Scripting-and-Programming-Foundations Certification Exam Questions in 3 User-Fri
Posted at 1/11/2026 11:58:29
View183
Replies2
P.S. Free & New Scripting-and-Programming-Foundations dumps are available on Google Drive shared by Real4Prep: https://drive.google.com/open?id=1IH7DteoM_V0BmpWLPUmjllimdM1Bjvnu
Currently more and more IT companies think highly of WGU certifications, IT workers are willing to clear exams (Scripting-and-Programming-Foundations valid practice exam online) and get certifications in order to improve their competitive power and obtain better opportunities. If you are ready to prepare for test questions and answers by PDF file or soft test engine in order to master better knowledge and skills, Scripting-and-Programming-Foundations valid practice exam online will be a nice choice.
WGU Scripting-and-Programming-Foundations Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Explaining Logic and Outcomes of Simple Algorithms: This section of the exam measures the skills of Entry Level Programmers and covers the ability to read simple algorithms and understand how they work. It focuses on predicting outputs, understanding step by step logic, and identifying how basic instructions create a final result. The goal is to help learners understand algorithm reasoning without requiring advanced coding knowledge.
| | Topic 2 | - Identifying Scripts for Computer Program Requirements: This section of the exam measures the skills of Junior Software Developers and covers the ability to match a task with the correct script or programming approach. It highlights how different scripts can satisfy specific requirements and how to recognize the right structure for a given programming problem.
| | Topic 3 | - Scripting and Programming Foundations: This section of the exam measures the skills of Junior Software Developers and covers the essential building blocks of programming. It focuses on variables, data types, flow control, and basic design concepts. Learners understand how programming logic works and how different languages handle similar tasks. The section also introduces the difference between interpreted and compiled languages in a simple and practical way.
| | Topic 4 | - Using Fundamental Programming Elements: This section of the exam measures skills of Entry Level Programmers and covers the use of basic programming components required in everyday tasks. It includes working with variables, loops, conditions, and simple logic to perform common operations. The focus is on applying these elements correctly to complete small programming assignments in a clear and organized way.
Heres The Proven And Quick Way To Get Success In WGU Scripting-and-Programming-Foundations ExamReal4Prep's product is prepared for people who participate in the WGU certification Scripting-and-Programming-Foundations exam. Real4Prep's training materials include not only WGU certification Scripting-and-Programming-Foundations exam training materials which can consolidate your expertise, but also high degree of accuracy of practice questions and answers about WGU Certification Scripting-and-Programming-Foundations Exam. Real4Prep can guarantee you passe the WGU certification Scripting-and-Programming-Foundations exam with high score the even if you are the first time to participate in this exam.
WGU Scripting and Programming Foundations Exam Sample Questions (Q91-Q96):NEW QUESTION # 91
A function should return 0 if a number, N is even and 1 if N is odd.
What should be the input to the function?
In the context of writing a function that determines whether a given number N is even or odd, the input to the function should be the number itself, represented by the variable N. The function will then perform the necessary logic to determine whether N is even or odd and return the appropriate value (0 for even, 1 for odd).
Here's how the function might look in Python:
Python
def check_even_odd(N):
Determines whether a given number N is even or odd.
Args:
N (int): The input number.
Returns:
int: 0 if N is even, 1 if N is odd.
if N % 2 == 0:
return 0 # N is even
else:
return 1 # N is odd
# Example usage:
number_to_check = 7
result = check_even_odd(number_to_check)
print(f"The result for {number_to_check} is: {result}")
AI-generated code. Review and use carefully. More info on FAQ.
In this example, if number_to_check is 7, the function will return 1 because 7 is an odd number.
* No specific external references are needed for this basic concept, as it is fundamental to programming and mathematics.
NEW QUESTION # 92
Given integer x = 12 and integer y = 4
What is the value of the expression x + y12?
The expression given is ( x + y
