[Linux] RK3568 PCIe Entry L1.1 and L1.2
31
Linux RK3568 PCIe Entry L1.1 and L1.2
Posted at 11/9/2021 16:25:45      View6420 | Replies5        Print      Only Author   [Copy Link] 1#
Hi Sirs,
In Linux Kernel driver, the driver don't support PCIe L1.1 and L1.2.
Could you please provide the sample code?
And I have check the TRM, the L1sub Status FSM don't have any description about the status.
Please provide the details register description.
Thanks
Posted at 11/22/2021 10:38:05        Only Author  2#
In the `Chapter 18 PCIe Controller` of `Rockchip RK3568 TRM Part2 V1.1-20210301.pdf`, all the descriptions of PCIe are already available.
Maybe you need to look at these entries: PCIE_CLIENT_POWER_CON, PCIE_CLIENT_POWER_STATUS.
https://en.t-firefly.com/doc/download/89.html#other_370
Posted at 1/21/2022 17:35:05        Only Author  3#
ʱĺ Posted at 11/22/2021 10:38
In the `Chapter 18 PCIe Controller` of `Rockchip RK3568 TRM Part2 V1.1-20210301.pdf`, all the descri ...
Hi Sirs,
I have check the TRM. And Enable The RC and DUT L1.2.
And check the l1sub status, the status is 3.
[0x0300] 0x00230313 CLIENT_LTSSM_STATUS
[22:20] [     RW] pm_current_data_rate                              = 0x2
[   17] [     RW] rdlh_link_up                                      = 0x1
[   16] [     RW] smlh_link_up                                      = 0x1
[10:08] [     RW] l1sub_state                                       = 0x3
[05:00] [     RW] smlh_ltssm_state                                  = 0x13
[0x0014] 0x00000133 CLIENT_INTR_STATUS_PMC
[    8] [    W1C] pm_dstate_update_int                              = 0x1
[    7] [    W1C] linkst_out_l0s_int                                = 0x0
[    6] [     RO] linkst_out_l2_int                                 = 0x0
[    5] [    W1C] linkst_out_l1_int                                 = 0x1
[    4] [    W1C] linkst_out_l1sub_int                              = 0x1
[    3] [    W1C] linkst_in_l0s_int                                 = 0x0
[    2] [    W1C] linkst_in_l2_int                                  = 0x0
[    1] [    W1C] linkst_in_l1_int                                  = 0x1
[    0] [    W1C] linkst_in_l1sub_int                               = 0x1
[0x002c] 0x00000008 CLIENT_POWER_CON
[31:16] [     WO] write_enable                                      = 0x0
[   13] [    W1C] clk_req_n_con                                     = 0x0
[   12] [    W1C] clk_req_n_bypass                                  = 0x0
[11:10] [     RW] p2_cpm_disable                                    = 0x0
[    9] [     RW] app_clk_pm_en                                     = 0x0
[    8] [     RW] sys_aux_pwr_det                                   = 0x0
[    6] [     RW] app_l1sub_disable                                 = 0x0
[    5] [     RW] app_xfer_pending                                  = 0x0
[    4] [     RW] app_req_exit_l1                                   = 0x0
[    3] [     RW] app_ready_entr_l23                                = 0x1
[    2] [     RW] app_req_entr_l1                                   = 0x0
[    1] [     RW] app_pm_xmt_pme                                    = 0x0
[    0] [     RW] app_clk_req_n                                     = 0x0
I have try to set the clkreq to bypass mode. And set the clkreq to tri-state. But the l1sub status is not correct.
Please help to provide the way to configure the PCIe ASPM.
Thanks,
Posted at 1/9/2026 08:21:13        Only Author  4#
Die Produkte von EchteFrage werden den Kandidaten nicht nur helfen, die Cisco 300-835 Zertifizierrungsprfung zu bestehen, sondern Ihnen auch einen einjährigen kostenlosen Update-Service bieten. Sie wird den Kunden die neuesten Cisco 300-835 Prfungsmaterialien so schnell wie möglich liefern, so dass sich die Kunden ber die Prfungsinformationen zur Cisco 300-835 Zertifizierung informieren können. Deshalb ist EchteFrage eine erstklassige Website. Außerdem ist der Service hier auch ausgezeichnet.
Posted at 2/1/2026 16:01:52        Only Author  5#
I appreciate your article, it really gave me a new perspective. The rich resources in MS-102 reliable exam vce are provided at no cost to enhance your understanding.
Posted at 2/17/2026 17:53:19        Only Author  6#
Im really inspired by the article, thanks a lot for sharing! This is the CTAL-TAE latest test camp file exam that helped me get ahead with a promotion and raise. Its free todaywishing you success in your career!
