2026 SC-300: Realistic Microsoft Identity and Access Administrator Valid Test Pa
Posted at 1/11/2026 12:58:53
View313
Replies5
P.S. Free 2026 Microsoft SC-300 dumps are available on Google Drive shared by Test4Sure: https://drive.google.com/open?id=1O0PvvQ-l-gqmGGy_pwmM2tXxeJw8AncX
It is evident to all that the SC-300 test torrent from our company has a high quality all the time. A lot of people who have bought our products can agree that our SC-300 test questions are very useful for them to get the certification. There have been 99 percent people used our SC-300 exam prep that have passed their exam and get the certification, more importantly, there are signs that this number is increasing slightly. It means that our SC-300 Test Questions are very useful for all people to achieve their dreams, and the high quality of our SC-300 exam prep is one insurmountable problem.
Test4Sure offers a free demo of Microsoft SC-300 exam dumps before the purchase to test the features of the products. Test4Sure also offers 12 months of free Microsoft SC-300 Exam Questions updates if the SC-300 certification exam content changes after purchasing our SC-300 exam dumps.
Valid SC-300 Exam Prep, New SC-300 Exam LabsMore successful cases of passing the SC-300 exam can be found and can prove our powerful strength. As a matter of fact, since the establishment, we have won wonderful feedback and ceaseless business, continuously working on developing our SC-300 test prep. We have been specializing SC-300 Exam Dumps many years and have a great deal of long-term old clients, and we would like to be a reliable cooperator on your learning path and in your further development. We will be your best friend to help you pass the SC-300 exam and get certification.
Microsoft Identity and Access Administrator Sample Questions (Q329-Q334):NEW QUESTION # 329
You need to implement password restrictions to meet the authentication requirements.
You install the Azure AD password Protection DC agent on DC1.
What should you do next? To answer, select the appropriate options in the answer area.
Server1
On DC1
NEW QUESTION # 330
You have a Microsoft 365 E5 subscription and an Azure subscription. You need to meet the following requirements:
* Ensure that users can sign in to Azure virtual machines by using their Microsoft 365 credentials.
* Delegate the ability to create new virtual machines.
What should you use for each requirement? To answer, drag the appropriate features to the correct requirements. Each feature may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content.
NEW QUESTION # 331
You have a Microsoft 365 tenant.
All users must use the Microsoft Authenticator app for multi-factor authentication (MFA) when accessing Microsoft 365 services.
Some users report that they received an MFA prompt on their Microsoft Authenticator app without initiating a sign-in request.
You need to block the users automatically when they report an MFA request that they did not initiate.
Solution: From the Azure Active Directory admin center, you configure the Block/unblock users settings for multi-factor authentication (MFA).
Does this meet the goal?
Report suspicious activity and the legacy Fraud Alert implementation can operate in parallel. You can keep your tenant-wide Fraud Alert functionality in place while you start to use Report suspicious activity with a targeted test group.
If Fraud Alert is enabled with Automatic Blocking, and Report suspicious activity is enabled, the user will be added to the blocklist and set as high-risk and in-scope for any other policies configured. These users will need to be removed from the blocklist and have their risk remediated to enable them to sign in with MFA.
https://learn.microsoft.com/en-u ... mfasettings#report- suspicious-activity-and-fraud-alert
NEW QUESTION # 332
You have a Microsoft Entra tenant that contains an administrative unit named AU1. AU1 is configured for assigned membership.
The tenant contains the users shown in the following table.
For AU1, you update the following configurations:
. Membership type: Dynamic User
Dynamic membership rule: (user.department -eq "hr")
HR is a member of AU1: No
User1 is a member of AU1: Yes
User2 is a member of AU1: No
Let's break this down step by step based on Microsoft Entra ID dynamic membership rules, administrative units, and group membership, as outlined in Microsoft Identity and Access Administrator documentation.
