[General] Key 1z0-1054-25 Concepts - 1z0-1054-25 Test Guide Online
87
General Key 1z0-1054-25 Concepts - 1z0-1054-25 Test Guide Online
Posted at 1/11/2026 12:51:37      View384 | Replies4        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of TorrentVCE 1z0-1054-25 dumps from Cloud Storage: https://drive.google.com/open?id=1WFg2UBujRzMdnlxwji08RFLlYITtiDRN
Do you always feel that your gains are not proportional to your efforts without valid 1z0-1054-25 study torrent? Do you feel that you always suffer from procrastination and cannot make full use of your sporadic time? If your answer is absolutely yes, then we would like to suggest you to try our 1z0-1054-25 Training Materials, which are high quality and efficiency 1z0-1054-25 test tools. Your success is 100% ensured to pass the 1z0-1054-25 exam and acquire the dreaming certification which will enable you to reach for more opportunities to higher incomes or better enterprises.
As the professional provider of exam related materials in IT certification test, TorrentVCE has been devoted to provide all candidates with the most excellent questions and answers and has helped countless people pass the exam. TorrentVCE Oracle 1z0-1054-25 study guide can make you gain confidence and help you take the test with ease. You can pass 1z0-1054-25 Certification test on a moment's notice by TorrentVCE exam dumps. Isn't it amazing? But it is true. As long as you use our products, TorrentVCE will let you see a miracle.
Free PDF Quiz 2026 Oracle 1z0-1054-25: Oracle Financials Cloud: General Ledger 2025 Implementation Professional Pass-Sure Key ConceptsOur test bank includes all the possible questions and answers which may appear in the real exam and the quintessence and summary of the exam papers in the past. We strive to use the simplest language to make the learners understand our 1z0-1054-25 study materials and the most intuitive method to express the complicated and obscure concepts. For the learners to fully understand our 1z0-1054-25 Study Materials, we add the instances, simulation and diagrams to explain the contents which are very hard to understand. So after you use our 1z0-1054-25 study materials you will feel that our 1z0-1054-25 study materials name matches with the reality.
Oracle 1z0-1054-25 Exam Syllabus Topics:
  • Implementing Ledgers: This part evaluates the competencies of Financial Systems Analysts and focuses on defining and configuring ledgers within Oracle Financials. Candidates are expected to manage ledger-level security and understand how to utilize General Ledger Balances Cubes for better financial visibility and reporting accuracy.
  • Performing Period Close: Designed for Oracle Financial Application Managers, this section evaluates expertise in executing and managing the period close lifecycle. Topics include reconciliations, revaluation, translation, and consolidation. Candidates are required to configure the Period Close Monitor and associated setups like revaluation, allocations, and chart mappings for financial consolidation.
  • Configuring Financial Reports: This portion of the exam measures the abilities of Financial Reporting Analysts and includes creating and managing a range of reports using tools like the Financial Reporting Center, Web Studio, OTBI, Smart View, and Dashboards. Candidates must know how to define account groups, set up infolets, and build custom analytics tailored to user needs.
  • Implementing Enterprise and Financial Reporting Structures: This section of the exam measures skills of Oracle ERP Implementation Consultants and covers the core components used in setting up enterprise structures and reporting configurations. It assesses knowledge in defining legal entities, jurisdictions, and geographies, as well as the design and configuration of Chart of Accounts. Candidates must also demonstrate how to set up and secure chart structures and manage reporting calendars and currencies.
Oracle Financials Cloud: General Ledger 2025 Implementation Professional Sample Questions (Q52-Q57):NEW QUESTION # 52
Your company wants to change theCumulative Translation Adjustment (CTA) accountto record gains/losses from varying currency rates.
What steps must you perform to achieve this objective without causing data corruption?
  • A. Open the Ledgers page and update the CTA account and then rerun Translation for all periods required.The system will automatically update the translated balances.
  • B. Query the Translation journals and delete all of them, then change the CTA account in the Ledger page, and rerun Translation for all periods required.
  • C. Define a new ledger and accounting configuration. The CTA account cannot be updated after the ledger has been in use.
  • D. Purge all translated balances, change the CTA account in the Ledger page, and rerun Translation for all periods required.
NEW QUESTION # 53
You are using the Create Budgets in a Spreadsheet option to load your budget balances into the General Ledger balances cube. Your FYXX Budget is not appearing in the Budget Name list of values.
What are two reasons for this?
  • A. A value for the budget scenario is not created.
  • B. Publish Chart of Accounts Dimension Members and Hierarchies to the Balances Cube has not been run.
  • C. Budgeting is not enabled in the Ledger options.
  • D. The Create Scenario Dimension Members program has not been run.
  • E. Transfer Budget Balances to Budget Cubes has not been run.
