[Hardware] HPE6-A85 Latest Mock Exam | Examcollection HPE6-A85 Dumps
90
【Hardware】 HPE6-A85 Latest Mock Exam | Examcollection HPE6-A85 Dumps
Posted at 1/11/2026 13:41:14      View:114 | Replies:1        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of PrepAwayExam HPE6-A85 dumps for free: https://drive.google.com/open?id=1WouAGAwebrgzs5lFQeUvkB4G3PR8GDfv
The HP HPE6-A85 pdf questions learning material provided to the customers from PrepAwayExam is in three different formats. The first format is PDF format which is printable and portable. It means it can be accessed from tablets, laptops, and smartphones to prepare for the Aruba Campus Access Associate Exam (HPE6-A85) exam. The HP HPE6-A85 PDF format can be used offline, and candidates can even prepare for it in the classroom or library by printing questions or on their smart devices.
HP HPE6-A85 (Aruba Campus Access Associate) Certification Exam is a certification exam that is designed to test the skills and knowledge of IT professionals in the area of Aruba networking technologies. HPE6-A85 exam is intended for individuals who want to demonstrate their expertise in installing, configuring and managing Aruba wireless networks in campus environments. Passing HPE6-A85 exam confirms that the candidate has the foundational knowledge and skills required to work with Aruba access points, switches, controllers, and other network infrastructure components.
HP HPE6-A85 (Aruba Campus Access Associate) Certification Exam is a globally recognized certification that tests the knowledge and skills of network professionals in configuring and managing enterprise-level wireless networks. It covers a wide range of topics related to wireless networking and requires in-depth knowledge and hands-on experience with wireless networking technologies. Aruba Campus Access Associate Exam certification is an essential certification for professionals who are looking to advance their careers in wireless networking and offers a competitive edge to certified professionals.
HP HPE6-A85 Exam | HPE6-A85 Latest Mock Exam - Excellent Exam Tool GuaranteedIf you are already determined to obtain an international certificate, you must immediately purchase our HPE6-A85 exam practice. Our products have been certified as the highest quality products in the industry. If you know HPE6-A85 Training Materials through acquaintance introduction, then you must also know the advantages of HPE6-A85. We are both perfect on the quality and the price of the HPE6-A85 study braindumps.
HP Aruba Campus Access Associate Exam Sample Questions (Q89-Q94):NEW QUESTION # 89
Which device configuration group types can a user define in Aruba Central during group creation? (Select two.)
  • A. Default group
  • B. Template group
  • C. ESP group
  • D. Ul group
  • E. Security group
Aruba Central allows you to create device configuration groups that define common settings for devices within each group. You can create different types of groupsdepending on your network requirements and management preferences. Two types of groups that you can define in Aruba Central during group creation are:
Template group: A template group allows you to create configuration templates using variables and expressions that can be applied to multiple devices or device groups. Template groups provide flexibility and scalability for managing large-scale deployments with similar configurations.
Default group: A default group is automatically created when you add devices to Aruba Central for the first time. The default group contains basic configuration settings that are applied to all devices that are not assigned to any other group. You can modify or delete the default group as needed.
References: https://www.arubanetworks.com/te ... s/device-groups.htm
https://www.arubanetworks.com/te ... template-groups.htm
https://www.arubanetworks.com/te ... s/default-group.htm
NEW QUESTION # 90
When using an Aruba standalone AP you select "Native VLAN" for the Client VLAN Assignment In which subnet will the client IPs reside?
  • A. The same subnet as the mobility controller
  • B. The same subnet as the Aruba ESP gateway
  • C. The same subnet as the mobility conductor
  • D. The same subnet as the access point
When using an Aruba standalone AP, selecting "Native VLAN" for the Client VLAN Assignment means that the clients will get their IP addresses from the same subnet as the access point's IP address. This is because the access point acts as a DHCP server for the clients in this mode.References:https://www.arubanetworks.
com/techdocs/Instant_86_WebHelp/Content/instant-ug/iap-dhcp/iap-dhcp.htm
NEW QUESTION # 91
What is the correct command to add a static route to a class-c-network 10.2.10.0 via a gateway of
172.16.1.1?