Understanding Administrative Units and Dynamic Membership in Microsoft Entra ID:
Administrative Units (AUs):Administrative Units in Microsoft Entra ID are used to delegate administrative tasks to a subset of users, groups, or devices. They allow you to scope administrative roles (e.g., User Administrator) to specific users or groups within the AU.
Membership Types for AUs:
Assigned Membership:Members (users, groups, or devices) are manually added to the AU by an administrator.
Dynamic Membership:Members are automatically added or removed based on a dynamic membership rule, similar to dynamic groups. Dynamic membership for AUs can be applied to users or devices (but not groups directly).
The question states that AU1 is initially configured for assigned membership but is then updated to useDynamic Usermembership with the rule (user.department -eq "HR").
Dynamic Membership Rule:The rule (user.department -eq "HR") means that AU1 will automatically include all users whose department attribute in Microsoft Entra ID is set to "HR". This rule applies to users, not groups or devices, because the membership type is "Dynamic User." Impact of Changing AU1 to Dynamic Membership:
When AU1's membership type is changed from assigned to dynamic, the existing assigned memberships (e.
g., User2, HR group, IT group) are no longer relevant. Thedynamic rule takes over, and AU1's membership is determined solely by the rule (user.department -eq "HR").
Dynamic User Membership:Only users whose attributes match the rule will be members of AU1. Groups (like HR and IT) are not evaluated by this rule because the membership type is "Dynamic User," not "Dynamic Group." Let's evaluate the users based on the rule:
User1 epartment = "HR". The rule (user.department -eq "HR") matches, so User1 will be dynamically added to AU1.
User2 epartment = "IT". The rule does not match, so User2 will not be a member of AU1, even though they were previously assigned to AU1 and are a member of the IT group.
Groups (HR and IT):The dynamic membership rule for AU1 applies to users, not groups. Therefore, groups like HR and IT are not directly evaluated by the rule. However, we need toconsider whether group membership in AU1 affects the statements.
Statement 1: HR is a member of AU1:
Analysis:
The HR group is listed in the second table with AU1 as its administrative unit, indicating that it was initially assigned to AU1 when AU1 used assigned membership.
However, AU1's membership type has been updated to "Dynamic User" with the rule (user.department -eq
"HR"). Dynamic User membership applies to users, not groups.
In Microsoft Entra ID, administrative units with dynamic user membership do not include groups as members unless the AU's membership type is explicitly set to "Dynamic Group" (which is not the case here).
When AU1 was changed to dynamic membership, the HR group would no longer be considered a member of AU1 because the dynamic rule only evaluates users. Groups are not dynamically added to AUs based on user attributes.
Conclusion:The HR group is not a member of AU1 after the change to dynamic membership. Therefore, this statement isNo.
Statement 2: User1 is a member of AU1:
Analysis:
User1 has the department attribute set to "HR" (from the first table).
The dynamic membership rule for AU1 is (user.department -eq "HR"), which matches User1's department.
Therefore, User1 will be automatically added to AU1 as a member based on the dynamic rule.
Additionally, User1 is a member of the HR group, which was initially assigned to AU1. However, since AU1 now uses dynamic membership, the HR group's assignment to AU1 is irrelevant. User1's membership in AU1 is determined solely by the dynamic rule, not their group membership.
Conclusion:User1 is a member of AU1 because their department matches the dynamic rule. Therefore, this statement isYes.
Statement 3: User2 is a member of AU1:
Analysis:
User2 has the department attribute set to "IT" (from the first table).
The dynamic membership rule for AU1 is (user.department -eq "HR"), which does not match User2's department.
User2 was initially assigned to AU1 (as shown in the first table) and is a member of the IT group, which was also assigned to AU1. However, when AU1's membership type was changed to "Dynamic User," the assigned memberships (including User2 and the IT group) are no longer relevant.
The dynamic rule only includes users with the department "HR," so User2 is not added to AU1.
Conclusion:User2 is not a member of AU1 because their department does not match the dynamic rule.