To use the Create Budgets in a Spreadsheet option, you need to have a budget scenario value and a scenario dimension member for your budget. A budget scenario value is a user-defined value that identifies a budget, such as FYXX Budget. A scenario dimension member is a member of the scenario dimension in the General Ledger balances cube that corresponds to a budget scenario value, such as FYXX_Budget. You can create budget scenario values and scenario dimension members using the Manage Budget Scenario Values task or the Create Scenario Dimension Members program. If you do not create these values and members, your budget will not appear in the Budget Name list of values in the spreadsheet. Therefore, the two reasons for your issue are:
* A value for the budget scenario is not created: You need to create a budget scenario value for your budget using the Manage Budget Scenario Values task. This task enables you to define and maintain budget scenario values and their attributes, such as description, start date, end date, and status. You can also specify whether the budget scenario value is enabled for budgeting and reporting. You need to enable the budget scenario value for budgeting to use it in the spreadsheet.
* The Create Scenario Dimension Members program has not been run: You need to run the Create Scenario Dimension Members program to create scenario dimension members for your budget scenario values. This program automatically creates scenario dimension members for all budget scenario values that are enabled for budgeting and do not have existing scenario dimension members. You can run this program manually or schedule it to run periodically. You need to run this program after you create or update budget scenario values to ensure that they are reflected in the scenario dimension.
NEW QUESTION # 54
You already ranTranslation, but a last-minuteadjusting journal entryin yourledger currencywas entered after you consolidated your results.
What does Oracle considerbest practicewhen this occurs?
  • A. Rerun Revaluation and then rerun Translation.
  • B. Rerun Translation and then reconsolidate your results.
  • C. Enter another adjusting journal entry in the target currency to true up the balances.
  • D. Translate only the adjusting journal entry.
NEW QUESTION # 55
NEW QUESTION # 56
You are capturing rental costs for a building in a corporate cost center. At month end, you want to allocate those costs to the cost centers in the building based on the floor area occupied. A statistical journal has been entered to record the floor area. You use Calculation Manager to create the allocation.
Where do you reference the statistical balance within the allocation component?
  • A. Offset
  • B. Basis
  • C. Target
  • D. Allocation Range
  • E. Source
Answer: E
The source is where you specify the amount to be allocated. You can use various sources, such as account balances, fixed amounts, or statistical balances. In this case, you want to use the statistical balance of the floor area as the source of the allocation. The basis is where you specify the driver or factor that determines how the source amount is distributed among the targets. The target is where you specify the destination accounts that receive the allocated amount. The offset is where you specify the account that records the opposite side of the allocation entry. The allocation range is where you specify the scope of the allocation, such as the ledger, balancing segment, or legal entity. References:
Oracle Financials Cloud Implementing Enterprise Structures and General Ledger, Chapter 3: Allocations and Periodic Entries, Allocation Components Oracle Financials Cloud Using General Ledger, Chapter 3: Allocations and Periodic Entries, Overview
NEW QUESTION # 57
Dear everyone, you can download the 1z0-1054-25 free demo for a little try. If you are satisfied with the 1z0-1054-25 exam torrent, you can make the order and get the latest 1z0-1054-25 study material right now. Our 1z0-1054-25 training material comes with 100% money back guarantee to ensure the reliable and convenient shopping experience. The accurate, reliable and updated Oracle 1z0-1054-25 study torrent are compiled, checked and verified by our senior experts, which can ensure you 100% pass.
1z0-1054-25 Test Guide Online: https://www.torrentvce.com/1z0-1054-25-valid-vce-collection.html
2026 Latest TorrentVCE 1z0-1054-25 PDF Dumps and 1z0-1054-25 Exam Engine Free Share: https://drive.google.com/open?id=1WFg2UBujRzMdnlxwji08RFLlYITtiDRN
Posted at 1/13/2026 01:35:00        Only Author  2#
Data-Cloud-Consultant-JPNJYȡäJYȡäȡιä_k̶țQޤ뤿ᡢData-Cloud-Consultant-JPNԇYɤϸΤ돾ITˤʤ뤿˾ƤޤҤˑäƤ↖}ޤ󡣌gHData-Cloud-Consultant-JPNԇY˺ϸ񤹤뤿ηϽҕǤData-Cloud-Consultant-JPNΥƥȜʂ򿼤ƤˤϤ_ɤǤǤʤयΥƥĤͬrҙ뤳ȤǤޤ
Posted at 1/30/2026 08:01:49        Only Author  3#
This is so good, Im liking it immediately. We are offering Latest test PMI-RMP dumps free, full of valuable content, for free, hoping it proves helpful.
Posted at 2/17/2026 03:18:43        Only Author  4#
This article is a gem, thank you for sharing it with us! Heres the Reliable Portworx-Enterprise-Professional dumps files test material for free. Best of luck in your exams!
Posted at 3/4/2026 17:39:30        Only Author  5#
I appreciate your article; it was truly eye-catching and unique. With the SPI latest test notes, I was able to secure a promotion and salary hike. Its now available for free to all. Good luck on your career growth!
