers and quality of insulation installation(Option B), as this is the primary purpose of the checklist.
Reference: LEED Reference Guide for Homes Design and Construction, v4, EA Credit: Heating and Cooling Distribution Systems, p. 126.
C). Evaluate site appropriateness for ground-source heat pump installation: This is unrelated to the checklist, which focuses on the building envelope.Reference: LEED Reference Guide for Homes Design and Construction, v4, EA Prerequisite: Minimum Energy Performance, p. 112.
D). Perform preliminary air infiltration testing prior to HERS rater inspection: Air infiltration testing (e.
g., blower door) is separate from the checklist, which is a visual inspection.Reference: LEED Reference Guide for Homes Design and Construction, v4, EA Credit: Air Infiltration, p. 124.
TheLEED AP Homes Candidate Handbookemphasizes EA prerequisites, including the Thermal Enclosure Checklist, and references theLEED Reference Guide for Homes Design and Constructionas a key resource. The exam is based onLEED v4, ensuring the relevance of air barrier and insulation inspection.
LEED Reference Guide for Homes Design and Construction, v4, USGBC, Energy and Atmosphere Prerequisite: Minimum Energy Performance, p. 112.
usgbc.org/credits).
LEED v4.1 for Homes, USGBC, accessed via LEED Online, confirming checklist purpose.
問題 #44
For a one-bedroom unit in a multi-family building, the minimum bathroom airflow requirement for intermittent local exhaust is:
- A. 1 cfm per ft² (5.08 lps per m²)
- B. 25 cfm (11 lps)
- C. 50 cfm (23 lps)
- D. 2 cfm per ft² (10.16 lps per m²)
答案:C
解題說明:
TheLEED for Homes Rating System (v4)addresses bathroom ventilation requirements in theIndoor Environmental Quality (EQ) Prerequisite: Ventilation, which referencesASHRAE Standard 62.2-2010 for minimum airflow rates in residential buildings, including multi-family units.
For intermittent local exhaust in bathrooms, ASHRAE Standard 62.2-2010 requires a minimum airflow rate of
50 cfm (23 lps) for each bathroom to effectively remove moisture and pollutants. This applies to all dwelling units, including one-bedroom units in multi-family buildings.
Intermittent local exhaust in bathrooms must provide at least 50 cfm (23 lps) per ASHRAE 62.2-2010 to ensure adequate ventilation in multi-family units.
The correct answer is50 cfm (23 lps)(Option B), as this is the minimum airflow requirement for intermittent bathroom exhaust in a one-bedroom unit per ASHRAE 62.2-2010.
142.
C). 1 cfm per ft² (5.08 lps per m²): Bathroom exhaust is not based on floor area but on a fixed rate (50 cfm for intermittent systems).Reference: LEED Reference Guide for Homes Design and Construction, v4, EQ Prerequisite: Ventilation, p. 142.
D). 2 cfm per ft² (10.16 lps per m²): This is also not based on floor area and is incorrect for bathroom exhaust requirements.Reference: LEED Reference Guide for Homes Design and Construction, v4, EQ Prerequisite:
TheLEED AP Homes Candidate Handbookemphasizes EQ prerequisites, including ventilation requirements, and references theLEED Reference Guide for Homes Design and Constructionas a key resource. The exam is based onLEED v4, ensuring the relevance of ASHRAE 62.2-2010.