Additional Considerations:
If AU1's membership type were "Dynamic Group" instead of "Dynamic User," we would evaluate whether the HR and IT groups match a group-based rule. However, the question specifies "Dynamic User," so the rule applies to user attributes only.
The initial assigned memberships (e.g., User2, HR group, IT group) are overridden by the dynamic membership rule. Microsoft Entra ID does not retain assigned memberships when an AU or group is converted to dynamic membership.
The HR and IT groups being assigned to AU1 initially does not affect the dynamic membership of users, but it might be relevant for administrative scoping (e.g., if an admin role is scoped to AU1). However, the statements are about membership, not administrative roles.
Conclusion:Based on the dynamic membership rule (user.department -eq "HR") for AU1:
HR group:Not a member of AU1 because dynamic user membership does not apply to groups.
User1:A member of AU1 because their department is "HR," matching the rule.
User2:Not a member of AU1 because their department is "IT," which does not match the rule.Therefore, the answers are:
HR is a member of AU1:No
User1 is a member of AU1:Yes
User2 is a member of AU1:No
Microsoft Entra ID documentation: "Dynamic membership rules for groups and administrative units" (Microsoft Learn:https://learn.microsoft.com/en-u ... -dynamic-membership) Microsoft Entra ID documentation: "Manage administrative units" (Microsoft Learn:https://learn.microsoft.
com/en-us/entra/identity/role-based-access-control/administrative-units) Microsoft Identity and Access Administrator (SC-300) exam study guide, which covers dynamic membership rules and administrative units in Microsoft Entra ID.
NEW QUESTION # 333
You have an AzureAD tenant that contains the users shown in the following table.
You have the locations shown in the following table.
The tenantcontainsa named location that Das the following configurations:
* Name: location1
* Mark as trusted location: Enabled
* IPv4 range: 10.10.0.0/16
MFA has a trusted iPad dress range of 193.17.17.0/24.
You have a Conditional Access policy that has the following settings:
* Name: CAPolicy1
* Assignments
o Users or workload identities: Group 1
o Cloud apps or actions: All cloud apps
* Conditions
* Locations All trusted locations
* Access controls
o Gant
* Grant access: Require multi-factor authentication
Session: 0 controls selected
* Enable policy: On
For each of the following statements select Yes if the statement is true. Otherwise, select No. NOTE: Each correct selection is worth one point.
NEW QUESTION # 334
Microsoft SC-300 Exam provided by Test4Sure is of the highest quality, and it enables participants to pass the exam on their first try. For successful preparation, it is essential to have good Microsoft SC-300 exam dumps and to prepare questions that may come up in the exam. Test4Sure helps candidates overcome all the difficulties they may encounter in their exam preparation. To ensure the candidates' satisfaction, Test4Sure has a support team that is available 24/7 to assist with a wide range of issues.
Valid SC-300 Exam Prep: https://www.test4sure.com/SC-300-pass4sure-vce.html
We offer money back guarantee if anyone fails but that doesn't happen if one use our SC-300 dumps, If you put just a bTest4Sure of extra effort, you can score the highest possible score in the real Microsoft Certified Technician certification because our SC-300 dumps are designed for the best results.SC-300 Practice Exam Software Start learning the futuristic way, Even if you fail the exams, the customer will be reimbursed for any loss or damage after buying our SC-300 guide dump.
You will see them side by side, You know that she's selling her work, despite something, We offer money back guarantee if anyone fails but that doesn't happen if one use our SC-300 Dumps.
If you put just a bTest4Sure of extra effort, SC-300 you can score the highest possible score in the real Microsoft Certified Technician certification because our SC-300 dumps are designed for the best results.SC-300 Practice Exam Software Start learning the futuristic way.
SC-300 Valid Test Pattern & Free PDF 2026 Microsoft Microsoft Identity and Access Administrator Realistic Valid Exam PrepEven if you fail the exams, the customer will be reimbursed for any loss or damage after buying our SC-300 guide dump, Our CEO has the proven-track of success in the Microsoft Certified: Identity and Access Administrator Associate.
