[General] 2V0-15.25 Exam Prepare is a Stepping Stone for You to Pass 2V0-15.25 Exam - Dump
71
General 2V0-15.25 Exam Prepare is a Stepping Stone for You to Pass 2V0-15.25 Exam - Dump
Posted at 1/11/2026 11:37:40      View167 | Replies1        Print      Only Author   [Copy Link] 1#
The PDF version of our 2V0-15.25 study tool is very practical, which is mainly reflected on the special function. As I mentioned above, our company are willing to provide all people with the demo for free. You must want to know how to get the trial demo of our 2V0-15.25 question torrent; the answer is the PDF version. You can download the free demo form the PDF version of our 2V0-15.25 Exam Torrent. If you download our study materials successfully, you can print our study materials on pages by the PDF version of our 2V0-15.25 exam torrent.
VMware 2V0-15.25 Exam Syllabus Topics:
  • VMware by Broadcom Solution: This section focuses on understanding VMware by Broadcom's virtualization and cloud infrastructure platform for managing modern enterprise workloads.
  • Troubleshoot and Optimize the VMware by Broadcom Solution: This domain focuses on troubleshooting VCF deployment, upgrades, conversions, workload domains, fleet operations (certificates, passwords, identity), licensing, compute resources, storage (vSAN, supplemental storage), networking (VDS, NSX), VCF Operations tools, Identity Broker automation, and HCX workload migrations.
  • Install, Configure, Administrate the VMware by Broadcom Solution: This area covers installing, configuring, and managing VMware solutions including VCF Fleet deployment, expansion, and reduction operations.
  • IT Architectures, Technologies, Standards: This domain covers fundamental frameworks, tools, and best practices for building scalable, secure, and interoperable enterprise IT systems.
Topic 5
  • Plan and Design the VMware by Broadcom Solution: This domain addresses architectural planning and design principles for creating scalable, secure virtual environments aligned with business requirements.
100% Pass 2026 2V0-15.25: VMware Cloud Foundation 9.0 Support CEfficient Exam FeesThe PDF version of the DumpsReview VMware Cloud Foundation 9.0 Support (2V0-15.25) prep material is easily accessible. This format is ideal for someone who is constantly on the move, as you can prepare for your VMware Cloud Foundation 9.0 Support (2V0-15.25) exam whether you are using your smartphone, tablet, or laptop. You can study anywhere, at any time, without having to worry about installing anything. Furthermore, you can study with a hard copy by printing all of your VMware Cloud Foundation 9.0 Support (2V0-15.25) PDF questions. We offer regular updates in PDF format to improve VMware Cloud Foundation 9.0 Support (2V0-15.25) questions according to changes in the exam.
VMware Cloud Foundation 9.0 Support Sample Questions (Q46-Q51):NEW QUESTION # 46
An administrator is tasked with replacing a VMware vCenter certificate in VMware Cloud Foundation (VCF) Operations with an external CA-signed certificate. The certificate import completes successfully but when running the certificate replacement task, it fails with the following error: Certificate replacement has failed...
The Certificate Chain validation failed due to 'Signature does not match' What is the possible cause of this issue?
  • A. The external CA is not trusted by VCF Operations.
  • B. The external CA is not accessible to VCF Operations.
  • C. The Certificate Signing Request (CSR) included the IP address of the vCenter.
  • D. The server certificate was copied to the wrong field.
When replacing certificates in VMware Cloud Foundation (VCF) Operations, the system performs strict certificate chain validation. The error shown:
"Certificate chain validation failed due to 'Signature does not match'" indicates that VCF Operations attempted to validate the presented certificate chain but detected that the server certificate did not correctly match the signing CA certificate. This occursmost commonly when the administrator pastes the server certificate and CA root/intermediate certificates into the wrong fields during import.
VCF requires the certificate bundle to be uploaded in the correct format:
* Server certificate# Server Certificate field
* Intermediate certificates# Intermediate Chain field
* Root certificate# Root CA field
If the chain order is wrong or the server certificate is mistakenly placed in an intermediate or root CA field, the cryptographic signature validation fails. This exact failure mode is documented in VMware certificate replacement workflows.