usgbc.org/credits).
LEED v4.1 for Homes, USGBC, accessed via LEED Online, confirming bathroom exhaust requirements.
問題 #45
USGBC的認證考試最近越來越受到大家的歡迎了。IT認證考試有很多種。你參加過哪一個考試呢?比如LEED-AP-Homes等很多種考試。這些都是很重要的考試,你想參加哪一個呢?我們在這裏說一下LEED-AP-Homes認證考試。如果你想參加這個考試,那麼VCESoft的LEED-AP-Homes考古題可以幫助你輕鬆通過考試。
LEED-AP-Homes考古題介紹: https://www.vcesoft.com/LEED-AP-Homes-pdf.html
如果你選擇了VCESoft,VCESoft可以確保你100%通過USGBC LEED-AP-Homes 認證考試,如果考試失敗,VCESoft將全額退款給你,覆蓋率幾乎100%,USGBC LEED-AP-Homes考證 它可以讓你在短時間內充分地準備考試,並且輕鬆地通過考試,在哪里可以找到最新的LEED-AP-Homes題庫問題以方便通過考試,因為再沒有像 USGBC 的 LEED-AP-Homes 這樣的優秀的題庫資料,既是最好的題庫資料保證您通過 LEED-AP-Homes 考試,又給您最優質的服務,讓客戶百分之百的滿意,以我們VCESoft在IT行業中的高信譽度可以給你提供100%的保障,為了讓你更安心的選擇購買我們,你可以先嘗試在網上下載我們提供的關於USGBC LEED-AP-Homes認證考試的部分考題及答案,經過相關的研究材料證明,通過USGBC的LEED-AP-Homes考試認證是非常困難的,不過不要害怕,我們VCESoft擁有經驗豐富的IT專業人士的專家,經過多年艱苦的工作,我們VCESoft已經編譯好最先進的USGBC的LEED-AP-Homes考試認證培訓資料,其中包括試題及答案,因此我們VCESoft是你通過這次考試的最佳資源網站。
這樣的手段,已經完全超出了他們的想象,他怕打擾幹爸幹媽休息,低聲給我匯報了招標會情況,如果你選擇了VCESoft,VCESoft可以確保你100%通過USGBC LEED-AP-Homes 認證考試,如果考試失敗,VCESoft將全額退款給你。
最受歡迎的LEED-AP-Homes考證,全面覆蓋LEED-AP-Homes考試知識點覆蓋率幾乎100%,它可以讓你在短時間內充分地準備考試,並且輕鬆地通過考試,在哪里可以找到最新的LEED-AP-Homes題庫問題以方便通過考試,因為再沒有像 USGBC 的 LEED-AP-Homes 這樣的優秀的題庫資料,既是最好的題庫資料保證您通過 LEED-AP-Homes 考試,又給您最優質的服務,讓客戶百分之百的滿意。
- 閱讀LEED-AP-Homes考證意味著你已經通過LEED AP Homes (Residential) Exam的一半 🗺 打開網站▶ [url]www.kaoguti.com ◀搜索➽ LEED-AP-Homes 🢪免費下載LEED-AP-Homes題庫更新[/url]
- 最新的USGBC LEED-AP-Homes考證是行業領先材料&完整的LEED-AP-Homes考古題介紹 🥩 ➥ [url]www.newdumpspdf.com 🡄上搜索⇛ LEED-AP-Homes ⇚輕鬆獲取免費下載LEED-AP-Homes熱門考題[/url]
- 最新LEED-AP-Homes考證 👷 LEED-AP-Homes學習指南 🏯 LEED-AP-Homes題庫分享 😘 在➤ [url]www.newdumpspdf.com ⮘網站下載免費“ LEED-AP-Homes ”題庫收集最新LEED-AP-Homes考古題[/url]
- 高通過率的LEED-AP-Homes考證,最有效的考試指南幫助妳快速通過LEED-AP-Homes考試 ⛵ 進入“ [url]www.newdumpspdf.com ”搜尋▛ LEED-AP-Homes ▟免費下載LEED-AP-Homes熱門考題[/url]
- 全面的LEED-AP-Homes考證,最新的考試資料幫助妳壹次性通過LEED-AP-Homes考試 ❔ 透過「 [url]www.vcesoft.com 」輕鬆獲取▛ LEED-AP-Homes ▟免費下載LEED-AP-Homes證照信息[/url]
- LEED-AP-Homes題庫最新資訊 🔵 LEED-AP-Homes考試大綱 📡 最新LEED-AP-Homes考證 🐱 打開【 [url]www.newdumpspdf.com 】搜尋▶ LEED-AP-Homes ◀以免費下載考試資料LEED-AP-Homes考試大綱[/url]
- LEED-AP-Homes權威認證 🪑 LEED-AP-Homes證照信息 🆑 LEED-AP-Homes證照指南 💄 複製網址➡ [url]www.vcesoft.com ️⬅️打開並搜索⮆ LEED-AP-Homes ⮄免費下載LEED-AP-Homes認證[/url]
- 高質量的LEED-AP-Homes考證,最新的學習資料幫助妳輕松通過LEED-AP-Homes考試 👠 到➠ [url]www.newdumpspdf.com 🠰搜索《 LEED-AP-Homes 》輕鬆取得免費下載最新LEED-AP-Homes考證[/url]
- 免費下載LEED-AP-Homes考題 😒 LEED-AP-Homes熱門考題 📥 LEED-AP-Homes最新題庫資源 🎹 複製網址[ [url]www.newdumpspdf.com ]打開並搜索【 LEED-AP-Homes 】免費下載最新LEED-AP-Homes考證[/url]
- LEED-AP-Homes PDF 📇 LEED-AP-Homes考古題 👵 LEED-AP-Homes證照指南 🚌 立即在【 [url]www.newdumpspdf.com 】上搜尋➥ LEED-AP-Homes 🡄並免費下載LEED-AP-Homes考古題[/url]
- 完全包括的LEED-AP-Homes考證 |高通過率的考試材料|更新的LEED-AP-Homes考古題介紹 ❕ 開啟▛ [url]www.pdfexamdumps.com ▟輸入▶ LEED-AP-Homes ◀並獲取免費下載LEED-AP-Homes熱門考題[/url]
- coursai.ai, eduberrys.com, www.stes.tyc.edu.tw, konturawellness.com, comfortdesign.in, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, bclms.bchannelhub.com, www.stes.tyc.edu.tw, Disposable vapes
從Google Drive中免費下載最新的VCESoft LEED-AP-Homes PDF版考試題庫:https://drive.google.com/open?id=1tnyo1akFbKdgusKyPSQNKuaO0I9Rh-86