You only need little time to prepare for our exam.
- Hot SC-300 Valid Test Pattern | Easy To Study and Pass Exam at first attempt - Free Download SC-300: Microsoft Identity and Access Administrator 🙄 Enter [url]www.prepawayete.com and search for ➥ SC-300 🡄 to download for free 🥰
df SC-300 Torrent[/url] - Latest SC-300 Reliable Torrent - SC-300 Actual Pdf - SC-300 Exam Questions 🚪 Download ⏩ SC-300 ⏪ for free by simply entering ▛ [url]www.pdfvce.com ▟ website 🍼SC-300 Reliable Test Cost[/url]
- Hot SC-300 Valid Test Pattern | Easy To Study and Pass Exam at first attempt - Free Download SC-300: Microsoft Identity and Access Administrator 🙏 The page for free download of ➥ SC-300 🡄 on ⇛ [url]www.troytecdumps.com ⇚ will open immediately 🧦Latest Braindumps SC-300 Ppt[/url]
- Microsoft SC-300 Desktop-Based Practice Program 🧝 Immediately open ➠ [url]www.pdfvce.com 🠰 and search for ✔ SC-300 ️✔️ to obtain a free download 🈺Latest Braindumps SC-300 Ppt[/url]
- Exam Questions SC-300 Vce 🚚 SC-300 Latest Learning Materials 🌘 SC-300 Practice Test Fee 🕞 ➠ [url]www.troytecdumps.com 🠰 is best website to obtain ✔ SC-300 ️✔️ for free download 👨SC-300 Latest Learning Materials[/url]
- SC-300 Practice Test Fee 🕚 SC-300 Customizable Exam Mode ⬛ SC-300 Exam Actual Questions 📑 Easily obtain SC-300 for free download through [url]www.pdfvce.com 🏨SC-300 Free Test Questions[/url]
- Valid SC-300 Exam Sims 🐺 Latest Braindumps SC-300 Ppt 🛵 Reliable SC-300 Test Pass4sure 🔕 Search for ▶ SC-300 ◀ and obtain a free download on [url]www.vce4dumps.com 🐫SC-300 Latest Learning Materials[/url]
- SC-300 Valid Real Test ☑ SC-300 Free Test Questions 🐟 Pdf SC-300 Torrent 💝 Copy URL ➽ [url]www.pdfvce.com 🢪 open and search for ⇛ SC-300 ⇚ to download for free 💨
df SC-300 Torrent[/url] - High-quality Microsoft SC-300 Valid Test Pattern offer you accurate Valid Exam Prep | Microsoft Identity and Access Administrator 🥇 Search for ➠ SC-300 🠰 and download it for free immediately on ✔ [url]www.troytecdumps.com ️✔️ 🦮Reliable SC-300 Test Pass4sure[/url]
- Latest Braindumps SC-300 Ppt 🧆 Examcollection SC-300 Questions Answers 🎿 SC-300 Reliable Test Cost 📎 ➡ [url]www.pdfvce.com ️⬅️ is best website to obtain ➠ SC-300 🠰 for free download 🌗SC-300 Visual Cert Exam[/url]
- SC-300 Reliable Test Cost 🎑 Valid SC-300 Exam Sims 📞 SC-300 Valid Real Test 🦼 Download ☀ SC-300 ️☀️ for free by simply searching on [url]www.practicevce.com 🌹SC-300 Exam Answers[/url]
- bbs.t-firefly.com, app.parler.com, cursos.confrariadotiro.com.br, forum.phuongnamedu.vn, www.stes.tyc.edu.tw, lb.abcbbk.com, 132.148.13.112, bbs.xltyun.com, thewpstyle.com, mpgimer.edu.in, Disposable vapes
BONUS!!! Download part of Test4Sure SC-300 dumps for free: https://drive.google.com/open?id=1O0PvvQ-l-gqmGGy_pwmM2tXxeJw8AncX