Option A is incorrect because including an IP address in a CSR does not invalidate chain signatures.
Option B is incorrect because an untrusted CA produces atrustfailure, not asignature mismatch.
Option C is unrelated: accessibility is not required for certificate validation.
NEW QUESTION # 47
An administrator has received reports of high CPU ready times on several Virtual Machines (VMs) running within a VMware Cloud Foundation (VCF) with error" F.iain and has been tasked with collecting detailed metrics for all running Virtual Machines from each ESX host. com.vmware.esx.setungs_aaemon.sonware.
scan_spec.".
What is the cause of this error?
  • A. A component was removed from the image.
  • B. The cluster was not assigned a default image.
  • C. A vendor add-on was not provided in the image.
  • D. A device driver Is incompatible with the included firmware.
The error message com.vmware.esx.settings.daemon.software.scan_spec (reconstructed from the typo setungs_aaemon.sonware.scan_spec) is a specific failure generated by thevSphere Lifecycle Manager (vLCM)compliance engine on the ESXi host.
* Cause - Removed Component:This error is a documented known issue in vSphere 8.x/VCF 5.x+, specifically occurring when an administrator hasremoved a componentfrom the Cluster Image that the system validates as "required" or "structural" for the host's hardware configuration (common with hosts using DPUs or specific OEM add-ons).
* The Scenario:The mention of "High CPU ready times" likely implies the administrator attempted to streamline the host image byremovinga perceived "bloatware" component (like a vendor monitoring agent or unused driver) to improve performance.
* The Result:When vLCM attempts to build the "Scan Specification" (scan_spec) to validate the host against this modified image, the internal struct validation fails because the removed component creates an invalid dependency state, throwing the Invalid field software_spec... or scan_spec exception.
NEW QUESTION # 48
An administrator recently deployed a new three-node VMware vSAN Express Storage Architecture (ESA) cluster to an existing workload domain. After creating a number of Virtual Machines (VMs), the administrator discovers that storage is being consumed a lot quicker than expected.
While investigating the issue, the administrator discovers that the datastore default policy has been set to RAID-1 by Auto-Policy Management rather than the expected RAID-5.
What is a possible cause?
  • A. The vSAN ESA cluster must have a minimum of four hosts.
  • B. The RAID-5 policy is only supported on a vSAN ESA storage cluster.
  • C. The vSAN ESA cluster has Host Rebuild Reserved enabled.
  • D. The vSAN storage policy has Force Provisioning enabled.
In vSAN Express Storage Architecture (ESA),Auto-Policy Managementdetermines which default storage policies can be used based on the number of hosts in the cluster. RAID-5 and RAID-6 policies require a minimum number of hosts to satisfy fault domain and component placement rules.
ForvSAN ESA, the minimum hosts required are:
* RAID-1 (FTT=1)# minimum3 hosts
* RAID-5 (FTT=1)# minimum4 hosts
* RAID-6 (FTT=2)# minimum6 hosts
In this scenario, the administrator deployed athree-host ESA cluster. Since RAID-5 requires at leastfour ESA-capable hosts, vSAN Auto-Policy Managementautomatically falls back to RAID-1, the highest level of resilience possible with the available cluster size. This results insignificantly higher storage consumption, which matches exactly what the administrator observed.
Option A is incorrect because RAID-5 is fully supported on ESA-but only with enough hosts.
Option C (Force Provisioning) does not change the default policy selected.
Option D (Host Rebuild Reserve) does not control RAID policy selection.
NEW QUESTION # 49
An administrator has successfully deployed and configured the Application Monitoring Telegraf Agent to 30 virtual machines through VMware Cloud Foundation (VCF) Operations.
After 24 hours, the administrator is alerted to the fact that no additional data has been collected since the agents were deployed on the virtual machines.
What could be the possible cause of the issue?
  • A. There is a compatibility issue between the version of Virtual Machine Hardware and VMware Tools.
  • B. The Service Discovery Management Pack has not been configured.
  • C. Application monitoring has been configured to use a single Cloud Proxy rather than a Collector Group.