  • A. ip-route 10.2.10.0/24 172.16.1.1
  • B. ip route 10.2.10.0/24.172.16.11
  • C. ip route-static 10.2 10.0.255.255.255.0 172.16.1.1
  • D. ip route 10.2.10.0.255.255.255.0 172.16.1.1 description aruba
The correct command to add a static route to a class-c-network 10.2.10.0 via a gateway of 172.16.1.1 is ip-route 10.2.10.0/24 172.16.1.1. This command specifies the destination network address (10.2.10.0) and prefix length (/24) and the next-hop address (172.16.1 .1) for reaching that network from the switch.
The other commands are either incorrect syntax or incorrect parameters for adding a static route.
References: https://www.arubanetworks.com/te ... ontent/cx-noscg/ip- routing/sta
NEW QUESTION # 92
A network technician has successfully connected to the employee SSID via 802 1X Which RADIUS message should you look for to ensure a successful connection?
  • A. Success
  • B. Authorized
  • C. Access-Accept
  • D. Authenticated
The RADIUS message that you should look for to ensure a successful connection via 802.1X is Access-Accept. This message indicates that the RADIUS server has authenticated and authorized the supplicant (the device that wants to access the network) and has granted it access to the network resources. The Access-Accept message may also contain additional attributes such as VLAN ID, session timeout, or filter ID that specify how the authenticator (the device that controls access to the network, such as a switch) should treat the supplicant's traffic.
The other options are not RADIUS messages because:
Authorized: This is not a RADIUS message, but a state that indicates that a port on an authenticator is allowed to pass traffic from a supplicant after successful authentication and authorization.
Success: This is not a RADIUS message, but a status that indicates that an EAP Extensible Authentication Protocol (EAP) is an authentication framework that provides support for multiple authentication methods, such as passwords, certificates, tokens, or biometrics. EAP is used in wireless networks and point-to-point connections to provide secure authentication between a supplicant (a device that wants to access the network) and an authentication server (a device that verifies the credentials of the supplicant). exchange has completed successfully between a supplicant and an authentication server.
Authenticated: This is not a RADIUS message, but a state that indicates that a port on an authenticator has received an EAP-Success message from an authentication server after successful authentication of a supplicant.
NEW QUESTION # 93
Match the switching technology with the appropriate use case.
Based on the provided use cases, the matching of the switching technology with the appropriate use case is as follows:
802.1Q: Tags Ethernet frames with an additional VLAN header.
802.1X: Used to authenticate EAP-capable clients on a switch port.
LACP: Controls the dynamic addition and removal of ports to groups (this refers to the creation of Link Aggregation Groups).
LLDP: Used to identify a voice VLAN to an IP phone (LLDP can be used to communicate network policies to IP phones, such as VLAN assignment).
NEW QUESTION # 94
The HPE6-A85 exam questions that PrepAwayExam provide with you is compiled by professionals elaborately and boosts varied versions: PDF version, Soft version and APP version, which aimed to help you pass the HPE6-A85 exam by the method which is convenient for you. Our HPE6-A85 training braindump is not only cheaper than other dumps but also more effective. The high pass rate of our HPE6-A85 study materials has been approved by thousands of candidates, they recognized our website as only study tool to pass HPE6-A85 exam.
Examcollection HPE6-A85 Dumps: https://www.prepawayexam.com/HP/braindumps.HPE6-A85.ete.file.html
Posted at 1/15/2026 20:28:50        Only Author  2#
当社のIIA-CIA-Part2学習ガイド資料は、高品質のおかげで多くのお客様に支持されています。ユーザーが認定試験に合格する必要があるときに開始し、IIA-CIA-Part2の実際の質問を選択します。2回目または3回目のバックアップオプションはありません。 IIA-CIA-Part2実践ガイドは、ユーザーがテストに迅速に合格できるようにするために使用される方法を調査することに専念しています。したがって、絶え間ない努力により、IIA-CIA-Part2の実際の質問の合格率は98%〜100%です。