  • D. There is a time synchronization issue between the Telegraf Agent and the Cloud Proxy.
Application Monitoring in VCF Operations uses Telegraf agents running inside virtual machines. These agents forward metrics to theCloud Proxy, which then sends them to the Operations analytics cluster. One of the most common reasons an agent stops reporting data-especially exactly24 hoursafter deployment-is clock drift or time mismatchbetween the VM (running the Telegraf agent) and the Cloud Proxy.
VCF Operations enforcesstrict timestamp validation. If the timestamps from the agent are outside the acceptable drift window, the Cloud Proxyrejectsincoming data as invalid. In this case, the Telegraf agents appear installed and functional, but no new metrics are received by the analytics engine.
This is a well-known issue documented in VMware Aria/VCF Operations agent-based monitoring, where:
* Agents send metrics with local system time.
* Cloud Proxy enforces time validation to prevent corrupt metric ingestion.
* A drift >5 minutes commonly results inzero data collectiondespite healthy connectivity.
Options B and C cannot stop data flow after exactly 24 hours; they would preventinitialcollection. Option D (virtual hardware/tools compatibility) affects VM operations butnotTelegraf metric time-stamp validation.
NEW QUESTION # 50
An administrator has been tasked with expanding an existing VMware Cloud Foundation (VCF) workload domain by adding a new cluster. The VCF fleet has the following configuration:
* Three workload domains, including the management domain are configured.
* The management domain (WLD-01) and one of the workload domains (WLD-02) are running VCF 9.0.
* The other workload domain (WLD-03) is running VCF 5.2.1 and is an isolated workload domain.
When attempting to perform the required steps using the vSphere Client UI the cluster cannot be added to the WLD-02 workload domain. What step should the administrator perform to complete the workload domain expansion?
  • A. Use the SDDC Manager API to create the cluster in WLD-03.
  • B. Use the VCF Operations Fleet Manager UI to create the cluster in WLD-02.
  • C. Use the vSphere Client UI to create the cluster in WLD-03.
  • D. Use the SDDC Manager UI to create the cluster in WLD-02.
VMware Cloud Foundation 9.0 introduces a major architectural redesign that replaces the traditional SDDC Manager-centric domain management model with aunified Fleet Management architectureimplemented throughVCF Operations Fleet Manager. In this model, each Workload Domain operates withits own vCenter, but Enhanced Linked Mode (ELM) isremovedto improve isolation, reduce blast radius, and support multi-site scalability. As a result, administrators logged into the vSphere Client of the Management Domain can no longer manage or expand clusters in other Workload Domains, which explains why the vSphere UI blocks the attempted expansion of WLD-02.
Fleet Manager becomes the new authoritative control plane for lifecycle, topology, host commissioning, and workload domain expansion. Only Fleet Manager maintains the fullglobal viewnecessary to orchestrate cluster addition operations across distributed vCenters and domains. Because WLD-02 is running VCF 9.0 and is fully fleet-aware, its expansion must occur throughVCF Operations Fleet Manager, not through the vSphere Client or legacy SDDC Manager workflows.
Options involving WLD-03 are invalid since that domain is running VCF 5.2.1, is isolated, and cannot participate in fleet-aware operations. SDDC Manager (A) is no longer the correct interface for VCF 9.0 domain expansion operations.
NEW QUESTION # 51
Do you feel anxiety about your coming 2V0-15.25 exam test? Do you want to find the valid and latest material for the 2V0-15.25 actual test? DumpsReview will help you and bring you to the right direction. Firstly, 2V0-15.25 free demo is allowable for you to try before you buy. Besides, we will offer you the benefits of 365 days free update. SO, even if the 2V0-15.25 Actual Test is changed frequently, you do not worry about it, because our 2V0-15.25 training material is updated according to the actual test and can ensure you pass.
Latest 2V0-15.25 Test Notes: https://www.dumpsreview.com/2V0-15.25-exam-dumps-review.html
Posted at 1/16/2026 02:45:10        Only Author  2#
What a captivating article, I truly appreciate your sharing it. Explore the extensive content in CIPT official study guide, freely provided to benefit you.
